Currently, pinctrl_register() just returns NULL on error, so the
callers can not know the exact reason of the failure.
Some of the pinctrl drivers return -EINVAL, some -ENODEV, and some
-ENOMEM on error of pinctrl_register(), although the error code
might be different from the real cause of the error.
This commit reworks pinctrl_register() to return the appropriate
error code and modifies all of the pinctrl drivers to use IS_ERR()
for the error checking and PTR_ERR() for getting the error code.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Lee Jones <lee@kernel.org>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Ray Jui <rjui@broadcom.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
Acked-by: Wei Chen <Wei.Chen@csr.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Sanity check on resource happening with devm_ioremap_resource().
Signed-off-by: Varka Bhadram <varkab@cdac.in>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 2243a87d90b42eb38bc281957df3e57c712b5e56
"pinctrl: avoid duplicated calling enable_pinmux_setting for a pin"
removed the .disable callback from the struct pinmux_ops,
making the .enable() callback the only remaining callback.
However .enable() is a bad name as it seems to imply that a
muxing can also be disabled. Rename the callback to .set_mux()
and also take this opportunity to clean out any remaining
mentions of .disable() from the documentation.
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Acked-by: Fan Wu <fwu@marvell.com>
What the patch does:
1. Call pinmux_disable_setting ahead of pinmux_enable_setting
each time pinctrl_select_state is called
2. Remove the HW disable operation in pinmux_disable_setting function.
3. Remove the disable ops in struct pinmux_ops
4. Remove all the disable ops users in current code base.
Notes:
1. Great thanks for the suggestion from Linus, Tony Lindgren and
Stephen Warren and Everyone that shared comments on this patch.
2. The patch also includes comment fixes from Stephen Warren.
The reason why we do this:
1. To avoid duplicated calling of the enable_setting operation
without disabling operation inbetween which will let the pin
descriptor desc->mux_usecount increase monotonously.
2. The HW pin disable operation is not useful for any of the
existing platforms.
And this can be used to avoid the HW glitch after using the
item #1 modification.
In the following case, the issue can be reproduced:
1. There is a driver that need to switch pin state dynamically,
e.g. between "sleep" and "default" state
2. The pin setting configuration in a DTS node may be like this:
component a {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&a_grp_setting &c_grp_setting>;
pinctrl-1 = <&b_grp_setting &c_grp_setting>;
The "c_grp_setting" config node is totally identical, maybe like
following one:
c_grp_setting: c_grp_setting {
pinctrl-single,pins = <GPIO48 AF6>;
3. When switching the pin state in the following official pinctrl
sequence:
pin = pinctrl_get();
state = pinctrl_lookup_state(wanted_state);
pinctrl_select_state(state);
pinctrl_put();
Test Result:
1. The switch is completed as expected, that is: the device's
pin configuration is changed according to the description in the
"wanted_state" group setting
2. The "desc->mux_usecount" of the corresponding pins in "c_group"
is increased without being decreased, because the "desc" is for
each physical pin while the setting is for each setting node
in the DTS.
Thus, if the "c_grp_setting" in pinctrl-0 is not disabled ahead
of enabling "c_grp_setting" in pinctrl-1, the desc->mux_usecount
will keep increasing without any chance to be decreased.
According to the comments in the original code, only the setting,
in old state but not in new state, will be "disabled" (calling
pinmux_disable_setting), which is correct logic but not intact. We
still need consider case that the setting is in both old state
and new state. We can do this in the following two ways:
1. Avoid to "enable"(calling pinmux_enable_setting) the "same pin
setting" repeatedly
2. "Disable"(calling pinmux_disable_setting) the "same pin setting",
actually two setting instances, ahead of enabling them.
Analysis:
1. The solution #2 is better because it can avoid too much
iteration.
2. If we disable all of the settings in the old state and one of
the setting(s) exist in the new state, the pins mux function
change may happen when some SoC vendors defined the
"pinctrl-single,function-off"
in their DTS file.
old_setting => disabled_setting => new_setting.
3. In the pinmux framework, when a pin state is switched, the
setting in the old state should be marked as "disabled".
Conclusion:
1. To Remove the HW disabling operation to above the glitch mentioned
above.
2. Handle the issue mentioned above by disabling all of the settings
in old state and then enable the all of the settings in new state.
Signed-off-by: Fan Wu <fwu@marvell.com>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
In the TB10x pin database, a port index of -1 is used to indicate
unmuxed GPIO pin groups. This bug fixes a 'cast to unsigned' bug of
this value.
Thanks to Dan Carpenter for highlighting this.
CC: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com>
module_platform_driver() makes the code simpler by eliminating
boilerplate code.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This patch fix the error handling in tb10x_pinctrl_probe():
- devm_ioremap_resource() return ERR_PTR() and never return NULL
- remove the dev_err call to avoid redundant error message
- pinctrl_register() returns NULL not ERR_PTR()
The pinmux driver of the Abilis Systems TB10x platform based on ARC700 CPUs.
Used to control the pinmux and is a prerequisite for the GPIO driver.
Signed-off-by: Pierrick Hascoet <pierrick.hascoet@abilis.com>
