commit c0bfc549e96231e0ead4424de6e4933fde819d70 upstream.
I ran into a build error when I disabled CONFIG_ACPI and tried to
compile this driver:
drivers/perf/xgene_pmu.c:1242:1: warning: data definition has no type or storage class
MODULE_DEVICE_TABLE(of, xgene_pmu_of_match);
drivers/perf/xgene_pmu.c:1242:1: error: type defaults to 'int' in declaration of 'MODULE_DEVICE_TABLE' [-Werror=implicit-int]
Include module.h for the MODULE_DEVICE_TABLE macro that's
implicitly included through ACPI.
Tested-by: Tai Nguyen <ttnguyen@apm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
In acpi_get_pmu_hw_inf we pass the address of a local variable to IS_ERR(),
which doesn't make sense, as the pointer must be a real, valid pointer.
This doesn't cause a functional problem, as IS_ERR() will evaluate as
false, but the check is bogus and causes static checkers to complain.
Remove the bogus check.
The bug is reported by Dan Carpenter <dan.carpenter@oracle.com> in [1]
[1] https://www.spinics.net/lists/arm-kernel/msg535957.html
Signed-off-by: Tai Nguyen <ttnguyen@apm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
Pull CPU hotplug updates from Thomas Gleixner:
"Yet another batch of cpu hotplug core updates and conversions:
- Provide core infrastructure for multi instance drivers so the
drivers do not have to keep custom lists.
- Convert custom lists to the new infrastructure. The block-mq custom
list conversion comes through the block tree and makes the diffstat
tip over to more lines removed than added.
- Handle unbalanced hotplug enable/disable calls more gracefully.
- Remove the obsolete CPU_STARTING/DYING notifier support.
- Convert another batch of notifier users.
The relayfs changes which conflicted with the conversion have been
shipped to me by Andrew.
The remaining lot is targeted for 4.10 so that we finally can remove
the rest of the notifiers"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits)
cpufreq: Fix up conversion to hotplug state machine
blk/mq: Reserve hotplug states for block multiqueue
x86/apic/uv: Convert to hotplug state machine
s390/mm/pfault: Convert to hotplug state machine
mips/loongson/smp: Convert to hotplug state machine
mips/octeon/smp: Convert to hotplug state machine
fault-injection/cpu: Convert to hotplug state machine
padata: Convert to hotplug state machine
cpufreq: Convert to hotplug state machine
ACPI/processor: Convert to hotplug state machine
virtio scsi: Convert to hotplug state machine
oprofile/timer: Convert to hotplug state machine
block/softirq: Convert to hotplug state machine
lib/irq_poll: Convert to hotplug state machine
x86/microcode: Convert to hotplug state machine
sh/SH-X3 SMP: Convert to hotplug state machine
ia64/mca: Convert to hotplug state machine
ARM/OMAP/wakeupgen: Convert to hotplug state machine
ARM/shmobile: Convert to hotplug state machine
arm64/FP/SIMD: Convert to hotplug state machine
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"It's a bit all over the place this time with no "killer feature" to
speak of. Support for mismatched cache line sizes should help people
seeing whacky JIT failures on some SoCs, and the big.LITTLE perf
updates have been a long time coming, but a lot of the changes here
are cleanups.
We stray outside arch/arm64 in a few areas: the arch/arm/ arch_timer
workaround is acked by Russell, the DT/OF bits are acked by Rob, the
arch_timer clocksource changes acked by Marc, CPU hotplug by tglx and
jump_label by Peter (all CC'd).
Summary:
- Support for execute-only page permissions
- Support for hibernate and DEBUG_PAGEALLOC
- Support for heterogeneous systems with mismatches cache line sizes
- Errata workarounds (A53 843419 update and QorIQ A-008585 timer bug)
- arm64 PMU perf updates, including cpumasks for heterogeneous systems
- Set UTS_MACHINE for building rpm packages
- Yet another head.S tidy-up
- Some cleanups and refactoring, particularly in the NUMA code
- Lots of random, non-critical fixes across the board"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (100 commits)
arm64: tlbflush.h: add __tlbi() macro
arm64: Kconfig: remove SMP dependence for NUMA
arm64: Kconfig: select OF/ACPI_NUMA under NUMA config
arm64: fix dump_backtrace/unwind_frame with NULL tsk
arm/arm64: arch_timer: Use archdata to indicate vdso suitability
arm64: arch_timer: Work around QorIQ Erratum A-008585
arm64: arch_timer: Add device tree binding for A-008585 erratum
arm64: Correctly bounds check virt_addr_valid
arm64: migrate exception table users off module.h and onto extable.h
arm64: pmu: Hoist pmu platform device name
arm64: pmu: Probe default hw/cache counters
arm64: pmu: add fallback probe table
MAINTAINERS: Update ARM PMU PROFILING AND DEBUGGING entry
arm64: Improve kprobes test for atomic sequence
arm64/kvm: use alternative auto-nop
arm64: use alternative auto-nop
arm64: alternative: add auto-nop infrastructure
arm64: lse: convert lse alternatives NOP padding to use __nops
arm64: barriers: introduce nops and __nops macros for NOP sequences
arm64: sysreg: replace open-coded mrs_s/msr_s with {read,write}_sysreg_s
https://github.com/AppliedMicro/xgene-next into next/drivers
Pull "X-Gene driver changes queued for v4.9" from Duc Dang:
This patch set includes:
+ X-Gene SoC Performance Monitoring Unit (PMU) driver
* tag 'xgene-drivers-for-4.9' of https://github.com/AppliedMicro/xgene-next:
In preparation for ACPI support, add a pmu_probe_info table to
the arm_pmu_device_probe() call. This table gets used when
probing in the absence of a devicetree node for PMU.
Signed-off-by: Mark Salter <msalter@redhat.com>
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
This patch adds a driver for the SoC-wide (AKA uncore) PMU hardware
found in APM X-Gene SoCs.
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
In systems with heterogeneous CPUs, there are multiple logical CPU PMUs,
each of which covers a subset of CPUs in the system. In some cases
userspace needs to know which CPUs a given logical PMU covers, so we'd
like to expose a cpumask under sysfs, similar to what is done for uncore
PMUs.
Unfortunately, prior to commit 00e727bb389359c8 ("perf stat: Balance
opening and reading events"), perf stat only correctly handled a cpumask
holding a single CPU, and only when profiling in system-wide mode. In
other cases, the presence of a cpumask file could cause perf stat to
behave erratically.
Thus, exposing a cpumask file would break older perf binaries in cases
where they would otherwise work.
To avoid this issue while still providing userspace with the information
it needs, this patch exposes a differently-named file (cpus) under
sysfs. New tools can look for this and operate correctly, while older
tools will not be adversely affected by its presence.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Now that the 32-bit and 64-bit perf backends use the common groups
directly, remove the fallback and no longer allow the groups array to be
overridden.
In preparation for adding common attribute groups, add an array of
attribute group pointers to arm_pmu, which will be used if the
backend hasn't already set pmu::attr_groups.
Subsequent patches will move backends over to using these, before adding
common fields.
As declared by the chief penguin, and enforced by the NO_IRQ brigade,
IRQ0 doesn't exist, and is considered as an error (no irq).
Unfortunately, the arm_pmu driver still considers it as valid in
a large number of cases. Let's fix this.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160817171420.sdwk2qivxunzryz4@linutronix.de
Patch 7f1d642fbb5c ("drivers/perf: arm-pmu: Fix handling of SPI lacking
interrupt-affinity property") unintended also fixes perf_event support
for bcm2835 which doesn't have PMU interrupts. Unfortunately this change
introduce a NULL pointer dereference on bcm2835, because irq_is_percpu
always expected to be called with a valid IRQ. So fix this regression
by validating the IRQ before.
Tested-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Fixes: 7f1d642fbb5c ("drivers/perf: arm-pmu: Fix handling of SPI lacking "interrupt-affinity" property")
In case of a IRQ type mismatch in of_pmu_irq_cfg() the
device node for interrupt affinity isn't freed. So fix this
issue by calling of_node_put().
Fixes: fa8ad7889d83 ("arm: perf: factor arm_pmu core out to drivers")
Patch 19a469a58720 ("drivers/perf: arm-pmu: Handle per-interrupt
affinity mask") added support for partitionned PPI setups, but
inadvertently broke setups using SPIs without the "interrupt-affinity"
property (which is the case for UP platforms).
This patch restore the broken functionnality by testing whether the
interrupt is percpu or not instead of relying on the using_spi flag
that really means "SPI *and* interrupt-affinity property".
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Fixes: 19a469a58720 ("drivers/perf: arm-pmu: Handle per-interrupt affinity mask")
arm_pmu_mutex is never held long and we don't want to sleep while the
lock is being held as it's executed in the context of hotplug notifiers.
So it can be converted to a simple spinlock instead.
Without this patch we get the following warning:
BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620
in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/2
no locks held by swapper/2/0.
irq event stamp: 381314
hardirqs last enabled at (381313): _raw_spin_unlock_irqrestore+0x7c/0x88
hardirqs last disabled at (381314): cpu_die+0x28/0x48
softirqs last enabled at (381294): _local_bh_enable+0x28/0x50
softirqs last disabled at (381293): irq_enter+0x58/0x78
CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.7.0 #12
Call trace:
dump_backtrace+0x0/0x220
show_stack+0x24/0x30
dump_stack+0xb4/0xf0
___might_sleep+0x1d8/0x1f0
__might_sleep+0x5c/0x98
mutex_lock_nested+0x54/0x400
arm_perf_starting_cpu+0x34/0xb0
cpuhp_invoke_callback+0x88/0x3d8
notify_cpu_starting+0x78/0x98
secondary_start_kernel+0x108/0x1a8
This patch converts the mutex to spinlock to eliminate the above
warnings. This constraints pmu->reset to be non-blocking call which is
the case with all the ARM PMU backends.
Cc: Stephen Boyd <sboyd@codeaurora.org>
Fixes: 37b502f121ad ("arm/perf: Fix hotplug state machine conversion")
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Pull smp hotplug updates from Thomas Gleixner:
"This is the next part of the hotplug rework.
- Convert all notifiers with a priority assigned
- Convert all CPU_STARTING/DYING notifiers
The final removal of the STARTING/DYING infrastructure will happen
when the merge window closes.
Another 700 hundred line of unpenetrable maze gone :)"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
timers/core: Correct callback order during CPU hot plug
leds/trigger/cpu: Move from CPU_STARTING to ONLINE level
powerpc/numa: Convert to hotplug state machine
irqchip/armada: Avoid unused function warnings
ARC/time: Convert to hotplug state machine
clocksource/atlas7: Convert to hotplug state machine
clocksource/armada-370-xp: Convert to hotplug state machine
clocksource/exynos_mct: Convert to hotplug state machine
clocksource/arm_global_timer: Convert to hotplug state machine
rcu: Convert rcutree to hotplug state machine
KVM/arm/arm64/vgic-new: Convert to hotplug state machine
smp/cfd: Convert core to hotplug state machine
x86/x2apic: Convert to CPU hotplug state machine
profile: Convert to hotplug state machine
timers/core: Convert to hotplug state machine
hrtimer: Convert to hotplug state machine
x86/tboot: Convert to hotplug state machine
arm64/armv8 deprecated: Convert to hotplug state machine
hwtracing/coresight-etm4x: Convert to hotplug state machine
Mark Rutland pointed out that this commit is incomplete:
7d88eb695a1f ("arm/perf: Convert to hotplug state machine")
The problem is that:
> We may have multiple PMUs (e.g. two in big.LITTLE systems), and
> __oprofile_cpu_pmu only contains one of these. So this conversion is not
> correct.
> We were relying on the notifier list implicitly containing a list of
> those PMUs. It seems like we need an explicit list here.
> We keep __oprofile_cpu_pmu around for legacy 32-bit users of OProfile
> (on non-hetereogeneous systems), and that's all that the variable should
> be used for.
Introduce arm_pmu_list to correctly handle multiple PMUs in the system.
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: linux-tip-commits@vger.kernel.org
Link: http://lkml.kernel.org/r/20160719111733.GA22911@linutronix.de
Straight forward conversion w/o bells and whistles.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/20160713153335.794097159@linutronix.de
On a big-little system, PMUs can be wired to CPUs using per CPU
interrups (PPI). In this case, it is important to make sure that
the enable/disable do happen on the right set of CPUs.
So instead of relying on the interrupt-affinity property, we can
use the actual percpu affinity that DT exposes as part of the
interrupt specifier. The DT binding is also updated to reflect
the fact that the interrupt-affinity property shouldn't be used
in that case.
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Caesar Wang <wxt@rock-chips.com>
There is a problem in the non-devicetree PMU probing where some
probe functions may get the number of supported events through
smp_call_function_any() using the arm_pmu supported_cpus mask.
But at the time the probe function is called, the supported_cpus
mask is empty so the call fails. This patch makes sure the mask
is set before calling the init function rather than after.
pmu->irq_affinity will not be freed if an error occurred within
arm_pmu_device_probe after of_pmu_irq_cfg has been called.
Note that in the case of_pmu_irq_cfg is returning an error,
pmu->irq_affinity will not be set, but it should be NULL as pmu was
kzalloc'd. Therefore the result kfree(NULL) is benign.
Signed-off-by: Julien Grall <julien.grall@arm.com>
The global variable __oprofile_cpu_pmu is set before the PMU is fully
initialized. If an error occurs before the end of the initialization,
the PMU will be freed and the variable will contain an invalid pointer.
This will result in a kernel crash when perf will be used.
Fix it by moving the setting of __oprofile_cpu_pmu when the PMU is fully
initialized (i.e when it is no longer possible to fail).
Cc: <stable@vger.kernel.org>
The only function called by of_pmu_irq_cfg that will increment the
reference count on dn is of_parse_phandle.
Each time we successfully parse a possible CPU from an
interrupt-affinity property, we increment the refcount of that CPU node
once via of_parse_handle. After validating the CPU is possible, we
decrement the refcount once. Subsequently, we decrement the refcount
again, either as part of an early break if we don't have a matching SPI,
or as part of the end of the loop body.
This will lead to decrementing twice the refcounnt.
Remove the second pairs of call to of_node_put as nobody is using dn
between the first and second call to of_node_put.
Commit:
26657848502b7847 ("perf/core: Verify we have a single perf_hw_context PMU")
forcefully prevents multiple PMUs from sharing perf_hw_context, as this
generally doesn't make sense. It is a common bug for uncore PMUs to
use perf_hw_context rather than perf_invalid_context, which this detects.
However, systems exist with heterogeneous CPUs (and hence heterogeneous
HW PMUs), for which sharing perf_hw_context is necessary, and possible
in some limited cases.
To make this work we have to perform some gymnastics, as we did in these
commits:
66eb579e66ecfea5 ("perf: allow for PMU-specific event filtering")
c904e32a69b7c779 ("arm: perf: filter unschedulable events")
To allow those systems to work, we must allow PMUs for heterogeneous
CPUs to share perf_hw_context, though we must still disallow sharing
otherwise to detect the common misuse of perf_hw_context.
This patch adds a new PERF_PMU_CAP_HETEROGENEOUS_CPUS for this, updates
the core logic to account for this, and makes use of it in the arm_pmu
code that is used for systems with heterogeneous CPUs. Comments are
added to make the rationale clear and hopefully avoid accidental abuse.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20160426103346.GA20836@leverpostej
Commit da4e4f18afe0 ("drivers/perf: arm_pmu: implement CPU_PM notifier")
added code in the arm perf infrastructure that allows the kernel to
save/restore perf counters whenever the CPU enters a low-power
state. The kernel saves/restores the counters for each active event
through the armpmu_{stop/start} ARM pmu API, so that the low-power state
enter/exit cycle is emulated through pmu start/stop operations for each
event in use.
However, calling armpmu_start() for each active event on power up
executes code that requires RCU locking (perf_event_update_userpage())
to be functional, so, given that the core may call the CPU_PM notifiers
while running the idle thread in an quiescent RCU state this is not
allowed as detected through the following splat when kernel is run with
CONFIG_PROVE_LOCKING enabled:
[ 49.293286]
[ 49.294761] ===============================
[ 49.298895] [ INFO: suspicious RCU usage. ]
[ 49.303031] 4.6.0-rc3+ #421 Not tainted
[ 49.306821] -------------------------------
[ 49.310956] include/linux/rcupdate.h:872 rcu_read_lock() used
illegally while idle!
[ 49.318530]
[ 49.318530] other info that might help us debug this:
[ 49.318530]
[ 49.326451]
[ 49.326451] RCU used illegally from idle CPU!
[ 49.326451] rcu_scheduler_active = 1, debug_locks = 0
[ 49.337209] RCU used illegally from extended quiescent state!
[ 49.342892] 2 locks held by swapper/2/0:
[ 49.346768] #0: (cpu_pm_notifier_lock){......}, at:
[<ffffff8008163c28>] cpu_pm_exit+0x18/0x80
[ 49.355492] #1: (rcu_read_lock){......}, at: [<ffffff800816dc38>]
perf_event_update_userpage+0x0/0x260
This patch wraps the armpmu_start() call (that indirectly calls
perf_event_update_userpage()) on CPU_PM notifier power state exit (or
failed entry) within the RCU_NONIDLE() macro so that the RCU subsystem
is made aware the calling cpu is not idle from an RCU perspective for
the armpmu_start() call duration, therefore fixing the issue.
Fixes: da4e4f18afe0 ("drivers/perf: arm_pmu: implement CPU_PM notifier")
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reported-by: James Morse <james.morse@arm.com>
Suggested-by: Kevin Hilman <khilman@baylibre.com>
Cc: Ashwin Chaugule <ashwin.chaugule@linaro.org>
Cc: Kevin Hilman <khilman@baylibre.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Commit c6b90653f1f7 ("drivers/perf: arm_pmu: make info messages more
verbose") breaks booting on systems where the PMU is probed without
devicetree (e.g by inspecting the MIDR of the current CPU). In this case,
pdev->dev.of_node is NULL and we shouldn't try to access its ->fullname
field when printing probe error messages.
This patch fixes the probing code to use of_node_full_name, which safely
handles NULL nodes and removes the "Error %i" part of the string, since
it's not terribly useful.
Reported-by: Guenter Roeck <private@roeck-us.net>
When a CPU is suspended (either through suspend-to-RAM or CPUidle),
its PMU registers content can be lost, which means that counters
registers values that were initialized on power down entry have to be
reprogrammed on power-up to make sure the counters set-up is preserved
(ie on power-up registers take the reset values on Cold or Warm reset,
which can be architecturally UNKNOWN).
To guarantee seamless profiling conditions across a core power down
this patch adds a CPU PM notifier to ARM pmus, that upon CPU PM
entry/exit from low-power states saves/restores the pmu registers
set-up (by using the ARM perf API), so that the power-down/up cycle does
not affect the perf behaviour (apart from a black-out period between
power-up/down CPU PM notifications that is unavoidable).
Acked-by: Ashwin Chaugule <ashwin.chaugule@linaro.org>
Acked-by: Kevin Hilman <khilman@baylibre.com>
On a big.LITTLE system e.g. with Cortex A57 and A53 in case not all cores
are online at PMU probe time we might get
hw perfevents: failed to probe PMU!
hw perfevents: failed to register PMU devices!
making it unclear which cores failed, here.
Add the device tree full name which failed and the error value resulting
in a more verbose and helpful message like
hw perfevents: /soc/pmu_a53: failed to probe PMU! Error -6
hw perfevents: /soc/pmu_a53: failed to register PMU devices! Error -6
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
ARMv7 counters other than the CPU cycle counter only work if the Secure
Debug Enable Register (SDER) SUNIDEN bit is set.
Since access to the SDER is only possible in secure state, it will
only be done if the device tree property "secure-reg-access" is set.
Without this:
Performance counter stats for 'sleep 1':
14606094 cycles # 0.000 GHz
0 instructions # 0.00 insns per cycle
After applying:
5843809 cycles
2566484 instructions # 0.44 insns per cycle
1.020144000 seconds time elapsed
Some platforms (eg i.MX53) may also need additional platform specific
setup.
Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com>
Signed-off-by: Pooya Keshavarzi <Pooya.Keshavarzi@de.bosch.com>
Signed-off-by: George G. Davis <george_davis@mentor.com>
[will: add warning if property is found on arm64]
Nothing outside of drivers/perf/arm_pmu.c should call armpmu_register
any more, so it no longer needs to be in include/linux/perf/arm_pmu.h.
Additionally, by folding it in to arm_pmu_device_probe we can allow
drivers to override struct pmu fields without getting blatted by the
armpmu code.
This patch folds armpmu_register into arm_pmu_device_probe. The logging
to the console is moved to after the PMU is successfully registered with
the core perf code.
Suggested-by: Will Deacon <will.deacon@arm.com>
Cc: Drew Richardson <drew.richardson@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Pull arm64 updates from Catalin Marinas:
- "genirq: Introduce generic irq migration for cpu hotunplugged" patch
merged from tip/irq/for-arm to allow the arm64-specific part to be
upstreamed via the arm64 tree
- CPU feature detection reworked to cope with heterogeneous systems
where CPUs may not have exactly the same features. The features
reported by the kernel via internal data structures or ELF_HWCAP are
delayed until all the CPUs are up (and before user space starts)
- Support for 16KB pages, with the additional bonus of a 36-bit VA
space, though the latter only depending on EXPERT
- Implement native {relaxed, acquire, release} atomics for arm64
- New ASID allocation algorithm which avoids IPI on roll-over, together
with TLB invalidation optimisations (using local vs global where
feasible)
- KASan support for arm64
- EFI_STUB clean-up and isolation for the kernel proper (required by
KASan)
- copy_{to,from,in}_user optimisations (sharing the memcpy template)
- perf: moving arm64 to the arm32/64 shared PMU framework
- L1_CACHE_BYTES increased to 128 to accommodate Cavium hardware
- Support for the contiguous PTE hint on kernel mapping (16 consecutive
entries may be able to use a single TLB entry)
- Generic CONFIG_HZ now used on arm64
- defconfig updates
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (91 commits)
arm64/efi: fix libstub build under CONFIG_MODVERSIONS
ARM64: Enable multi-core scheduler support by default
arm64/efi: move arm64 specific stub C code to libstub
arm64: page-align sections for DEBUG_RODATA
arm64: Fix build with CONFIG_ZONE_DMA=n
arm64: Fix compat register mappings
arm64: Increase the max granular size
arm64: remove bogus TASK_SIZE_64 check
arm64: make Timer Interrupt Frequency selectable
arm64/mm: use PAGE_ALIGNED instead of IS_ALIGNED
arm64: cachetype: fix definitions of ICACHEF_* flags
arm64: cpufeature: declare enable_cpu_capabilities as static
genirq: Make the cpuhotplug migration code less noisy
arm64: Constify hwcap name string arrays
arm64/kvm: Make use of the system wide safe values
arm64/debug: Make use of the system wide safe value
arm64: Move FP/ASIMD hwcap handling to common code
arm64/HWCAP: Use system wide safe values
arm64/capabilities: Make use of system wide safe value
arm64: Delay cpu feature capability checks
of_cpu_device_node_get increments the reference count on the CPU
device_node, so we must take care to of_node_put once we've finished
with it.
This patch fixes the perf IRQ probing code to avoid the leak.
Now that the arm_pmu framework has been factored out to drivers/perf we
can make use of it for arm64, gaining support for heterogeneous PMUs
and unifying the two codebases before they diverge further.
The as yet unused PMU name for PMUv3 is changed to armv8_pmuv3, matching
the style previously applied to the 32-bit PMUs.
To enable sharing of the arm_pmu code with arm64, this patch factors it
out to drivers/perf/. A new drivers/perf directory is added for
performance monitor drivers to live under.
MAINTAINERS is updated accordingly. Files added previously without a
corresponsing MAINTAINERS update (perf_regs.c, perf_callchain.c, and
perf_event.h) are also added.
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
[will: augmented Kconfig help slightly]
