[ Upstream commit e855fa9a65c40788b5069abb0d094537daa22e05 ]
When using GPIO as IRQ source, the GPIO must be configured
in INPUT. Callbacks dedicated for this was missing in
pinctrl-st driver.
This fix the following kernel error when trying to lock a gpio
as IRQ:
[ 7.521095] gpio gpiochip7: (PIO11): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
[ 7.526018] gpio gpiochip7: (PIO11): unable to lock HW IRQ 6 for IRQ
[ 7.529405] genirq: Failed to request resources for 0-0053 (irq 81) on irqchip GPIO
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
[ Upstream commit 1c363531dd814dc4fe10865722bf6b0f72ce4673 ]
The build robot is complaining on Blackfin:
drivers/pinctrl/pinctrl-adi2.c: In function 'port_setup':
>> drivers/pinctrl/pinctrl-adi2.c:221:21: error: dereferencing
pointer to incomplete type 'struct gpio_port_t'
writew(readw(®s->port_fer) & ~BIT(offset),
drivers/pinctrl/pinctrl-adi2.c: In function 'adi_gpio_ack_irq':
>> drivers/pinctrl/pinctrl-adi2.c:266:18: error: dereferencing
pointer to incomplete type 'struct bfin_pint_regs'
if (readl(®s->invert_set) & pintbit)
It seems the driver need to include <asm/gpio.h> and <asm/irq.h>
to compile.
The Blackfin architecture was re-defining the Kconfig
PINCTRL symbol which is not OK, so replaced this with
PINCTRL_BLACKFIN_ADI2 which selects PINCTRL and PINCTRL_ADI2
just like most arches do.
Further, the old GPIO driver symbol GPIO_ADI was possible to
select at the same time as selecting PINCTRL. This was not
working because the arch-local <asm/gpio.h> header contains
an explicit #ifndef PINCTRL clause making compilation break
if you combine them. The same is true for DEBUG_MMRS.
Make sure the ADI2 pinctrl driver is not selected at the same
time as the old GPIO implementation. (This should be converted
to use gpiolib or pincontrol and move to drivers/...) Also make
sure the old GPIO_ADI driver or DEBUG_MMRS is not selected at
the same time as the new PINCTRL implementation, and only make
PINCTRL_ADI2 selectable for the Blackfin families that actually
have it.
This way it is still possible to add e.g. I2C-based pin
control expanders on the Blackfin.
Cc: Steven Miao <realmz6@gmail.com>
Cc: Huanhuan Feng <huanhuan.feng@analog.com>
commit 3fa53ec2ed885b0aec3f0472e3b4a8a6f1cd748c upstream.
The irq chip callbacks irq_request/release_resources() have absolutely no
business with masking and unmasking the irq.
The core code unmasks the interrupt after complete setup and masks it
before invoking irq_release_resources().
The unmask is actually harmful as it happens before the interrupt is
completely initialized in __setup_irq().
Remove it.
Fixes: f6a8249f9e55 ("pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs")
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
commit d81ece747d8727bb8b1cfc9a20dbe62f09a4e35a upstream.
The PH16 pin has a function with mux id 0x5, which is the DET pin of the
"sim" (smart card reader) IP block.
This function is missing in old versions of A10/A20 SoCs' datasheets and
user manuals, so it's also missing in the old drivers. The newest A10
Datasheet V1.70 and A20 Datasheet V1.41 contain this pin function, and
it's discovered during implementing R40 pinctrl driver.
Add it to the driver. As we now merged A20 pinctrl driver to the A10
one, we need to only fix the A10 driver now.
Fixes: f2821b1ca3a2 ("pinctrl: sunxi: Move Allwinner A10 pinctrl
driver to a driver of its own")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
commit 3091ae775fae17084013021d01513bc1ad274e6a upstream.
Update the sh_pfc_soc_info pointer after calling the SoC-specific
initialization function, as it may have been updated to e.g. handle
different SoC revisions. This makes sure the correct subdriver name is
printed later.
Fixes: 0c151062f32c9db8 ("sh-pfc: Add support for SoC-specific initialization")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit da6c2addf66d7ff7d0b090d6267d4292f951e4e6 upstream.
To set the mux mode of a pin two bits must be set. Up to now this is
implemented using the following idiom:
writel(mask, reg + CLR);
writel(value, reg + SET);
. This however results in the mux mode being 0 between the two writes.
On my machine there is an IC's reset pin connected to LCD_D20. The
bootloader configures this pin as GPIO output-high (i.e. not holding the
IC in reset). When Linux reconfigures the pin to GPIO the short time
LCD_D20 is muxed as LCD_D20 instead of GPIO_1_20 is enough to confuse
the connected IC.
The same problem is present for the pin's drive strength setting which is
reset to low drive strength before using the right value.
So instead of relying on the hardware to modify the register setting
using two writes implement the bit toggling using read-modify-write.
Fixes: 17723111e64f ("pinctrl: add pinctrl-mxs support")
Acked-by: Shawn Guo <shawnguo@kernel.org>
commit 7903d4f5e1dec53963cba9b1bc472a76a3532e07 upstream.
We use well known standard names for functions that have name, such as
I2C, SPI, SPDIF, etc..
Fix the function name of SPDIF, which was named OWA (One Wire Audio)
based on Allwinner datasheets.
Fixes: 4730f33f0d82 ("pinctrl: sunxi: add allwinner A83T PIO controller
support")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 97ba26b8a9343008504d4e3a87d212bc07b05212 upstream.
The nand_groups table uses different names for the NAND DQS pins than
the GROUP() definition in meson8b_cbus_groups (nand_dqs_0 vs nand_dqs0).
This prevents using the NAND DQS pins in the devicetree.
Fix this by ensuring that the GROUP() definition and the
meson8b_cbus_groups use the same name for these pins.
Fixes: 0fefcb6876d0 ("pinctrl: Add support for Meson8b")
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Acked-by: Kevin Hilman <khilman@baylibre.com>
commit 58439280f84e6b39fd7d61f25ab30489c1aaf0a9 upstream.
PINMUX_IPSR_MSEL() macro invocation for the TX2 signal has apparently wrong
1st argument -- most probably a result of cut&paste programming...
Fixes: 508845196238 ("pinctrl: sh-pfc: r8a7791 PFC support")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit e82d02580af45663fad6d3596e4344c606e81e10 ]
This should be a typo.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
commit a6566710adaa4a7dd5e0d99820ff9c9c30ee5951 upstream.
Clearing the status bit on irq_unmask will discard any pending interrupt
that did arrive after the irq_ack, i.e. while the IRQ handler function
was executing.
Fixes: f365be092572 ("pinctrl: Add Qualcomm TLMM driver")
Cc: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Timur Tabi <timur@codeaurora.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
commit bcb48cca23ec9852739e4a464307fa29515bbe48 upstream.
The Cherryview GPIO controller has 8 or 16 wires connected to the I/O-APIC
which can be used directly by the platform/BIOS or drivers. One such wire
is used as SCI (System Control Interrupt) which ACPI depends on to be able
to trigger GPEs (General Purpose Events).
The pinctrl driver itself uses another IRQ resource which is wire OR of all
the 8 (or 16) wires and follows what BIOS has programmed to the IntSel
register of each pin.
Currently the driver masks all interrupts at probe time and this prevents
these direct interrupts from working as expected. The reason for this is
that some early stage prototypes had some pins misconfigured causing lots
of spurious interrupts.
We fix this by leaving the interrupt mask untouched. This allows SCI and
other direct interrupts work properly. What comes to the possible spurious
interrupts we switch the default handler to be handle_bad_irq() instead of
handle_simple_irq() (which was not correct anyway).
Reported-by: Yu C Chen <yu.c.chen@intel.com>
Reported-by: Anisse Astier <anisse@astier.eu>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit ecc8995363ee6231b32dad61c955b371b79cc4cf upstream.
PADCFGLOCK (and PADCFGLOCK_TX) offset in Broxton actually starts at 0x060
and not 0x090 as used in the driver. Fix it to use the correct offset.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit 5d7400c4acbf7fe633a976a89ee845f7333de3e4 upstream.
Always stating PIN_CONFIG_BIAS_DISABLE is supported gives untrue output
when examining /sys/kernel/debug/pinctrl/e6060000.pfc/pinconf-pins if
the operation get_bias() is implemented but the pin is not handled by
the get_bias() implementation. In that case the output will state that
"input bias disabled" indicating that this pin has bias control
support.
Make support for PIN_CONFIG_BIAS_DISABLE depend on that the pin either
supports SH_PFC_PIN_CFG_PULL_UP or SH_PFC_PIN_CFG_PULL_DOWN. This also
solves the issue where SoC specific implementations print error messages
if their particular implementation of {set,get}_bias() is called with a
pin it does not know about.
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit f24d311f92b516a8aadef5056424ccabb4068e7b upstream.
The pinctrl_gpio_request is called with the "full" gpio number, already
containing the base, then meson_pmx_request_gpio is then called with the
final pin number.
Remove the base addition when calling meson_pmx_disable_other_groups.
Fixes: 6ac730951104 ("pinctrl: add driver for Amlogic Meson SoCs")
CC: Beniamino Galvani <b.galvani@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Beniamino Galvani <b.galvani@gmail.com>
commit d2cdf5dc58f6970e9d9d26e47974c21fe87983f3 upstream.
When the system is suspended to S3 the BIOS might re-initialize certain
GPIO pins back to their original state or it may re-program interrupt mask
of others. For example Acer TravelMate B116-M had BIOS bug where certain
GPIO pin (MF_ISH_GPIO_5) was programmed to trigger on high level, and the
pin state was high once the BIOS gave control to the OS on resume.
This triggers lots of messages like:
irq 117, desc: ffff88017a61e600, depth: 1, count: 0, unhandled: 0
->handle_irq(): ffffffff8109b613, handle_bad_irq+0x0/0x1e0
->irq_data.chip(): ffffffffa0020180, chv_pinctrl_exit+0x2d84/0x12 [pinctrl_cherryview]
->action(): (null)
IRQ_NOPROBE set
We reset the mask back to known state in chv_pinctrl_resume() but that is
called only after device interrupts have already been enabled.
Now, this particular issue was fixed by upgrading the BIOS to the latest
(v1.23) but not everybody upgrades their BIOSes so we fix it up in the
driver as well.
Prevent the possible interrupt storm by moving suspend and resume hooks to
be called at _noirq time instead. Since device interrupts are still
disabled we can restore the mask back to known state before interrupt storm
happens.
Reported-by: Christian Steiner <christian.steiner@outlook.de>
commit 56211121c0825cd188caad05574fdc518d5cac6f upstream.
If async suspend is enabled, the driver may access registers concurrently
with another instance which may fail because of the bug in Cherryview GPIO
hardware. Prevent this by taking the shared lock while accessing the
hardware in suspend and resume hooks.
commit 10ef8277ec658bf6619da9b3fd65c2db7353c2a4 upstream.
Without this, reading the "pins" in the debugfs causes kernel BUG.
Fixes: 6e9088920258 ("pinctrl: UniPhier: add UniPhier pinctrl core support")
commit 32844138e31347fc0f61d3bf2d7b9c4583f189e3 upstream.
resource_size_t may be defined as 32 or 64 bit depending on configuration,
so it cannot be printed using the normal format strings, as gcc correctly
warns:
pinctrl-at91-pio4.c: In function 'atmel_pinctrl_probe':
pinctrl-at91-pio4.c:1003:41: warning: format '%u' expects argument of type 'unsigned int', but argument 5 has type 'resource_size_t {aka long long unsigned int}' [-Wformat=]
dev_dbg(dev, "bank %i: hwirq=%u\n", i, res->start);
This changes the format string to use the special "%pr" format
string that prints a resource, and changes the arguments so we
the resource structure directly.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 486095fae3a8a6b1ae07c51844699d9bd5cfbebc upstream.
PG8, PG9 is said to be the CTS/RTS pins for UART1 according to the A23/33
datasheets. However, the function is wrongly named "uart2" in the pinctrl
driver. This patch fixes this by modifying them to be named "uart1".
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
commit a32ac2912f97d7ea9b67eb67bb4aa30b9156a88e upstream.
A previous patch attempted to fix the pinmuxes for mfio 84 - 89, but it
omitted a change to pistachio_pin_group pistachio_groups, which results
in incorrect pll_lock signals being routed.
Apply the correct mux settings throughout the driver.
fixes: cefc03e5995e ("pinctrl: Add Pistachio SoC pin control driver")
fixes: e9adb336d0bf ("pinctrl: pistachio: fix mfio84-89 function description and pinmux.")
Signed-off-by: James Hartley <james.hartley@imgtec.com>
Reviewed-by: Sifan Naeem <Sifan.Naeem@imgtec.com>
commit 8cf4345575a416e6856a6856ac6eaa31ad883126 upstream.
In the function amd_gpio_irq_enable() and
amd_gpio_direction_input(), remove the code which is setting
the default de-bounce time to 2.75ms.
The driver code shall use the same settings as specified in
BIOS. Any default assignment impacts TouchPad behaviour when
the LevelTrig is set to EDGE FALLING.
Reviewed-by: Ken Xue <Ken.Xue@amd.com>
Signed-off-by: Nitesh Kumar Agrawal <Nitesh-kumar.Agrawal@amd.com>
commit 0bd50d719b004110e791800450ad204399100a86 upstream.
Due to a silicon issue on the Atom X5-Z8000 "Cherry Trail" processor
series, a common lock must be used to prevent concurrent accesses
across the 4 GPIO controllers managed by this driver.
See Intel Atom Z8000 Processor Series Specification Update
(Rev. 005), errata #CHT34, for further information.
Signed-off-by: Dan O'Donovan <dan@emutex.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit ba562d5e54fd3136bfea0457add3675850247774 upstream.
Some PINs do not have a MUX register, it is not an error.
It is necessary to allow the continuation of the PINs configuration,
otherwise the whole PIN-group will be configured incorrectly.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
commit 0ac3c0a4025f41748a083bdd4970cb3ede802b15 upstream.
With many repeated suspend resume cycles, the pin specific wakeirq
may not always work on omaps. This is because the write to enable the
pin interrupt may not have reached the device over the interconnect
before suspend happens.
Let's fix the issue with a flush of posted write with a readback.
Reported-by: Nishanth Menon <nm@ti.com>
commit 5edf673d07fdcb6498be24914f3f38f8d8843199 upstream.
When a dual-edge irq is triggered, an incorrect irq will be reported on
condition that the external signal is not stable and this incorrect irq
has been registered.
Correct the register offset.
Signed-off-by: Hongkun Cao <hongkun.cao@mediatek.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
commit 71324fdc72ef0163e57631aa814a9a81e9e4770b upstream.
The range is registered into a linked list which can be referenced
throughout the lifetime of the driver. Ensure the range's memory is useful
for the same lifetime by adding it to the driver's private data structure.
The bug was introduced in the driver's initial commit, which was present in
v3.10.
Fixes: f0b9a7e521fa ("pinctrl: exynos5440: add pinctrl driver for Samsung EXYNOS5440 SoC")
Signed-off-by: Andrew Jeffery <andrew@aj.id.au>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit 5305a7b7e860bb40ab226bc7d58019416073948a upstream.
The default configuration of a pin is often with a value in the
pull-up/down field at chip reset. So, even if the internal logic of the
controller prevents writing a configuration with pull-up and pull-down at
the same time, we must ensure explicitly this condition before writing the
register.
This was leading to a pull-down condition not taken into account for
instance.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Fixes: 776180848b57 ("pinctrl: introduce driver for Atmel PIO4 controller")
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 56b367c0cd67d4c3006738e7dc9dda9273fd2bfe upstream.
pcs_parse_bits_in_pinctrl_entry uses ffs which gives bit indices
ranging from 1 to MAX. This leads to a corner case where we try to request
the pin number = MAX and fails.
bit_pos value is being calculted using ffs. pin_num_from_lsb uses
bit_pos value. pins array is populated with:
pin + pin_num_from_lsb.
The above is 1 more than usual bit indices as bit_pos uses ffs to compute
first set bit. Hence the last of the pins array is populated with the MAX
value and not MAX - 1 which causes error when we call pin_request.
mask_pos is rightly calculated as ((pcs->fmask) << (bit_pos - 1))
Consequently val_pos and submask are correct.
Hence use __ffs which gives (ffs(x) - 1) as the first bit set.
fixes: 4e7e8017a8 ("pinctrl: pinctrl-single: enhance to configure multiple pins of different modules")
Signed-off-by: Keerthy <j-keerthy@ti.com>
commit 5fedbb923936174ab4d1d5cc92bca1cf6b2e0ca2 upstream.
The debounce time unit for gpio_chip.set_debounce is us but
mtk_gpio_set_debounce regard it as ms.
Fix this by correct debounce time array dbnc_arr so it can find correct
debounce setting. Debounce time for first debounce setting is 500us,
correct this as well.
While I'm at it, also change the debounce time array name to
"debounce_time" for readability.
Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
commit 9a4f424531dabd877259ae0071b8bcc4dede9eb5 upstream.
On error path of_iomap() returns NULL, hence IS_ERR() check is invalid
and may cause a NULL pointer dereference, the change fixes this
problem.
While we are here invert a device node check to simplify the code.
Fixes: 26d8cde5260b ("pinctrl: freescale: imx: add shared input select reg support")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
commit 6ee334559324a55725e22463de633b99ad99fcad upstream.
Pull up was reported as pull down and vice versa. Fix this.
Fixes: 8f1774a2a971 "pinctrl: nomadik: improve GPIO debug prints"
commit 5e7515ba78fff2f5407eaa2f97c1d5c07801ac3d upstream.
pinctrl-sun8i-a33.c (and the dts) declare only 2 interrupt banks,
where as the closely related a23 has 3 banks. This matches with the
datasheet for the A33 where only interrupt banks B and G are specified
where as the A23 has banks A, B and G.
However the A33 being the A23 derative it is means that the interrupt
configure/status io-addresses for the 2 banks it has are not changed
from the A23, iow they have the same address as if bank A was still
present. Where as the sunxi pinctrl currently tries to use the A23 bank
A addresses for bank B, since the pinctrl code does not know about the
removed bank A.
Add a irq_bank_base parameter and use this where appropriate to take
the missing bank A into account.
This fixes external interrupts not working on the A33 (tested with
an i2c touchscreen controller which uses an external interrupt).
commit 0129801be4b87226bf502f18f5a9eabd356d1058 upstream.
If pinctrl_provide_dummies() is used unconditionally, then the dummy
state will be used even on DT platforms when the "init" state was
intentionally left out. Instead of "default", the dummy "init" state
will then be used during probe. Thus, when probing an I2C controller on
cold boot, communication triggered by bus notifiers broke because the
pins were not initialized.
Do it like OMAP2: use the dummy state only for non-DT platforms.
Fixes: ef0eebc05130 ("drivers/pinctrl: Add the concept of an "init" state")
Reported-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream.
mfio 84 to 89 are described wrongly, fix it to describe
the right pin and add them to right pin-mux group.
The correct order is:
pll1_lock => mips_pll -- MFIO_83
pll2_lock => audio_pll -- MFIO_84
pll3_lock => rpu_v_pll -- MFIO_85
pll4_lock => rpu_l_pll -- MFIO_86
pll5_lock => sys_pll -- MFIO_87
pll6_lock => wifi_pll -- MFIO_88
pll7_lock => bt_pll -- MFIO_89
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: James Hartley <James.Hartley@imgtec.com>
Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver")
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
Acked-by: Rob Herring <robh@kernel.org>
commit 2c7e3306d23864d49f686f22e56e180ff0fffb7f upstream.
The DT bindings for pinctrl-bcm2835 allow both the function and pull
to contain either one entry or one per pin. However, an error in the
DT parsing can cause failures if the number of pulls differs from the
number of functions.
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
Currently the provided initial value for bcm2835_gpio_direction_output
has no effect. So fix this issue by changing the value before
changing the GPIO direction. As a result we need to move the function below
bcm2835_gpio_set.
Suggested-by: Martin Sperl <kernel@martin.sperl.org>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Acked-by: Eric Anholt <eric@anholt.net>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Fixes: e1b2dc70cd5b ("pinctrl: add bcm2835 driver")
The calculation equation of PAD_OWN register offset is not
correct for Broxton, verified this fix will get right
offset for Broxton.
Signed-off-by: Qi Zheng <qi.zheng@intel.com>
Signed-off-by: Qipeng Zha <qipeng.zha@intel.com>
The group size for registers PADCFGLOCK, HOSTSW_OWN, GPI_IS,
GPI_IE, are not 24 for Broxton, Add a parameter to allow
different platform to set correct value.
To support i.MX7D Low Power State Retention IOMUXC, commit e7b37a522aa9
("pinctrl: freescale: imx: allow mux_reg offset zero") changes the way
of zero mux_reg offset support with a new flag ZERO_OFFSET_VALID. But,
unfortunately, it forgot to add this flag for vf610 pinctrl which has
zero mux_reg offset be valid as well, and hence breaks the vf610
support.
Fix the regression by adding flag ZERO_OFFSET_VALID for vf610 pinctrl
driver.
Fixes: e7b37a522aa9 ("pinctrl: freescale: imx: allow mux_reg offset zero")
Reported-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Stefan Agner <stefan@agner.ch>
When building for SH7734:
drivers/pinctrl/sh-pfc/pfc-sh7734.c:586:1: error: macro "_GP_DATA" passed 5 arguments, but takes just 4
drivers/pinctrl/sh-pfc/pfc-sh7734.c:586:2: error: '_GP_DATA' undeclared here (not in a function)
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2389:1: error: macro "_GP_INOUTSEL" passed 5 arguments, but takes just 4
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2389:53: error: '_GP_INOUTSEL' undeclared here (not in a function)
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2389:2: warning: initialization makes integer from pointer without a cast [enabled by default]
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2389:2: warning: (near initialization for '(anonymous)[0]') [enabled by default]
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2416:1: error: macro "_GP_INDT" passed 5 arguments, but takes just 4
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2416:47: error: '_GP_INDT' undeclared here (not in a function)
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2416:2: warning: initialization makes integer from pointer without a cast [enabled by default]
drivers/pinctrl/sh-pfc/pfc-sh7734.c:2416:2: warning: (near initialization for '(anonymous)[0]') [enabled by default]
Add the missing "cfg" macro parameters to the sh7734-specific
_GP_DATA(), _GP_INOUTSEL(), and _GP_INDT() macros to fix this.
Fixes: 22768fc60abbf58b ("pinctrl: sh-pfc: Add macros defining GP ports with config flags")
Since Linux gpio framework return 0 for output, 1 for input.
But HW use 0 stands for input, and 1 stands for output.
So use negative to correct it.
And gpio_chip.get is used to get input value, no need to get
output value, so removing it.
Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
When building pinctrl-ssbi-gpio and pinctrl-ssbi-mpp for ARM64, we get
a compile warning about invalid types:
drivers/pinctrl/qcom/pinctrl-ssbi-gpio.c: In function 'pm8xxx_gpio_probe':
drivers/pinctrl/qcom/pinctrl-ssbi-gpio.c:675:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
drivers/pinctrl/qcom/pinctrl-ssbi-mpp.c: In function 'pm8xxx_mpp_probe':
drivers/pinctrl/qcom/pinctrl-ssbi-mpp.c:766:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
This changes the code so we cast the pointer to 'unsigned long', which
is the right thing to do here.
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
for_each_child_of_node performs an of_node_get on each iteration,
so of_node_put is required on break out of the loop.
This is done using Coccinelle. And semantic patch used for this is
as follows:
expression root,e;
local idexpression child;
for_each_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
+ of_node_put(child);
? return ...;
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
The whole menu is guarded by
menu "Pin controllers"
depends on PINCTRL
endmenu
The if conditional outside of it is redundant.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for the v4.4 development cycle.
The only changes hitting outside drivers/gpio are in the pin control
subsystem and these seem to have settled nicely in linux-next.
Development mistakes and catfights are nicely documented in the
reverts as you can see. The outcome of the ABI fight is that we're
working on a chardev ABI for GPIO now, where hope to show results for
the v4.5 kernel.
Summary of changes:
GPIO core:
- Define and handle flags for open drain/open collector and open
source/open emitter, also know as "single-ended" configurations.
- Generic request/free operations that handle calling out to the
(optional) pin control backend.
- Some refactoring related to an ABI change that did not happen, yet
provide useful.
- Added a real-time compliance checklist. Many GPIO chips have
irqchips, and need to think this over with the RT patches going
upstream.
- Restructure, fix and clean up Kconfig menus a bit.
New drivers:
- New driver for AMD Promony.
- New driver for ACCES 104-IDIO-16, a port-mapped I/O card,
ISA-style. Very retro.
Subdriver changes:
- OMAP changes to handle real time requirements.
- Handle trigger types for edge and level IRQs on PL061 properly. As
this hardware is very common it needs to set a proper example for
others to follow.
- Some container_of() cleanups.
- Delete the unused MSM driver in favor of the driver that is
embedded inside the pin control driver.
- Cleanup of the ath79 GPIO driver used by many, many OpenWRT router
targets.
- A consolidated IT87xx driver replacing the earlier very specific
IT8761e driver.
- Handle the TI TCA9539 in the PCA953x driver. Also handle ACPI
devices in this subdriver.
- Drop xilinx arch dependencies as these FPGAs seem to profilate over
a few different architectures. MIPS and ARM come to mind"
* tag 'gpio-v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (57 commits)
gpio: fix up SPI submenu
gpio: drop surplus I2C dependencies
gpio: drop surplus X86 dependencies
gpio: dt-bindings: document the official use of "ngpios"
gpio: MAINTAINERS: Add an entry for the ATH79 GPIO driver
gpio / ACPI: Allow shared GPIO event to be read via operation region
gpio: group port-mapped I/O drivers in a menu
gpio: Add ACCES 104-IDIO-16 driver maintainer entry
gpio: zynq: Document interrupt-controller DT binding
gpio: xilinx: Drop architecture dependencies
gpio: generic: Revert to old error handling in bgpio_map
gpio: add a real time compliance notes
Revert "gpio: add a real time compliance checklist"
gpio: Add GPIO support for the ACCES 104-IDIO-16
gpio: driver for AMD Promontory
gpio: xlp: Convert to use gpiolib irqchip helpers
gpio/xilinx: enable for MIPS
gpiolib: Add and use OF_GPIO_SINGLE_ENDED flag
gpiolib: Split GPIO flags parsing and GPIO configuration
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"This is the big bulk of pin control changes for the v4.4 kernel
development cycle. Development pace is high in pin control again this
merge window. 28 contributors, 83 patches.
It hits a few sites outside the pin control subsystem:
- Device tree bindings in Documentation (as usual)
- MAINTAINERS
- drivers/base/* for the "init" state handling by Doug Anderson.
This has been ACKed by Greg.
- drivers/usb/renesas_usbhs/rcar2.c, for a dependent Renesas change
in the USB subsystem. This has been ACKed by both Greg and Felipe.
- arch/arm/boot/dts/sama5d2.dtsi - this should ideally have gone
through the ARM SoC tree but ended up here.
This time I am using Geert Uytterhoeven as submaintainer for SH PFC
since the are three-four people working in parallel with new Renesas
ASICs.
Summary of changes:
Infrastructure:
- Doug Anderson wrote a patch adding an "init" state different from
the "default" state for pin control state handling in the core
framework. This is applied before the driver's probe() call if
defined and takes precedence over "default". If both are defined,
"init" will be applied *before* probe() and "default" will be
applied *after* probe().
Significant subdriver improvements:
- SH PFC is switched to getting GPIO ranges from the device tree
ranges property on DT platforms.
- Got rid of CONFIG_ARCH_SHMOBILE_LEGACY, we are all modernized.
- Got rid of SH PFC hardcoded IRQ numbers.
- Allwinner sunxi external interrupt through the "r" controller.
- Moved the Cygnus driver to use DT-provided GPIO ranges.
New drivers:
- Atmel PIO4 pin controller for the SAMA4D2 family
New subdrivers:
- Rockchip RK3036 subdriver
- Renesas SH PFC R8A7795 subdriver
- Allwinner sunxi A83T PIO subdriver
- Freescale i.MX7d iomux lpsr subdriver
- Marvell Berlin BG4CT subdriver
- SiRF Atlas 7 step B SoC subdriver
- Intel Broxton SoC subdriver
Apart from this, the usual slew if syntactic and semantic fixes"
* tag 'pinctrl-v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (81 commits)
pinctrl: pinconf: remove needless loop
pinctrl: uniphier: guard uniphier directory with CONFIG_PINCTRL_UNIPHIER
pinctrl: zynq: fix UTF-8 errors
pinctrl: zynq: Initialize early
pinctrl: at91: add missing of_node_put
pinctrl: tegra-xusb: Correct lane mux options
pinctrl: intel: Add Intel Broxton pin controller support
pinctrl: intel: Allow requesting pins which are in ACPI mode as GPIOs
pinctrl: intel: Add support for multiple GPIO chips sharing the interrupt
pinctrl: uniphier: set input-enable before pin-muxing
pinctrl: cygnus: Add new compatible string for gpio controller driver
pinctrl: cygnus: Remove GPIO to Pinctrl pin mapping from driver
pinctrl: cygnus: Optional DT property to support pin mappings
pinctrl: sunxi: Add irq pinmuxing to sun6i "r" pincontroller
pinctrl: sunxi: Fix irq_of_xlate for the r_pio pinctrl block
pinctrl: sh-pfc: Remove obsolete r8a7778 platform_device_id entry
pinctrl: sh-pfc: Remove obsolete r8a7779 platform_device_id entry
pinctrl: sh-pfc: Stop including <linux/platform_data/gpio-rcar.h>
usb: renesas_usbhs: Remove unneeded #include <linux/platform_data/gpio-rcar.h>
This removes a needless loop which was caught in pinconf.c.
Suggested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Signed-off-by: Laurent Meunier <laurent.meunier@st.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
CONFIG_PINCTRL_UNIPHIER is more suitable than CONFIG_ARCH_UNIPHIER
to guard the drivers/pinctrl/uniphier directory.
The current CONFIG_PINCTRL_UNIPHIER_CORE is a bit long
(it would break the indentation in drivers/pinctrl/Makefile),
so rename it into CONFIG_PINCTRL_UNIPHIER.
Fix up Sören's name in the Zynq driver. I caused this. I fix it.
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
