Now the are optional, let us get rid of the ones that don't have
any content.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
skt->irq is a mere duplication of pcmcia_socket's pci_irq member.
Get rid of it.
pxa-regs.h and hardware.h are not intended for use directly in driver
code, remove those unnecessary references.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Russ Dill <russ.dill@gmail.com>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This just leaves include/asm-arm/plat-* to deal with.
Convert to use gpio_lib interface.
Remove support for second PCMCIA slot to avoid run-time conflicts with MMC/SD
because of shared GPIO
When a dynamically allocated platform device is 'put', the platform
device's platform_data is kfree'd. This is bad if it's pointing at
static data. Use the provided function to register platform data
for these devices.
This also means we can mark the pcmcia ops structures as __initdata.
cm_x270 and mainstone both register their PCMCIA devices using the same
name, resulting in a warning message from the kernel. Avoid this by
making the cm_x270 and mainstone PCMCIA initialisation conditional on
the machine type we're running on.
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
This patch provides support for PCMCIA on CM-X270
