path: root/drivers/platform/x86/ibm_rtl.c
2013-01-30efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: <stable@vger.kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-02-21asm-generic: architecture independent readq/writeq for 32bit environmentHitoshi Mitake
This provides unified readq()/writeq() helper functions for 32-bit drivers. For some cases, readq/writeq without atomicity is harmful, and order of io access has to be specified explicitly. So in this patch, new two header files which contain non-atomic readq/writeq are added. - <asm-generic/io-64-nonatomic-lo-hi.h> provides non-atomic readq/ writeq with the order of lower address -> higher address - <asm-generic/io-64-nonatomic-hi-lo.h> provides non-atomic readq/ writeq with reversed order This allows us to remove some readq()s that were added drivers when the default non-atomic ones were removed in commit dbee8a0affd5 ("x86: remove 32-bit versions of readq()/writeq()") The drivers which need readq/writeq but can do with the non-atomic ones must add the line: #include <asm-generic/io-64-nonatomic-lo-hi.h> /* or hi-lo.h */ But this will be nop in 64-bit environments, and no other #ifdefs are required. So I believe that this patch can solve the problem of 1. driver-specific readq/writeq 2. atomicity and order of io access This patch is tested with building allyesconfig and allmodconfig as ARCH=x86 and ARCH=i386 on top of tip/master. Cc: Kashyap Desai <Kashyap.Desai@lsi.com> Cc: Len Brown <lenb@kernel.org> Cc: Ravi Anand <ravi.anand@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: James Bottomley <James.Bottomley@parallels.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Roland Dreier <roland@purestorage.com> Cc: James Bottomley <jbottomley@parallels.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-14ibm_rtl: convert sysdev_class to a regular subsystemKay Sievers
After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-27ibm_rtl: Use pr_fmt and pr_<level>Joe Perches
Remove hard coded prefixes from logging messages. Neaten RTL_DEBUG macro and uses. Convert __FUNCTION__ to __func__. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27ibm_rtl: Remove warnings from casts of pointer to intJoe Perches
Just print them as %p. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-25x86: remove 32-bit versions of readq()/writeq()Roland Dreier
The presense of a writeq() implementation on 32-bit x86 that splits the 64-bit write into two 32-bit writes turns out to break the mpt2sas driver (and in general is risky for drivers as was discussed in <http://lkml.kernel.org/r/adaab6c1h7c.fsf@cisco.com>). To fix this, revert 2c5643b1c5c7 ("x86: provide readq()/writeq() on 32-bit too") and follow-on cleanups. This unfortunately leads to pushing non-atomic definitions of readq() and write() to various x86-only drivers that in the meantime started using the definitions in the x86 version of <asm/io.h>. However as discussed exhaustively, this is actually the right thing to do, because the right way to split a 64-bit transaction is hardware dependent and therefore belongs in the hardware driver (eg mpt2sas needs a spinlock to make sure no other accesses occur in between the two halves of the access). Build tested on 32- and 64-bit x86 allmodconfig. Link: http://lkml.kernel.org/r/x86-32-writeq-is-broken@mdm.bga.com Acked-by: Hitoshi Mitake <h.mitake@gmail.com> Cc: Kashyap Desai <Kashyap.Desai@lsi.com> Cc: Len Brown <lenb@kernel.org> Cc: Ravi Anand <ravi.anand@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Acked-by: James Bottomley <James.Bottomley@parallels.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-24ibm_rtl: _RTL_ is not available in UEFI modeVernon Mauery
Some of the IBM servers that are supported by ibm_rtl can run in both Legacy mode (BIOS) and in UEFI mode. When running in UEFI mode, it is possible that the EBDA table exists but cannot be mapped and reports errors. We need to make sure that by default we don't try to probe the machines if they are running in UEFI mode. Signed-off-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-11-24ibm_rtl: Loosen the DMI criteria to all IBM machinesVernon Mauery
Allow all IBM machines to pass the DMI check so that we don't have to add them one by one to the driver. Any IBM machine that has the _RTL_ table in the EBDA will work. Signed-off-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-11-24ibm_rtl: fix printk format warningRandy Dunlap
Fix printk format warning: drivers/platform/x86/ibm_rtl.c:305:warning: format '%#llx' expects type 'long long unsigned int', but argument 2 has type 'phys_addr_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Keith Mannthey <kmannth@us.ibm.com> Cc: Vernon Mauery <vernux@us.ibm.com> Cc: platform-driver-x86@vger.kernel.org Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-10-21IBM Real-Time "SMI Free" mode driver -v7Vernon Mauery
After a period of RFC for this driver, I think it is ready for inclusion in the platform-driver-x86 tree, hopefully to be staged in the next merge window into Linus's tree. --Vernon ------------------------------------------------------------ IBM Real-Time "SMI Free" mode driver This driver supports the Real-Time Linux (RTL) BIOS feature. The RTL feature allows non-fatal System Management Interrupts (SMIs) to be disabled on supported IBM platforms and is intended to be coupled with a user-space daemon to monitor the hardware in a way that can be prioritized and scheduled to better suit the requirements for the system. The Device is presented as a special "_RTL_" table to the OS in the Extended BIOS Data Area. There is a simple protocol for entering and exiting the mode at runtime. This driver creates a simple sysfs interface to allow a simple entry and exit from RTL mode in the UFI/BIOS. Since the driver is specific to IBM SystemX hardware (x86- based servers) it only builds on x86 builds. To reduce the risk of loading on the wrong hardware, the module uses DMI information and checks a list of servers that are known to work. Signed-off-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
