path: root/drivers/pcmcia/topic.h
2009-11-11pcmcia: correct handling for Zoomed Video registers in topic.hAvi Cohen Stuart
Fix handling of Zoomed Video Registers in the Topic pcmcia controller ( http://bugzilla.kernel.org/show_bug.cgi?id=14581 ). The information has been retrieved from the Topic manual which can be obtained from Toshiba. The Zoomed Video is used with PCMCIA Cards like the Margi DVD-to-Go. [linux@dominikbrodowski.net: whitespace & commit message fix] Signed-off-by: Avi Cohen Stuart <avi.cohenstuart@infor.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-07[PATCH] yenta: make ToPIC95 bridges work with 16bit cardsDaniel Ritz
ToPIC95 brides (and maybe some other too) require to use the ExCA registers to power up the socket if a 16bit card is pluged. allow socket drivers to set a flag so that yenta does just that. also clean up yenta_get_status() a bit to use the new yenta_get_power() function. Side note: ToPIC97 bridges (at least in Rev.5 i have) don't require this. Ryan Underwood <nemesis-lists@icequake.net> said: According to the mail that David Hinds received from a Toshiba engineer, ToPIC95 and 97 do require this, and ToPIC100 does not. Maybe you have a later revision. For all chips, 16-bit cards can be enabled through ExCA. So doesn't it make sense just to make this the default behavior for all Toshiba chips, to avoid corner cases showing up later? Daniel responded: I disagree with ryan to change anything for topic97 bridges. they work. and I couldn't find (read google) any report of a topic97 breaking on applying power with the CB registers. I'm having several toshba notebooks at work (and home) with topic95,97,100 bridges. Only the ones with a topic95 didn't work. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
