path: root/drivers/pinctrl
2013-01-08Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC fixes from Olof Johansson: "People are back from the holiday breaks, and it shows. Here are a bunch of fixes for a number of platforms: - A couple of small fixes for Nomadik - A larger set of changes for kirkwood/mvebu - uart driver selection, dt clocks, gpio-poweroff fixups, a few __init annotation fixes and some error handling improvement in their xor dma driver. - i.MX had a couple of minor fixes (and a critical one for flexcan2 clock setup) - MXS has a small board fix and a framebuffer bugfix - A set of fixes for Samsung Exynos, fixing default bootargs and some Exynos5440 clock issues - A set of OMAP changes including PM fixes and a few sparse warning fixups All in all a bit more positive code delta than we'd ideally want to see here, mostly from the OMAP PM changes, but nothing overly crazy." * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits) ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array pinctrl: mvebu: make pdma clock on dove mandatory ARM: Dove: Add pinctrl clock to DT dma: mv_xor: fix error handling for clocks dma: mv_xor: fix error handling of mv_xor_channel_add() arm: mvebu: Add missing ; for cpu node. arm: mvebu: Armada XP MV78230 has only three Ethernet interfaces arm: mvebu: Armada XP MV78230 has two cores, not one clk: mvebu: Remove inappropriate __init tagging ARM: Kirkwood: Use fixed-regulator instead of board gpio call ARM: Kirkwood: Fix missing sdio clock ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providers ...
2013-01-07pinctrl: mvebu: make pdma clock on dove mandatorySebastian Hesselbarth
With the ability to pass clocks through DT, now make the pdma clock of dove pinctrl mandatory. Otherwise, pinctrl will hang the system when accessing some registers. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03Merge tag 'driver-core-3.8-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman: "Here are the remaining __dev* removal patches against the 3.8-rc2 tree. All of these patches were previously sent to the subsystem maintainers, most of them were picked up and pushed to you, but there were a number that fell through the cracks, and new drivers were added during the merge window, so this series cleans up the rest of the instances of these markings. Third time's the charm... Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c. * tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits) misc: remove __dev* attributes. include: remove __dev* attributes. Documentation: remove __dev* attributes. Drivers: misc: remove __dev* attributes. Drivers: block: remove __dev* attributes. Drivers: bcma: remove __dev* attributes. Drivers: char: remove __dev* attributes. Drivers: clocksource: remove __dev* attributes. Drivers: ssb: remove __dev* attributes. Drivers: dma: remove __dev* attributes. Drivers: gpu: remove __dev* attributes. Drivers: infinband: remove __dev* attributes. Drivers: memory: remove __dev* attributes. Drivers: mmc: remove __dev* attributes. Drivers: iommu: remove __dev* attributes. Drivers: power: remove __dev* attributes. Drivers: message: remove __dev* attributes. Drivers: macintosh: remove __dev* attributes. Drivers: mfd: remove __dev* attributes. pstore: remove __dev* attributes. ...
2013-01-03Drivers: pinctrl: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Barry Song <baohua.song@csr.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-26pinctrl: nomadik: return if prcm_base is NULLFabio Baltieri
This patch adds a check for npct->prcm_base to make sure that the address is not NULL before using it, as the driver was made capable of loading even without a proper memory resource in: f1671bf pinctrl/nomadik: make independent of prcmu driver Also, refuses to probe without prcm_base on anything else than nomadik. This solves the following crash, introduced during the merge window when booting on U8500 with device tree: pinctrl-nomadik pinctrl-db8500: No PRCM base, assume no ALT-Cx control is available Unable to handle kernel NULL pointer dereference at virtual address 00000138 pgd = c0004000 [00000138] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT SMP ARM Modules linked in: CPU: 0 Not tainted (3.7.0-02892-g1ebaf4f #631) PC is at nmk_pmx_enable+0x1bc/0x4d0 LR is at clk_disable+0x40/0x44 [snip] [<c01d5e50>] (nmk_pmx_enable+0x1bc/0x4d0) from [<c01d3ba8>] (pinmux_enable_setting+0x12c/0x1ec) [<c01d3ba8>] (pinmux_enable_setting+0x12c/0x1ec) from [<c01d1dc8>] (pinctrl_select_state_locked+0xfc/0x134) [<c01d1dc8>] (pinctrl_select_state_locked+0xfc/0x134) from [<c01d2814>] (pinctrl_register+0x26c/0x43c) [<c01d2814>] (pinctrl_register+0x26c/0x43c) from [<c01d668c>] (nmk_pinctrl_probe+0x114/0x238) [<c01d668c>] (nmk_pinctrl_probe+0x114/0x238) from [<c0211cc4>] (platform_drv_probe+0x28/0x2c) [<c0211cc4>] (platform_drv_probe+0x28/0x2c) from [<c0210738>] (driver_probe_device+0x84/0x21c) [<c0210738>] (driver_probe_device+0x84/0x21c) from [<c02109c0>] (__device_attach+0x50/0x54) [<c02109c0>] (__device_attach+0x50/0x54) from [<c020eb1c>] (bus_for_each_drv+0x54/0x9c) [<c020eb1c>] (bus_for_each_drv+0x54/0x9c) from [<c0210668>] (device_attach+0x84/0x9c) [<c0210668>] (device_attach+0x84/0x9c) from [<c020fbac>] (bus_probe_device+0x94/0xb8) [<c020fbac>] (bus_probe_device+0x94/0xb8) from [<c020e084>] (device_add+0x4f0/0x5bc) [<c020e084>] (device_add+0x4f0/0x5bc) from [<c0276400>] (of_device_add+0x40/0x48) [<c0276400>] (of_device_add+0x40/0x48) from [<c0276a98>] (of_platform_device_create_pdata+0x68/0x98) [<c0276a98>] (of_platform_device_create_pdata+0x68/0x98) from [<c0276bac>] (of_platform_bus_create+0xe4/0x260) [<c0276bac>] (of_platform_bus_create+0xe4/0x260) from [<c0276bf8>] (of_platform_bus_create+0x130/0x260) [<c0276bf8>] (of_platform_bus_create+0x130/0x260) from [<c0276d94>] (of_platform_populate+0x6c/0xac) [<c0276d94>] (of_platform_populate+0x6c/0xac) from [<c04a8224>] (u8500_init_machine+0x78/0x140) [<c04a8224>] (u8500_init_machine+0x78/0x140) from [<c04a3560>] (customize_machine+0x24/0x30) [<c04a3560>] (customize_machine+0x24/0x30) from [<c00087b0>] (do_one_initcall+0x130/0x1b0) [<c00087b0>] (do_one_initcall+0x130/0x1b0) from [<c033ff9c>] (kernel_init+0x138/0x2e8) [<c033ff9c>] (kernel_init+0x138/0x2e8) from [<c000eb18>] (ret_from_fork+0x14/0x20) Code: 0a00001b e19400b2 e59a200c e0822000 (e592c000) ---[ end trace 1b75b31a2719ed1c ]--- note: swapper/0[1] exited with preempt_count 1 Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-26pinctrl: sirf: enable GPIO pullup/down configuration from dtsBarry Song
commit 7bec207427c2efb794 remove sirfsoc_gpio_set_pull function, this patches takes the feature back by adding sirf,pullups and sirf,pulldowns prop in dts, and the driver will set the GPIO pull according to the dts. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-26pinctrl: fix comment mistakeLinus Walleij
This variable pertains to pinctrl handles not muxes specifically. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-26drivers/pinctrl/pinctrl-at91.c: convert kfree to devm_kfreeJulia Lawall
The function at91_dt_node_to_map is ultimately called by the function pinctrl_get, which is an exported function. Since it is possible that this function is not called from within a probe function, for safety, the kfree is converted to a devm_kfree, to both free the data and remove it from the device in a failure situation. Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-26pinctrl: imx5: fix GPIO_8 pad CAN1_RXCAN configurationPhilipp Zabel
3 is an invalid value for the CAN1_IPP_IND_CANRX_SELECT_INPUT register. Set it to 2, which correctly selects the GPIO_8 pad. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-18pinctrl: exynos5440/samsung: Staticize pcfgsAxel Lin
I got below build error with random config if CONFIG_PINCTRL_SAMSUNG=y && CONFIG_PINCTRL_EXYNOS5440=y. Fix the build error by making pcfgs static. LD drivers/pinctrl/built-in.o drivers/pinctrl/pinctrl-exynos5440.o: In function `.LANCHOR0': pinctrl-exynos5440.c:(.data+0x54): multiple definition of `pcfgs' drivers/pinctrl/pinctrl-samsung.o:pinctrl-samsung.c:(.data+0x54): first defined here make[2]: *** [drivers/pinctrl/built-in.o] Error 1 make[1]: *** [drivers/pinctrl] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-12-18pinctrl: samsung: Fix a typo in pinctrl-samsung.hSachin Kamat
struct samsung_pin_bank does not have a member called reg_offset. It should be pctl_offset instead. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-12-13Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform conversion patches from Olof Johansson: "Here are more patches in the progression towards multiplatform, sparse irq conversions in particular. Tegra has a handful of cleanups and general groundwork, but is not quite there yet on full enablement. Platforms that are enabled through this branch are VT8500 and Zynq. Note that i.MX was converted in one of the earlier cleanup branches as well (before we started a separate topic for multiplatform). And both new platforms for this merge window, sunxi and bcm, were merged with multiplatform support enabled." Fix up conflicts mostly as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: zynq: Remove all unused mach headers ARM: zynq: add support for ARCH_MULTIPLATFORM ARM: zynq: make use of debug_ll_io_init() ARM: zynq: remove TTC early mapping ARM: tegra: move debug-macro.S to include/debug ARM: tegra: don't include iomap.h from debug-macro.S ARM: tegra: decouple uncompress.h and debug-macro.S ARM: tegra: simplify DEBUG_LL UART selection options ARM: tegra: select SPARSE_IRQ ARM: tegra: enhance timer.c to get IO address from device tree ARM: tegra: enhance timer.c to get IRQ info from device tree ARM: timer: fix checkpatch warnings ARM: tegra: add TWD to device tree ARM: tegra: define DT bindings for and instantiate RTC ARM: tegra: define DT bindings for and instantiate timer clocksource/mtu-nomadik: use apb_pclk clk: ux500: Register mtu apb_pclocks ARM: plat-nomadik: convert platforms to SPARSE_IRQ mfd/db8500-prcmu: use the irq_domain_add_simple() mfd/ab8500-core: use irq_domain_add_simple() ...
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-12-12Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates from Olof Johansson: "This contains the bulk of new SoC development for this merge window. Two new platforms have been added, the sunxi platforms (Allwinner A1x SoCs) by Maxime Ripard, and a generic Broadcom platform for a new series of ARMv7 platforms from them, where the hope is that we can keep the platform code generic enough to have them all share one mach directory. The new Broadcom platform is contributed by Christian Daudt. Highbank has grown support for Calxeda's next generation of hardware, ECX-2000. clps711x has seen a lot of cleanup from Alexander Shiyan, and he's also taken on maintainership of the platform. Beyond this there has been a bunch of work from a number of people on converting more platforms to IRQ domains, pinctrl conversion, cleanup and general feature enablement across most of the active platforms." Fix up trivial conflicts as per Olof. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits) mfd: vexpress-sysreg: Remove LEDs code irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids irq: versatile: delete dangling variable ARM: sunxi: add missing include for mdelay() ARM: EXYNOS: Avoid early use of of_machine_is_compatible() ARM: dts: add node for PL330 MDMA1 controller for exynos4 ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412 ARM: EXYNOS: add UART3 to DEBUG_LL ports ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers ARM: sunxi: Add missing sun4i.dtsi file pinctrl: samsung: Do not initialise statics to 0 ARM i.MX6: remove gate_mask from pllv3 ARM i.MX6: Fix ethernet PLL clocks ARM i.MX6: rename PLLs according to datasheet ARM i.MX6: Add pwm support ARM i.MX51: Add pwm support ARM i.MX53: Add pwm support ARM: mx5: Replace clk_register_clkdev with clock DT lookup ...
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-11Merge tag 'pinctrl-for-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl changes from Linus Walleij: "These are the first and major pinctrl changes for the v3.8 merge cycle. Some of this is used as merge base for other trees so I better be early on the trigger. As can be seen from the diffstat the major changes are: - A big conversion of the AT91 pinctrl driver and the associated ACKed platform changes under arch/arm/max-at91 and its device trees. This has been coordinated with the AT91 maintainers to go in through the pinctrl tree. - A larger chunk of changes to the SPEAr drivers and the addition of the "plgpio" driver for the SPEAr as well. - The removal of the remnants of the Nomadik driver from the arch/arm tree and fusion of that into the Nomadik driver and platform data header files. - Some local movement in the Marvell MVEBU drivers, these now have their own subdirectory. - The addition of a chunk of code to gpiolib under drivers/gpio to register gpio-to-pin range mappings from the GPIO side of things. This has been requested by Grant Likely and is now implemented, it is particularly useful for device tree work. Then we have incremental updates all over the place, many of these are cleanups and fixes from Axel Lin who has done a great job of removing minor mistakes and compilation annoyances." * tag 'pinctrl-for-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (114 commits) ARM: mmp: select PINCTRL for ARCH_MMP pinctrl: Drop selecting PINCONF for MMP2, PXA168 and PXA910 pinctrl: pinctrl-single: Fix error check condition pinctrl: SPEAr: Update error check for unsigned variables gpiolib: Fix use after free in gpiochip_add_pin_range gpiolib: rename pin range arguments pinctrl: single: support gpio request and free pinctrl: generic: add input schmitt disable parameter pinctrl/u300/coh901: stop spawning pinctrl from GPIO pinctrl/u300/coh901: let the gpio_chip register the range pinctrl: add function to retrieve range from pin gpiolib: return any error code from range creation pinctrl: make range registration defer properly gpiolib: rename find_pinctrl_* gpiolib: let gpiochip_add_pin_range() specify offset ARM: at91: pm9g45: add mmc support ARM: at91: Animeo IP: add mmc support ARM: at91: dt: add mmc pinctrl for Atmel reference boards ARM: at91: dt: at91sam9: add mmc pinctrl support ARM: at91/dts: add nodes for atmel hsmci controllers for atmel boards ...
2012-12-02pinctrl: Drop selecting PINCONF for MMP2, PXA168 and PXA910Axel Lin
These drivers do not need to select PINCONF. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-30Merge branch 'next/pinctrl-samsung-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc From Kukjin Kim: * 'next/pinctrl-samsung-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: pinctrl: samsung: Do not initialise statics to 0 Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-28pinctrl: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Viresh Kumar <viresh.linux@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pinctrl: remove use of __devinitconstBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitconst is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Barry Song <baohua.song@csr.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pinctrl: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pinctrl: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26Merge tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux ↵Olof Johansson
into next/dt From Jason Cooper: orion dt for v3.8 - ehci-orion dt binding - gpio-poweroff - use dt regulators - move mpp to DT/pinctrl Depends on: - orion/boards - merge conflicts - keep all 'select's in Kconfig - remove all #includes in board-*.c - pinctrl/devel up to: - 06763c7 pinctrl: mvebu: move to its own directory * tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux: (211 commits) ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ARM: Kirkwood: Convert dnskw to pinctrl ARM: Kirkwood: Convert iConnect to pinctrl. ARM: Kirkwood: Convert TS219 to pinctrl. ARM: Kirkwood: Add DTSI files for pinctrl ARM: Kirkwood: Make use of mvebu pincltl and gpio drivers ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-26Merge branch 'next/soc-exynos5440' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc From Kukjin Kim: This is adding support for exynos5440, including Quad ARM Cortex-A15 cores and its reference board SSDK5440. Note, at this moment, just enabled minimal system part for initial kernel boot and pinctrl driver. * 'next/soc-exynos5440' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: dts: Add pin controller node for Samsung EXYNOS5440 SoC pinctrl: exynos5440: add pinctrl driver for Samsung EXYNOS5440 SoC ARM: dts: add initial dts file for EXYNOS5440, SSDK5440 ARM: EXYNOS: add support for EXYNOS5440 SoC Add/add conflict in arch/arm/boot/dts/Makefile. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-24ARM: Kirkwood: support 98DX412x kirkwoods with pinctrlValentin Longchamp
The Marvell 98DX412x SoC embed a kirkwood variant that does not have pinctrl support yet. Even though this kirkwood is very similar to the 88f6281, on the MPP front a lot of pins are not available. That's why a new kirkwood pinctrl variant is needed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-24pinctrl: mvebu: Fix dove_audio1_ctrl_set functionAxel Lin
When setting audio1 pinmux the bits in the corresponding registers are not cleared. This fix first clears all bits and then sets the required bits according to the selected function. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-24pinctrl: mvebu: fix iomem pointer for dove pinctrlSebastian Hesselbarth
There has been a change in readl/writel to require registers addresses marked as IOMEM(). This patch takes care of this and also replaces ORing address offsets with adding them. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-24pinctrl: samsung: Do not initialise statics to 0Sachin Kamat
Static variables are initialised to 0 by GCC. Fixes the following checkpatch error: ERROR: do not initialise statics to 0 or NULL FILE: pinctrl/pinctrl-samsung.c:50: static unsigned int pin_base = 0; Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-11-23pinctrl: pinctrl-single: Fix error check conditionSachin Kamat
*map should be tested for NULL instead of map. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-23pinctrl: SPEAr: Update error check for unsigned variablesTushar Behera
Checking '< 0' for unsigned variables always returns false. For error codes, use IS_ERR_VALUE() instead. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-22pinctrl: exynos5440: add pinctrl driver for Samsung EXYNOS5440 SoCThomas Abraham
Add a new pinctrl driver for Samsung EXYNOS5440 SoC. The pin controller module in EXYNOS5440 is different from the pin controller found on other Samsung SoC. Hence, the pin controller driver for EXYNOS5440 SoC is independent of the Samsung pinctrl framework. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-11-21Merge branch 'next/dt-samsung' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt From Kukjin Kim: Here is Samsung DT for v3.8 and this is including DT for EXYNOS4X12 SoC, SMDK4412 board, pinctrl for exynos4x12, TMU, MFC, SATA and SATA PHY. As I commented on [4/7], this branch merged pinctrl/samsung to support pinctrl for exynos4x12 without useless merge conflicts. * 'next/dt-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (32 commits) ARM: EXYNOS: DT Support for SATA and SATA PHY ARM: dts: Remove broken-voltage property from sdhci node for exynos4210-trats ARM: dts: Add node for touchscreen for exynos4210-trats ARM: dts: Add node for touchscreen voltage regulator for exynos4210-trats ARM: dts: Add node for i2c3 bus for exynos4210-trats ARM: dts: Add nodes for GPIO keys available on Trats ARM: dts: Update for pinctrl-samsung driver for exynos4210-trats ARM: dts: Add nodes for pin controllers for exynos4x12 pinctrl: samsung: Add support for EXYNOS4X12 gpio: samsung: Skip registration if pinctrl driver is present on EXYNOS4X12 ARM: EXYNOS: Skip wakeup-int setup if pinctrl driver is used on EXYNOS4X12 ARM: dts: add board dts file for EXYNOS4412 based SMDK board ARM: dts: Add support for EXYNOS4X12 SoCs ARM: EXYNOS: Add devicetree node for TMU driver for exynos5 ARM: EXYNOS: Add devicetree node for TMU driver for exynos4 ARM: EXYNOS: Add MFC device tree support ARM: dts: Enable serial controllers on Origen and SMDKV310 Documentation: Update samsung-pinctrl device tree bindings documentation pinctrl: samsung: Add GPIO to IRQ translation pinctrl: exynos: Set pin function to EINT in irq_set_type of wake-up EINT ... Add/add conflicts in: arch/arm/boot/dts/exynos5250-smdk5250.dts arch/arm/boot/dts/exynos5250.dtsi arch/arm/mach-exynos/mach-exynos5-dt.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21Merge branch 'samsung/pinctrl' into next/socOlof Johansson
From Kukjin Kim: Here is Samsung DT for v3.8 and this is including DT for EXYNOS4X12 SoC, SMDK4412 board, pinctrl for exynos4x12, TMU, MFC, SATA and SATA PHY. As I commented on [4/7], this branch merged pinctrl/samsung to support pinctrl for exynos4x12 without useless merge conflicts. * samsung/pinctrl: pinctrl: samsung: Update error check for unsigned variables pinctrl: samsung: Add support for EXYNOS4X12 Documentation: Update samsung-pinctrl device tree bindings documentation pinctrl: samsung: Add GPIO to IRQ translation pinctrl: exynos: Set pin function to EINT in irq_set_type of wake-up EINT pinctrl: samsung: Use per-bank IRQ domain for wake-up interrupts pinctrl: samsung: Use one GPIO chip per pin bank pinctrl: exynos: Use one IRQ domain per pin bank pinctrl: samsung: Include bank-specific eint offset in bank struct pinctrl: samsung: Hold pointer to driver data in bank struct pinctrl: samsung: Match pin banks with their device nodes ARM: dts: exynos4210-pinctrl: Add nodes for pin banks pinctrl: samsung: Distinguish between pin group and bank nodes pinctrl: samsung: Remove static pin enumerations pinctrl: samsung: Assing pin numbers dynamically pinctrl: samsung: Do not pass gpio_chip to pin_to_reg_bank pinctrl: samsung: Detect and handle unsupported configuration types
2012-11-21Merge branch 'at91' into develLinus Walleij
2012-11-21pinctrl: single: support gpio request and freeHaojian Zhuang
Marvell's PXA/MMP silicon also match the behavior of pinctrl-single. Each pin binds to one register. A lot of pins could be configured as gpio. GPIO range is defined as a child node of pinmux in .dtsi file. If those pins are with the same gpio function configuration in the pinmux register, they could be defined in the same GPIO range. For this new child node, two properties are used. reg = <the start of pinmux register in range, size of range> pinctrl-single,gpio: <gpio base in range, the gpio function of the range in the pinmux register> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21pinctrl: generic: add input schmitt disable parameterHaojian Zhuang
In Marvell PXA/MMP silicons, input schmitt disable value is 0x40, not 0. So append new config parameter -- input schmitt disable. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21pinctrl/u300/coh901: stop spawning pinctrl from GPIOLinus Walleij
Let's stop spawning the pinctrl driver from the GPIO driver, we have these two mechanisms broken apart now, and they can each probe in isolation. If the GPIO driver cannot find its pin controller (pinctrl-u300), the pin controller core will tell it to defer probing. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21pinctrl/u300/coh901: let the gpio_chip register the rangeLinus Walleij
Instead of having the pinctrl driver register the GPIO range for the gpio_chip, making it necessary to instantiate the pin controller from the GPIO driver and pass the GPIO chip as platform data, now let the GPIO chip driver register it's own ranges and have the pinctrl driver look up the GPIO chip from the pinctrl core as necessary. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21pinctrl: add function to retrieve range from pinLinus Walleij
This adds a function to the pinctrl core to retrieve the GPIO range associated with a certain pin for a certain controller. This is needed when a pinctrl driver want to look up the corresponding struct gpio_chip for a certain pin. As the GPIO drivers can now create these ranges themselves, the pinctrl driver no longer knows about all its associated GPIO chips. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21pinctrl: make range registration defer properlyLinus Walleij
This makes the pinctrl_find_and_add_gpio_range() return -EPROBE_DEFER if the range hosting pin controller cannot be located. We may assume that the common case for why adding a range fails is that the targe pin controller device has not probed yet. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21gpiolib: rename find_pinctrl_*Linus Walleij
Rename the function find_pinctrl_and_add_gpio_range() to pinctrl_find_and_add_gpio_range() so as to be consistent with the rest of the functions. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21Merge branch 'delivery/pinctrl-at91-3.8' of ↵Linus Walleij
http://github.com/at91linux/linux-at91 into at91
2012-11-19pinctrl: samsung: Update error check for unsigned variablesTushar Behera
Checking '< 0' for unsigned variables always returns false. For error codes, use IS_ERR_VALUE() instead. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-11-19pinctrl: samsung: Add support for EXYNOS4X12Tomasz Figa
This patch extends the driver with any necessary SoC-specific definitions to support EXYNOS4X12 SoCs. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-11-19Merge remote-tracking branch 'pinctrl/samsung' into next/pinctrl-samsungKukjin Kim
2012-11-19pinctrl: at91 add deglitch, debounce, pull down and schmitt trigger mux ↵Jean-Christophe PLAGNIOL-VILLARD
option support add : set_deglitch: enable/disable deglitch set_debounce: enable/disable debounce set_pulldown: enable/disable pulldown disable_schmitt_trig: disable schmitt trigger Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-11-19pinctrl: at91: provide gpio namesJean-Christophe PLAGNIOL-VILLARD
2012-11-15pinctrl: nomadik: Staticize non-exported symbolsAxel Lin
They are not referenced outside of this file, make them static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-15pinctrl: nomadik: Prevent NULL dereference if of_match_device returns NULLAxel Lin
of_match_device() may return NULL. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-15pinctrl: single: dump pinmux register valueHaojian Zhuang
Dump pinmux register value, not only function part in the pinmux register. Also fix the issue on caluclating pin offset. The last parameter should be pin number, not register offset. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
