commit d6fa71f1c003fb2bc824276bb424a4171f9a717f upstream.
Add missing terminating entry to peaq_dmi_table.
Fixes: 3b95206110a2 ("platform/x86: peaq-wmi: Add DMI check before ...")
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit 3b95206110a2c13076c3a7fa8ddeae36c2dbcf42 upstream.
It seems that the WMI GUID used by the PEAQ 2-in-1 WMI hotkeys is not
as unique as a GUID should be and is used on some other devices too.
This is causing spurious key-press reports on these other devices.
This commits adds a DMI check to the PEAQ 2-in-1 WMI hotkeys driver to
ensure that it is actually running on a PEAQ 2-in-1, fixing the
spurious key-presses on these other devices.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1497861
BugLink: https://bugzilla.suse.com/attachment.cgi?id=743182
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
Currently, update_no_reboot_bit() function implemented in this driver
uses mutex_lock() to protect its register updates. But this function is
called with in atomic context in iTCO_wdt_start() and iTCO_wdt_stop()
functions in iTCO_wdt.c driver, which in turn causes "sleeping into
atomic context" issue. This patch fixes this issue by replacing the
mutex_lock() with spin_lock() to protect the GCR read/write/update APIs.
Fixes: 9d855d4 ("platform/x86: intel_pmc_ipc: Fix iTCO_wdt GCS memory mapping failure")
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kupuswamy@linux.intel.com>
This patch cleans up unnecessary free/alloc calls in ipc_plat_probe(),
ipc_pci_probe() and ipc_plat_get_res() functions by using devm_*
calls.
This patch also adds proper error handling for failure cases in
ipc_pci_probe() function.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
[andy: fixed style issues, missed devm_free_irq(), removed unnecessary log message]
My Fujitsu-Siemens Lifebook S6120 doesn't have the FUJ02E3 device,
but it does have FUJ02B1. That means we do register the backlight
device (and it even seems to work), but the code will oops as soon
as we try to set the backlight brightness because it's trying to
call call_fext_func() with a NULL device. Let's just skip those
function calls when the FUJ02E3 device is not present.
Cc: Jonathan Woithe <jwoithe@just42.net>
Cc: Andy Shevchenko <andy@infradead.org>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: <stable@vger.kernel.org> # 4.13.x
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
... and __initconst if applicable.
Based on similar work for an older kernel in the Grsecurity patch.
[JD: fix toshiba-wmi build]
[JD: add htcpen]
[JD: move __initconst where checkscript wants it]
Signed-off-by: Jean Delvare <jdelvare@suse.de>
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"Several fixes from static analysis and message noise reduction.
Correct WMI core and related drivers to evaluate instance number 0x0
in accordance with the documentation. Add intel-telemetry support for
Gemini Lake. Various individual driver fixes noted below.
dell-wmi:
- Update dell_wmi_check_descriptor_buffer() to new model
intel-vbtn:
- reduce unnecessary messages for normal users
- match power button on press rather than release
intel-hid:
thinkpad_acpi:
- Fix warning about deprecated hwmon_device_register
wmi:
- Fix check for method instance number
ideapad-laptop:
- Expose conservation mode switch
intel_pmc_core:
- Make the driver PCH family agnostic
peaq-wmi:
- Evaluate wmi method with instance number 0x0
- silence a static checker warning
mxm-wmi:
asus-wmi:
intel_scu_ipc:
- make intel_scu_ipc_pdata_t const
intel_mid_powerbtn:
- make mid_pb_ddata const
- fix error return code in mid_pb_probe()
hp-wmi:
- Remove unused macro helper
- Correctly determine method id in WMI calls
dell-wmi:
- Fix driver interface version query
intel_telemetry:
- remove redundant macro definition
- Add GLK PSS Event Table
alienware-wmi:
- fix format string overflow warning
ibm_rtl:
- remove unnecessary static in ibm_rtl_write()
msi-wmi:
- remove unnecessary static in msi_wmi_notify()"
* tag 'platform-drivers-x86-v4.14-1' of git://git.infradead.org/linux-platform-drivers-x86: (23 commits)
platform/x86: dell-wmi: Update dell_wmi_check_descriptor_buffer() to new model
platform/x86: intel-vbtn: reduce unnecessary messages for normal users
platform/x86: intel-hid: reduce unnecessary messages for normal users
platform/x86: thinkpad_acpi: Fix warning about deprecated hwmon_device_register
platform/x86: wmi: Fix check for method instance number
platform/x86: ideapad-laptop: Expose conservation mode switch
platform/x86: intel_pmc_core: Make the driver PCH family agnostic
platform/x86: peaq-wmi: Evaluate wmi method with instance number 0x0
platform/x86: mxm-wmi: Evaluate wmi method with instance number 0x0
platform/x86: asus-wmi: Evaluate wmi method with instance number 0x0
platform/x86: intel_scu_ipc: make intel_scu_ipc_pdata_t const
platform/x86: intel_mid_powerbtn: make mid_pb_ddata const
platform/x86: intel_mid_powerbtn: fix error return code in mid_pb_probe()
platform/x86: hp-wmi: Remove unused macro helper
platform/x86: hp-wmi: Correctly determine method id in WMI calls
platform/x86: intel-vbtn: match power button on press rather than release
platform/x86: dell-wmi: Fix driver interface version query
platform/x86: intel_telemetry: remove redundant macro definition
platform/x86: intel_telemetry: Add GLK PSS Event Table
platform/x86: alienware-wmi: fix format string overflow warning
* pm-sleep:
ACPI / PM: Check low power idle constraints for debug only
PM / s2idle: Rename platform operations structure
PM / s2idle: Rename ->enter_freeze to ->enter_s2idle
PM / s2idle: Rename freeze_state enum and related items
PM / s2idle: Rename PM_SUSPEND_FREEZE to PM_SUSPEND_TO_IDLE
ACPI / PM: Prefer suspend-to-idle over S3 on some systems
platform/x86: intel-hid: Wake up Dell Latitude 7275 from suspend-to-idle
PM / suspend: Define pr_fmt() in suspend.c
PM / suspend: Use mem_sleep_labels[] strings in messages
PM / sleep: Put pm_test under CONFIG_PM_SLEEP_DEBUG
PM / sleep: Check pm_wakeup_pending() in __device_suspend_noirq()
PM / core: Add error argument to dpm_show_time()
PM / core: Split dpm_suspend_noirq() and dpm_resume_noirq()
PM / s2idle: Rearrange the main suspend-to-idle loop
PM / timekeeping: Print debug messages when requested
PM / sleep: Mark suspend/hibernation start and finish
PM / sleep: Do not print debug messages by default
PM / suspend: Export pm_suspend_target_state
This converts dell_wmi_check_descriptor_buffer() to the new driver
model interface and puts the interface version in dell_wmi_priv
where it belongs.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
Unsupported events is only useful for developers and does not meaningful
for users. Using dev_dbg makes more sense and reduces noise in kernel
messages.
Signed-off-by: Alex Hung <alex.hung@canonical.com>
messages.
Use hwmon_device_register_with_groups instead of deprecated
hwmon_device_register and fix a dmesg warning.
This patch however changes the userspace API.
hwmon_device_register_with_groups takes `hwmon' name as an argument and
creates a name file in the `hwmon' device, not in the `platform_device'.
This allows us to remove custom `name' device attribute, but in order to
make lm-sensors happy we also have to move fans and thermal attributes
to the `hwmon' device.
Even though this patch changes userspace API, it's still compatible with
the lm-sensors. Starting with lm-sensors 3.0 (circa 2007), it looks at
both hwmon and the backing device for the name and other attributes.
before:
$ cat /sys/devices/platform/thinkpad_hwmon/{name,fan1_input}
thinkpad
2007
$ cat /sys/devices/platform/thinkpad_hwmon/hwmon/hwmon1/{name,fan1_input}
cat: /sys/devices/platform/thinkpad_hwmon/hwmon/hwmon1/name: No such file or directory
cat: /sys/devices/platform/thinkpad_hwmon/hwmon/hwmon1/fan1_input: No such file or directory
$ cat /sys/class/hwmon/hwmon1/{name,fan1_input}
cat: /sys/class/hwmon/hwmon1/name: No such file or directory
cat: /sys/class/hwmon/hwmon1/fan1_input: No such file or directory
$ sensors
thinkpad-isa-0000
Adapter: ISA adapter
fan1: 3533 RPM
after:
cat: /sys/devices/platform/thinkpad_hwmon/name: No such file or directory
cat: /sys/devices/platform/thinkpad_hwmon/fan1_input: No such file or directory
thinkpad
3478
thinkpad
3478
$ sensors
thinkpad-isa-0000
fan1: 3489 RPM
$ sensors -v
sensors version 3.4.0 with libsensors version 3.4.0
Signed-off-by: Stanislav Fomichev <kernel@fomichev.me>
[dvhart: cleaned up commit log, bumped version to 4.14 in the doc change]
instance_count defines number of instances of data block and instance
itself is indexed from zero, which means first instance has number 0.
Therefore check for invalid instance should be non-strict inequality.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
This exposes the battery conservation mode present on some (?) IdeaPads.
The mode is set by calling ACPI method SBMC with argument 3 (on) or
5 (off). Status is reported in bit 5 of the return value of ACPI method
GBMD.
Signed-off-by: Hao Wei Tee <angelsl@in04.sg>
Although this driver did pretty good job in abstracting PCH specific
interfaces, but still there are some loose ends. For example
SLP_S0 counter (for reading SLP_S0 residency), PM config offset (for
checking permissions to read XRAM) and PPFEAR offset (for reading IP
status) is still hardcoded for a specific family of PCH.
This change extended the struct pmc_reg_map to allow per family
configuration of offsets and bits.
No functional change is expected with this change. This change allows
seamless additions to new PCH and create a baseline for other platform
specific extensions.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
According to Hans de Goede, WMI interface of thh peaq-wmi module has 10
instances but corresponding ACPI WMBC method does not check Arg0 (instance
number) at all. Therefore evaluate WMI method with first instance number
(0x0) instead of second (0x1).
Cc: Hans de Goede <hdegoede@redhat.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
According to MXM 2.1 specification, there is the only one instance of the
WMI GUID F6CB5C3C-9CAE-4EBD-B577-931EA32A2CC0 and so it is instance 0x0.
MXM 2.1 specification:
https://lekensteyn.nl/files/docs/mxm-2.1-software-spec.pdf
_WDG dump:
// Methods GUID {F6CB5C3C-9CAE-4EBD-B577-931EA32A2CC0}
0x3C, 0x5C, 0xCB, 0xF6, 0xAE, 0x9C, 0xBD, 0x4E, 0xB5, 0x77, 0x93,
0x1E, 0xA3, 0x2A, 0x2C, 0xC0,
0x4D, 0x58, // Object ID "MX" = method "WMMX"
1, // Instance Count
0x02, // Flags (WMIACPI_REGFLAG_METHOD)
According to available DSDT dump from Asus machine, there is the only one
instance of the WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 and so it is
0x0. Moreover corresponding method WMBC does not check Arg0 (instance
number) at all.
DSDT dump is available at:
https://lwn.net/Articles/391249/
_WDG dump:
0xD0, 0x5E, 0x84, 0x97, 0x6D, 0x4E, 0xDE, 0x11, 0x8A, 0x39, 0x08,
0x00, 0x20, 0x0C, 0x9A, 0x66,
0x42, 0x43, // Object ID "BC" = method "WMBC"
0x01, // Instance count
0x02, // Flags
Make these const as they are only used during a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
platform_get_irq() returns an error code, but the intel_mid_powerbtn
driver ignores it and always returns -EINVAL. This is not correct and,
prevents -EPROBE_DEFER from being propagated properly.
Print error message and propagate the return value of platform_get_irq
on failure.
This issue was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
The commit d8193cff3390
("platform/x86: hp-wmi: Standardize enum usage for constants")
introduced a macro that had been never used.
Remove it.
Signed-off-by: Paulo Alcantara <pcacjr@zytor.com>
[andy wrote commit message]
The WMI queries are performed by evaluating the WMPV() method from ACPI
DSDT tables, and it takes three arguments: instance index, method id and
input data (buffer).
Currently the method id is hard-coded to 0x3 in hp_wmi_perform_query()
which means that it will perform WMI calls that expect an output data of
size 0x80 (128). The output size is usually OK for the WMI queries we
perform, however it would be better to pick the correct one before
evaluating the WMI method.
Which correct method id to choose can be figured out by looking at the
following ASL code from WVPI() method:
Name (PVSZ, Package (0x05)
Zero,
0x04,
0x80,
0x0400,
0x1000
Store (Zero, Local0)
If (LAnd (LGreaterEqual (Arg1, One), LLessEqual (Arg1, 0x05)))
Store (DerefOf (Index (PVSZ, Subtract (Arg1, One))), Local0)
Arg1 is the method id and PVSZ is the package used to index the
corresponding output size; 1 -> 0, 2 -> 4, 3 -> 128, 4 -> 1024, 5 ->
4096.
This patch maps the output size passed in hp_wmi_perform_query() to the
correct method id before evaluating the WMI method.
This fixes a problem where the system gets stuck in a loop
unable to wakeup via power button in s2idle.
The problem happens because:
- press power button:
- system emits 0xc0 (power press), event ignored
- system emits 0xc1 (power release), event processed,
emited as KEY_POWER
- set wakeup_mode to true
- system goes to s2idle
- system emits 0xc0 (power press), wakeup_mode is true,
system wakes
emited as KEY_POWER
- system goes to s2idle again
To avoid this situation, process the presses (which matches what
intel-hid does too).
Verified on an Dell XPS 9365
Signed-off-by: Mario Limonciello <mario.limonciello@dell.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
emited as KEY_POWER
system wakes
emited as KEY_POWER
When I converted dell-wmi to the new bus infrastructure, I left the
call to dell_wmi_check_descriptor_buffer() in dell_wmi_init(). This
could cause two problems:
- An error message when loading the driver on a system without
dell-wmi. We'd try to read the event descriptor even if the WMI
GUID wasn't there.
- A possible race if dell-wmi was loaded manually before wmi was
fully initialized.
Fix it by moving the call to the probe function where it belongs.
Fixes: bff589be59c5 ("platform/x86: dell-wmi: Convert to the WMI bus infrastructure")
On Dell Latitude 7275 the 5-button array is not exposed in the
ACPI tables, but still notifies are sent to the Intel HID device
object (device ID INT33D5) in response to power button actions while
suspended to idle. However, they are currently ignored as the
intel-hid driver is not prepared to take care of them.
As a result, power button wakeup from suspend-to-idle doesn't work
on this platform, but suspend-to-idle is the only reliable suspend
variant on it (the S3 implementation in the platform firmware turns
out to be broken), so it would be good to handle it properly.
For this reason, add an upfront check against the power button press
event (0xCE) to notify_handler() in the wakeup mode which allows it
to catch the power button wakeup notification on the affected
platform (even though priv->array is NULL on it) and should not
change the behavior on platforms with priv->array present (because
priv->array contains the event in question in those cases).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196115
Tested-by: Jérôme de Bretagne <jerome.debretagne@gmail.com>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-By: Mario Limonciello <mario.limonciello@dell.com>
GUID wasn't there.
fully initialized.
Telemetry driver includes intel_telemetry.h which defines
TELEM_MAX_OS_ALLOCATED_EVENTS already.
Signed-off-by: Rajneesh Bhardwaj <rajneesh.bhardwaj@intel.com>
Reviewed-by: Souvik K Chakravarty <souvik.k.chakravarty@intel.com>
Some of the Primary Subsystem events differ on Gemini Lake but the IOSS
events remain same. This patch adds the updated PSS event table to enable
Telemetry driver on Gemini Lake.
Signed-off-by: Shanth Murthy <shanth.murthy@intel.com>
gcc points out a possible format string overflow for a large value of 'zone':
drivers/platform/x86/alienware-wmi.c: In function 'alienware_wmi_init':
drivers/platform/x86/alienware-wmi.c:461:24: error: '%02X' directive writing between 2 and 8 bytes into a region of size 6 [-Werror=format-overflow=]
sprintf(buffer, "zone%02X", i);
drivers/platform/x86/alienware-wmi.c:461:19: note: directive argument in the range [0, 2147483646]
drivers/platform/x86/alienware-wmi.c:461:3: note: 'sprintf' output between 7 and 13 bytes into a destination of size 10
This replaces the 'int' variable with an 'u8' to make sure
it always fits, renaming the variable to 'zone' for clarity.
Unfortunately, gcc-7.1.1 still warns about it with that change, which
seems to be unintended by the gcc developers. I have opened a bug
against gcc with a reduced test case. As a workaround, I also
change the format string to use "%02hhX", which shuts up the
warning in that version.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81483
Link: https://patchwork.ozlabs.org/patch/788415/
Suggested-by: Andy Shevchenko <andy@infradead.org>
[andy: added empty lines after u8 zone; definitions]
Remove unnecessary static on local variable cmd_port_val. Such variable
is initialized before being used, on every execution path throughout
the function. The static has no benefit and, removing it reduces the
object file size.
This issue was detected using Coccinelle and the following semantic patch:
https://github.com/GustavoARSilva/coccinelle/blob/master/static/static_unused.cocci
In the following log you can see a difference in the object file size.
This log is the output of the size command, before and after the code
change:
before:
3932 3440 512 7884 1ecc drivers/platform/x86/ibm_rtl.o
after:
3887 3384 448 7719 1e27 drivers/platform/x86/ibm_rtl.o
Remove unnecessary static on local variable _key_. Such variable is
In the following log you can see a significant difference in the object
file size. Also, there is a significant difference in the bss segment.
change:
before:
6530 3736 320 10586 295a drivers/platform/x86/msi-wmi.o
after:
6494 3648 256 10398 289e drivers/platform/x86/msi-wmi.o
There is a harmless static checker warning here that unsigned values are
always >= 0. The code looks like:
if (peaq_ignore_events_counter && --peaq_ignore_events_counter >= 0)
The first part of the condition ensures that we never wrap around so the
code works as intended. I've tweaked it slightly to avoid the warning.
The order of resource deallocations is messed up in acpi_wmi_init().
It should be vice versa.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
The new driver fails to build without INPUT_POLLDEV
drivers/platform/x86/peaq-wmi.o: In function `peaq_wmi_exit':
peaq-wmi.c:(.exit.text+0x1c): undefined reference to `input_unregister_polled_device'
drivers/platform/x86/peaq-wmi.o: In function `peaq_wmi_init':
peaq-wmi.c:(.init.text+0x23): undefined reference to `input_allocate_polled_device'
peaq-wmi.c:(.init.text+0x18e): undefined reference to `input_register_polled_device'
For some reason, all other drivers that need this use 'select'
here rather than 'depends on', so I'm doing the same.
Fixes: 13bb0fd5519d ("platform/x86: peaq-wmi: Add new peaq-wmi driver")
Pull MIPS updates from Ralf Baechle:
"Boston platform support:
- Document DT bindings
- Add CLK driver for board clocks
CM:
- Avoid per-core locking with CM3 & higher
- WARN on attempt to lock invalid VP, not BUG
CPS:
- Select CONFIG_SYS_SUPPORTS_SCHED_SMT for MIPSr6
- Prevent multi-core with dcache aliasing
- Handle cores not powering down more gracefully
- Handle spurious VP starts more gracefully
DSP:
- Add lwx & lhx missaligned access support
eBPF:
- Add MIPS support along with many supporting change to add the
required infrastructure
Generic arch code:
- Misc sysmips MIPS_ATOMIC_SET fixes
- Drop duplicate HAVE_SYSCALL_TRACEPOINTS
- Negate error syscall return in trace
- Correct forced syscall errors
- Traced negative syscalls should return -ENOSYS
- Allow samples/bpf/tracex5 to access syscall arguments for sane
traces
- Cleanup from old Kconfig options in defconfigs
- Fix PREF instruction usage by memcpy for MIPS R6
- Fix various special cases in the FPU eulation
- Fix some special cases in MIPS16e2 support
- Fix MIPS I ISA /proc/cpuinfo reporting
- Sort MIPS Kconfig alphabetically
- Fix minimum alignment requirement of IRQ stack as required by
ABI / GCC
- Fix special cases in the module loader
- Perform post-DMA cache flushes on systems with MAARs
- Probe the I6500 CPU
- Cleanup cmpxchg and add support for 1 and 2 byte operations
- Use queued read/write locks (qrwlock)
- Use queued spinlocks (qspinlock)
- Add CPU shared FTLB feature detection
- Handle tlbex-tlbp race condition
- Allow storing pgd in C0_CONTEXT for MIPSr6
- Use current_cpu_type() in m4kc_tlbp_war()
- Support Boston in the generic kernel
Generic platform:
- yamon-dt: Pull YAMON DT shim code out of SEAD-3 board
- yamon-dt: Support > 256MB of RAM
- yamon-dt: Use serial* rather than uart* aliases
- Abstract FDT fixup application
- Set RTC_ALWAYS_BCD to 0
- Add a MAINTAINERS entry
core kernel:
- qspinlock.c: include linux/prefetch.h
Loongson 3:
- Add support
Perf:
- Add I6500 support
SEAD-3:
- Remove GIC timer from DT
- Set interrupt-parent per-device, not at root node
- Fix GIC interrupt specifiers
SMP:
- Skip IPI setup if we only have a single CPU
VDSO:
- Make comment match reality
- Improvements to time code in VDSO"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (86 commits)
locking/qspinlock: Include linux/prefetch.h
MIPS: Fix MIPS I ISA /proc/cpuinfo reporting
MIPS: Fix minimum alignment requirement of IRQ stack
MIPS: generic: Support MIPS Boston development boards
MIPS: DTS: img: Don't attempt to build-in all .dtb files
clk: boston: Add a driver for MIPS Boston board clocks
dt-bindings: Document img,boston-clock binding
MIPS: Traced negative syscalls should return -ENOSYS
MIPS: Correct forced syscall errors
MIPS: Negate error syscall return in trace
MIPS: Drop duplicate HAVE_SYSCALL_TRACEPOINTS select
MIPS16e2: Provide feature overrides for non-MIPS16 systems
MIPS: MIPS16e2: Report ASE presence in /proc/cpuinfo
MIPS: MIPS16e2: Subdecode extended LWSP/SWSP instructions
MIPS: MIPS16e2: Identify ASE presence
MIPS: VDSO: Fix a mismatch between comment and preprocessor constant
MIPS: VDSO: Add implementation of gettimeofday() fallback
MIPS: VDSO: Add implementation of clock_gettime() fallback
MIPS: VDSO: Fix conversions in do_monotonic()/do_monotonic_coarse()
MIPS: Use current_cpu_type() in m4kc_tlbp_war()
Pull more x86 platform driver updates from Darren Hart:
"Add new platform matches for silead_dmi and ideapad-laptop. Several
constify patches for attribute_group structures. Fixes for peaq-wmi
and intel_telemetry.
silead_dmi:
- Add entry for Ployer Momo7w tablet touchscreen
- Add touchscreen info for I.T.Works TW891 2-in-1
toshiba_acpi:
- constify attribute_group structures.
asus-wmi:
panasonic-laptop:
alienware-wmi:
samsung-laptop:
compal-laptop:
fujitsu-laptop:
- add NULL check on devm_kzalloc() return value
peaq-wmi:
- Fix peaq_ignore_events_counter handling off by 1
ideapad-laptop:
- Fix indentation in DMI table
- Add several models to no_hw_rfkill
- Add IdeaPad V510-15IKB to no_hw_rfkill
intel_telemetry:
- Add debugfs entry for S0ix residency
intel_telemetry_debugfs:
- fix some error codes in init
- fix oops when load/unload module"
* tag 'platform-drivers-x86-v4.13-2' of git://git.infradead.org/linux-platform-drivers-x86:
platform/x86: silead_dmi: Add entry for Ployer Momo7w tablet touchscreen
platform/x86: toshiba_acpi: constify attribute_group structures.
platform/x86: asus-wmi: constify attribute_group structures.
platform/x86: panasonic-laptop: constify attribute_group structures.
platform/x86: alienware-wmi: constify attribute_group structures.
platform/x86: samsung-laptop: constify attribute_group structures.
platform/x86: compal-laptop: constify attribute_group structures.
platform/x86: fujitsu-laptop: constify attribute_group structures.
platform/x86: peaq-wmi: Fix peaq_ignore_events_counter handling off by 1
platform/x86: fujitsu-laptop: add NULL check on devm_kzalloc() return value
platform/x86: silead_dmi: Add touchscreen info for I.T.Works TW891 2-in-1
platform/x86: ideapad-laptop: Fix indentation in DMI table
platform/x86: ideapad-laptop: Add several models to no_hw_rfkill
platform/x86: ideapad-laptop: Add IdeaPad V510-15IKB to no_hw_rfkill
platform/x86: intel_telemetry: Add debugfs entry for S0ix residency
platform/x86: intel_telemetry_debugfs: fix some error codes in init
platform/x86: intel_telemetry_debugfs: fix oops when load/unload module
This Ployer Momo7w revision has the same hardware as the Trekstor
ST70416-6, so we re-use the surftab_wintron70_st70416_6_data.
git://git.kernel.org/pub/scm/linux/kernel/git/bleung/chrome-platform
Pull chrome platform updates from Benson Leung:
"Changes in this pull request are around catching up cros_ec with the
internal chromeos-kernel versions of cros_ec, cros_ec_lpc, and
cros_ec_lightbar.
Also, switching maintainership from olof to bleung"
* tag 'chrome-platform-for-linus-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/bleung/chrome-platform:
platform/chrome : Add myself as Maintainer
platform/chrome: cros_ec_lightbar - hide unused PM functions
cros_ec: Don't signal wake event for non-wake host events
cros_ec: Fix deadlock when EC is not responsive at probe
cros_ec: Don't return error when checking command version
platform/chrome: cros_ec_lightbar - Avoid I2C xfer to EC during suspend
platform/chrome: cros_ec_lightbar - Add userspace lightbar control bit to EC
platform/chrome: cros_ec_lightbar - Control of suspend/resume lightbar sequence
platform/chrome: cros_ec_lightbar - Add lightbar program feature to sysfs
platform/chrome: cros_ec_lpc: Add MKBP events support over ACPI
platform/chrome: cros_ec_lpc: Add power management ops
platform/chrome: cros_ec_lpc: Add support for GOOG004 ACPI device
platform/chrome: cros_ec_lpc: Add support for mec1322 EC
platform/chrome: cros_ec_lpc: Add R/W helpers to LPC protocol variants
mfd: cros_ec: Add support for dumping panic information
cros_ec_debugfs: Pass proper struct sizes to cros_ec_cmd_xfer()
mfd: cros_ec: add debugfs, console log file
mfd: cros_ec: Add EC console read structures definitions
mfd: cros_ec: Add helper for event notifier.
attribute_groups are not supposed to change at runtime. All functions
working with attribute_groups provided by <linux/sysfs.h> work
with const attribute_group. So mark the non-const structs as const.
File size before:
26360 1072 24 27456 6b40 drivers/platform/x86/toshiba_acpi.o
File size After adding 'const':
26424 1008 24 27456 6b40 drivers/platform/x86/toshiba_acpi.o
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
File size before:
13140 840 1 13981 369d drivers/platform/x86/asus-wmi.o
13268 712 1 13981 368d drivers/platform/x86/asus-wmi.o
File size before:
2505 600 4 3109 c25 drivers/platform/x86/panasonic-laptop.o
2569 536 4 3109 c25 drivers/platform/x86/panasonic-laptop.o
File size before:
6932 1016 48 7996 1f3c drivers/platform/x86/alienware-wmi.o
7060 888 48 7996 1f64 drivers/platform/x86/alienware-wmi.o
File size before:
8710 5452 23 14185 3769 drivers/platform/x86/samsung-laptop.o
8774 5388 23 14185 3769 drivers/platform/x86/samsung-laptop.o
File size before:
6781 6144 34 12959 329f drivers/platform/x86/compal-laptop.o
6845 6080 34 12959 329f drivers/platform/x86/compal-laptop.o
File size before:
7474 1205 24 8703 21ff drivers/platform/x86/fujitsu-laptop.o
7538 1141 24 8703 21ff drivers/platform/x86/fujitsu-laptop.o
Reviewed-by: Jonathan Woithe <jwoithe@just42.net>
If peaq_ignore_events_counter gets set to 1 we should skip polling 1
time, rather then ignoring it.
