A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
According to compiler warnings, quite some suspend/resume functions
in platform x86 drivers are not used for CONFIG_PM_SLEEP unset, so
add #ifdefs to prevent them from being built in that case.
Make the HDAPS driver define its PM callbacks through
a struct dev_pm_ops object rather than by using legacy PM hooks
in struct platform_driver.
I haven't had a working gmail address for many years - update to my
actual working address.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Trivial fix for some -Wuninitialized compiler warnings.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Turn off the following triggered with gcc 4.6.1 on Debian testing:
drivers/platform/x86/hdaps.c: In function ‘hdaps_temp2_show’:
drivers/platform/x86/hdaps.c:398:16: warning: ‘temp’ may be used uninitialized in this function [-Wuninitialized]
drivers/platform/x86/hdaps.c: In function ‘hdaps_temp1_show’:
drivers/platform/x86/hdaps.c:385:16: warning: ‘temp’ may be used uninitialized in this function [-Wuninitialized]
Cc: Frank Seidel <frank@f-seidel.de>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: platform-driver-x86@vger.kernel.org
Signed-off-by: Borislav Petkov <bp@alien8.de>
Added pr_fmt, converted printks and removed
hard coded prefixes.
The hdaps driver isn't a hardware monitoring driver, so it shouldn't
live under driver/hwmon. drivers/platform/x86 seems much more
appropriate, as the driver is only useful on x86 laptops.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
