path: root/drivers/pcmcia/sa1100_generic.c
2011-05-06pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.dataUwe Kleine-König
sa11x0_pcmcia_hw_init is only used by sa11x0_drv_pcmcia_probe which lives in .devinit.text so it can go to .devinit.data. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-01-05Merge branches 'ftrace', 'gic', 'io', 'kexec', 'mod', 'sa11x0', 'sh' and ↵Russell King
'versatile' into devel
2010-12-21ARM: 6458/1: pcmcia: Adds nanoEngine PCMCIA support.Marcelo Roberto Jimenez
This patch adds nanoEngine PCMCIA support, with support for two sockets. In order to have a fully functional pcmcia subsystem in a BSE nanoEngine board you should carefully read this: http://cambuca.ldhs.cetuc.puc-rio.br/nanoengine/ Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-10pcmcia/sa1100: don't put machine specific init functions in .init.textUwe Kleine-König
These are called by sa11x0_drv_pcmcia_probe (which is marked now with __devinit) so they can go to .devinit.text now, too. This fixes: WARNING: drivers/pcmcia/sa1100_cs.o(.text+0x10): Section mismatch in reference from the function sa11x0_drv_pcmcia_probe() to the function .init.text:pcmcia_simpad_init() The function sa11x0_drv_pcmcia_probe() references the function __init pcmcia_simpad_init(). This is often because sa11x0_drv_pcmcia_probe lacks a __init annotation or the annotation of pcmcia_simpad_init is wrong. and a similar warning for pcmcia_collie_init, pcmcia_cerf_init, pcmcia_h3600_init and pcmcia_shannon_init. While at it mark pcmcia_assabet_init with __devinit, too. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Russell King <linux@arm.linux.org.uk> CC: Eric Miao <eric.y.miao@gmail.com> CC: linux-arm-kernel@lists.infradead.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24pcmcia: use dev_pm_ops for class pcmcia_socket_classDominik Brodowski
Instead of requiring PCMCIA socket drivers to call various functions during their (bus) resume and suspend functions, register an own dev_pm_ops for this class. This fixes several suspend/resume bugs seen on db1xxx-ss, and probably on some other socket drivers, too. With regard to the asymmetry with only _noirq suspend, but split up resume, please see bug 14334 and commit 9905d1b411946fb3 . Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-06ARM: 5824/1: SA1100: reuse h3600 PCMCIA driver on h3100Dmitry Artamonow
Both iPAQs h3600 and h3100 share the same control GPIOs for PCMCIA, so driver can be reused. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-09PCMCIA: soc_common: push socket removal down to SoC specific supportRussell King - ARM Linux
Mechanically transplant the removal code from soc_common into each SoC specific base support file, thereby allowing soc_common_drv_pcmcia_remove to be removed. No other changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-09-29PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()Rafael J. Wysocki
pcmcia_socket_dev_suspend() doesn't use its second argument, so it may be dropped safely. This change is necessary for the subsequent yenta suspend/resume fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2009-03-24platform driver: fix incorrect use of 'platform_bus_type' with 'struct ↵Ming Lei
device_driver' This patch fixes the bug reported in http://bugzilla.kernel.org/show_bug.cgi?id=11681. "Lots of device drivers register a 'struct device_driver' with the '.bus' member set to '&platform_bus_type'. This is wrong, since the platform_bus functions expect the 'struct device_driver' to be wrapped up in a 'struct platform_driver' which provides some additional callbacks (like suspend_late, resume_early). The effect may be that platform_suspend_late() uses bogus data outside the device_driver struct as a pointer pointer to the device driver's suspend_late() function or other hard to reproduce failures."(Lothar Wassmann) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[ARM] Support pcmcia slot on sharp sl-5500Pavel Machek
This adds support for pcmcia slot on sharp zaurus sl-5500. pxa2xx_sharpsl.c thus becomes quite miss-named, but I guess that is not worth fixing? Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-03[ARM] 2873/1: PCMCIA soc: Allow access to filesystems on CF at boot timeRichard Purdie
Patch from Richard Purdie This change makes the soc pcmcia interfaces available earlier in the boot process meaning devices like CF microdrives can be used for the root filesystem. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in pcmciaPavel Machek
This fixes u32 vs. pm_message_t in pcmcia. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
