path: root/drivers/pcmcia
2013-07-25PCI: Delay enabling bridges until they're neededYinghai Lu
We currently enable PCI bridges after scanning a bus and assigning resources. This is often done in arch code. This patch changes this so we don't enable a bridge until necessary, i.e., until we enable a PCI device behind the bridge. We do this in the generic pci_enable_device() path, so this also removes the arch-specific code to enable bridges. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-02Merge tag 'driver-core-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver core merge for 3.11-rc1 Lots of little things, and larger firmware subsystem updates, all described in the shortlog. Nice thing here is that we finally get rid of CONFIG_HOTPLUG, after 10+ years, thanks to Stephen Rohtwell (it had been always on for a number of kernel releases, now it's just removed)" * tag 'driver-core-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (27 commits) driver core: device.h: fix doc compilation warnings firmware loader: fix another compile warning with PM_SLEEP unset build some drivers only when compile-testing firmware loader: fix compile warning with PM_SLEEP set kobject: sanitize argument for format string sysfs_notify is only possible on file attributes firmware loader: simplify holding module for request_firmware firmware loader: don't export cache_firmware and uncache_firmware drivers/base: Use attribute groups to create sysfs memory files firmware loader: fix compile warning firmware loader: fix build failure with !CONFIG_FW_LOADER_USER_HELPER Documentation: Updated broken link in HOWTO Finally eradicate CONFIG_HOTPLUG driver core: firmware loader: kill FW_ACTION_NOHOTPLUG requests before suspend driver core: firmware loader: don't cache FW_ACTION_NOHOTPLUG firmware Documentation: Tidy up some drivers/base/core.c kerneldoc content. platform_device: use a macro instead of platform_driver_register firmware: move EXPORT_SYMBOL annotations firmware: Avoid deadlock of usermodehelper lock at shutdown dell_rbu: Select CONFIG_FW_LOADER_USER_HELPER explicitly ...
2013-06-17pcmcia: Remove ARCH_CLPS711X dependencyAlexander Shiyan
No dependencies of PCMCIA and ARCH_CLPS711X. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-08pcmcia: pd6729: fix error return code in pd6729_pci_probe()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia/trivial: at91_cf: fix checkpatch errorLaurent Navet
fix this checkpatch error: - ERROR: switch and case should be at the same indent Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: use module_platform_driver_probe()Fabio Porcedda
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: add support for DTJoachim Eastwood
Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: clean up header includesJoachim Eastwood
Use includes from linux/ instead of asm/ and remove a unnecessary mach/ include. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: use devm_ functions for allocationsJoachim Eastwood
2013-06-06pcmcia: at91_cf: convert to dev_ print functionsJoachim Eastwood
Convert all pr_* functions to equivalent dev_* functions and drop the driver_name variable. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06pcmcia: at91_cf: fix gpio_get_value in at91_cf_get_statusJoachim Eastwood
Commit 80af9e6d (pcmcia at91_cf: fix raw gpio number usage) forgot to change the parameter in gpio_get_value after adding gpio validation. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: stable <stable@vger.kernel.org> # 3.4+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03Finally eradicate CONFIG_HOTPLUGStephen Rothwell
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"), it has been basically impossible to build a kernel with CONFIG_HOTPLUG turned off. Remove all the remaining references to it. Cc: Russell King <linux@arm.linux.org.uk> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05pcmcia: remove RPX board stuffArtem Bityutskiy
The RPX board is not supported by the kernel because CONFIG_RPXCLASSIC and CONFIG_RPXLITE symbols and not defined anywhere. Clean-up the m8xx_pcmcia driver a little bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05pcmcia: remove Motorola MBX860 supportArtem Bityutskiy
The CONFIG_MBX symbol is not defined anywhere in the kernel tree, which means this platform is not supported by the Linux kernel and we can remove the corresponding code from the 'm8xx_pcmcia' driver. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21pcmcia: move unbind/rebind into dev_pm_ops.completeChristian Lamparter
Move the device rebind procedures for cardbus devices from the pm.resume into the pm.complete callback. The reason for moving the code is: "[...] The PM code needs to send suspend and resume messages to every device in the right order, and it can't do that if new devices are being added at the same time. [...]" However the situation really isn't quite that rigid. In particular, adding new children during a resume callback shouldn't cause much of problem because the children don't need to be resumed anyway (since they were never suspended). On the other hand, if you do it you will get a dev_warn() from the PM core, something like 'parent should not be sleeping'. Still, it is considered bad form and should be avoided if possible." (Alan Stern's full comment about the topic can be found here: <https://lkml.org/lkml/2012/7/10/254>) Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg KH <greg@kroah.com> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-21pcmcia: avoid static analysis complaint about use-after-freeJesper Juhl
Coverity complains about a use after free for 'res1' and 'res2' since we use the value of the pointers in a 'dev_dbg()' after they have been freed. That's not really a problem, but it still seems cleaner to defer freeing until we are completely done with the pointers. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-17pcmcia/vrc4171: Add missing spinlock initJean Delvare
It doesn't seem this spinlock was properly initialized. This bug was introduced by commit 7a410e8d4d97457c8c381e2de9cdc7bd3306badc. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17pcmcia: i82092: fix i82092aa_pci_remove()Dan Carpenter
Smatch complains because the call to pci_set_drvdata(dev, &sockets[i].socket); is reading one step beyond the end of the sockets[] array. It will crash when we use it later. The only place which uses pci_get_drvdata() is i82092aa_pci_remove(). That function should loop through all the sockets and unregister them. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11drivers/pcmcia: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Manuel Lauss <manuel.lauss@googlemail.com> CC: Dominik Brodowski <linux@dominikbrodowski.net> CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-12-12Merge tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC Header cleanups from Olof Johansson: "This is a collection of header file cleanups, mostly for OMAP and AT91, that keeps moving the platforms in the direction of multiplatform by removing the need for mach-dependent header files used in drivers and other places." Fix up mostly trivial conflicts as per Olof. * tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits) ARM: OMAP2+: Move iommu/iovmm headers to platform_data ARM: OMAP2+: Make some definitions local ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h ARM: OMAP2+: Move iopgtable header to drivers/iommu/ ARM: OMAP: Merge iommu2.h into iommu.h atmel: move ATMEL_MAX_UART to platform_data/atmel.h ARM: OMAP: Remove omap_init_consistent_dma_size() arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig ARM: OMAP: Remove NEED_MACH_GPIO_H ARM: OMAP: Remove unnecessary mach and plat includes ...
2012-11-28pcmcia: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pcmcia: remove CONFIG_HOTPLUG ifdefsBill Pemberton
Remove conditional code based on CONFIG_HOTPLUG being false. It's always on now in preparation of it going away as an option. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-12Merge tag 'for-3.8-at91_header_clean' of ↵Arnd Bergmann
git://github.com/at91linux/linux-at91 into next/headers From Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>: arm: at91: mach header cleanup This first patch serie start the cleanup of the header in mach by moving all the platform data to include/linux/platform_data and move the board header and drivers header next to them * tag 'for-3.8-at91_header_clean' of git://github.com/at91linux/linux-at91: arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-06arm: at91: move platfarm_data to include/linux/platform_data/atmel.hJean-Christophe PLAGNIOL-VILLARD
2012-11-05Merge branch 'depends/tty' into next/headersOlof Johansson
Merging in Greg's tty tree including a cleanup patch needed by the OMAP serial header cleanups. * depends/tty: (305 commits) tty/serial/8250: Make omap hardware workarounds local to 8250.h serial/8250/8250_early: Prevent rounding error in uartclk serial: samsung: use clk_prepare_enable and clk_disable_unprepare TTY: Report warning when low_latency flag is wrongly used console: use might_sleep in console_lock TTY: move tty buffers to tty_port TTY: add port -> tty link TTY: tty_buffer, cache pointer to tty->buf TTY: move TTY_FLUSH* flags to tty_port TTY: n_tty, propagate n_tty_data TTY: move ldisc data from tty_struct: locks TTY: move ldisc data from tty_struct: read_* and echo_* and canon_* stuff TTY: move ldisc data from tty_struct: bitmaps TTY: move ldisc data from tty_struct: simple members TTY: n_tty, add ldisc data to n_tty TTY: audit, stop accessing tty->icount TTY: n_tty, remove bogus checks TTY: n_tty, simplify read_buf+echo_buf allocation TTY: hci_ldisc, remove invalid check in open TTY: ldisc, wait for idle ldisc in release ...
2012-10-19Merge branch 'testing/driver-warnings' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into fixes A collection of warning fixes on non-ARM code from Arnd Bergmann: * 'testing/driver-warnings' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: s3c: mark s3c2440_clk_add as __init_refok spi/s3c64xx: use correct dma_transfer_direction type pcmcia: sharpsl: don't discard sharpsl_pcmcia_ops USB: EHCI: mark ehci_orion_conf_mbus_windows __devinit mm/slob: use min_t() to compare ARCH_SLAB_MINALIGN SCSI: ARM: make fas216_dumpinfo function conditional SCSI: ARM: ncr5380/oak uses no interrupts
2012-10-17ARM: OMAP1: Move plat/tc.h to mach/tc.h for omap1Tony Lindgren
We cannot keep this in plat as it causes problems with the ARM single zImage support. Cc: Felipe Balbi <balbi@ti.com> Cc: linux-pcmcia@lists.infradead.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-12pcmcia: sharpsl: don't discard sharpsl_pcmcia_opsArnd Bergmann
The sharpsl_pcmcia_ops structure gets passed into sa11xx_drv_pcmcia_probe, where it gets accessed at run-time, unlike all other pcmcia drivers that pass their structures into platform_device_add_data, which makes a copy. This means the gcc warning is valid and the structure must not be marked as __initdata. Without this patch, building collie_defconfig results in: drivers/pcmcia/pxa2xx_sharpsl.c:22:31: fatal error: mach-pxa/hardware.h: No such file or directory compilation terminated. make[3]: *** [drivers/pcmcia/pxa2xx_sharpsl.o] Error 1 make[2]: *** [drivers/pcmcia] Error 2 make[1]: *** [drivers] Error 2 make: *** [sub-make] Error 2 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pavel Machek <pavel@suse.cz> Cc: linux-pcmcia@lists.infradead.org Cc: Jochen Friedrich <jochen@scram.de> Cc: stable@vger.kernel.org
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-10-01Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM soc bug fixes from Olof Johansson: "These were submitted as bug fixes before v3.6 but not considered important enough to be included in it. Some of them cross over to cleanup territory as well, and aren't strictly bugfixes." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: nomadik: remove NAND_NO_READRDY use ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe() ARM: SAMSUNG: Add missing variable declaration in s3c64xx_spi1_set_platdata() ARM: S3C24XX: removes unnecessary semicolon ARM: S3C24xx: delete double assignment ARM: EXYNOS: fix address for EXYNOS4 MDMA1 ARM: EXYNOS: fixed SYSMMU setup definition to mate parameter name ARM: ep93xx: Move ts72xx.h out of include/mach ARM: ep93xx: use __iomem pointers for MMIO ARM: msm: Fix early debug uart mapping on some memory configs ARM: msm: io: Change the default static iomappings to be shared ARM: msm: io: Remove 7x30 iomap region from 7x00 ARM: msm: Remove call to missing FPGA init on 8660 ARM: OMAP4: wakeupgen: remove duplicate AUXCOREBOOT* read/write ARM: OMAP4: wakeupgen: Fix the typo in AUXCOREBOOT register save dma: tegra: make data used as *of_device_id.data const can: mpc5xxx_can: make data used as *of_device_id.data const macintosh/mediabay: make data used as *of_device_id.data const i2c/mpc: make data used as *of_device_id.data const mfd/da9052: make i2c_device_id array const ...
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-21ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe()Wei Yongjun
In case of error, the function clk_get() returns ERR_PTR() and never returns NULL pointer. The NULL test in the error handling should be replaced with IS_ERR(). dpatch engine is used to auto generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-09-20ARM: OMAP1: Make plat/mux.h omap1 onlyTony Lindgren
We are moving omap2+ to use the device tree based pinctrl-single.c and will be removing the old mux framework. This will remove the omap1 specific parts from plat-omap. Acked-by: Felipe Balbi <balbi@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-usb@vger.kernel.org Cc: linux-pcmcia@lists.infradead.org Cc: spi-devel-general@lists.sourceforge.net Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-14ARM: pxa: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the pxa include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Acked-By: Stefan Schmidt <stefan@openezx.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Cc: Harald Welte <laforge@openezx.org> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Tomas Cech <sleep_walker@suse.cz> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: Dan Williams <djbw@fb.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: openezx-devel@lists.openezx.org
2012-08-22pcmcia: Use common pci_stop_and_remove_bus_device()Bjorn Helgaas
Use pci_stop_and_remove_bus_device() like most other hotplug drivers rather than the special-purpose "behind_bridge" variant. This just means we have to iterate through all the devices downstream of the bridge ourselves, which is the same thing pci_stop_behind_bridge() did. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org>
2012-07-27Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "First ARM push of this merge window, post me coming back from holiday. This is what has been in linux-next for the last few weeks. Not much to say which isn't described by the commit summaries." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (32 commits) ARM: 7463/1: topology: Update cpu_power according to DT information ARM: 7462/1: topology: factorize the update of sibling masks ARM: 7461/1: topology: Add arch_scale_freq_power function ARM: 7456/1: ptrace: provide separate functions for tracing syscall {entry,exit} ARM: 7455/1: audit: move syscall auditing until after ptrace SIGTRAP handling ARM: 7454/1: entry: don't bother with syscall tracing on ret_from_fork path ARM: 7453/1: audit: only allow syscall auditing for pure EABI userspace ARM: 7452/1: delay: allow timer-based delay implementation to be selected ARM: 7451/1: arch timer: implement read_current_timer and get_cycles ARM: 7450/1: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs ARM: 7449/1: use generic strnlen_user and strncpy_from_user functions ARM: 7448/1: perf: remove arm_perf_pmu_ids global enumeration ARM: 7447/1: rwlocks: remove unused branch labels from trylock routines ARM: 7446/1: spinlock: use ticket algorithm for ARMv6+ locking implementation ARM: 7445/1: mm: update CONTEXTIDR register to contain PID of current process ARM: 7444/1: kernel: add arch-timer C3STOP feature ARM: 7460/1: remove asm/locks.h ARM: 7439/1: head.S: simplify initial page table mapping ARM: 7437/1: zImage: Allow DTB command line concatenation with ATAG_CMDLINE ARM: 7436/1: Do not map the vectors page as write-through on UP systems ...
2012-07-09ARM: sa11x0/pxa: convert OS timer registers to IOMEMRussell King
Make the OS timer registers have IOMEM like properities so they can be passed to readl_relaxed/writel_relaxed() et.al. rather than being straight volatile dereferences. Add linux/io.h includes where required. linux/io.h includes added to arch/arm/mach-sa1100/cpu-sa1100.c, arch/arm/mach-sa1100/jornada720_ssp.c, arch/arm/mach-sa1100/leds-lart.c drivers/input/touchscreen/jornada720_ts.c, drivers/pcmcia/sa1100_shannon.c from Arnd. This fixes these warnings: arch/arm/mach-sa1100/time.c: In function 'sa1100_timer_init': arch/arm/mach-sa1100/time.c:104: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type arch/arm/mach-pxa/time.c: In function 'pxa_timer_init': arch/arm/mach-pxa/time.c:126: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-06-13PCI: replace struct pci_bus secondary/subordinate with busn_resYinghai Lu
Replace the struct pci_bus secondary/subordinate members with the struct resource busn_res. Later we'll build a resource tree of these bus numbers. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-05-07pcmcia: add driver for hx4700Paul Parsons
This patch adds support for the HP iPAQ hx4700 to the existing pxa2xx-pcmcia driver. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmciaLinus Torvalds
Pull a few PCMCIA updates from Dominik Brodowski. Fix up trivial conflict (modified code in question had been removed) in drivers/pcmcia/soc_common.c. * git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia: pcmcia at91_cf: fix raw gpio number usage ARM: pxa: fix error handling in pxa2xx_drv_pcmcia_probe pcmcia: Convert to DEFINE_PCI_DEVICE_TABLE pcmcia: convert drivers/pcmcia/* to use module_platform_driver() pcmcia: irq: Remove IRQF_DISABLED
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
