path: root/drivers/pcmcia/yenta_socket.c
2012-11-28pcmcia: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13PCI: replace struct pci_bus secondary/subordinate with busn_resYinghai Lu
Replace the struct pci_bus secondary/subordinate members with the struct resource busn_res. Later we'll build a resource tree of these bus numbers. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-03-03pcmcia: Convert to DEFINE_PCI_DEVICE_TABLEAxel Lin
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Also convert to use PCI_DEVICE macro for better readablity. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-06-07pcmcia: yenta_socket.c Remove extra #ifdef CONFIG_YENTA_TIJustin P. Mattock
Seems pointless to have two #ifdef's with the same CONFIG_YENTA_TI. Remove the extra one and move CARDBUS_TYPE_ENE with the others. [linux@dominikbrodowski.net: spelling & whitespace fixes] Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-06-07pcmcia: only keep saved I365_CSCINT flag if there is no PCI irqDominik Brodowski
Keeping the saved I365_CSCINT flag around breaks PCMCIA on some system, and is only needed on a few systems to get PCMCIA to work. This patch allows PCMCIA to work on both types, and it fixes https://bugzilla.kernel.org/show_bug.cgi?id=16015 Reported-by: Justin P. Mattock <justinmattock@gmail.com> CC: <stable@kernel.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: remove suspend-related comment from yenta_socket.cDominik Brodowski
While pci_set_power_state() is called by the PCI core unconditionally on all PCI devices, it is not called on _any_ PCI bridge device. Therefore, it is not surprising calling pci_set_power_state() on CardBus devices causes trouble. CC: dbrownell@users.sourceforge.net CC: gregkh@suse.de Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24pcmcia: use dev_pm_ops for class pcmcia_socket_classDominik Brodowski
Instead of requiring PCMCIA socket drivers to call various functions during their (bus) resume and suspend functions, register an own dev_pm_ops for this class. This fixes several suspend/resume bugs seen on db1xxx-ss, and probably on some other socket drivers, too. With regard to the asymmetry with only _noirq suspend, but split up resume, please see bug 14334 and commit 9905d1b411946fb3 . Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-15pcmcia: re-route Cardbus IRQ to ISA on ti1130 bridges if necessaryJens Künzer
As the PCI irq pin of the ti1130 pcmcia bridge is not connected (at least on some old IBM Thinkpad 760ED notebooks), the Cardbus IRQ has to be routed to an ISA irq. Part 3 of a series to allow the ISA irq to be used for Cardbus devices if the socket's PCI irq is unusable. [linux@dominikbrodowski.net: split up the original patch, commit message, cleanup] Signed-off-by: Jens Kuenzer <Jens.Kuenzer@fpga.homeip.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-15pcmcia: allow for cb_irq to differ from pci_dev's irq in yenta_socketJens Künzer
cb_irq is presumed to be the same as the pci_dev's irq. This won't be true any more as soon as we allow the ISA irq to be used for Cardbus devices. Therefore, use the pci_dev's irq explicitely whenever we care about it. Part 2 of a series to allow the ISA irq to be used for Cardbus devices if the socket's PCI irq is unusable. [linux@dominikbrodowski.net: split up the original patch, commit message] Signed-off-by: Jens Kuenzer <Jens.Kuenzer@fpga.homeip.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-15pcmcia: honor saved flags in yenta_socket's I365_CSCINT registerJens Künzer
Instead of overwriting the I365_CSCINT register, save the old value and merely change the bits we care about. Part 1 of a series to allow the ISA irq to be used for Cardbus devices if the socket's PCI irq is unusable. [linux@dominikbrodowski.net: split up the original patch, commit message] Signed-off-by: Jens Kuenzer <Jens.Kuenzer@fpga.homeip.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-02yenta_socket: ENE CB712 CardBus bridge needs special treatment with Echo ↵Michal Pecio
Audio Indigo soundcards Indigos are well known for distortions when running on some buggy ENE controllers. There is a workaround in the yenta driver, but for some reason it isn't activated on CB712. However, I own a laptop with such chip and it seems that it also is affected - I can clearly hear occasional cracks, especially under heavy network load, and in Windows XP the card is completely unusable. This simple change fixed things for me. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15191 [linux@dominikbrodowski.net: extend it to the other ENE bridges] Signed-off-by: Michal Pecio <michal.pecio@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: validate late-added resources pcmcia: allow for extension of resource interval pcmcia: remove useless msleep in ds.c pcmcia: use read_cis_mem return value pcmcia: handle error in serial_cs config calls pcmcia: add locking to pcmcia_{read,write}_cis_mem pcmcia: avoid prod_id memleak pcmcia: avoid sysfs-related lockup for cardbus pcmcia: use state machine for extended requery pcmcia: delay re-scanning and re-querying of PCMCIA bus pcmcia: use pccardd to handle eject, insert, suspend and resume requests pcmcia: use ops_mutex for rsrc_{mgr,nonstatic} locking pcmcia: use mutex for dynid lock pcmcia: assert locking to struct pcmcia_device pcmcia: add locking documentation pcmcia: simplify locking pcmcia: add locking to struct pcmcia_socket->pcmcia_state() pcmcia: protect s->device_count pcmcia: properly lock skt->irq, skt->irq_mask pcmcia: lock ops->set_socket ...
2010-02-23PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refsBjorn Helgaas
No functional change; this converts loops that iterate from 0 to PCI_BUS_NUM_RESOURCES through pci_bus resource[] table to use the pci_bus_for_each_resource() iterator instead. This doesn't change the way resources are stored; it merely removes dependencies on the fact that they're in a table. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-17pcmcia/yenta: add module parameter for O2 speedupsWolfram Sang
O2-bridges can do read prefetch and write burst. However, for some combinations of older bridges and cards, this causes problems, so it is disabled for those bridges. Now, as some users know their setup works with the speedups enabled, a new parameter is introduced to the driver. Now, a user can specifically enable or disable these features, while the default is what we have today: detect the bridge and decide accordingly. Fixes Bugzilla entry 15014. Simplify and unify the printouts, fix a whitespace issue while we are here. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: frodone@gmail.com [linux@dominikbrodowski.net: whitespace fixes] Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-07pcmcia: CodingStyle fixesDominik Brodowski
Fix several CodingStyle issues in drivers/pcmcia/ . checkpatch.pl no longer reports errors in the PCMCIA core. The remaining warnings mostly relate to wrong indent -- PCMCIA historically used 4 spaces --, to lines over 80 characters and to hundreds of typedefs. The cleanup of those will follow in the future. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-03PM / yenta: Split resume into early and late parts (rev. 4)Rafael J. Wysocki
Commit 0c570cdeb8fdfcb354a3e9cd81bfc6a09c19de0c (PM / yenta: Fix cardbus suspend/resume regression) caused resume to fail on systems with two CardBus bridges. While the exact nature of the failure is not known at the moment, it can be worked around by splitting the yenta resume into an early part, executed during the early phase of resume, that will only resume the socket and power it up if there was a card in it during suspend, and a late part, executed during "regular" resume, that will carry out all of the remaining yenta resume operations. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14334, which is a listed regression from 2.6.31. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Reported-by: Stephen J. Gowdy <gowdy@cern.ch> Tested-by: Jose Marino <braket@hotmail.com>
2009-09-29PM / yenta: Fix cardbus suspend/resume regressionRafael J. Wysocki
Since 2.6.29 the PCI PM core have been restoring the standard configuration registers of PCI devices in the early phase of resume. In particular, PCI devices without drivers have been handled this way since commit 355a72d75b3b4f4877db4c9070c798238028ecb5 (PCI: Rework default handling of suspend and resume). Unfortunately, this leads to post-resume problems with CardBus devices which cannot be accessed in the early phase of resume, because the sockets they are on have not been woken up yet at that point. To solve this problem, move the yenta socket resume to the early phase of resume and, analogously, move the suspend of it to the late phase of suspend. Additionally, remove some unnecessary PCI code from the yenta socket's resume routine. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13092, which is a post-2.6.28 regression. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Florian <fs-kernelbugzilla@spline.de> Cc: stable@kernel.org
2009-09-29PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()Rafael J. Wysocki
pcmcia_socket_dev_suspend() doesn't use its second argument, so it may be dropped safely. This change is necessary for the subsequent yenta suspend/resume fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2009-09-22pcmcia: yenta: add missing __devexit markingMike Frysinger
The remove member of the pci_driver yenta_cardbus_driver uses __devexit_p(), so the remove function itself should be marked with __devexit. Even more so considering the probe function is marked with __devinit. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Daniel Ritz <daniel.ritz-ml@swissonline.ch> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09yenta: Use pci_claim_resourceMatthew Wilcox
Instead of open-coding pci_find_parent_resource and request_resource, just call pci_claim_resource. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-08-23pcmcia: use dev_printk and dev_dbg in yenta_socketDominik Brodowski
2007-12-10pcmcia: fix kernel-doc commentsRandy Dunlap
Fix kernel-doc comments in drivers/pcmcia/: - ti113x.h does not contain kernel-doc, so don't use /** to begin a doc comment - yenta_socket.c: remove /** on non-kernel-doc comments; escape the ':' in an "http:" comment so that it won't be treated as a section heading; - cs.c: remove /** on non-kernel-doc comments & add function parameter info - ds.c: fix function parameter info Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07Driver core: convert pcmcia code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Cc: <linux-pcmcia@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-25[PATCH] PCMCIA: handle sysfs, PCI errorsJeff Garzik
Handle sysfs and PCI errors correctly. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-10-25[PATCH] CONFIG_PM=n slim: drivers/pcmcia/*Alexey Dobriyan
Remove some code which is unneeded if CONFIG_PM=n. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] pcmcia: fix kernel-doc function nameRandy Dunlap
Fix kernel-doc function name spello. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-06-30[PATCH] pcmcia: TI PCIxx12 CardBus controller supportAlex Williamson
The patch below adds support for the TI PCIxx12 CardBus controllers. This seems to be sufficient to detect the cardbus bridge on an HP nc6320 and works with an orinoco wifi card. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-06-30[PATCH] yenta: fix hidden PCI bus numbersBernhard Kaindl
Fixup the subordinate number parent bridge of yenta Cardbus Bridges before the PCI bus scan starts to make the cardbus cards which are otherwise hidden for PCI scans work. Signed-off-by: Bernhard Kaindl <bk@suse.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-06-30[PATCH] yenta: do power-up only after socket is configuredDaniel Ritz
Power-up the card only after the socket is configured. power-down in the old place. The point is not to power-up the card before the interrupt routing is set up correctly. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: kzalloc conversionDominik Brodowski
Convert users of kmalloc and memset to kzalloc Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] yenta: make bridge specific init code configurableDaniel Ritz
Make the bridge specific initialization code config options depending on CONFIG_EMBEDDED. Config options for TI/EnE, Toshiba, Ricoh and O2Micro are available. Disabling all of the specific tweaks cuts off more than half of yenta_socket.ko. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: remove get_socket callbackDominik Brodowski
The .get_socket callback is never used by the PCMCIA core, therefore remove it. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] yenta: optimize interrupt handlerDaniel Ritz
Don't waste cpu time in yenta interrupt handler when the interrupt was for another device. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-10-28pcmcia: add socket register data to sysfs for yenta devicesLinus Torvalds
It's simple, and it's a good debugging aid. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] yenta: more ENE bridgesDaniel Ritz
Adds better support for the CB-710, CB-712, CB-720 and CB-722 bridges from EnE Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-26[PATCH] yenta: add support for more TI bridgesDaniel Ritz
Support some more TI cardbus bridges. most of them are multifunction devices which adds 1394 controllers, smartcard readers etc. this could also help with the various problems with the XX21 controllers seen on the linux-pcmcia list. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-26[PATCH] yenta: tiny cleanupDominik Brodowski
pci_set_power_state is not needed, as we call pci_enable_device() somewhere else. Also, the resource we write to PCI_BASE_ADDRESS_0 needs to be converted to bus-centric view first. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-26[PATCH] yenta: don't mess with bridge control registerDaniel Ritz
In interrupt probing (both ISA and PCI) the bridge control register is used to change interrupt routing to ISA or PCI by changing bit 7. But this bit only controls the routing of card functional interrupts, not the CSC interrupts which are used for interrupt probing. A bad side effect of messing with this register in yenta_probe_irq() is that it can lead to irq storms if a card is inserted and already powered by the BIOS. Usage in yenta_sock_init() and yenta_config_init() seem to be fishy as well. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
