path: root/drivers/pinctrl/pinctrl-imx35.c
2013-04-09pinctrl: imx: move hard-coding data into device treeShawn Guo
Currently, all imx pinctrl drivers maintain a big array of struct imx_pin_reg which hard-codes data like register offset and mux mode setting for each pin function. Every time a new imx SoC support is added, we need to add such a big mount of data. With moving to single kernel build, it's only matter of time to be blamed on memory consuming. With DTC pre-processor support in place, the patch moves all these data into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and changing the PIN_FUNC_ID parsing code a little bit. The pin id gets re-numbered based on mux register offset, or config register offset if the pin has no mux register, so that kernel can identify the pin id from register offsets provided by device tree. As a bonus point of the change, those arbitrary magic numbers standing for particular PIN_FUNC_ID in device tree sources are now replaced by macros to improve the readability of dts files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-03Drivers: pinctrl: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Barry Song <baohua.song@csr.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pinctrl: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pinctrl: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-03pinctrl: pinctrl-imx: add imx35 pinctrl driverUwe Kleine-König
This is mostly cut'n'paste from the imx51 pinctrl driver. The data was generated using sed and awk on arch/arm/plat-mxc/include/mach/iomux-mx35.h. Changes since (implicit) v1 - remove references to file names in binding documentation - remove sed commands from comments in driver - add explicit numbers for pins and functions Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
