Add PFC support for the R8A7794 SoC including pin groups for some
on-chip devices such as ETH, I2C, INTC, MSIOF, QSPI, [H]SCIF...
Sergei: squashed together several patches, fixed the MLB_CLK typo,
added IRQ4.. IRQ9 pin groups, fixed IRQn comments, added ETH B pin
group names, removed stray new line and fixed typos in the comments
in the pinmux_config_regs[] initializer, removed the platform device
ID, took into account limited number of signals in the GPIO1/5/6
controllers, added reasonable and removed unreasonable
copyrights, modified the bindings document, renamed, added changelog.
Changes in version 5:
- resolved rejects, refreshed the patch;
- added Laurent Pinchart's ACK.
Changes in version 4:
- reused the PORT_GP_26() macro to #define PORT_GP_28().
Changes in version 3:
- removed the platform device ID;
- added PORT_GP_26() and PORT_GP_28() macros, used them for GPIO1/5/6 in the
CPU_ALL_PORT() macro.
Changes in version 2:
- rebased the patch.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Remove sh7372 PFC support as part of the sh7372 and Mackerel
legacy code removal.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Add PFC support for the EMMA Mobile EV2 SoC including pin groups for
on-chip devices.
Signed-off-by: Niklas Söderlund <niso@kth.se>
Add PFC support for the r8a7791 SoC V2 including pin groups for
on-chip devices such as MSIOF, SCIF, USB, MMC, SDHI, DU.
Signed-off-by: Kunihito Higashiyama <kunihito.higashiyama.ur@renesas.com>
Signed-off-by: Yoshikazu Fujikawa <yoshikazu.fujikawa.ue@renesas.com>
Signed-off-by: Nobuyuki HIRAI <nobuyuki.hirai.xe@renesas.com>
Signed-off-by: Shinobu Uehara <shinobu.uehara.xc@renesas.com>
Signed-off-by: Koji Matsuoka <koji.matsuoka.xm@renesas.com>
Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com>
[damm@opensource.se: Forward ported to upstream, minor fixes]
Signed-off-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
The sh73a0 has an internal power gate on the VCCQ power supply for the
SDHI0 device that is controlled (for some strange reason) by a bit in a
PFC register. This feature should be exposed as a regulator.
As the same register is also used for pin control purposes there is no
way to achieve atomic read/write sequences with a separate regulator
driver. We thus need to implement the regulator here.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Make GPIO support optional for platforms that don't support GPIOLIB.
Add initial PFC support for the r8a7790 SoC.
At this point only GPIO interface is supported, move to
newer interfaces planned as incremental changes.
Original authors is Koji Matsuoka-san, thanks for him
and his team for the heavy lifting. Adjusted by Magnus
to work together with updated code in drivers/pinctrl.
Signed-off-by: Koji Matsuoka <koji.matsuoka.xm@rms.renesas.com>
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
GENERIC_GPIO is now equivalent to GPIOLIB and features that depended on
GENERIC_GPIO can now depend on GPIOLIB to allow removal of this option.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Add initial PFC support for the r8a73a4 SoC.
At this point only GPIO interface is supported, move to newer interfaces
Original authors are Morimoto-san with help from Yoshii-san, thanks to
them for the heavy lifting. Adjusted by Magnus to work together with
Signed-off-by: Takashi Yoshii <takashi.yoshii.zj@renesas.com>
The existing PFC pinconf implementation, tied to the PFC-specific pin
types, isn't used by drivers or boards. Replace it with the generic
pinconf types to implement bias (pull-up/down) setup. Other pin
configuration options can be implemented later if needed.
Acked-by: Paul Mundt <lethal@linux-sh.org>
