path: root/drivers/pinctrl
2012-10-28pinctrl: tegra: set low power mode bank width to 2Pritesh Raithatha
commit 154f3ebf53edcfbe28728452b4ab37a118581125 upstream. Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28pinctrl: tegra: correct bank for pingroup and drv pingroupPritesh Raithatha
commit a03690e44468dcd3088f6600ab036d17bd2130ff upstream. Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-11pinctrl: implement pinctrl_check_opsStephen Warren
Most code assumes that the pinctrl ops are present. Validate this when registering a pinctrl driver. Remove the one place in the code that was checking whether one of these non-optional ops was present. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-12pinctrl: support pinconfig on the U300Linus Walleij
This adds pin configuration support for the U300 driver pair, we can now read out the biasing and drive mode in debugfs and configure it using the new configuration API. ChangeLog v1->v2: - Migrate to pin config and generic pin config changes. ChangeLog v2->v3: - Adjust to generic pin config changes in v7 patch set. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-12pinctrl/coh901: use generic pinconf enums and parametersLinus Walleij
Adjust the COH 901 driver to use the standard enums for biasing and driving pins, alter signature of config function to suit the framework. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-12pinctrl: introduce generic pin configLinus Walleij
This is a split-off from the earlier patch set which adds generic pin configuration for the pin controllers that want it. Since we may have a system with mixed generic and custom pin controllers, we pass a boolean in the pin controller ops vtable to indicate if it is generic. ChangeLog v1->v5: - Follow parent patch versioning number system. - Document the semantic meaning of return values from pin config get functions, so we can iterate over pins and check their properties from debugfs as part of the generic config code. - Use proper cast functions in the generic debugfs pin config file. - Expand generic config to optionally cover groups too. ChangeLog v5->v6: - Update to match underlying changes. ChangeLog v6->v7: - Drop DRIVE_OFF parameter, use bias high impedance for this - Delete argument for drive modes push-pull, od and os. These are now just state transitions. - Delete slew rate rising/falling due to discussions on on proper semantics - Drop config wakeup, struct irq_chip does this for now, add back if need be. - Set PIN_CONFIG_END to 0x7fff making room for custom config parameters from 0x8000 and up. - Prefix accessor functions with pinconf_
2012-03-12pinctrl: fix error path in pinconf_map_to_setting()Linus Walleij
The code was using the union member setting->data.configs.group_or_pin to store a potential error code, but since that member is unsigned the < 0 comparison was not true, letting errors pass through, ending up as mapped to pin "-22". Fix this up and print the error. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-12pinctrl: allow concurrent gpio and mux function ownership of pinsStephen Warren
Per recent updates to Documentation/gpio.txt, gpiolib drivers should inform pinctrl when a GPIO is requested. pinctrl then marks that pin as in-use for that GPIO function. When an SoC muxes pins in a group, it's quite possible for the group to contain e.g. 6 pins, but only 4 of them actually be needed by the HW module that's mux'd to them. In this case, the other 2 pins could be used as GPIOs. However, pinctrl marks all the pins within the group as in-use by the selected mux function. To allow the expected gpiolib interaction, separate the concepts of pin ownership into two parts: One for the mux function and one for GPIO usage. Finally, allow those two ownerships to exist in parallel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-06Merge branch 'pinctrl-tegra-for-next-diet' into for-nextLinus Walleij
2012-03-06pinctrl: include machine header to core.hLinus Walleij
struct pinctrl_setting contains an enum pinctrl_map_type field, so we need to include machine.h. Also fix kerneldoc to indicate that the pinctrl_setting is about both muxing and other config. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-06pinctrl: add a driver for NVIDIA TegraStephen Warren
This adds a driver for the Tegra pinmux, and required parameterization data for Tegra20 and Tegra30. The driver is initially added with driver name and device tree compatible value that won't cause this driver to be used. A later change will switch the pinctrl driver to use the correct values, switch the old pinmux driver to be disabled, and update all code that uses the old pinmux APIs to use the new pinctrl APIs. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net> [squashed "fix case of Tegra30's foo_groups[] arrays"] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: Show selected function and group in pinmux-pins debugfsStephen Warren
Until recently, the pinctrl pinmux-pins debugfs file displayed the selected function for each owned pin. This feature was removed during restructing in support of recent API rework. This change restoreds this feature, and also displays the group that the function was selected on, in case a pin is a member of multiple groups. Based on work by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: enhance mapping table to support pin config operationsStephen Warren
The pinctrl mapping table can now contain entries to: * Set the mux function of a pin group * Apply a set of pin config options to a pin or a group This allows pinctrl_select_state() to apply pin configs settings as well as mux settings. v3: Fix find_pinctrl() to iterate over the correct list. s/_MUX_CONFIGS_/_CONFIGS_/ in mapping table macros. Fix documentation to use correct mapping table macro. v2: Added numerous extra PIN_MAP_*() special-case macros. Fixed kerneldoc typo. Delete pinctrl_get_pin_id() and replace it with pin_get_from_name(). Various minor fixes. Updates due to rebase. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: API changes to support multiple states per deviceStephen Warren
The API model is changed from: p = pinctrl_get(dev, "state1"); pinctrl_enable(p); ... pinctrl_disable(p); pinctrl_put(p); p = pinctrl_get(dev, "state2"); pinctrl_enable(p); ... pinctrl_disable(p); pinctrl_put(p); to this: p = pinctrl_get(dev); s1 = pinctrl_lookup_state(p, "state1"); s2 = pinctrl_lookup_state(p, "state2"); pinctrl_select_state(p, s1); ... pinctrl_select_state(p, s2); ... pinctrl_put(p); This allows devices to directly transition between states without disabling the pin controller programming and put()/get()ing the configuration data each time. This model will also better suit pinconf programming, which doesn't have a concept of "disable". The special-case hogging feature of pin controllers is re-written to use the regular APIs instead of special-case code. Hence, the pinmux-hogs debugfs file is removed; see the top-level pinctrl-handles files for equivalent data. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: add usecount to pins for muxingStephen Warren
Multiple mapping table entries could reference the same pin, and hence "own" it. This would be unusual now that pinctrl_get() represents a single state for a client device, but in the future when it represents all known states for a device, this is quite likely. Implement reference counting for pin ownership to handle this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: refactor struct pinctrl handling in core.c vs pinmux.cStephen Warren
This change separates two aspects of struct pinctrl: a) The data representation of the parsed mapping table, into: 1) The top-level struct pinctrl object, a single entity returned by pinctrl_get(). 2) The parsed version of each mapping table entry, struct pinctrl_setting, of which there is one per mapping table entry. b) The code that handles this; the code for (1) above is in core.c, and the code to parse/execute each entry in (2) above is in pinmux.c, while the iteration over multiple settings is lifted to core.c. This will allow the following future changes: 1) pinctrl_get() API rework, so that struct pinctrl represents all states for the device, and the device can select between them without calling put()/get() again. 2) To support that, a struct pinctrl_state object will be inserted into the data model between the struct pinctrl and struct pinctrl_setting. 3) The mapping table will be extended to allow specification of pin config settings too. To support this, struct pinctrl_setting will be enhanced to store either mux settings or config settings, and functions will be added to pinconf.c to parse/execute pin configuration settings. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: fix and simplify lockingStephen Warren
There are many problems with the current pinctrl locking: struct pinctrl_dev's gpio_ranges_lock isn't effective; pinctrl_match_gpio_range() only holds this lock while searching for a gpio range, but the found range is return and manipulated after releading the lock. This could allow pinctrl_remove_gpio_range() for that range while it is in use, and the caller may very well delete the range after removing it, causing pinctrl code to touch the now-free range object. Solving this requires the introduction of a higher-level lock, at least a lock per pin controller, which both gpio range registration and pinctrl_get()/put() will acquire. There is missing locking on HW programming; pin controllers may pack the configuration for different pins/groups/config options/... into one register, and hence have to read-modify-write the register. This needs to be protected, but currently isn't. Related, a future change will add a "complete" op to the pin controller drivers, the idea being that each state's programming will be programmed into the pinctrl driver followed by the "complete" call, which may e.g. flush a register cache to HW. For this to work, it must not be possible to interleave the pinctrl driver calls for different devices. As above, solving this requires the introduction of a higher-level lock, at least a lock per pin controller, which will be held for the duration of any pinctrl_enable()/disable() call. However, each pinctrl mapping table entry may affect a different pin controller if necessary. Hence, with a per-pin-controller lock, almost any pinctrl API may need to acquire multiple locks, one per controller. To avoid deadlock, these would need to be acquired in the same order in all cases. This is extremely difficult to implement in the case of pinctrl_get(), which doesn't know which pin controllers to lock until it has parsed the entire mapping table, since it contains somewhat arbitrary data. The simplest solution here is to introduce a single lock that covers all pin controllers at once. This will be acquired by all pinctrl APIs. This then makes struct pinctrl's mutex irrelevant, since that single lock will always be held whenever this mutex is currently held. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-02pinctrl: fix the pin descriptor kerneldocLinus Walleij
The introduction of the owner field on the pin descriptor was not properly documented so fix this up. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-02pinctrl: assume map table entries can't have a NULL name fieldStephen Warren
pinctrl_register_mappings() already requires that every mapping table entry have a non-NULL name field. Logically, this makes sense too; drivers should always request a specific named state so they know what they're getting. Relying on getting the first mentioned state in the mapping table is error-prone, and a nasty special case to implement, given that a given the mapping table may define multiple states for a device. Remove a small part of the documentation that talked about optionally requesting a specific state; it's mandatory now. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-02pinctrl: introduce PINCTRL_STATE_DEFAULT, define hogs as that stateStephen Warren
This provides a single centralized name for the default state. Update PIN_MAP_* macros to use this state name, instead of requiring the user to pass a state name in. With this change, hog entries in the mapping table are defined as those with state name PINCTRL_STATE_DEFAULT, i.e. all entries have the same name. This interacts badly with the nested iteration over mapping table entries in pinctrl_hog_maps() and pinctrl_hog_map() which would now attempt to claim each hog mapping table entry multiple times. Replacing the custom hog code with a simple pinctrl_get()/pinctrl_enable(). Update documentation and mapping tables to use this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-02pinctrl: enhance pinctrl_get() to handle multiple functionsStephen Warren
At present, pinctrl_get() assumes that all matching mapping table entries have the same "function" value, albeit potentially applied to different pins/groups. This change removes this restriction; pinctrl_get() can now handle a set of mapping tables where different functions are applied to the various pins/groups. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-29pinctrl: move pinctrl-maps debugfs file to top-levelStephen Warren
The debugfs file pinctrl-maps is a system-wide file, not specific to any pin controller, so place it in the top-level directory. Also, move the code implementing the file to keep the order of all the functions matching the order they're created in pinctrl_init_*debugfs(). The only non-obvious change here is no private data is passed to debugfs_create_file() or single_open(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-29pinctrl: make the pinmux-pins more helpfulLinus Walleij
The debugfs file pinmux-pins used to tell which function was enabled but now states simply which device owns the pin. Being owned by the pinctrl driver itself means just that it's hogged so be a bit more helpful by printing that. ChangeLog v1->v2: - Preserve the self-referential owner field, just clarify that when the pin controller states itself as owner this means that it's hogged. Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-24pinctrl: remove pin and hogs locks from struct pinctrl_devStephen Warren
struct pinctrl_dev's pin_desc_tree_lock and pinctrl_hogs_lock aren't useful; the data they protect is read-only except when registering or unregistering a pinctrl_dev, and at those times, it doesn't make sense to protect one part of the structure independently from the rest. Move pinctrl_init_device_debugfs() to the end of pinctrl_register() so that debugfs can't access the struct pinctrl_dev until it's fully initialized, i.e. after the hogs are set up. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-24pinctrl: allocate sizeof(*p) instead of sizeof(struct foo)Stephen Warren
This hopefully makes it harder to take the sizeof the wrong type. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-24pinctrl: use dev_*() instead of pr_*(), add some msgs, minor cleanupsStephen Warren
e.g. dev_err instead of pr_err prints messages in a slightly more standardized format. Also, add a few more error messages to track down errors. Also, some small cleanups of messages. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-24pinctrl: disallow map table entries with NULL dev_name fieldStephen Warren
Hog entries are mapping table entries with .ctrl_dev_name == .dev_name. All other mapping table entries need .dev_name set so that they will match some pinctrl_get() call. All extant PIN_MAP*() macros set .dev_name. So, there is no reason to allow mapping table entries without .dev_name set. Update the code and documentation to disallow this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: fix pinconf_groups_show() to emit newlineStephen Warren
pinconf_groups_show() wrote all debug information on one line. Fix it to match pinconf_pins_show() and be legible. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: record a pin owner, not mux function, when requesting pinsStephen Warren
When pins are requested/acquired/got, some device becomes the owner of their mux setting. At this point, it isn't certain which mux function will be selected for the pin, since this may vary between each of the device's states in the pinctrl mapping table. As such, we should record the owning device, not what we think the initial mux setting will be, when requesting pins. This doesn't make a lot of difference right now since pinctrl_get gets only one single device/state combination, but this will make a difference when pinctrl_get gets all states, and pinctrl_select_state can switch between states. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: error if mapping table's control dev can't be foundStephen Warren
This is a serious error, and the pin control system will not function correctly if it ends up not programing the mapping table entries into the HW. Instead of just ignoring this, error out. Signed-off-by: Stephen Warren <swarren@nvidia.com> [rebased to fit the applied patch series, cast error to pointer] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: downgrade pinctrl_get warning when no maps are foundStephen Warren
This may be perfectly legitimate. An IP block may get re-used across SoCs. Not all of those SoCs may need pinmux settings for the IP block, e.g. if one SoC dedicates pins to that function but another doesn't. The driver won't know this, and will always attempt to set up the pinmux. The mapping table defines whether any HW programming is actually needed. Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> [rebased to fit the applied patch series] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: assume map table entries can't have a NULL ctrl_dev_name fieldStephen Warren
These are already disallowed. Clean up some code that doesn't assume this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: spawn U300 pinctrl from the COH901 GPIOLinus Walleij
This solves the riddle on how the U300 pin controller shall be able to reference the struct gpio_chip even though these are two separate drivers: spawn the pinctrl child from the GPIO driver and pass in the struct gpio_chip as platform data. In the process we rename the U300 "pinmux-u300" to "pinctrl-u300" so as not to confuse. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: core.c/h cleanupsStephen Warren
* Make all functions internal to core.c static. Remove any of these from core.h. * Add any missing EXPORT_SYMBOL_GPL(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: Re-order pinconf.[ch] to match each-otherStephen Warren
Modify the two files so that the order of function prototypes in the header matches the order of implementations in the .c file. Don't prototype a couple of internal functions. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: Re-order pinmux.[ch] to match each-otherStephen Warren
Modify the two files so that the order of function prototypes in the header matches the order of implementations in the .c file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: Store mapping table as a list of chunksStephen Warren
Instead of storing a single array of mapping table entries, which requires realloc()ing that array each time it's extended and copying the new data, simply store a list of pointers to the individual chunks. This also removes the need to copy the mapping table at all; a pointer is maintained to the original table, this saving memory. A macro for_each_maps() is introduced to hide the additional complexity of iterating over the map entries. This change will also simplify removing chunks of entries from the mapping table. This isn't important right now, but will be in the future, when mapping table entries are dynamically added when parsing them from the device tree, and removed when drivers no longer need to interact with pinctrl. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: use list_add_tail instead of list_addStephen Warren
This mostly makes debugfs files print things in the order that they were added or acquired, which just feels a little more consistent. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: pinctrl_register_mappings() shouldn't be __initStephen Warren
It may be common for pinctrl_register_mappings() to be used from __init context, but there's no reason that additional mappings shouldn't be added at a later point, e.g. if loading modules that add pin controllers and their mapping tables. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: make "hog" mapping table entries workStephen Warren
Commit 77a5988 "pinctrl: changes hog mechanism to be self-referential" modified the way "hog" entries were represented in the mapping table. However, the new representation failed some error checks in pinctrl_hog_map(). Remove the now-bogus error-check, and fix the code to solve the issue the error-check used to avoid. Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-10pinctrl: changes hog mechanism to be self-referentialLinus Walleij
Instead of a specific boolean field to indicate if a map entry shall be hogged, treat self-reference as an indication of desired hogging. This drops one field off the map struct and has a nice Douglas R. Hofstadter-feel to it. Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-10pinctrl: factor pin control handles over to the coreLinus Walleij
This moves the per-devices struct pinctrl handles and device map over from the pinmux part of the subsystem to the core pinctrl part. This makes the device handles core infrastructure with the goal of using these handles also for pin configuration, so that device drivers (or boards etc) will need one and only one handle to the pin control core. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-10pinctrl: move generic functions to the pinctrl_ namespaceLinus Walleij
Since we want to use the former pinmux handles and mapping tables for generic control involving both muxing and configuration we begin refactoring by renaming them from pinmux_* to pinctrl_*. ChangeLog v1->v2: - Also rename the PINMUX_* macros in machine.h to PIN_ as indicated in the documentation so as to reflect the generic nature of these mapping entries from now on. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-10pinctrl: break out a pinctrl consumer headerLinus Walleij
This breaks out a <linux/pinctrl/consumer.h> header to be used by all pinmux and pinconfig alike, so drivers needing services from pinctrl does not need to include different headers. This is similar to the approach taken by the regulator API. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-01pinctrl: enable pinmux for mmp seriesHaojian Zhuang
Support PXA168/PXA910/MMP2 pinmux. Now only support function switch. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> [Rebase and fix some whitespace issues] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-01pinctrl: delete raw device pointers in pinmux mapsLinus Walleij
After discussion with Mark Brown in an unrelated thread about ADC lookups, it came to my knowledge that the ability to pass a struct device * in the regulator consumers is just a historical artifact, and not really recommended. Since there are no in-kernel users of these pointers, we just kill them right now, before someone starts to use them. Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-01pinctrl: restore pin namingLinus Walleij
Commit ca53c5f1ca5c936777caca46b7c716a40682ce83 ("pinctrl: conjure names for unnamed pins") made pins lose their identity and only get autogenerated names. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-26pinctrl: add checks for empty function namesTony Lindgren
This is needed as otherwise we can get the following when dealing with buggy data in a pinmux driver for pinmux_search_function: Unable to handle kernel NULL pointer dereference at virtual address 00000000 ... PC is at strcmp+0xc/0x34 LR is at pinmux_get+0x350/0x8f4 ... As we need pctldev initialized to call ops->list_functions, let's initialize it before check_ops calls and pass the pctldev to the check_ops functions. Do this for both pinmux and pinconf check_ops functions. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-26pinctrl: fix pinmux_hog_maps when ctrl_dev_name is not setTony Lindgren
The ctrl_dev_name is optional for struct pinmux_map assuming that ctrl_dev is set. Without this patch we can get: Unable to handle kernel NULL pointer dereference at virtual address 00000000 ... (pinmux_hog_maps+0xa4/0x20c) (pinctrl_register+0x2a4/0x378) ... Fix this by adding adding a test for map->ctrl_dev. Additionally move the test for map->ctrl_dev earlier to optimize out the loop a bit. Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-26pinctrl: fix some pinmux typosTony Lindgren
Fix some pinmux typos so implementing pinmux drivers is a bit easier. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
