path: root/drivers/pcmcia
2014-01-22Merge tag 'pci-v3.14-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v3.14 merge window: Resource management - Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas) - Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu) - Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas) - Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas) - Enforce bus address limits in resource allocation (Yinghai Lu) - Allocate 64-bit BARs above 4G when possible (Yinghai Lu) - Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu) PCI device hotplug - Major rescan/remove locking update (Rafael J. Wysocki) - Make ioapic builtin only (not modular) (Yinghai Lu) - Fix release/free issues (Yinghai Lu) - Clean up pciehp (Bjorn Helgaas) - Announce pciehp slot info during enumeration (Bjorn Helgaas) MSI - Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev) - Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev) - Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev) - Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman) - Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong) SR-IOV - Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao) Virtualization - Add support for save/restore of extended capabilities (Alex Williamson) - Add Virtual Channel to save/restore support (Alex Williamson) - Never treat a VF as a multifunction device (Alex Williamson) - Add pci_try_reset_function(), et al (Alex Williamson) AER - Ignore non-PCIe error sources (Betty Dall) - Support ACPI HEST error sources for domains other than 0 (Betty Dall) - Consolidate HEST error source parsers (Bjorn Helgaas) - Add a TLP header print helper (Borislav Petkov) Freescale i.MX6 - Remove unnecessary code (Fabio Estevam) - Make reset-gpio optional (Marek Vasut) - Report "link up" only after link training completes (Marek Vasut) - Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut) - Fix PCIe startup code (Richard Zhu) Marvell MVEBU - Remove duplicate of_clk_get_by_name() call (Andrew Lunn) - Drop writes to bridge Secondary Status register (Jason Gunthorpe) - Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe) - Support a bridge with no IO port window (Jason Gunthorpe) - Use max_t() instead of max(resource_size_t,) (Jingoo Han) - Remove redundant of_match_ptr (Sachin Kamat) - Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni) NVIDIA Tegra - Disable Gen2 for Tegra20 and Tegra30 (Eric Brower) Renesas R-Car - Add runtime PM support (Valentine Barshak) - Fix rcar_pci_probe() return value check (Wei Yongjun) Synopsys DesignWare - Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen) - Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen) - Fix missing MSI IRQs (Harro Haan) - Add dw_pcie prefix before cfg_read/write (Pratyush Anand) - Fix I/O transfers by using CPU (not realio) address (Pratyush Anand) - Whitespace cleanup (Jingoo Han) EISA - Call put_device() if device_register() fails (Levente Kurusa) - Revert EISA initialization breakage ((Bjorn Helgaas) Miscellaneous - Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger) - Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas) - Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas) - Use dev_is_pci() to identify PCI devices (Yijing Wang) - Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches) - Update documentation 00-INDEX (Erik Ekman)" * tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits) Revert "EISA: Initialize device before its resources" Revert "EISA: Log device resources in dmesg" vfio-pci: Use pci "try" reset interface PCI: Check parent kobject in pci_destroy_dev() xen/pcifront: Use global PCI rescan-remove locking powerpc/eeh: Use global PCI rescan-remove locking PCI: Fix pci_check_and_unmask_intx() comment typos PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus() MPT / PCI: Use pci_stop_and_remove_bus_device_locked() platform / x86: Use global PCI rescan-remove locking PCI: hotplug: Use global PCI rescan-remove locking pcmcia: Use global PCI rescan-remove locking ACPI / hotplug / PCI: Use global PCI rescan-remove locking ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug PCI: Add global pci_lock_rescan_remove() PCI: Cleanup pci.h whitespace PCI: Reorder so actual code comes before stubs PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0 ACPICA: Add helper macros to extract bus/segment numbers from HEST table. PCI: Make local functions static ...
2014-01-14pcmcia: Use global PCI rescan-remove lockingRafael J. Wysocki
Multiple race conditions are possible between the cardbus PCI device addition and removal and the generic PCI bus rescan and device removal that can be triggered via sysfs. To avoid those race conditions make the cardbus code use global PCI rescan-remove locking. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-21PCI: Convert pcibios_resource_to_bus() to take a pci_bus, not a pci_devYinghai Lu
These interfaces: pcibios_resource_to_bus(struct pci_dev *dev, *bus_region, *resource) pcibios_bus_to_resource(struct pci_dev *dev, *resource, *bus_region) took a pci_dev, but they really depend only on the pci_bus. And we want to use them in resource allocation paths where we have the bus but not a device, so this patch converts them to take the pci_bus instead of the pci_dev: pcibios_resource_to_bus(struct pci_bus *bus, *bus_region, *resource) pcibios_bus_to_resource(struct pci_bus *bus, *resource, *bus_region) In fact, with standard PCI-PCI bridges, they only depend on the host bridge, because that's the only place address translation occurs, but we aren't going that far yet. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-08pcmcia: Remove superfluous name castsGeert Uytterhoeven
device_driver.name is "const char *" Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-pcmcia@lists.infradead.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-11powerpc: add missing explicit OF includes for ppcdevicetree-for-3.13Rob Herring
Commit b5b4bb3f6a11f9 (of: only include prom.h on sparc) removed implicit includes of of_*.h headers by powerpc's prom.h. Some components were missed in initial clean-up patch, so add the necessary includes to fix powerpc builds. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-ide@vger.kernel.org Cc: linux-crypto@vger.kernel.org
2013-11-07Merge tag 'driver-core-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core / sysfs patches from Greg KH: "Here's the big driver core / sysfs update for 3.13-rc1. There's lots of dev_groups updates for different subsystems, as they all get slowly migrated over to the safe versions of the attribute groups (removing userspace races with the creation of the sysfs files.) Also in here are some kobject updates, devres expansions, and the first round of Tejun's sysfs reworking to enable it to be used by other subsystems as a backend for an in-kernel filesystem. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (83 commits) sysfs: rename sysfs_assoc_lock and explain what it's about sysfs: use generic_file_llseek() for sysfs_file_operations sysfs: return correct error code on unimplemented mmap() mdio_bus: convert bus code to use dev_groups device: Make dev_WARN/dev_WARN_ONCE print device as well as driver name sysfs: separate out dup filename warning into a separate function sysfs: move sysfs_hash_and_remove() to fs/sysfs/dir.c sysfs: remove unused sysfs_get_dentry() prototype sysfs: honor bin_attr.attr.ignore_lockdep sysfs: merge sysfs_elem_bin_attr into sysfs_elem_attr devres: restore zeroing behavior of devres_alloc() sysfs: fix sysfs_write_file for bin file input: gameport: convert bus code to use dev_groups input: serio: remove bus usage of dev_attrs input: serio: use DEVICE_ATTR_RO() i2o: convert bus code to use dev_groups memstick: convert bus code to use dev_groups tifm: convert bus code to use dev_groups virtio: convert bus code to use dev_groups ipack: convert bus code to use dev_groups ...
2013-10-16pcmcia: convert bus code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the pcmcia bus code to use the correct field. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: <linux-pcmcia@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-09-26pcmcia: at91_cf: fix deferred probe from __initJohan Hovold
Move probe out of __init section and don't use platform_driver_probe which cannot be used with deferred probing. Since commit e9354576 ("gpiolib: Defer failed gpio requests by default") this driver might return -EPROBE_DEFER if a gpio_request fails. Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26drivers/pcmcia/yenta_socket.c: convert to module_pci_driverLibo Chen
Use module_pci_driver instead of init/exit, make code clean. Signed-off-by: Libo Chen <libo.chen@huawei.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26drivers/pcmcia/pd6729.c: convert to module_pci_driverLibo Chen
Use module_pci_driver instead of init/exit, make code clean. Signed-off-by: Libo Chen <libo.chen@huawei.com> Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25PCI: Delay enabling bridges until they're neededYinghai Lu
We currently enable PCI bridges after scanning a bus and assigning resources. This is often done in arch code. This patch changes this so we don't enable a bridge until necessary, i.e., until we enable a PCI device behind the bridge. We do this in the generic pci_enable_device() path, so this also removes the arch-specific code to enable bridges. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-02Merge tag 'driver-core-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver core merge for 3.11-rc1 Lots of little things, and larger firmware subsystem updates, all described in the shortlog. Nice thing here is that we finally get rid of CONFIG_HOTPLUG, after 10+ years, thanks to Stephen Rohtwell (it had been always on for a number of kernel releases, now it's just removed)" * tag 'driver-core-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (27 commits) driver core: device.h: fix doc compilation warnings firmware loader: fix another compile warning with PM_SLEEP unset build some drivers only when compile-testing firmware loader: fix compile warning with PM_SLEEP set kobject: sanitize argument for format string sysfs_notify is only possible on file attributes firmware loader: simplify holding module for request_firmware firmware loader: don't export cache_firmware and uncache_firmware drivers/base: Use attribute groups to create sysfs memory files firmware loader: fix compile warning firmware loader: fix build failure with !CONFIG_FW_LOADER_USER_HELPER Documentation: Updated broken link in HOWTO Finally eradicate CONFIG_HOTPLUG driver core: firmware loader: kill FW_ACTION_NOHOTPLUG requests before suspend driver core: firmware loader: don't cache FW_ACTION_NOHOTPLUG firmware Documentation: Tidy up some drivers/base/core.c kerneldoc content. platform_device: use a macro instead of platform_driver_register firmware: move EXPORT_SYMBOL annotations firmware: Avoid deadlock of usermodehelper lock at shutdown dell_rbu: Select CONFIG_FW_LOADER_USER_HELPER explicitly ...
2013-06-17pcmcia: Remove ARCH_CLPS711X dependencyAlexander Shiyan
No dependencies of PCMCIA and ARCH_CLPS711X. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-08pcmcia: pd6729: fix error return code in pd6729_pci_probe()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia/trivial: at91_cf: fix checkpatch errorLaurent Navet
fix this checkpatch error: - ERROR: switch and case should be at the same indent Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: use module_platform_driver_probe()Fabio Porcedda
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: add support for DTJoachim Eastwood
Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: clean up header includesJoachim Eastwood
Use includes from linux/ instead of asm/ and remove a unnecessary mach/ include. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: use devm_ functions for allocationsJoachim Eastwood
2013-06-06pcmcia: at91_cf: convert to dev_ print functionsJoachim Eastwood
Convert all pr_* functions to equivalent dev_* functions and drop the driver_name variable. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: fix gpio_get_value in at91_cf_get_statusJoachim Eastwood
Commit 80af9e6d (pcmcia at91_cf: fix raw gpio number usage) forgot to change the parameter in gpio_get_value after adding gpio validation. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: stable <stable@vger.kernel.org> # 3.4+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03Finally eradicate CONFIG_HOTPLUGStephen Rothwell
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"), it has been basically impossible to build a kernel with CONFIG_HOTPLUG turned off. Remove all the remaining references to it. Cc: Russell King <linux@arm.linux.org.uk> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05pcmcia: remove RPX board stuffArtem Bityutskiy
The RPX board is not supported by the kernel because CONFIG_RPXCLASSIC and CONFIG_RPXLITE symbols and not defined anywhere. Clean-up the m8xx_pcmcia driver a little bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05pcmcia: remove Motorola MBX860 supportArtem Bityutskiy
The CONFIG_MBX symbol is not defined anywhere in the kernel tree, which means this platform is not supported by the Linux kernel and we can remove the corresponding code from the 'm8xx_pcmcia' driver. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21pcmcia: move unbind/rebind into dev_pm_ops.completeChristian Lamparter
Move the device rebind procedures for cardbus devices from the pm.resume into the pm.complete callback. The reason for moving the code is: "[...] The PM code needs to send suspend and resume messages to every device in the right order, and it can't do that if new devices are being added at the same time. [...]" However the situation really isn't quite that rigid. In particular, adding new children during a resume callback shouldn't cause much of problem because the children don't need to be resumed anyway (since they were never suspended). On the other hand, if you do it you will get a dev_warn() from the PM core, something like 'parent should not be sleeping'. Still, it is considered bad form and should be avoided if possible." (Alan Stern's full comment about the topic can be found here: <https://lkml.org/lkml/2012/7/10/254>) Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg KH <greg@kroah.com> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-21pcmcia: avoid static analysis complaint about use-after-freeJesper Juhl
Coverity complains about a use after free for 'res1' and 'res2' since we use the value of the pointers in a 'dev_dbg()' after they have been freed. That's not really a problem, but it still seems cleaner to defer freeing until we are completely done with the pointers. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-17pcmcia/vrc4171: Add missing spinlock initJean Delvare
It doesn't seem this spinlock was properly initialized. This bug was introduced by commit 7a410e8d4d97457c8c381e2de9cdc7bd3306badc. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17pcmcia: i82092: fix i82092aa_pci_remove()Dan Carpenter
Smatch complains because the call to pci_set_drvdata(dev, &sockets[i].socket); is reading one step beyond the end of the sockets[] array. It will crash when we use it later. The only place which uses pci_get_drvdata() is i82092aa_pci_remove(). That function should loop through all the sockets and unregister them. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11drivers/pcmcia: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Manuel Lauss <manuel.lauss@googlemail.com> CC: Dominik Brodowski <linux@dominikbrodowski.net> CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-12-12Merge tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC Header cleanups from Olof Johansson: "This is a collection of header file cleanups, mostly for OMAP and AT91, that keeps moving the platforms in the direction of multiplatform by removing the need for mach-dependent header files used in drivers and other places." Fix up mostly trivial conflicts as per Olof. * tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits) ARM: OMAP2+: Move iommu/iovmm headers to platform_data ARM: OMAP2+: Make some definitions local ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h ARM: OMAP2+: Move iopgtable header to drivers/iommu/ ARM: OMAP: Merge iommu2.h into iommu.h atmel: move ATMEL_MAX_UART to platform_data/atmel.h ARM: OMAP: Remove omap_init_consistent_dma_size() arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig ARM: OMAP: Remove NEED_MACH_GPIO_H ARM: OMAP: Remove unnecessary mach and plat includes ...
2012-11-28pcmcia: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove CONFIG_HOTPLUG ifdefsBill Pemberton
Remove conditional code based on CONFIG_HOTPLUG being false. It's always on now in preparation of it going away as an option. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-12Merge tag 'for-3.8-at91_header_clean' of ↵Arnd Bergmann
git://github.com/at91linux/linux-at91 into next/headers From Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>: arm: at91: mach header cleanup This first patch serie start the cleanup of the header in mach by moving all the platform data to include/linux/platform_data and move the board header and drivers header next to them * tag 'for-3.8-at91_header_clean' of git://github.com/at91linux/linux-at91: arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-06arm: at91: move platfarm_data to include/linux/platform_data/atmel.hJean-Christophe PLAGNIOL-VILLARD
2012-11-05Merge branch 'depends/tty' into next/headersOlof Johansson
Merging in Greg's tty tree including a cleanup patch needed by the OMAP serial header cleanups. * depends/tty: (305 commits) tty/serial/8250: Make omap hardware workarounds local to 8250.h serial/8250/8250_early: Prevent rounding error in uartclk serial: samsung: use clk_prepare_enable and clk_disable_unprepare TTY: Report warning when low_latency flag is wrongly used console: use might_sleep in console_lock TTY: move tty buffers to tty_port TTY: add port -> tty link TTY: tty_buffer, cache pointer to tty->buf TTY: move TTY_FLUSH* flags to tty_port TTY: n_tty, propagate n_tty_data TTY: move ldisc data from tty_struct: locks TTY: move ldisc data from tty_struct: read_* and echo_* and canon_* stuff TTY: move ldisc data from tty_struct: bitmaps TTY: move ldisc data from tty_struct: simple members TTY: n_tty, add ldisc data to n_tty TTY: audit, stop accessing tty->icount TTY: n_tty, remove bogus checks TTY: n_tty, simplify read_buf+echo_buf allocation TTY: hci_ldisc, remove invalid check in open TTY: ldisc, wait for idle ldisc in release ...
2012-10-19Merge branch 'testing/driver-warnings' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into fixes A collection of warning fixes on non-ARM code from Arnd Bergmann: * 'testing/driver-warnings' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: s3c: mark s3c2440_clk_add as __init_refok spi/s3c64xx: use correct dma_transfer_direction type pcmcia: sharpsl: don't discard sharpsl_pcmcia_ops USB: EHCI: mark ehci_orion_conf_mbus_windows __devinit mm/slob: use min_t() to compare ARCH_SLAB_MINALIGN SCSI: ARM: make fas216_dumpinfo function conditional SCSI: ARM: ncr5380/oak uses no interrupts
2012-10-17ARM: OMAP1: Move plat/tc.h to mach/tc.h for omap1Tony Lindgren
We cannot keep this in plat as it causes problems with the ARM single zImage support. Cc: Felipe Balbi <balbi@ti.com> Cc: linux-pcmcia@lists.infradead.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-12pcmcia: sharpsl: don't discard sharpsl_pcmcia_opsArnd Bergmann
The sharpsl_pcmcia_ops structure gets passed into sa11xx_drv_pcmcia_probe, where it gets accessed at run-time, unlike all other pcmcia drivers that pass their structures into platform_device_add_data, which makes a copy. This means the gcc warning is valid and the structure must not be marked as __initdata. Without this patch, building collie_defconfig results in: drivers/pcmcia/pxa2xx_sharpsl.c:22:31: fatal error: mach-pxa/hardware.h: No such file or directory compilation terminated. make[3]: *** [drivers/pcmcia/pxa2xx_sharpsl.o] Error 1 make[2]: *** [drivers/pcmcia] Error 2 make[1]: *** [drivers] Error 2 make: *** [sub-make] Error 2 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pavel Machek <pavel@suse.cz> Cc: linux-pcmcia@lists.infradead.org Cc: Jochen Friedrich <jochen@scram.de> Cc: stable@vger.kernel.org
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-10-01Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM soc bug fixes from Olof Johansson: "These were submitted as bug fixes before v3.6 but not considered important enough to be included in it. Some of them cross over to cleanup territory as well, and aren't strictly bugfixes." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: nomadik: remove NAND_NO_READRDY use ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe() ARM: SAMSUNG: Add missing variable declaration in s3c64xx_spi1_set_platdata() ARM: S3C24XX: removes unnecessary semicolon ARM: S3C24xx: delete double assignment ARM: EXYNOS: fix address for EXYNOS4 MDMA1 ARM: EXYNOS: fixed SYSMMU setup definition to mate parameter name ARM: ep93xx: Move ts72xx.h out of include/mach ARM: ep93xx: use __iomem pointers for MMIO ARM: msm: Fix early debug uart mapping on some memory configs ARM: msm: io: Change the default static iomappings to be shared ARM: msm: io: Remove 7x30 iomap region from 7x00 ARM: msm: Remove call to missing FPGA init on 8660 ARM: OMAP4: wakeupgen: remove duplicate AUXCOREBOOT* read/write ARM: OMAP4: wakeupgen: Fix the typo in AUXCOREBOOT register save dma: tegra: make data used as *of_device_id.data const can: mpc5xxx_can: make data used as *of_device_id.data const macintosh/mediabay: make data used as *of_device_id.data const i2c/mpc: make data used as *of_device_id.data const mfd/da9052: make i2c_device_id array const ...
