[ Upstream commit 02aeb2f21530c98fc3ca51028eda742a3fafbd9f ]
pinmux_func_gpios[] contains a hole due to the missing function GPIO
definition for the "CTX0&CTX1" signal, which is the logical "AND" of the
first two CAN outputs.
A closer look reveals other issues:
- Some functionality is available on alternative pins, but the
PINMUX_DATA() entries is using the wrong marks,
- Several configurations are missing.
Fix this by:
- Renaming CTX0CTX1CTX2_MARK, CRX0CRX1_PJ22_MARK, and
CRX0CRX1CRX2_PJ20_MARK to CTX0_CTX1_CTX2_MARK, CRX0_CRX1_PJ22_MARK,
resp. CRX0_CRX1_CRX2_PJ20_MARK for consistency with the
corresponding enum IDs,
- Adding all missing enum IDs and marks,
- Use the right (*_PJ2x) variants for alternative pins,
- Adding all missing configurations to pinmux_data[],
- Adding all missing function GPIO definitions to pinmux_func_gpios[].
See SH7268 Group, SH7269 Group User’s Manual: Hardware, Rev. 2.00:
[1] Table 1.4 List of Pins
[2] Figure 23.29 Connection Example when Using Channels 0 and 1 as One
Channel (64 Mailboxes × 1 Channel) and Channel 2 as One Channel
(32 Mailboxes × 1 Channel),
[3] Figure 23.30 Connection Example when Using Channels 0, 1, and 2 as
One Channel (96 Mailboxes × 1 Channel),
[4] Table 48.3 Multiplexed Pins (Port B),
[5] Table 48.4 Multiplexed Pins (Port C),
[6] Table 48.10 Multiplexed Pins (Port J),
[7] Section 48.2.4 Port B Control Registers 0 to 5 (PBCR0 to PBCR5).
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Link: https://lore.kernel.org/r/20191218194812.12741-5-geert+renesas@glider.be
[ Upstream commit a23680594da7a9e2696dbcf4f023e9273e2fa40b ]
Suspending Goodix touchscreens requires changing the interrupt pin to
output before sending them a power-down command. Followed by wiggling
the interrupt pin to wake the device up, after which it is put back
in input mode.
On Bay Trail devices with a Goodix touchscreen direct-irq mode is used
in combination with listing the pin as a normal GpioIo resource.
This works fine, until the goodix driver gets rmmod-ed and then insmod-ed
again. In this case byt_gpio_disable_free() calls
byt_gpio_clear_triggering() which clears the IRQ flags and after that the
(direct) IRQ no longer triggers.
This commit fixes this by adding a check for the BYT_DIRECT_IRQ_EN flag
to byt_gpio_clear_triggering().
Note that byt_gpio_clear_triggering() only gets called from
byt_gpio_disable_free() for direct-irq enabled pins, as these are excluded
from the irq_valid mask by byt_init_irq_valid_mask().
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[ Upstream commit 55b1cb1f03ad5eea39897d0c74035e02deddcff2 ]
two CAN outputs.
Fix this by:
- Renaming CRX0_CRX1_MARK to CTX0_CTX1_MARK, as PJ2MD[2:0]=010
configures the combined "CTX0&CTX1" output signal,
- Renaming CRX0X1_MARK to CRX0_CRX1_MARK, as PJ3MD[1:0]=10 configures
the shared "CRX0/CRX1" input signal, which is fed to both CAN
inputs,
- Adding the missing function GPIO definition for "CTX0&CTX1" to
pinmux_func_gpios[],
- Moving all CAN enums next to each other.
See SH7262 Group, SH7264 Group User's Manual: Hardware, Rev. 4.00:
[1] Figure 1.2 (3) (Pin Assignment for the SH7264 Group (1-Mbyte
Version),
[2] Figure 1.2 (4) Pin Assignment for the SH7264 Group (640-Kbyte
Version,
[3] Table 1.4 List of Pins,
[4] Figure 20.29 Connection Example when Using This Module as 1-Channel
Module (64 Mailboxes x 1 Channel),
[5] Table 32.10 Multiplexed Pins (Port J),
[6] Section 32.2.30 (3) Port J Control Register 0 (PJCR0).
Note that the last 2 disagree about PJ2MD[2:0], which is probably the
root cause of this bug. But considering [4], "CTx0&CTx1" in [5] must
be correct, and "CRx0&CRx1" in [6] must be wrong.
Link: https://lore.kernel.org/r/20191218194812.12741-4-geert+renesas@glider.be
commit 805f635703b2562b5ddd822c62fc9124087e5dd5 upstream.
The FN_SDSELF_B and FN_SD1_CLK_B enum IDs are used twice, which means
one set of users must be wrong. Replace them by the correct enum IDs.
Fixes: 87f8c988636db0d4 ("sh-pfc: Add r8a7778 pinmux support")
Link: https://lore.kernel.org/r/20191218194812.12741-2-geert+renesas@glider.be
[ Upstream commit 0e6e448bdcf896d001a289a6112a704542d51516 ]
There are two pin groups for the FSIC SPDIF signal, but the FSIC pin
group array lists only one, and it refers to a nonexistent group.
Fixes: 2ecd4154c906b7d6 ("sh-pfc: sh73a0: Add FSI pin groups and functions")
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit b9fd50488b4939ce5b3a026d29e752e17c2d1800 ]
The vin1_data18_b pin group itself is present, but it is not listed in
the VIN1 pin group array, and thus cannot be selected.
Fixes: 7dd74bb1f058786e ("pinctrl: sh-pfc: r8a7792: Add VIN pin groups")
[ Upstream commit a4b0350047f1b10207e25e72d7cd3f7826e93769 ]
The entry for "scifb2_data_c" in the SCIFB2 pin group array contains a
typo, thus the group cannot be selected.
Fixes: 5088451962389924 ("pinctrl: sh-pfc: r8a7791 PFC support")
[ Upstream commit 1ecd8c9cb899ae277e6986ae134635cb1a50f5de ]
The err_rst_reqb, ext_clki, lowpwr, and ref_clko pin groups are present,
but no pinmux functions refer to them, hence they can not be selected.
Fixes: 1e7d5d849cf4f0c5 ("sh-pfc: Add emev2 pinmux support")
[ Upstream commit 4d374bacd7c9665179f9752a52d5d602c45d8190 ]
The IP10[5:3] field in Peripheral Function Select Register 10 has a
width of 3 bits, i.e. it allows programming one out of 8 different
configurations.
However, 9 values are provided instead of 8, overflowing into the
subsequent field in the register, and thus breaking the configuration of
the latter.
Fix this by dropping a bogus zero value.
Fixes: ac1ebc2190f575fc ("sh-pfc: Add sh7734 pinmux support")
[ Upstream commit 9540cbdfcd861caf67a6f0e4bb7f46d41c4aad86 ]
The Port C I/O Register 0 contains 7 reserved bits, but the descriptor
contains only dummy configuration values for 6 reserved bits, thus
breaking the configuration of all subsequent fields in the register.
Fix this by adding the two missing configuration values.
Fixes: f5e811f2a43117b2 ("sh-pfc: Add sh7269 pinmux support")
[ Upstream commit 94482af7055e1ffa211c1135256b85590ebcac99 ]
The Peripheral Function Select Register 11 contains 3 reserved bits and
15 variable-width fields, but the variable field descriptor does not
contain the 3-bit field IP11[25:23].
Fixes: 856cb4bb337ee504 ("sh: Add support pinmux for SH7734")
[ Upstream commit 6a6c195d98a1a5e70faa87f594d7564af1dd1bed ]
The Peripheral Function Select Register 9 contains 12 fields, but the
variable field descriptor contains a 13th bogus field of 3 bits.
Fixes: 43c4436e2f1890a7 ("pinctrl: sh-pfc: add R8A7794 PFC support")
[ Upstream commit 124cde98f856b6206b804acbdec3b7c80f8c3427 ]
The tpu4_to3_mux[] array contains the TPU4TO3 pin mark, but the
tpu4_to3_pins[] array lacks the corresponding pin number.
Add the missing pin number, for non-GPIO pin F26.
Fixes: 5da4eb049de803c7 ("sh-pfc: sh73a0: Add TPU pin groups and functions")
[ Upstream commit 0d6256cb880166a4111bebce35790019e56b6e1b ]
The vin1_b_data18_mux[] arrays contains pin marks for the 2 LSB bits of
the color components. The vin1_b_data18_pins[] array rightfully does
not include the corresponding pin numbers, as RGB18 is subset of RGB24,
containing only the 6 MSB bits of each component.
Fixes: 8e32c9671f84acd8 ("pinctrl: sh-pfc: r8a7791: Add VIN pins")
[ Upstream commit 884fa25fb6e5e63ab970d612a628313bb68f37cc ]
The qspi_data4_b_mux[] array contains pin marks for the clock and chip
select pins. The qspi_data4_b_pins[] array rightfully does not contain
the corresponding pin numbers, as the control pins are provided by a
separate group (qspi_ctrl_b).
Fixes: 2d0c386f135e4186 ("pinctrl: sh-pfc: r8a7791: Add QSPI pin groups")
[ Upstream commit 96bb2a6ab4eca10e5b6490b3f0738e9f7ec22c2b ]
The lcd0_data24_1_pins[] array contains the LCD0 D1[2-5] pin numbers,
but the lcd0_data24_1_mux[] array lacks the corresponding pin marks.
Fixes: 06c7dd866da70f6c ("sh-pfc: r8a7740: Add LCDC0 and LCDC1 pin groups and functions")
[ Upstream commit 1ebc589a7786f17f97b9e87b44e0fb4d0290d8f8 ]
The gether_gmii_mux[] array contains the REF125CK pin mark, but the
gether_gmii_pins[] array lacks the corresponding pin number.
Fixes: bae11d30d0cafdc5 ("sh-pfc: r8a7740: Add GETHER pin groups and functions")
[ Upstream commit 40ecab551232972a39cdd8b6f17ede54a3fdb296 ]
Commit 39ce8150a079 ("pinctrl: baytrail: Serialize all register access")
added a spinlock around all register accesses because:
"There is a hardware issue in Intel Baytrail where concurrent GPIO register
access might result reads of 0xffffffff and writes might get dropped
completely."
Testing has shown that this does not catch all cases, there are still
2 problems remaining
1) The original fix uses a spinlock per byt_gpio device / struct,
additional testing has shown that this is not sufficient concurent
accesses to 2 different GPIO banks also suffer from the same problem.
This commit fixes this by moving to a single global lock.
2) The original fix did not add a lock around the register accesses in
the suspend/resume handling.
Since pinctrl-baytrail.c is using normal suspend/resume handlers,
interrupts are still enabled during suspend/resume handling. Nothing
should be using the GPIOs when they are being taken down, _but_ the
GPIOs themselves may still cause interrupts, which are likely to
use (read) the triggering GPIO. So we need to protect against
concurrent GPIO register accesses in the suspend/resume handlers too.
This commit fixes this by adding the missing spin_lock / unlock calls.
The 2 fixes together fix the Acer Switch 10 SW5-012 getting completely
confused after a suspend resume. The DSDT for this device has a bug
in its _LID method which reprograms the home and power button trigger-
flags requesting both high and low _level_ interrupts so the IRQs for
these 2 GPIOs continuously fire. This combined with the saving of
registers during suspend, triggers concurrent GPIO register accesses
resulting in saving 0xffffffff as pconf0 value during suspend and then
when restoring this on resume the pinmux settings get all messed up,
resulting in various I2C busses being stuck, the wifi no longer working
and often the tablet simply not coming out of suspend at all.
Cc: stable@vger.kernel.org
Fixes: 39ce8150a079 ("pinctrl: baytrail: Serialize all register access")
[ Upstream commit 884caadad128efad8e00c1cdc3177bc8912ee8ec ]
The definitions for bit field [19:18] of the Peripheral Function Select
Register 3 were accidentally copied from bit field [20], leading to
duplicates for the TCLK1_B function, and missing TCLK0, CAN_CLK_B, and
ET0_ETXD4 functions.
Fix this by adding the missing GPIO_FN_CAN_CLK_B and GPIO_FN_ET0_ETXD4
enum values, and correcting the functions.
Reported-by: Ben Dooks <ben.dooks@codethink.co.uk>
Link: https://lore.kernel.org/r/20191024131308.16659-1-geert+renesas@glider.be
controller init
[ Upstream commit 7f028caadf6c37580d0f59c6c094ed09afc04062 ]
In s3c64xx_eint_eint0_init() the for_each_child_of_node() loop is used
with a break to find a matching child node. Although each iteration of
for_each_child_of_node puts the previous node, but early exit from loop
misses it. This leads to leak of device node.
Cc: <stable@vger.kernel.org>
Fixes: 61dd72613177 ("pinctrl: Add pinctrl-s3c64xx driver")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit a322b3377f4bac32aa25fb1acb9e7afbbbbd0137 upstream.
Several functions use for_each_child_of_node() loop with a break to find
Fixes: 9a2c1c3b91aa ("pinctrl: samsung: Allow grouping multiple pinmux/pinconf nodes")
controller init
commit 6fbbcb050802d6ea109f387e961b1dbcc3a80c96 upstream.
In s3c24xx_eint_init() the for_each_child_of_node() loop is used with a
Fixes: af99a7507469 ("pinctrl: Add pinctrl-s3c24xx driver")
[ Upstream commit 7ed07855773814337b9814f1c3e866df52ebce68 ]
When attempting to setup up a gpio hog, device probing will repeatedly
fail with -EPROBE_DEFERED errors. It is caused by a circular dependency
between the gpio and pinctrl frameworks. If the gpio-ranges property is
present in device tree, then the gpio framework will handle the gpio pin
registration and eliminate the circular dependency.
See Christian Lamparter's commit a86caa9ba5d7 ("pinctrl: msm: fix
gpio-hog related boot issues") for a detailed commit message that
explains the issue in much more detail. The code comment in this commit
came from Christian's commit.
I did not test this change against any hardware supported by this
particular driver, however I was able to validate this same fix works
for pinctrl-spmi-gpio.c using a LG Nexus 5 (hammerhead) phone.
Signed-off-by: Brian Masney <masneyb@onstation.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
[ Upstream commit 054f2400f706327f96770219c3065b5131f8f154 ]
Some values in the Peripheral Function Select Register 10 descriptor are
shifted by one position, which may cause a peripheral function to be
programmed incorrectly.
Fixing this makes all HSCIF0 pins use Function 4 (value 3), like was
already the case for the HSCK0 pin in field IP10[5:3].
[ Upstream commit 1b99d0c80bbe1810572c2cb77b90f67886adfa8d ]
The Port F Control Register 3 (PFCR3) contains only a single field.
However, counting from left to right, it is the fourth field, not the
first field.
Insert the missing dummy configuration values (3 fields of 16 values) to
fix this.
The descriptor for the Port F Control Register 0 (PFCR0) lacks the
description for the 4th field (PF0 Mode, PF0MD[2:0]).
Add the missing configuration values to fix this.
Fixes: a8d42fc4217b1ea1 ("sh-pfc: Add sh7264 pinmux support")
[ Upstream commit 9b4924da4711674e62d97d4f5360446cc78337af ]
This patch is based on commit a86caa9ba5d7 ("pinctrl: msm: fix gpio-hog
related boot issues").
It fixes the issue that the gpio ranges needs to be defined before
gpiochip_add().
Therefore, we also have to swap the order of registering the pinctrl
driver and registering the gpio chip.
You also have to add the "gpio-ranges" property to the pinctrl device
node to get it finally working.
Signed-off-by: Martin Schiller <ms@dev.tdt.de>
Acked-by: John Crispin <john@phrozen.org>
[ Upstream commit cd8a145a066a1a3beb0ae615c7cb2ee4217418d7 ]
Clang warns when one enumerated type is implicitly converted to another:
drivers/pinctrl/pinctrl-zynq.c:985:18: warning: implicit conversion from
enumeration type 'enum zynq_pin_config_param' to different enumeration
type 'enum pin_config_param' [-Wenum-conversion]
{"io-standard", PIN_CONFIG_IOSTANDARD, zynq_iostd_lvcmos18},
drivers/pinctrl/pinctrl-zynq.c:990:16: warning: implicit conversion from
= { PCONFDUMP(PIN_CONFIG_IOSTANDARD, "IO-standard", NULL, true),
./include/linux/pinctrl/pinconf-generic.h:163:11: note: expanded from
macro 'PCONFDUMP'
.param = a, .display = b, .format = c, .has_arg = d \
2 warnings generated.
It is expected that pinctrl drivers can extend pin_config_param because
of the gap between PIN_CONFIG_END and PIN_CONFIG_MAX so this conversion
isn't an issue. Most drivers that take advantage of this define the
PIN_CONFIG variables as constants, rather than enumerated values. Do the
same thing here so that Clang no longer warns.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
[ Upstream commit f24bfb39975c241374cadebbd037c17960cf1412 ]
drivers/pinctrl/pinctrl-lpc18xx.c:643:29: warning: implicit conversion
from enumeration type 'enum lpc18xx_pin_config_param' to different
enumeration type 'enum pin_config_param' [-Wenum-conversion]
{"nxp,gpio-pin-interrupt", PIN_CONFIG_GPIO_PIN_INT, 0},
drivers/pinctrl/pinctrl-lpc18xx.c:648:12: warning: implicit conversion
PCONFDUMP(PIN_CONFIG_GPIO_PIN_INT, "gpio pin int", NULL, true),
macro 'PCONFDUMP'
Link: https://github.com/ClangBuiltLinux/linux/issues/140
[ Upstream commit 149a96047237574b756d872007c006acd0cc6687 ]
When attempting to setup up a gpio hog, device probing would repeatedly
fail with -EPROBE_DEFERED errors. It was caused by a circular dependency
[ Upstream commit 0c3dfa176912b5f87732545598200fb55e9c1978 ]
Sharing the same irqchip with multiple gpiochips is not a good
practice. For instance, when installing hooks, we change the state
of the irqchip. The initial state of the irqchip for the second
gpiochip to register is then disrupted.
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit b97760ae8e3dc8bb91881c13425a0bff55f2bd85 ]
Smatch complains about this condition:
if (has_config && num_pins >= 1)
The "has_config" variable is either uninitialized or true. The
"num_pins" variable is unsigned and we verified that it is non-zero on
the lines before so we know "num_pines >= 1" is true. Really, we could
just check "num_configs" directly and remove the "has_config" variable.
Fixes: 776180848b57 ("pinctrl: introduce driver for Atmel PIO4 controller")
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit 39b65fbb813089e366b376bd8acc300b6fd646dc ]
The pinctrl->functions[] array has pinctrl->num_functions elements and
the pinctrl->groups[] array is the same way. These are set in
ns2_pinmux_probe(). So the > comparisons should be >= so that we don't
read one element beyond the end of the array.
Fixes: b5aa1006e4a9 ("pinctrl: ns2: add pinmux driver support for Broadcom NS2 SoC")
Link: https://lore.kernel.org/r/20190926081426.GB2332@mwanda
Acked-by: Scott Branden <scott.branden@broadcom.com>
[ Upstream commit c2cf351eba2ff6002ce8eb178452219d2521e38e ]
pmx_writel uses writel which inserts write barrier before the
register write.
This patch has fix to replace writel with writel_relaxed followed
by a readback and memory barrier to ensure write operation is
completed for successful pinctrl change.
Acked-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Sowjanya Komatineni <skomatineni@nvidia.com>
Link: https://lore.kernel.org/r/1565984527-5272-2-git-send-email-skomatineni@nvidia.com
[ Upstream commit 3c89c70634bb0b6f48512de873e7a45c7e1fbaa5 ]
The call to of_parse_phandle returns a node pointer with refcount
incremented thus it must be explicitly decremented after the last
usage.
Detected by coccinelle with the following warnings:
./drivers/pinctrl/pinctrl-rockchip.c:3221:2-8: ERROR: missing of_node_put; acquired a node pointer with refcount incremented on line 3196, but without a corresponding object release within this function.
./drivers/pinctrl/pinctrl-rockchip.c:3223:1-7: ERROR: missing of_node_put; acquired a node pointer with refcount incremented on line 3196, but without a corresponding object release within this function.
Signed-off-by: Wen Yang <wen.yang99@zte.com.cn>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: linux-gpio@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
[ Upstream commit 44a4455ac2c6b0981eace683a2b6eccf47689022 ]
The call to of_get_child_by_name returns a node pointer with refcount
usage.
./drivers/pinctrl/pinctrl-pistachio.c:1422:1-7: ERROR: missing of_node_put; acquired a node pointer with refcount incremented on line 1360, but without a corresponding object release within this function.
[ Upstream commit c17abcfa93bf0be5e48bb011607d237ac2bfc839 ]
Fix the mismatch between the "sdxc_d13_1_a" pin group definition from
meson8b_cbus_groups and the entry in sdxc_a_groups ("sdxc_d0_13_1_a").
This makes it possible to use "sdxc_d13_1_a" in device-tree files to
route the MMC data 1..3 pins to GPIOX_1..3.
Fixes: 0fefcb6876d0d6 ("pinctrl: Add support for Meson8b")
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
commit 1f60652dd586d1b3eee7c4602892a97a62fa937a upstream.
drivers/pinctrl/pinctrl-max77620.c:56:12: warning: implicit conversion
from enumeration type 'enum max77620_pinconf_param' to different
.param = MAX77620_ACTIVE_FPS_SOURCE,
Link: https://github.com/ClangBuiltLinux/linux/issues/139
commit a86caa9ba5d70696ceb35d1d39caa20d8b641387 upstream.
Sven Eckelmann reported an issue with the current IPQ4019 pinctrl.
Setting up any gpio-hog in the device-tree for his device would
"kill the bootup completely":
| [ 0.477838] msm_serial 78af000.serial: could not find pctldev for node /soc/pinctrl@1000000/serial_pinmux, deferring probe
| [ 0.499828] spi_qup 78b5000.spi: could not find pctldev for node /soc/pinctrl@1000000/spi_0_pinmux, deferring probe
| [ 1.298883] requesting hog GPIO enable USB2 power (chip 1000000.pinctrl, offset 58) failed, -517
| [ 1.299609] gpiochip_add_data: GPIOs 0..99 (1000000.pinctrl) failed to register
| [ 1.308589] ipq4019-pinctrl 1000000.pinctrl: Failed register gpiochip
| [ 1.316586] msm_serial 78af000.serial: could not find pctldev for node /soc/pinctrl@1000000/serial_pinmux, deferring probe
| [ 1.322415] spi_qup 78b5000.spi: could not find pctldev for node /soc/pinctrl@1000000/spi_0_pinmux, deferri
This was also verified on a RT-AC58U (IPQ4018) which would
no longer boot, if a gpio-hog was specified. (Tried forcing
the USB LED PIN (GPIO0) to high.).
The problem is that Pinctrl+GPIO registration is currently
peformed in the following order in pinctrl-msm.c:
1. pinctrl_register()
2. gpiochip_add()
3. gpiochip_add_pin_range()
The actual error code -517 == -EPROBE_DEFER is coming from
pinctrl_get_device_gpio_range(), which is called through:
gpiochip_add
of_gpiochip_add
of_gpiochip_scan_gpios
gpiod_hog
gpiochip_request_own_desc
__gpiod_request
chip->request
gpiochip_generic_request
pinctrl_gpio_request
pinctrl_get_device_gpio_range() is unable to find any valid
pin ranges, since nothing has been added to the pinctrldev_list yet.
so the range can't be found, and the operation fails with -EPROBE_DEFER.
This patch fixes the issue by adding the "gpio-ranges" property to
the pinctrl device node of all upstream Qcom SoC. The pin ranges are
then added by the gpio core.
In order to remain compatible with older, existing DTs (and ACPI)
a check for the "gpio-ranges" property has been added to
msm_gpio_init(). This prevents the driver of adding the same entry
to the pinctrldev_list twice.
Reported-by: Sven Eckelmann <sven.eckelmann@openmesh.com>
Tested-by: Sven Eckelmann <sven.eckelmann@openmesh.com> [ipq4019]
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit 2b745ac3cceb8fc1d9985990c8241a821ea97e53 ]
The GPIOAO pins (as well as the two exotic GPIO_BSD_EN and GPIO_TEST_N)
only belong to the pin controller in the AO domain. With the current
definition these pins cannot be referred to in .dts files as group
(which is possible on GXBB and GXL for example).
Add a separate "gpio_aobus" function to fix the mapping between the pin
controller and the GPIO pins in the AO domain. This is similar to how
the GXBB and GXL drivers implement this functionality.
Fixes: 9dab1868ec0db4 ("pinctrl: amlogic: Make driver independent from two-domain configuration")
[ Upstream commit 42f9b48cc5402be11d2364275eb18c257d2a79e8 ]
[ Upstream commit 614b1868a125a0ba24be08f3a7fa832ddcde6bca ]
We just changed the code so we apply bias disable on the correct
register but forgot to align the register calculation. The result
is that we apply the change on the correct register, but possibly
at the incorrect offset/bit
This went undetected because offsets tends to be the same between
REG_PULL and REG_PULLEN for a given pin the EE controller. This
is not true for the AO controller.
Fixes: e39f9dd8206a ("pinctrl: meson: fix pinconf bias disable")
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
commit 478b6767ad26ab86d9ecc341027dd09a87b1f997 upstream.
Pin PH11 is used on various A83T board to detect a change in the OTG
port's ID pin, as in when an OTG host cable is plugged in.
The incorrect offset meant the gpiochip/irqchip was activating the wrong
pin for interrupts.
Fixes: 4730f33f0d82 ("pinctrl: sunxi: add allwinner A83T PIO controller support")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
[ Upstream commit e39f9dd8206ad66992ac0e6218ef1ba746f2cce9 ]
If a bias is enabled on a pin of an Amlogic SoC, calling .pin_config_set()
with PIN_CONFIG_BIAS_DISABLE will not disable the bias. Instead it will
force a pull-down bias on the pin.
Instead of the pull type register bank, the driver should access the pull
enable register bank.
Fixes: 6ac730951104 ("pinctrl: add driver for Amlogic Meson SoCs")
[ Upstream commit b432414b996d32a1bd9afe2bd595bd5729c1477f ]
If you look at "pinconf-groups" in debugfs for ssbi-gpio you'll notice
it looks like nonsense.
The problem is fairly well described in commit 1cf86bc21257 ("pinctrl:
qcom: spmi-gpio: Fix pmic_gpio_config_get() to be compliant") and
commit 05e0c828955c ("pinctrl: msm: Fix msm_config_group_get() to be
compliant"), but it was pointed out that ssbi-gpio has the same
problem. Let's fix it there too.
Fixes: b4c45fe974bc ("pinctrl: qcom: ssbi: Family A gpio & mpp drivers")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Stephen Boyd <sboyd@kernel.org>
[ Upstream commit 0d5b476f8f57fcb06c45fe27681ac47254f63fd2 ]
If you look at "pinconf-groups" in debugfs for ssbi-mpp you'll notice
compliant"), but it was pointed out that ssbi-mpp has the same
NOTE: in case it's helpful to someone reading this, the way to tell
whether to do the -EINVAL or not is to look at the PCONFDUMP for a
given attribute. If the last element (has_arg) is false then you need
to do the -EINVAL trick.
ALSO NOTE: it seems unlikely that the values returned when we try to
get PIN_CONFIG_BIAS_PULL_UP will actually be printed since "has_arg"
is false for that one, but I guess it's still fine to return different
values so I kept doing that. It seems like another driver (ssbi-gpio)
uses a custom attribute (PM8XXX_QCOM_PULL_UP_STRENGTH) for something
similar so maybe a future change should do that here too.
Fixes: cfb24f6ebd38 ("pinctrl: Qualcomm SPMI PMIC MPP pin controller driver")
[ Upstream commit 89c68b102f13f123aaef22b292526d6b92501334 ]
It looks like we parse the drive strength setting here, but never
actually write it into the hardware to update it. Parse the setting and
then write it at the end of the pinconf setting function so that it
actually sticks in the hardware.
Fixes: 0e948042c420 ("pinctrl: qcom: spmi-mpp: Implement support for sink mode")
Cc: Doug Anderson <dianders@chromium.org>
Signed-off-by: Stephen Boyd <swboyd@chromium.org>
[ Upstream commit 69f8455f6cc78fa6cdf80d0105d7a748106271dc ]
'ret' should be returned while pmic_mpp_write_mode_ctl fails.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 1cf86bc21257a330e3af51f2a4e885f1a705f6a5 ]
If you do this on an sdm845 board:
grep "" /sys/kernel/debug/pinctrl/*spmi:pmic*/pinconf-groups
...it looks like nonsense. For every pin you see listed:
input bias disabled, input bias high impedance, input bias pull down, input bias pull up, ...
That's because pmic_gpio_config_get() isn't complying with the rules
that pinconf_generic_dump_one() expects. Specifically for boolean
parameters (anything with a "struct pin_config_item" where has_arg is
false) the function expects that the function should return its value
not through the "config" parameter but should return "0" if the value
is set and "-EINVAL" if the value isn't set.
Let's fix this.
>From a quick sample of other pinctrl drivers, it appears to be
tradition to also return 1 through the config parameter for these
boolean parameters when they exist. I'm not one to knock tradition,
so I'll follow tradition and return 1 in these cases. While I'm at
it, I'll also continue searching for four leaf clovers, kocking on
wood three times, and trying not to break mirrors.
NOTE: This also fixes an apparent typo for reading
PIN_CONFIG_BIAS_DISABLE where the old driver was accidentally
using "=" instead of "==" and thus was setting some internal
state when you tried to query PIN_CONFIG_BIAS_DISABLE. Oops.
Fixes: eadff3024472 ("pinctrl: Qualcomm SPMI PMIC GPIO pin controller driver")
commit 19da44cd33a3a6ff7c97fff0189999ff15b241e4 upstream.
The info->groups[] array is allocated in imx1_pinctrl_parse_dt(). It
has info->ngroups elements. Thus the > here should be >= to prevent
reading one element beyond the end of the array.
Fixes: 30612cd90005 ("pinctrl: imx1 core driver")
Reviewed-by: Uwe Kleine-König <u.kleine-könig@pengutronix.de>
Acked-by: Dong Aisheng <Aisheng.dong@nxp.com>
[ Upstream commit c29e9da56bebb4c2c794e871b0dc0298bbf08142 ]
platform_get_resource() may fail and return NULL, so we should
better check it's return value to avoid a NULL pointer dereference
a bit later in the code.
This is detected by Coccinelle semantic patch.
expression pdev, res, n, t, e, e1, e2;
res = platform_get_resource(pdev, t, n);
+ if (!res)
+ return -EINVAL;
... when != res == NULL
e = devm_ioremap_nocache(e1, res->start, e2);
Fixes: cc4fa83f66e9 ("pinctrl: nsp: add pinmux driver support for Broadcom NSP SoC")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
