path: root/drivers/platform
2011-12-05toshiba_acpi: Fix machines that don't support HCI_SYSTEM_EVENTSeth Forshee
The Satellite C670-10V generates notifications for hotkeys but does not support HCI_SYSTEM_EVENT. As a result when a hotkey is pressed it gets stuck in an infinite loop in toshiba_acpi_notify. To fix this, detect whether or not HCI_SYSTEM_EVENT is supported up-front and don't try to read system events if it isn't supported. In addition, limit the number of retries when reading HCI_SYSTEM_EVENT fails so that this loop cannot run unbounded. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-11-17platform/x86: fix dell-laptop function prototypesRandy Dunlap
Fix build warnings: drivers/platform/x86/dell-laptop.c:592:13: warning: function declaration isn't a prototype drivers/platform/x86/dell-laptop.c:599:13: warning: function declaration isn't a prototype Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-08x86 platform drivers: add POWER_SUPPLY to selected drivers for DellLinus Torvalds
The Kconfig loop detection goes crazy without this. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-08x86 platform drivers: make Dell laptop driver select needed LED supportLinus Torvalds
Otherwise we get compile errors like this: ERROR: "led_classdev_unregister" [drivers/platform/x86/dell-laptop.ko] undefined! ERROR: "led_classdev_register" [drivers/platform/x86/dell-laptop.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 when the dell-laptop support is enabled without the necessary LED support being enabled. Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Acked-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31Merge branch 'akpm' (Andrew's incoming)Linus Torvalds
Quoth Andrew: - Most of MM. Still waiting for the poweroc guys to get off their butts and review some threaded hugepages patches. - alpha - vfs bits - drivers/misc - a few core kerenl tweaks - printk() features - MAINTAINERS updates - backlight merge - leds merge - various lib/ updates - checkpatch updates * akpm: (127 commits) epoll: fix spurious lockdep warnings checkpatch: add a --strict check for utf-8 in commit logs kernel.h/checkpatch: mark strict_strto<foo> and simple_strto<foo> as obsolete llist-return-whether-list-is-empty-before-adding-in-llist_add-fix wireless: at76c50x: follow rename pack_hex_byte to hex_byte_pack fat: follow rename pack_hex_byte() to hex_byte_pack() security: follow rename pack_hex_byte() to hex_byte_pack() kgdb: follow rename pack_hex_byte() to hex_byte_pack() lib: rename pack_hex_byte() to hex_byte_pack() lib/string.c: fix strim() semantics for strings that have only blanks lib/idr.c: fix comment for ida_get_new_above() lib/percpu_counter.c: enclose hotplug only variables in hotplug ifdef lib/bitmap.c: quiet sparse noise about address space lib/spinlock_debug.c: print owner on spinlock lockup lib/kstrtox: common code between kstrto*() and simple_strto*() functions drivers/leds/leds-lp5521.c: check if reset is successful leds: turn the blink_timer off before starting to blink leds: save the delay values after a successful call to blink_set() drivers/leds/leds-gpio.c: use gpio_get_value_cansleep() when initializing drivers/leds/leds-lm3530.c: add __devexit_p where needed ...
2011-10-31lis3: change exported function to use passed parameterÉric Piel
Change exported functions to use the device given as parameter instead of the global one. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31hp_accel: add HP ProBook 655xÉric Piel
Add axis correction for HP ProBook 6555b. Signed-off-by: Malte Starostik <m-starostik@versanet.de> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3: add support for HP EliteBook 8540wÉric Piel
Add axis correction for HP EliteBook 8540w. Reported-by: Lyall Pearce <lyall.pearce@hp.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3: add support for HP EliteBook 2730pÉric Piel
Add axis correction for HP EliteBook 2730p. Tested-by: Witold Pilat <witold.pilat@gmail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3lv02d: avoid divide by zero due to uncheckedÉric Piel
After an "unexpected" reboot, I found this Oops in my logs: divide error: 0000 [#1] PREEMPT SMP=20 CPU 0=20 Modules linked in: lis3lv02d hp_wmi input_polldev [...] Pid: 390, comm: modprobe Tainted: G C 2.6.39-rc7-wl+=20 RIP: 0010:[<ffffffffa014b427>] [<ffffffffa014b427>] lis3lv02d_poweron+0x4e/0x94 [lis3lv02d] RSP: 0018:ffff8801d6407cf8 EFLAGS: 00010246 RAX: 0000000000000bb8 RBX: ffffffffa014e000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffffea00066e4708 RDI: ffff8801df002700 RBP: ffff8801d6407d18 R08: ffffea00066c5a30 R09: ffffffff812498c9 R10: ffff8801d7bfcea0 R11: ffff8801d7bfce10 R12: 0000000000000bb8 R13: 00000000ffffffda R14: ffffffffa0154120 R15: ffffffffa0154030 =46S: 00007fc0705db700(0000) GS:ffff8801dfa00000(0000) knlGS:0 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f33549174f0 CR3: 00000001d65c9000 CR4: 00000000000406f0 Process modprobe (pid: 390, threadinfo ffff8801d6406000, task ffff8801d6b40= 000) Stack: ffffffffa0154120 62ffffffa0154030 ffffffffa014e000 00000000ffffffea ffff8801d6407d58 ffffffffa014bcc1 0000000000000000 0000000000000048 ffff8801d8bae800 00000000ffffffea 00000000ffffffda ffffffffa0154120 Call Trace: [<ffffffffa014bcc1>] lis3lv02d_init_device+0x1ce/0x496 [lis3lv02d] [<ffffffffa01522ff>] lis3lv02d_add+0x10f/0x17c [hp_accel] [<ffffffff81233e11>] acpi_device_probe+0x49/0x117 [...] Code: 3a 75 06 80 4d ef 50 eb 04 80 4d ef 40 0f b6 55 ef be 21 00 00 00 48 89 df ff 53 18 44 8b 63 6c e8 3e fc ff ff 89 c1 44 89 e0 99 <f7> f9 89 c7 e8 93 82 ef e0 48 83 7b 30 00 74 2d 45 31 e4 80 7b=20 RIP [<ffffffffa014b427>] lis3lv02d_poweron+0x4e/0x94 [lis3lv02d] RSP <ffff8801d6407cf8> >From my POV, it looks like the hardware is not working as expected and returns a bogus data rate. The driver doesn't check the result and directly uses it as some sort of divisor in some places: msleep(lis3->pwron_delay / lis3lv02d_get_odr()); Under this circumstances, this could very well cause the "divide by zero" exception from above. For now, I fixed it the easiest and most obvious way: Check if the result is sane and if it isn't use a sane default instead. I went for "100" in the latter case, simply because /sys/devices/platform/lis3lv02d/rate returns it on a successful boot. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31x86: fix up files really needing to include module.hPaul Gortmaker
These files aren't just exporting symbols -- they are also defining a MODULE_LICENSE etc. so give them the full module.h file. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (45 commits) acer-wmi: replaced the hard coded bitmap by the communication devices bitmap from SMBIOS acer-wmi: check the existence of internal wireless device when set capability acer-wmi: add ACER_WMID_v2 interface flag to represent new notebooks sony-laptop:irq: Remove IRQF_DISABLED asus-laptop: Add rfkill support for Pegatron Lucid tablet asus-laptop: pega_accel - Report accelerometer orientation change through udev asus-laptop: fix module description asus-laptop: hide leds on Pegatron Lucid asus-laptop: Pegatron Lucid accelerometer asus-laptop: allow boot time control of Pegatron ALS sensor Platform: samsung_laptop: add support for X520 machines. platform: samsung_laptop: add dmi information for Samsung R700 laptops hp_accel: Add axis-mapping for HP ProBook / EliteBook hp_accel: Add a new PNP id WMI: properly cleanup devices to avoid crashes ideapad: remove sysfs node for cfg ideapad: add debugfs support ideapad: add event for Novo key ideapad: change parameter of ideapad_sync_rfk_state ideapad: define vpc commands ...
2011-10-24acer-wmi: replaced the hard coded bitmap by the communication devices bitmap ↵Lee, Chun-Yi
from SMBIOS Before set communication devices state, we need query out all devices state to set the states bitmap. That will be better use the devices bitmap in SMBIOS type Aah instead of hardcode in driver. Tested on Acer Travelmate 8572. Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: check the existence of internal wireless device when set capabilityLee, Chun-Yi
That will be better to check the existence of internal wireless device when we set wireless capability and generate killswitch for it. It can avoid userland access wireless rfkill but the machine doesn't have internal wireless device. Tested on Acer Travelmate 8572 Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: add ACER_WMID_v2 interface flag to represent new notebooksLee, Chun-Yi
There have new acer notebooks' BIOS provide new WMID_GUID3 and ACERWMID_EVENT_GUID methods. Some of machines still keep the old WMID_GUID1 method but more and more machines were already removed old wmi methods from DSDT. So, this patch add a new ACER_WMID_v2 interface flag to represent new acer notebooks, the following is definition: + ACER_WMID: It means this machine only provides WMID_GUID1/2 methods. + ACER_WMID_v2: It means this machine provide new WMID_GUID3 and WMID_EVENT_GUID methods. Some ACER_WMID_v2 machines also provide old WMID_GUID1/2 methods, but we still query/set communication device's state by new WMID_GUID3 method. Tested on Acer Travelmate 8572 Tested on Acer Aspire 4739Z Tested-by: AceLan Kao <acelan.kao@canonical.com> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24sony-laptop:irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: Add rfkill support for Pegatron Lucid tabletAnisse Astier
Add three new rfkill switches in this driver that are specific to Pegatron Lucid tablet. Please note that you might not need all three switches. For example if you don't have a 3G module inside your tablet. Also, on my device, the gpio for the wifi/bt module is connected to the bluetooth line. Therefore to activate your wireless lan interface, you need to use the "pega-bt" rfkill switch. Finally, the rfkill switch only works before the wireless module is loaded the first time. Unloading ath9k doesn't help, a reboot is necessary. Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: pega_accel - Report accelerometer orientation change through udevAnisse Astier
Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: fix module descriptionCorentin Chary
2011-10-24asus-laptop: hide leds on Pegatron LucidCorentin Chary
2011-10-24asus-laptop: Pegatron Lucid accelerometerAndy Ross
Support the built-in accelerometer on the Lucid tablets as a standard 3-axis input device. Signed-off-by: Andy Ross <andy.ross@windriver.com> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: allow boot time control of Pegatron ALS sensorAndy Ross
2011-10-24Platform: samsung_laptop: add support for X520 machines.Tommaso Massimi
my samsung laptop would be very happy if you add these lines to the file drivers/platform/x86/samsung-laptop.c Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24platform: samsung_laptop: add dmi information for Samsung R700 laptopsStefan Beller
My DMI model is this: >dmesg |grep DMI [ 0.000000] DMI present. [ 0.000000] DMI: SAMSUNG ELECTRONICS CO., LTD. SR700/SR700, BIOS 04SR 02/20/2008 adding dmi information of Samsung R700 laptops This adds the dmi information of Samsungs R700 laptops. Signed-off-by: Stefan Beller <stefanbeller@googlemail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24hp_accel: Add axis-mapping for HP ProBook / EliteBookTakashi Iwai
Add the corrected axis-mapping for some HP laptops. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24hp_accel: Add a new PNP idTakashi Iwai
New HP laptops assign a new PNP id "HPQ6000" for DriveGuard. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24WMI: properly cleanup devices to avoid crashesDmitry Torokhov
We need to remove devices that we destroy from the list, otherwise we'll crash if there are more than one "_WDG" methods in DSDT. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=32052 Tested-by: Ilya Tumaykin <librarian_rus@yahoo.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24ideapad: remove sysfs node for cfgIke Panhc
Replaced by the one in debugfs. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24ideapad: add debugfs supportIke Panhc
Add two nodes in debugfs which shows cfg value and its meaning, and status info read from VPC2004. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24ideapad: add event for Novo keyIke Panhc
Novo key is the Lenovo define key on every ideapads, which has two definition. Long press and short click. Driver will report KEY_PROG1 on short click and KEY_PROG2 when long press. On pre-install OS for ideapads there are application waiting for the event and there is no such application for Linux yet, so I think to report KEY_PROG is fine in anyway. Also change the scancode from hex to decimal because they are related to vpc bit in notify function which is in decimal. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24ideapad: change parameter of ideapad_sync_rfk_stateIke Panhc
This could save us a local variable. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24ideapad: define vpc commandsIke Panhc
Better then write hex number everywhere. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24intel_scu_ipcutil: fix major device number handlingKirill A. Shutemov
We need to save major device number to be able to use it for unregister_chrdev() in ipc_module_exit(). ipc_module_init() must return 0 on success, not major device number. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24[PATCH] ideapad: Check if acpi already handle backlight power to avoid a ↵Rene Bollford
page fault This patch avoid a page fault in the ideapad-laptop extras when turning the backlight power on or off. Signed-off-by: Rene Bolldorf <xsecute@googlemail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: check wireless capability flag before register rfkillLee, Chun-Yi
There will be better to check the wireless capability flag (ACER_CAP_WIRELESS) before register wireless rfkill because maybe the machine doesn't have wifi module or the module removed by user. Tested on Acer Travelmate 8572 Tested on Acer Aspire 4739Z Tested-by: AceLan Kao <acelan.kao@canonical.com> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24platform-drivers-x86: asus-laptop: fix wrong test for successful registered ↵Axel Lin
led_classdev device_create returns &struct device pointer on success, or ERR_PTR() on error. Thus if led_classdev_register fails, led_cdev->dev is always not NULL. Thus to unregister a successful registered led_classdev, we should check IS_ERR_OR_NULL macro for led_cdev->dev instead of checking if led_cdev->dev is NULL or not. we use IS_ERR_OR_NULL instead of IS_ERR because if we havn't call led_classdev_register, the led_cdev->dev is NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24platform-drivers-x86: asus-wmi: fix resource leak in asus_wmi_led_exitAxel Lin
This patch fixes wrong test for successful registered led_classdev, and also fixes a leak due to missing led_classdev_unregister call for asus->kbd_led in asus_wmi_led_exit. device_create returns &struct device pointer on success, or ERR_PTR() on error. Thus if led_classdev_register fails, led_cdev->dev is always not NULL. Thus to unregister a successful registered led_classdev, we should check (!IS_ERR_OR_NULL(asus->tpd_led.dev)) instead of (asus->tpd_led.dev). we use IS_ERR_OR_NULL instead of IS_ERR because if we havn't call led_classdev_register, the led_cdev->dev is NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24platform-drivers-x86: eeepc-laptop: fix wrong test for successful registered ↵Axel Lin
led_classdev device_create returns &struct device pointer on success, or ERR_PTR() on error. Thus if led_classdev_register fails, led_cdev->dev is always not NULL. If IS_ERR(eeepc->tpd_led.dev) is ture, it means led_classdev_register fails. If (asus->tpd_led.dev) is NULL, it means we call eeepc_led_exit before calling led_classdev_register for &eeepc->tpd_led. We only want to call led_classdev_unregister for sucessfully registered led_classdev, then we should check (!IS_ERR_OR_NULL(eeepc->tpd_led.dev)). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: Pegatron Lucid ALS sensorAndy Ross
Ambient light sensor for Pegatron Lucid. Supports pre-existing ls_switch sysfs interface to en/disable automatic control, and exports the brightness from the device as "ls_value". Signed-off-by: Andy Ross <andy.ross@windriver.com> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: Platform detection for Pegatron LucidAndy Ross
Recognize the Pegatron Lucid tablets by their method signatures. Signed-off-by: Andy Ross <andy.ross@windriver.com> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24Platform: Detect samsung laptop quirk when initial level is zeroJohn Serock
This patch depends on the "Platform: Brightness quirk for samsung laptop driver" patch from Jason Stubbs. This patch adds a check for an initial brightness level of 0; if the level is 0, this patch changes the brightness level to 1 before the driver attempts to detect the brightness quirk. The Samsung N150 netbook experiences the brightness quirk. Without Jason's patch, the only brightness levels available on the N150 are 0, 1, and 8. This patch ensures that, when the initial brightness level is 0, the samsang-laptop driver detects the brightness quirk on the N150, thereby making brightness levels 0 through 8 available. Signed-off-by: John Serock <john.serock@gmail.com> Acked-by: Jason Stubbs <jasonbstubbs@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: Add wireless quirk for Lenovo 3000 N200Seth Forshee
This quirk fixes the wlan rfkill status on this machine. Without it, wlan is permanently soft blocked whenever acer-wmi is loaded. BugLink: https://bugs.launchpad.net/bugs/857297 Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Reviewed-by: Lee, Chun-Yi <jlee@novell.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24dell-laptop: support Synaptics/Alps touchpad ledAceLan Kao
This patch supports Dell laptop with Synaptics and Alps touchpad chip that with LED to indicate the functionality of touchpad is disabled or enabled. The command for touchpad LED is 0x97, and the data 1 means turn on the touchpad LED, 2 means turn it off. BTW, I add dell_quirks to white list those machines that supports this behavior, so that the code won't affect those who don't have a touchpad LED machine. We can easily to turn it on/off by echo 1 > /sys/class/leds/dell-laptop::touchpad/brightness echo 0 > /sys/class/leds/dell-laptop::touchpad/brightness Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24topstar-latop: ignore 0x82 eventManuel Lauss
Event 0x82 is emitted whenever a backlight event happens (brightness change, backlight on/off). For instance, when display is switched off after a timeout, event 0x82 is emitted, and along with it a keypress which switches the display back on again. This patch adds 0x82 to the event ignore list so that the display stays off when it is automatically switched off. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24toshiba_acpi: Initialize brightness in backlight deviceSeth Forshee
2011-10-24toshiba_acpi: Don't add devices for unsupported featuresSeth Forshee
Test for features up-front to determine whether or not they are supported, and avoid creating devices and proc files for unsupported features. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24toshiba_acpi: Support SPFC as an HCI methodSeth Forshee
Some Toshiba models, notably those with the TOS1900 device, use the SPFC method for HCI calls instead of GHCI. Test for this method if GHCI isn't found, and if it exists use it for all HCI calls. Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24toshiba_acpi: Use handle for HCI callsSeth Forshee
Now that we're using an acpi driver we already have a handle to the namespace of the HCI call, so there's no need to test various paths to the HCI call or even be aware of the path at all. Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24toshiba_acpi: Fix up return codesSeth Forshee
Many routines are returning success on failure, and those that are indicating failure frequently return incorrect error codes. Fix these up throughout the driver. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
