git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
"Here are some overly ripe pin control fixes for the v4.2 series.
They got delayed because of various crap commits and having to clean
and rinse the patch stack a few times. Now they are however looking
good.
- some dead defines dropped from the Samsung driver, was targeted for
-rc2 but got delayed
- drop the strict mode from abx500, this was too strict
- fix the R-Car sparse IRQs code to work as intended
- fix the IRQ code for the pinctrl-single GPIO backend to not enforce
threaded IRQs
- clear the latched events/IRQs for the Broadcom BCM2835 driver
- fix up debugfs for the Freescale imx1 driver
- fix a typo bug in the Schmitt Trigger setup in the LPC18xx driver"
* tag 'pinctrl-v4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: lpc18xx: fix schmitt trigger setup
Subject: pinctrl: imx1-core: Fix debug output in .pin_config_set callback
pinctrl: bcm2835: Clear the event latch register when disabling interrupts
pinctrl: single: ensure pcs irq will not be forced threaded
sh-pfc: fix sparse GPIOs for R-Car SoCs
pinctrl: abx500: remove strict mode
pinctrl: samsung: Remove old unused defines
The param_val variable is what determines if schmitt
trigger is enabled on a pin or not. A typo here mean
that schmitt trigger was always enabled for standard
and i2c pins.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
imx1_pinconf_set assumes that the array of pins in struct
imx1_pinctrl_soc_info can be indexed by pin id to get the
pinctrl_pin_desc for a pin. This used to be correct up to commit
607af165c047 which removed some entries from the array and so made it
wrong to access the array by pin id.
The result of this bug is a wrong pin name in the output for small pin
ids and an oops for the bigger ones.
This patch is the result of a discussion that includes patches by Markus
Pargmann and Chris Ruehl.
Fixes: 607af165c047 ("pinctrl: i.MX27: Remove nonexistent pad definitions")
Cc: stable@vger.kernel.org
Reported-by: Chris Ruehl <chris.ruehl@gtsys.com.hk>
Reviewed-by: Markus Pargmann <mpa@pengutronix.de>
It's possible to hit a race condition if interrupts are generated on a GPIO
pin when the IRQ line in question is being disabled.
If the interrupt is freed, bcm2835_gpio_irq_disable() is called which
disables the event generation sources (edge, level). If an event occurred
between the last disabling of hard IRQs and the write to the event
source registers, a bit would be set in the GPIO event detect register
(GPEDSn) which goes unacknowledged by bcm2835_gpio_irq_handler()
so Linux complains loudly.
There is no per-GPIO mask register, so when disabling GPIO interrupts
write 1 to the relevant bit in GPEDSn to clear out any stale events.
Signed-off-by: Jonathan Bell <jonathan@raspberrypi.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The PSC IRQ is requested using request_irq() API and as result it can
be forced to be threaded IRQ in RT-Kernel if PCS_QUIRK_HAS_SHARED_IRQ
is enabled for pinctrl domain.
As result, following 'possible irq lock inversion dependency' report
can be seen:
[ INFO: possible irq lock inversion dependency detected ]
3.14.43-rt42-00360-g96ff499-dirty #24 Not tainted
irq/369-pinctrl/927 just changed the state of lock:
(&pcs->lock){+.....}, at: [<c0375b54>] pcs_irq_handle+0x48/0x9c
but this lock was taken by another, HARDIRQ-safe lock in the past:
(&irq_desc_lock_class){-.....}
and interrupts could create inverse lock ordering between them.
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&pcs->lock);
local_irq_disable();
lock(&irq_desc_lock_class);
lock(&pcs->lock);
<Interrupt>
*** DEADLOCK ***
no locks held by irq/369-pinctrl/927.
the shortest dependencies between 2nd lock and 1st lock:
-> (&irq_desc_lock_class){-.....} ops: 58724 {
IN-HARDIRQ-W at:
[<c0090040>] lock_acquire+0x9c/0x158
[<c07065c8>] _raw_spin_lock+0x48/0x58
[<c009edac>] handle_fasteoi_irq+0x24/0x15c
[<c009abb0>] generic_handle_irq+0x3c/0x4c
[<c000f83c>] handle_IRQ+0x50/0xa0
[<c0008674>] gic_handle_irq+0x3c/0x6c
[<c0707a04>] __irq_svc+0x44/0x8c
[<c000fc44>] arch_cpu_idle+0x40/0x4c
[<c009aadc>] cpu_startup_entry+0x270/0x2e0
[<c06fcbf8>] rest_init+0xd4/0xe4
[<c0a44bfc>] start_kernel+0x3d0/0x3dc
[<80008084>] 0x80008084
INITIAL USE at:
[<c070674c>] _raw_spin_lock_irqsave+0x54/0x68
[<c009aff8>] __irq_get_desc_lock+0x64/0xa4
[<c009e38c>] irq_set_chip+0x30/0x78
[<c009ec30>] irq_set_chip_and_handler_name+0x24/0x3c
[<c036ca10>] gic_irq_domain_map+0x48/0xb4
[<c00a0a80>] irq_domain_associate+0x84/0x1d4
[<c00a1154>] irq_create_mapping+0x80/0x11c
[<c00a1270>] irq_create_of_mapping+0x80/0x120
[<c05cdaa8>] irq_of_parse_and_map+0x34/0x3c
[<c0a4ea24>] omap_dm_timer_init_one+0x90/0x30c
[<c0a4eef0>] omap5_realtime_timer_init+0x8c/0x48c
[<c0a486b0>] time_init+0x28/0x38
[<c0a44a6c>] start_kernel+0x240/0x3dc
... key at: [<c1049ce0>] irq_desc_lock_class+0x0/0x8
... acquired at:
[<c0375a90>] pcs_irq_unmask+0x58/0xa0
[<c009ea48>] irq_enable+0x38/0x48
[<c009ead0>] irq_startup+0x78/0x7c
[<c009d440>] __setup_irq+0x4a8/0x4f4
[<c009d5dc>] request_threaded_irq+0xb8/0x138
[<c0415a5c>] omap_8250_startup+0x4c/0x148
[<c041276c>] serial8250_startup+0x24/0x30
[<c040d0ec>] uart_startup.part.9+0x5c/0x1b4
[<c040dbcc>] uart_open+0xf4/0x16c
[<c03f0540>] tty_open+0x170/0x61c
[<c0157028>] chrdev_open+0xbc/0x1b4
[<c0150494>] do_dentry_open+0x1e8/0x2bc
[<c0150a84>] finish_open+0x44/0x5c
[<c0160d50>] do_last.isra.47+0x710/0xca0
[<c01613a4>] path_openat+0xc4/0x640
[<c0162904>] do_filp_open+0x3c/0x98
[<c0151bdc>] do_sys_open+0x114/0x1d8
[<c0151cc8>] SyS_open+0x28/0x2c
[<c0a44d70>] kernel_init_freeable+0x168/0x1e4
[<c06fcc24>] kernel_init+0x1c/0xf8
[<c000eee8>] ret_from_fork+0x14/0x20
-> (&pcs->lock){+.....} ops: 65 {
HARDIRQ-ON-W at:
[<c0375c5c>] pcs_irq_handler+0x1c/0x28
[<c009c458>] irq_forced_thread_fn+0x30/0x74
[<c009c784>] irq_thread+0x158/0x1c4
[<c0063fc4>] kthread+0xd4/0xe8
INITIAL USE at:
[<c0375344>] pcs_enable+0x7c/0xe8
[<c0372a44>] pinmux_enable_setting+0x178/0x220
[<c036fecc>] pinctrl_select_state+0x110/0x194
[<c04732dc>] pinctrl_bind_pins+0x7c/0x108
[<c045853c>] driver_probe_device+0x70/0x254
[<c0458810>] __driver_attach+0x9c/0xa0
[<c045674c>] bus_for_each_dev+0x78/0xac
[<c0458030>] driver_attach+0x2c/0x30
[<c0457c78>] bus_add_driver+0x15c/0x204
[<c0458ee0>] driver_register+0x88/0x108
[<c045a168>] __platform_driver_register+0x64/0x6c
[<c0a8170c>] omap_hsmmc_driver_init+0x1c/0x20
[<c0008a94>] do_one_initcall+0x110/0x170
[<c0a44d48>] kernel_init_freeable+0x140/0x1e4
... key at: [<c1088a8c>] __key.18572+0x0/0x8
... acquired at:
[<c008cdd4>] mark_lock+0x388/0x76c
[<c008df40>] __lock_acquire+0x6d0/0x1f98
stack backtrace:
CPU: 1 PID: 927 Comm: irq/369-pinctrl Not tainted 3.14.43-rt42-00360-g96ff499-dirty #24
[<c00177e0>] (unwind_backtrace) from [<c00130b0>] (show_stack+0x20/0x24)
[<c00130b0>] (show_stack) from [<c0702958>] (dump_stack+0x84/0xd0)
[<c0702958>] (dump_stack) from [<c008bcfc>] (print_irq_inversion_bug+0x1d0/0x21c)
[<c008bcfc>] (print_irq_inversion_bug) from [<c008bf18>] (check_usage_backwards+0xb4/0x11c)
[<c008bf18>] (check_usage_backwards) from [<c008cdd4>] (mark_lock+0x388/0x76c)
[<c008cdd4>] (mark_lock) from [<c008df40>] (__lock_acquire+0x6d0/0x1f98)
[<c008df40>] (__lock_acquire) from [<c0090040>] (lock_acquire+0x9c/0x158)
[<c0090040>] (lock_acquire) from [<c07065c8>] (_raw_spin_lock+0x48/0x58)
[<c07065c8>] (_raw_spin_lock) from [<c0375b54>] (pcs_irq_handle+0x48/0x9c)
[<c0375b54>] (pcs_irq_handle) from [<c0375c5c>] (pcs_irq_handler+0x1c/0x28)
[<c0375c5c>] (pcs_irq_handler) from [<c009c458>] (irq_forced_thread_fn+0x30/0x74)
[<c009c458>] (irq_forced_thread_fn) from [<c009c784>] (irq_thread+0x158/0x1c4)
[<c009c784>] (irq_thread) from [<c0063fc4>] (kthread+0xd4/0xe8)
[<c0063fc4>] (kthread) from [<c000eee8>] (ret_from_fork+0x14/0x20)
To fix it use IRQF_NO_THREAD to ensure that pcs irq will not be forced threaded.
Cc: Tony Lindgren <tony@atomide.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
The PFC driver causes the kernel to hang on the R-Car gen2 SoC based boards
when the CPU_ALL_PORT() macro is fixed to reflect the reality, i.e. when the
GPIO space becomes actually sparse. This happens because the _GP_GPIO() macro
includes an indexed initializer which causes the "holes" (array entries filled
with all 0s) between the groups of the existing GPIOs; and the driver can't
cope with that. There seems to be no reason to use the indexed initializer,
so we can remove the index specifier and so avoid the "holes".
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Commit a21763a0b1e5a5ab8310f581886d04beadc16616
"pinctrl: nomadik: activate strict mux mode"
put all Nomadik pin controllers to strict mode. This was
not good on the Snowball platform: the muxing of GPIOs to
different pins is done with hogs in the DTS file, and then
these GPIOs are used by offset, relying on hogs to mux the
pins. Since that means the pin controller "owns" the pins
and at the same time we have a GPIO user, this pin controller
is by definition not strict.
Switch to my kernel.org alias instead of a badly named gmail address,
which I rarely use.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Since 9a2c1c3b91aa ("pinctrl: samsung: Allow grouping multiple
pinmux/pinconf nodes") the defines for GPIO group and function names are
not used anywhere in the driver.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Inspired-by: Dan Carpenter <dan.carpenter@oracle.com>
Pull irq fixes from Thomas Gleixner:
"This contains:
- a series of fixes for interrupt drivers to prevent a potential race
when installing a chained interrupt handler
- a fix for cpumask pointer misuse
- a fix for using the wrong interrupt number from struct irq_data
- removal of unused code and outdated comments
- a few new helper functions which allow us to cleanup the interrupt
handling code further in 4.3
I decided against doing the cleanup at the end of this merge window
and rather do the preparatory steps for 4.3, so we can run the final
ABI change at the end of the 4.3 merge window with less risk"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked()
genirq: Implement irq_set_handler_locked()/irq_set_chip_handler_name_locked()
genirq: Introduce helper irq_desc_get_irq()
genirq: Remove irq_node()
genirq: Clean up outdated comments related to include/linux/irqdesc.h
mn10300: Fix incorrect use of irq_data->affinity
MIPS/ralink: Fix race in installing chained IRQ handler
MIPS/pci: Fix race in installing chained IRQ handler
MIPS/ath25: Fix race in installing chained IRQ handler
m68k/psc: Fix race in installing chained IRQ handler
avr32/at32ap: Fix race in installing chained IRQ handler
sh/intc: Fix race in installing chained IRQ handler
sh/intc: Fix potential race in installing chained IRQ handler
pinctrl/sun4i: Fix race in installing chained IRQ handler
pinctrl/samsung: Fix race in installing chained IRQ handler
pinctrl/exynos: Fix race in installing chained IRQ handler
pinctrl/st: Fix race in installing chained IRQ handler
pinctrl/adi2: Fix race in installing chained IRQ handler
Pull ARM SoC driver updates from Kevin Hilman:
"Some of these are for drivers/soc, where we're now putting
SoC-specific drivers these days. Some are for other driver subsystems
where we have received acks from the appropriate maintainers.
Some highlights:
- simple-mfd: document DT bindings and misc updates
- migrate mach-berlin to simple-mfd for clock, pinctrl and reset
- memory: support for Tegra132 SoC
- memory: introduce tegra EMC driver for scaling memory frequency
- misc. updates for ARM CCI and CCN busses"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
drivers: soc: sunxi: Introduce SoC driver to map SRAMs
arm-cci: Add aliases for PMU events
arm-cci: Add CCI-500 PMU support
arm-cci: Sanitise CCI400 PMU driver specific code
arm-cci: Abstract handling for CCI events
arm-cci: Abstract out the PMU counter details
arm-cci: Cleanup PMU driver code
arm-cci: Do not enable CCI-400 PMU by default
firmware: qcom: scm: Add HDCP Support
ARM: berlin: add an ADC node for the BG2Q
ARM: berlin: remove useless chip and system ctrl compatibles
clk: berlin: drop direct of_iomap of nodes reg property
ARM: berlin: move BG2Q clock node
ARM: berlin: move BG2CD clock node
ARM: berlin: move BG2 clock node
clk: berlin: prepare simple-mfd conversion
pinctrl: berlin: drop SoC stub provided regmap
ARM: berlin: move pinctrl to simple-mfd nodes
pinctrl: berlin: prepare to use regmap provided by syscon
reset: berlin: drop arch_initcall initialization
Fix a race where a pending interrupt could be received and the handler
called before the handler's data has been setup, by converting to
irq_set_chained_handler_and_data().
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_chained_handler(E1, E3) != 0)
- BUG();
-irq_set_chained_handler(E1, E3);
-irq_set_handler_data(E1, E2);
+irq_set_chained_handler_and_data(E1, E3, E2);
- BUG();
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Fan Wu <fwu@marvell.com>
Cc: abdoulaye berthe <berthe.ab@gmail.com>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: linux-gpio@vger.kernel.org
- BUG();
- BUG();
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Cc: linux-samsung-soc@vger.kernel.org
- BUG();
- BUG();
- BUG();
- BUG();
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
- BUG();
- BUG();
Cc: Srinivas Kandagatla <srinivas.kandagatla@gmail.com>
Cc: Maxime Coquelin <maxime.coquelin@st.com>
Cc: Patrice Chotard <patrice.chotard@st.com>
Cc: kernel@stlinux.com
- BUG();
- BUG();
- BUG();
- BUG();
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Hongzhou Yang <hongzhou.yang@mediatek.com>
Cc: Axel Lin <axel.lin@ingics.com>
Cc: Yingjoe Chen <yingjoe.chen@mediatek.com>
Cc: Maoguang Meng <maoguang.meng@mediatek.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: linux-mediatek@lists.infradead.org
Pull pin control updates from Linus Walleij:
"Here is the bulk of pin control changes for the v4.2 series: Quite a
lot of new SoC subdrivers and two new main drivers this time, apart
from that business as usual.
Details:
Core functionality:
- Enable exclusive pin ownership: it is possible to flag a pin
controller so that GPIO and other functions cannot use a single pin
simultaneously.
New drivers:
- NXP LPC18xx System Control Unit pin controller
- Imagination Pistachio SoC pin controller
New subdrivers:
- Freescale i.MX7d SoC
- Intel Sunrisepoint-H PCH
- Renesas PFC R8A7793
- Renesas PFC R8A7794
- Mediatek MT6397, MT8127
- SiRF Atlas 7
- Allwinner A33
- Qualcomm MSM8660
- Marvell Armada 395
- Rockchip RK3368
Cleanups:
- A big cleanup of the Marvell MVEBU driver rectifying it to
correspond to reality
- Drop platform device probing from the SH PFC driver, we are now a
DT only shop for SuperH
- Drop obsolte multi-platform check for SH PFC
- Various janitorial: constification, grammar etc
Improvements:
- The AT91 GPIO portions now supports the set_multiple() feature
- Split out SPI pins on the Xilinx Zynq
- Support DTs without specific function nodes in the i.MX driver"
* tag 'pinctrl-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (99 commits)
pinctrl: rockchip: add support for the rk3368
pinctrl: rockchip: generalize perpin driver-strength setting
pinctrl: sh-pfc: r8a7794: add SDHI pin groups
pinctrl: sh-pfc: r8a7794: add MMCIF pin groups
pinctrl: sh-pfc: add R8A7794 PFC support
pinctrl: make pinctrl_register() return proper error code
pinctrl: mvebu: armada-39x: add support for Armada 395 variant
pinctrl: mvebu: armada-39x: add missing SATA functions
pinctrl: mvebu: armada-39x: add missing PCIe functions
pinctrl: mvebu: armada-38x: add ptp functions
pinctrl: mvebu: armada-38x: add ua1 functions
pinctrl: mvebu: armada-38x: add nand functions
pinctrl: mvebu: armada-38x: add sata functions
pinctrl: mvebu: armada-xp: add dram functions
pinctrl: mvebu: armada-xp: add nand rb function
pinctrl: mvebu: armada-xp: add spi1 function
pinctrl: mvebu: armada-39x: normalize ref clock naming
pinctrl: mvebu: armada-xp: rename spi to spi0
pinctrl: mvebu: armada-370: align spi1 clock pin naming
pinctrl: mvebu: armada-370: align VDD cpu-pd pin naming with datasheet
The rk3368 is the first ARM64 soc from Rockchip, but seems to share most
peripherals with the ARM32 soc, including the pinctrl functionality.
The only notable difference is - as with every Rockchip soc - that the
offsets in the General Register Files moved around and a split of the pmu
section of the rk3288 into pmu and pmugrf (pmu general register files)
sections. The pinctrl driver of course only needs the pmugrf registers
for controlling the pin settings.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The upcoming support for the RK3368 ARM64 SoC also supports perpin
drive strength settings (at different register positions), so generalize
the register and offset calculation to easily support this one too.
Add SDHI0/1/2 pin groups to R8A7794 PFC driver.
Signed-off-by: Shinobu Uehara <shinobu.uehara.xc@renesas.com>
[Sergei: renamed SD data pins to match the driver, rebased, renamed, added
changelog.]
Add MMCIF pin groups to R8A7794 PFC driver.
[Sergei: rebased, renamed, added changelog.]
Add PFC support for the R8A7794 SoC including pin groups for some
on-chip devices such as ETH, I2C, INTC, MSIOF, QSPI, [H]SCIF...
Sergei: squashed together several patches, fixed the MLB_CLK typo,
added IRQ4.. IRQ9 pin groups, fixed IRQn comments, added ETH B pin
group names, removed stray new line and fixed typos in the comments
in the pinmux_config_regs[] initializer, removed the platform device
ID, took into account limited number of signals in the GPIO1/5/6
controllers, added reasonable and removed unreasonable
copyrights, modified the bindings document, renamed, added changelog.
Changes in version 5:
- resolved rejects, refreshed the patch;
- added Laurent Pinchart's ACK.
Changes in version 4:
- reused the PORT_GP_26() macro to #define PORT_GP_28().
Changes in version 3:
- removed the platform device ID;
- added PORT_GP_26() and PORT_GP_28() macros, used them for GPIO1/5/6 in the
CPU_ALL_PORT() macro.
Changes in version 2:
- rebased the patch.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
Currently, pinctrl_register() just returns NULL on error, so the
callers can not know the exact reason of the failure.
Some of the pinctrl drivers return -EINVAL, some -ENODEV, and some
-ENOMEM on error of pinctrl_register(), although the error code
might be different from the real cause of the error.
This commit reworks pinctrl_register() to return the appropriate
error code and modifies all of the pinctrl drivers to use IS_ERR()
for the error checking and PTR_ERR() for getting the error code.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Lee Jones <lee@kernel.org>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Ray Jui <rjui@broadcom.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
Acked-by: Wei Chen <Wei.Chen@csr.com>
The Armada 39x SoC family has grown a new variant, the Armada 395,
which sits between the Armada 390 and Armada 398 in terms of
features. This commit adds support for this additional variant to the
Armada 39x pinctrl driver.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The latest version of the Armada 39x datasheet documents several new
SATA related functions on various MPP pins. This commit adds the
description of these new functions to the Armada 39x pinctrl driver as
well as to its DT binding documentation.
PCIe related functions on various MPP pins. This commit adds the
The latest version of the Armada 38x datasheet documents several new
PTP related functions on various MPP pins. This commit adds the
description of these new functions to the Armada 38x pinctrl driver as
UART1 related functions on various MPP pins. This commit adds the
NAND related functions on various MPP pins. This commit adds the
The latest Armada XP datasheet documents several new DRAM related
functions on various MPPs. This commit adds the description of these
new functions in the Armada XP pinctrl driver and its DT binding
documentation.
The latest version of the Armada XP datasheet documents a new
NAND-related MPP function on MPP48, for which this commit adds
support.
The latest Armada XP datasheet documents that some of the MPP pins can
be used to access the second SPI bus, labelled 'spi1'. This commit
adds the corresponding pins in the pinctrl driver and its DT binding
documentation.
This commit normalizes the subnames of the reference clock MPP pins in
the Armada 39x pinctrl driver to match with the name used on other
SoCs.
Since only the subnames are changed, DT backward compatibility is not
affected.
After updating to the latest Armada XP datasheet, we discovered that
there is a second SPI bus accessible from the MPP pins, called 'spi1'.
In order to be consistent with other SoCs having two SPI busses, this
commit renames the functions of the first SPI bus to 'spi0' instead of
just 'spi'.
This commit obviously breaks the DT backward compatibility for the
people using the "spi" function name in their Device Tree.
Across all SoCs, even on Armada 370 for SPI0, the clock pin uses the
'sck' subname and not 'clk', so this commit adjusts the code and
documentation accordingly.
Since this commit only changes the subname, DT backward compatibility
is not affected.
For consistency with the datasheet, this commit renames the VDD
function of the MPP4 pin.
While this changes the DT compatibility, it is not considered to be a
problem since this pin is unlikely to be used for anything but
debugging purposes.
This commit normalizes the naming of the Ethernet txclkout pin to be
the same accross Marvell SoCs. It is worth mentioning that the DT
binding documentation of the Armada XP was wrong for MPP12: it said
the function was ge1(txd0), while it is in fact ge1(txclkout). It is
however not really a fix worth sending to stable since it does not
change the behavior, and the driver itself was correct.
affected.
This commit aligns the naming of the audio 'lrclk' pin accross Marvell
SoCs.
Since only the subname is changed, the DT backward compatibility is
not affected.
This commit normalizes the naming of PCIe pins to use 'rstout' instead
of 'rstoutn' or 'rst-out'.
Since only the subnames are changed, DT compatibility is not affected.
This commit normalizes the naming of the TDM pins accross the
different Marvell SoCs. Mainly it consists in:
* Removing the 'n' from signal names: 'intn' becomes 'int' and 'rstn'
becomes 'rst'
* Renaming the main name 'tdm2c' to 'tdm' on Armada 38x.
* Change the main name 'tdm-1' to 'tdm' for one of the pins of the
Armada XP
The last two changes affect DT compatibility, but since the TDM
interface is nowhere near being supported in mainline, it should not
be considered to be a serious problem at this point.
All SoCs use "nand" to designate NAND pins, only Armada 39x is using
"nd", which is not consistent. This commit fixes that by renaming the
corresponding functions.
It also changes the subnames from rbn0/rbn1 to rb0/rb1, to respect the
convention used everywhere that we don't encode the 'n' part of signal
names.
While this commit changes the main name of function, therefore
potentially breaking the DT compatibility, this is not a problem since
Armada 39x is a brand new SoC which isn't used in production yet.
This commit modifies the definition of the Device Bus interface pins
to be consistent accross SoCs. Especially, it removes the 'n'
indicators that we don't encode in the subnames of pins:
'dev(wen0)' becomes 'dev(we0)'
'dev(wen1)' becomes 'dev(we1)'
'dev(oen)' becomes 'dev(oe)'
etc.
In addition, it fixes the Armada 375 DT binding documentation, which
forgot to document the 'dev' function for MPP46, MPP57 and MPP63.
Since only the subnames are changed, this commit does not affect DT
compatibility.
In order to be consistent with the datasheet and some other SoCs, this
commit renames the SDIO pins of the Armada 39x from "sd" to "sd0".
While this changes the DT binding, this is not a problem since Armada
39x is a brand new SoC which isn't used in production yet (so now is
the right time to fix such things).
This commit makes the naming of SATA related MPP functions consistent
accross SoCs by adjusting the Armada 39x definition to use "prsnt"
instead of "present".
Since only the subnames are changed, the DT binding is not modified at
all.
This commit makes the dram functions naming (both the name and
subname) consistent accross SoC, by using:
dram(vttctrl)
dram(deccerr)
in all Marvell SoCs.
Due to the change to the name, it changes the DT binding, but these
functions are not used by any in-tree Device Tree file, and are very
unlikely to be used by anyone.
The subnames are purely informative, but it's nicer when they match
accross SoCs. This commit adjusts the Armada 375, Armada 38x and
Armada 39x MPP definitions so that the subnames of the PTP pins match
the ones used on Armada XP and Kirkwood.
The pinctrl_gpio_range[] array described a first bank of 32 GPIOs and
a second one of 27 GPIOs. However, since there is a total of 60 MPP
pins that can be muxed as GPIOs, the second bank really has 28 GPIOs.
Cc: <stable@vger.kernel.org> # v4.1+
Fixes: ee086577abe7f ("pinctrl: mvebu: add pinctrl driver for Marvell Armada 39x")
