[ Upstream commit a23680594da7a9e2696dbcf4f023e9273e2fa40b ]
Suspending Goodix touchscreens requires changing the interrupt pin to
output before sending them a power-down command. Followed by wiggling
the interrupt pin to wake the device up, after which it is put back
in input mode.
On Bay Trail devices with a Goodix touchscreen direct-irq mode is used
in combination with listing the pin as a normal GpioIo resource.
This works fine, until the goodix driver gets rmmod-ed and then insmod-ed
again. In this case byt_gpio_disable_free() calls
byt_gpio_clear_triggering() which clears the IRQ flags and after that the
(direct) IRQ no longer triggers.
This commit fixes this by adding a check for the BYT_DIRECT_IRQ_EN flag
to byt_gpio_clear_triggering().
Note that byt_gpio_clear_triggering() only gets called from
byt_gpio_disable_free() for direct-irq enabled pins, as these are excluded
from the irq_valid mask by byt_init_irq_valid_mask().
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[ Upstream commit 40ecab551232972a39cdd8b6f17ede54a3fdb296 ]
Commit 39ce8150a079 ("pinctrl: baytrail: Serialize all register access")
added a spinlock around all register accesses because:
"There is a hardware issue in Intel Baytrail where concurrent GPIO register
access might result reads of 0xffffffff and writes might get dropped
completely."
Testing has shown that this does not catch all cases, there are still
2 problems remaining
1) The original fix uses a spinlock per byt_gpio device / struct,
additional testing has shown that this is not sufficient concurent
accesses to 2 different GPIO banks also suffer from the same problem.
This commit fixes this by moving to a single global lock.
2) The original fix did not add a lock around the register accesses in
the suspend/resume handling.
Since pinctrl-baytrail.c is using normal suspend/resume handlers,
interrupts are still enabled during suspend/resume handling. Nothing
should be using the GPIOs when they are being taken down, _but_ the
GPIOs themselves may still cause interrupts, which are likely to
use (read) the triggering GPIO. So we need to protect against
concurrent GPIO register accesses in the suspend/resume handlers too.
This commit fixes this by adding the missing spin_lock / unlock calls.
The 2 fixes together fix the Acer Switch 10 SW5-012 getting completely
confused after a suspend resume. The DSDT for this device has a bug
in its _LID method which reprograms the home and power button trigger-
flags requesting both high and low _level_ interrupts so the IRQs for
these 2 GPIOs continuously fire. This combined with the saving of
registers during suspend, triggers concurrent GPIO register accesses
resulting in saving 0xffffffff as pconf0 value during suspend and then
when restoring this on resume the pinmux settings get all messed up,
resulting in various I2C busses being stuck, the wifi no longer working
and often the tablet simply not coming out of suspend at all.
Cc: stable@vger.kernel.org
Fixes: 39ce8150a079 ("pinctrl: baytrail: Serialize all register access")
[ Upstream commit 9291c65b01d1c67ebd56644cb19317ad665c44b3 ]
On some systems, some PCB traces attached to GpioInts are routed in such
a way that they pick up enough interference to constantly (many times per
second) trigger.
Enabling glitch-filtering fixes this.
[ Upstream commit 3655a1ca6bd8e7300f2bb196208d5139aa6b2eda ]
Apparently each GPIO pad's register are 16 bytes, so multiply the pad_map
by that. The same is done in byt_gpio_reg the only other place where
pad_map is used.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
[ Upstream commit 827e1579e1d5cb66e340e7be1944b825b542bbdf ]
The commit 04ff5a095d66 ("pinctrl: baytrail: Rectify debounce support")
almost fixes the logic of debuonce but missed couple of things, i.e.
typo in mask when disabling debounce and lack of enabling it back.
This patch addresses above issues.
Reported-by: Jean Delvare <jdelvare@suse.de>
Fixes: 04ff5a095d66 ("pinctrl: baytrail: Rectify debounce support")
Reviewed-by: Jean Delvare <jdelvare@suse.de>
commit 1b89970d81bbd52720fc64a3fe9572ee33588363 upstream.
Debounce value is set globally per community. Otherwise user will easily
get a kernel crash when they start using the feature:
BUG: unable to handle kernel paging request at ffffc900003be000
IP: byt_gpio_dbg_show+0xa9/0x430
Make it clear in byt_gpio_reg().
Note that this fix just prevents kernel to crash, but doesn't make any
difference to the existing logic. It means the last caller will win the
trade and debounce value will be configured accordingly. The actual
logic fix needs to be thought about and it's not as important as crash
fix. That's why the latter goes separately and right now.
Fixes: 658b476c742f ("pinctrl: baytrail: Add debounce configuration")
Cc: Cristina Ciocan <cristina.ciocan@intel.com>
commit cdca06e4e85974d8a3503ab15709dbbaf90d3dd1 upstream.
According to VLI64 Intel Atom E3800 Specification Update (#329901)
concurrent read accesses may result in returning 0xffffffff and write
accesses may be dropped silently.
To workaround all accesses must be protected by locks.
commit 04ff5a095d662e0879f0eb04b9247e092210aeff upstream.
The commit 658b476c742f ("pinctrl: baytrail: Add debounce configuration")
implements debounce for Baytrail pin control, but seems wasn't tested properly.
The register which keeps debounce value is separated from the configuration
one. Writing wrong values to the latter will guarantee wrong behaviour of the
driver and even might break something physically.
Besides above there is missed case how to disable it, which is actually done
through the bit in configuration register.
Rectify implementation here by using proper register for debounce value.
Initialize the spinlock before using it.
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.8.0-dwc-bisect #4
Hardware name: Intel Corp. VALLEYVIEW C0 PLATFORM/BYT-T FFD8, BIOS BLAKFF81.X64.0088.R10.1403240443 FFD8_X64_R_2014_13_1_00 03/24/2014
0000000000000000 ffff8800788ff770 ffffffff8133d597 0000000000000000
0000000000000000 ffff8800788ff7e0 ffffffff810cfb9e 0000000000000002
ffff8800788ff7d0 ffffffff8205b600 0000000000000002 ffff8800788ff7f0
Call Trace:
[<ffffffff8133d597>] dump_stack+0x67/0x90
[<ffffffff810cfb9e>] register_lock_class+0x52e/0x540
[<ffffffff810d2081>] __lock_acquire+0x81/0x16b0
[<ffffffff810cede1>] ? save_trace+0x41/0xd0
[<ffffffff810d33b2>] ? __lock_acquire+0x13b2/0x16b0
[<ffffffff810cf05a>] ? __lock_is_held+0x4a/0x70
[<ffffffff810d3b1a>] lock_acquire+0xba/0x220
[<ffffffff8136f1fe>] ? byt_gpio_get_direction+0x3e/0x80
[<ffffffff81631567>] _raw_spin_lock_irqsave+0x47/0x60
[<ffffffff8136f1fe>] byt_gpio_get_direction+0x3e/0x80
[<ffffffff813740a9>] gpiochip_add_data+0x319/0x7d0
[<ffffffff81631723>] ? _raw_spin_unlock_irqrestore+0x43/0x70
[<ffffffff8136fe3b>] byt_pinctrl_probe+0x2fb/0x620
[<ffffffff8142fb0c>] platform_drv_probe+0x3c/0xa0
Based on the diff it looks like the problem was introduced in
commit 71e6ca61e826 ("pinctrl: baytrail: Register pin control handling")
but I wasn't able to verify that empirically as the parent commit
just oopsed when I tried to boot it.
Fixes: 71e6ca61e826 ("pinctrl: baytrail: Register pin control handling")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"This is the bulk of pin control changes for the v4.8 kernel cycle.
Nothing stands out as especially exiting: new drivers, new subdrivers,
lots of cleanups and incremental features.
Business as usual.
New drivers:
- New driver for Oxnas pin control and GPIO. This ARM-based chipset
is used in a few storage (NAS) type devices.
- New driver for the MAX77620/MAX20024 pin controller portions.
- New driver for the Intel Merrifield pin controller.
New subdrivers:
- New subdriver for the Qualcomm MDM9615
- New subdriver for the STM32F746 MCU
- New subdriver for the Broadcom NSP SoC.
Cleanups:
- Demodularization of bool compiled-in drivers.
Apart from this there is just regular incremental improvements to a
lot of drivers, especially Uniphier and PFC"
* tag 'pinctrl-v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (131 commits)
pinctrl: fix pincontrol definition for marvell
pinctrl: xway: fix typo
Revert "pinctrl: amd: make it explicitly non-modular"
pinctrl: iproc: Add NSP and Stingray GPIO support
pinctrl: Update iProc GPIO DT bindings
pinctrl: bcm: add OF dependencies
pinctrl: ns2: remove redundant dev_err call in ns2_pinmux_probe()
pinctrl: Add STM32F746 MCU support
pinctrl: intel: Protect set wake flow by spin lock
pinctrl: nsp: remove redundant dev_err call in nsp_pinmux_probe()
pinctrl: uniphier: add Ethernet pin-mux settings
sh-pfc: Use PTR_ERR_OR_ZERO() to simplify the code
pinctrl: ns2: fix return value check in ns2_pinmux_probe()
pinctrl: qcom: update DT bindings with ebi2 groups
pinctrl: qcom: establish proper EBI2 pin groups
pinctrl: imx21: Remove the MODULE_DEVICE_TABLE() macro
Documentation: dt: Add new compatible to STM32 pinctrl driver bindings
includes: dt-bindings: Add STM32F746 pinctrl DT bindings
pinctrl: sunxi: fix nand0 function name for sun8i
pinctrl: uniphier: remove pointless pin-mux settings for PH1-LD11
Fix plt clock 3, 4 and 5 pins, which were not in the proper order.
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
The Kconfig currently controlling compilation of this code is:
config PINCTRL_BAYTRAIL
bool "Intel Baytrail GPIO pin control"
...meaning that it currently is not being built as a module by anyone.
Lets remove the modular code that is essentially orphaned, so that
when reading the driver there is no doubt it is builtin-only.
We explicitly disallow a driver unbind, since that doesn't have a
sensible use case anyway, and it allows us to drop the ".remove"
code for non-modular drivers.
Since module_init() was already not in use in this driver, we don't
have any concerns with init ordering changes here.
Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code.
We also delete the MODULE_LICENSE tag etc. since all that information
is already contained at the top of the file in the comments.
Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Cc: linux-gpio@vger.kernel.org
gcc-4.4 and thereabouts has issues with initializers of anonymous
unions, and it generates the following warnings:
drivers/pinctrl/intel/pinctrl-baytrail.c:413: error: unknown field 'simple_funcs' specified in initializer
drivers/pinctrl/intel/pinctrl-baytrail.c:413: warning: missing braces around initializer
drivers/pinctrl/intel/pinctrl-baytrail.c:413: warning: (near initialization for 'byt_score_groups[0].<anonymous>')
drivers/pinctrl/intel/pinctrl-baytrail.c:415: error: unknown field 'simple_funcs' specified in initializer
drivers/pinctrl/intel/pinctrl-baytrail.c:417: error: unknown field 'simple_funcs' specified in initializer
Work around this.
Cc: Linus Walleij <linus.walleij@linaro.org>
We need to unlock before continuing. Also the continue was accidentally
left out on one error path which would lead to a NULL dereference.
Fixes: 86e3ef812fe3 ('pinctrl: baytrail: Update gpio chip operations')
Make debounce setting and getting functionality available when
configurating a certain pin.
This patch updates device's probing, removal and irq handling in order to
register it as pinctrl device. Pin control data is matched by ACPI UID,
since it is passed along as driver data in acpi_device_id structure.
This patch updates the irq chip implementation in order
to interact with the pin control chip model: the chip
contains reference to SOC data and pin/group/community
information is retrieved through the SOC reference.
This patch updates the gpio chip implementation in order
to interact with the pin control model: the chip contains
reference to SOC data and pin/group/community information
Add implementation for:
- pin control, group information retrieval: count, name and pins
- pin muxing:
- function information (count, name and groups)
- mux setting
- gpio control (enable, disable, set direction)
- pin configuration:
- pull disable
- pull up/down and pull strength
- debounce
- any other option is treated as not supported.
In order to implement pin control for Baytrail, we need data
structures in which to store and pass along pin, group, function,
community and SOC data information.
Baytrail has 3 GPIO controllers. Add SCORE, NCORE and SUS
controller data:
- pins (for all controllers),
- pad map for pins (for all controllers; we need this since pads
are not ordered),
- groups (for SCORE and SUS controllers),
- functions (for SCORE and SUS controllers),
- communities (for all controllers),
- soc specific data gathering all of the above and the ACPI UID
This information is useful for pin control functionality.
NCORE data is lighter than the other two controllers' due to
lack of pin documentation in the public datasheet.
Datasheet:
http://www.intel.com/content/www/us/en/embedded/products/bay-trail/atom-e3800-family-datasheet.html
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
As we want gpio_chip .get() calls to be able to return negative
error codes and propagate to drivers, we need to go over all
drivers and make sure their return values are clamped to [0,1].
We do this by using the ret = !!(val) design pattern.
The name .dev in a struct is normally reserved for a struct device
that is let us say a superclass to the thing described by the struct.
struct gpio_chip stands out by confusingly using a struct device *dev
to point to the parent device (such as a platform_device) that
represents the hardware. As we want to give gpio_chip:s real devices,
this is not working. We need to rename this member to parent.
This was done by two coccinelle scripts, I guess it is possible to
combine them into one, but I don't know such stuff. They look like
this:
struct gpio_chip *var;
-var->dev
+var->parent
and:
struct gpio_chip var;
-var.dev
+var.parent
and:
struct bgpio_chip *var;
-var->gc.dev
+var->gc.parent
Plus a few instances of bgpio that I couldn't figure out how
to teach Coccinelle to rewrite.
This patch hits all over the place, but I *strongly* prefer this
solution to any piecemal approaches that just exercise patch
mechanics all over the place. It mainly hits drivers/gpio and
drivers/pinctrl which is my own backyard anyway.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Alek Du <alek.du@intel.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
When CONFIG_PM is not set we get following compilation warnings:
warning: ‘byt_gpio_runtime_suspend’ defined but not used [-Wunused-function]
warning: ‘byt_gpio_runtime_resume’ defined but not used [-Wunused-function]
Fix this by guarding byt_gpio_runtime_suspend()/byt_gpio_runtime_resume()
with #ifdef CONFIG_PM.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
The Intel Baytrail pinctrl driver implements irqchip callbacks which are
called with desc->lock raw_spinlock held. In mainline this is fine because
spinlock resolves to raw_spinlock. However, running the same code in -rt we
get:
BUG: sleeping function called from invalid context at kernel/locking/rtmutex.c:917
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: swapper/0
Preemption disabled at:[<ffffffff81092e9f>] cpu_startup_entry+0x17f/0x480
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.1.5-rt5 #13
Call Trace:
<IRQ> [<ffffffff816283c6>] dump_stack+0x4a/0x61
[<ffffffff81077e17>] ___might_sleep+0xe7/0x170
[<ffffffff8162d6cf>] rt_spin_lock+0x1f/0x50
[<ffffffff812e3b88>] byt_gpio_clear_triggering+0x38/0x60
[<ffffffff812e3bc1>] byt_irq_mask+0x11/0x20
[<ffffffff810a7013>] handle_level_irq+0x83/0x150
[<ffffffff810a3457>] generic_handle_irq+0x27/0x40
[<ffffffff812e3a5f>] byt_gpio_irq_handler+0x7f/0xc0
[<ffffffff810050aa>] handle_irq+0xaa/0x190
This is because in -rt spinlocks are preemptible so taking the driver
private spinlock in irqchip callbacks causes might_sleep() to trigger.
In order to keep -rt happy but at the same time make sure that register
accesses get serialized, convert the driver to use raw_spinlock instead.
Also shorten the critical section a bit in few places.
Suggested-by: Linus Walleij <linus.walleij@linaro.org>
completely.
Prevent this from happening by taking the serializing lock in all places
where it is possible that more than one thread might be accessing the
hardware concurrently.
The FSF address is already mentioned in the COPYING file. No need to
duplicate that information to individual files.
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Cc: Julia Lawall <julia.lawall@lip6.fr>
The BIOS might reconfigure pins as it needs when S3 is entered. This might
cause drivers using the GPIOs to fail because the state was wrong or
interrupts stopped working.
Fix this by saving and restoring enough pin context over system sleep.
Reported-by: Hans Holmberg <hans.holmberg@intel.com>
Instead of handling everything in the driver's first level interrupt
handler, we can take advantage of already existing flow handlers that are
provided by the IRQ core.
This changes the functionality a bit also. Previously the driver looped
over pending interrupts in a single loop, restarting the loop if some
interrupt changed state. This caused problem with Lenovo Thinkpad 10
digitizer that it was not able to deassert the interrupt before the driver
disabled the interrupt for good (looplimit was exhausted).
Rework the interrupt handling logic a bit so that we provide proper mask,
ack and unmask operations in terms of Baytrail GPIO hardware and loop over
pending interrupts only once. If the interrupt remains asserted the first
level handler will be re-triggered automatically.
If the pin is already configured as GPIO and it has any of the triggering
flags set, we may get spurious interrupts depending on the state of the
pin.
Prevent this by clearing the triggering flags on such pins. However, if the
pin is also configured as "direct IRQ" we leave the flags as is. Otherwise
it will prevent interrupts that are routed directly to IO-APIC.
Zotac ZBOX PI320, a Baytrail based mini-PC, has power button connected to a
GPIO pin and it is exposed to the operating system as Windows 8 button
array. This is implemented in Linux as a driver using gpio_keys.
However, BIOS on this particula machine forgot to mux the pin to be a GPIO
instead of native function, which results following message to be seen on
the console:
byt_gpio INT33FC:02: pin 16 cannot be used as GPIO.
This causes power button to not work as the driver was not able to request
the GPIO it needs.
So instead of completely preventing this we allow turning the pin as GPIO
but issue warning that something might be wrong.
Reported-by: Benjamin Adler <benadler@gmx.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Pull pin control changes from Linus Walleij:
"Here is a stash of pin control changes I have collected for the v3.19
series. Mainly new hardware support, with Intels new embedded SoC as
the especially interesting thing standing out, fully using the
subsystem.
- Force conversion of the ux500 pin control device trees and parsers
to use the generic pin control bindings.
- New driver and device tree bindings for the Qualcomm PMIC MPP pin
controller and GPIO.
- Some ACPI infrastructure for pin controllers.
- New driver for the Intel CherryView/Braswell pin controller, the
first Intel pin controller to fully take advantage of the pin
control subsystem.
- Support the Freescale i.MX VF610 variant.
- Support the sunxi A80 variant.
- Support the Samsung Exynos 4415 and Exynos 7 variants.
- Split out Intel pin controllers to their own subdirectory.
- A large slew of rockchip pin control updates, including
suspend/resume support.
- A large slew of Samsung Exynos pin controller updates.
- Various minor updates and fixes"
* tag 'pinctrl-v3.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (49 commits)
pinctrl: at91: enhance (debugfs) at91_gpio_dbg_show
pinctrl: meson: add device tree bindings documentation
gpio: tz1090: Fix error handling of irq_of_parse_and_map
pinctrl: tz1090-pinctrl.txt: Fix typo in binding
pinctrl: pinconf-generic: Declare dt_params/conf_items const
pinctrl: exynos: Add support for Exynos4415
pinctrl: exynos: Add initial driver data for Exynos7
pinctrl: exynos: Add irq_chip instance for Exynos7 wakeup interrupts
pinctrl: exynos: Consolidate irq domain callbacks
pinctrl: exynos: Generalize the eint16_31 demux code
pinctrl: samsung: Separate per-bank init and runtime data
pinctrl: samsung: Constify samsung_pin_ctrl struct
pinctrl: samsung: Constify samsung_pin_bank_type struct
pinctrl: samsung: Drop unused label field in samsung_pin_ctrl struct
pinctrl: samsung: Make samsung_pinctrl_get_soc_data use ERR_PTR()
pinctrl: Add Intel Cherryview/Braswell pin controller support
gpio / ACPI: Add knowledge about pin controllers to acpi_get_gpiod()
pinctrl: Fix path error in documentation
pinctrl: rockchip: save and restore gpio6_c6 pinmux in suspend/resume
pinctrl: rockchip: add suspend/resume functions
We are going to have more pinctrl drivers for Intel hardware so separate
all our pin controller drivers to own directory.
