[ Upstream commit dece3c2a320b0a6d891da6ff774ab763969b6860 ]
When call function hwmon_device_register failed, use the actual
return value instead of always -ENOMEM.
Fixes: 64f09aa967e1 ("MIPS: Loongson-3: Add CPU Hwmon platform driver")
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
Signed-off-by: Paul Burton <paulburton@kernel.org>
Cc: James Hogan <jhogan@kernel.org>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: linux-mips@vger.kernel.org
[ Upstream commit 6d1f8b3d75419a8659ac916a1e9543bb3513a882 ]
The "out_data" variable is uninitialized at the point. Originally, this
used to print "status" instead and that seems like the correct thing to
print.
Fixes: bc2ef884320b ("alienware-wmi: For WMAX HDMI method, introduce a way to query HDMI cable status")
Reviewed-by: Mario Limonciello <mario.limonciello@dell.com>
[ Upstream commit 98e2630284ab741804bd0713e932e725466f2f84 ]
Currently the kfree of output.pointer can be potentially freeing
an uninitalized pointer in the case where out_data is NULL. Fix this
by reworking the case where out_data is not-null to perform the
ACPI status check and also the kfree of outpoint.pointer in one block
and hence ensuring the pointer is only freed when it has been used.
Also replace the if (ptr != NULL) idiom with just if (ptr).
Fixes: ff0e9f26288d ("platform/x86: alienware-wmi: Correct a memory leak")
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
[ Upstream commit c355ec651a8941864549f2586f969d0eb7bf499a ]
In the function wmi_dev_match() the variable id is dereferenced without
first performing a NULL check. The variable can for example be NULL if
a WMI driver is registered without specifying the id_table field in
struct wmi_driver.
Add a NULL check and return that the driver can't handle the device if
the variable is NULL.
Fixes: 844af950da94 ("platform/x86: wmi: Turn WMI into a bus driver")
Signed-off-by: Mattias Jacobsson <2pi@mok.nu>
commit 176a7fca81c5090a7240664e3002c106d296bf31 upstream.
Some of ASUS laptops like UX431FL keyboard backlight cannot be set to
brightness 0. According to ASUS' information, the brightness should be
0x80 ~ 0x83. This patch fixes it by following the logic.
Fixes: e9809c0b9670 ("asus-wmi: add keyboard backlight support")
Signed-off-by: Jian-Hong Pan <jian-hong@endlessm.com>
Reviewed-by: Daniel Drake <drake@endlessm.com>
commit e8796c6c69d129420ee94a1906b18d86b84644d4 upstream.
The CONNECT X300 uses the PMC clock for on-board components and gets
stuck during boot if the clock is disabled. Therefore, add this
device to the critical systems list.
Tested on CONNECT X300.
Fixes: 648e921888ad ("clk: x86: Stop marking clocks as CLK_IS_CRITICAL")
Signed-off-by: Michael Haener <michael.haener@siemens.com>
commit 133b2acee3871ae6bf123b8fe34be14464aa3d2c upstream.
At least on the HP Envy x360 15-cp0xxx model the WMI interface
for HPWMI_FEATURE2_QUERY requires an outsize of at least 128 bytes,
otherwise it fails with an error code 5 (HPWMI_RET_INVALID_PARAMETERS):
Dec 06 00:59:38 kernel: hp_wmi: query 0xd returned error 0x5
We do not care about the contents of the buffer, we just want to know
if the HPWMI_FEATURE2_QUERY command is supported.
This commits bumps the buffer size, fixing the error.
Fixes: 8a1513b4932 ("hp-wmi: limit hotkey enable")
Cc: stable@vger.kernel.org
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1520703
commit f3e4f3fc8ee9729c4b1b27a478c68b713df53c0c upstream.
The AML code implementing the WMI methods creates a variable length
field to hold the input data we pass like this:
CreateDWordField (Arg1, 0x0C, DSZI)
Local5 = DSZI /* \HWMC.DSZI */
CreateField (Arg1, 0x80, (Local5 * 0x08), DAIN)
If we pass 0 as bios_args.datasize argument then (Local5 * 0x08)
is 0 which results in these errors:
[ 71.973305] ACPI BIOS Error (bug): Attempt to CreateField of length zero (20190816/dsopcode-133)
[ 71.973332] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_OPERAND_VALUE) (20190816/psparse-529)
[ 71.973413] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_OPERAND_VALUE) (20190816/psparse-529)
And in our HPWMI_WIRELESS2_QUERY calls always failing. for read commands
like HPWMI_WIRELESS2_QUERY the DSZI value is not used / checked, except for
read commands where extra input is needed to specify exactly what to read.
So for HPWMI_WIRELESS2_QUERY we can safely pass the size of the expected
output as insize to hp_wmi_perform_query(), as we are already doing for all
other HPWMI_READ commands we send. Doing so fixes these errors.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=197007
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=201981
commit 16245db1489cd9aa579506f64afeeeb13d825a93 upstream.
The HP WMI calls may take up to 128 bytes of data as input, and
the AML methods implementing the WMI calls, declare a couple of fields for
accessing input in different sizes, specifycally the HWMC method contains:
CreateField (Arg1, 0x80, 0x0400, D128)
Even though we do not use any of the WMI command-types which need a buffer
of this size, the APCI interpreter still tries to create it as it is
declared in generoc code at the top of the HWMC method which runs before
the code looks at which command-type is requested.
This results in many of these errors on many different HP laptop models:
[ 14.459261] ACPI Error: Field [D128] at 1152 exceeds Buffer [NULL] size 160 (bits) (20170303/dsopcode-236)
[ 14.459268] ACPI Error: Method parse/execution failed [\HWMC] (Node ffff8edcc61507f8), AE_AML_BUFFER_LIMIT (20170303/psparse-543)
[ 14.459279] ACPI Error: Method parse/execution failed [\_SB.WMID.WMAA] (Node ffff8edcc61523c0), AE_AML_BUFFER_LIMIT (20170303/psparse-543)
This commit increases the size of the data element of the bios_args struct
to 128 bytes fixing these errors.
asus_nb_wmi
[ Upstream commit 401fee8195d401b2b94dee57383f627050724d5b ]
Commit 78f3ac76d9e5 ("platform/x86: asus-wmi: Tell the EC the OS will
handle the display off hotkey") causes the backlight to be permanently off
on various EeePC laptop models using the eeepc-wmi driver (Asus EeePC
1015BX, Asus EeePC 1025C).
The asus_wmi_set_devstate(ASUS_WMI_DEVID_BACKLIGHT, 2, NULL) call added
by that commit is made conditional in this commit and only enabled in
the quirk_entry structs in the asus-nb-wmi driver fixing the broken
display / backlight on various EeePC laptop models.
Cc: João Paulo Rechi Vita <jprvita@endlessm.com>
Fixes: 78f3ac76d9e5 ("platform/x86: asus-wmi: Tell the EC the OS will handle the display off hotkey")
[ Upstream commit db2582afa7444a0ce6bb1ebf1431715969a10b06 ]
This patch adds support for ALS on the Zenbook UX430UQ to the asus_nb_wmi
driver. It also renames "quirk_asus_ux330uak" to "quirk_asus_forceals"
because it is now used for more than one model of computer, and should
thus have a more general name.
Signed-off-by: Kiernan Hager <kah.listaddress@gmail.com>
[andy: massaged commit message, fixed indentation and commas in the code]
commit ad0d315b4d4e7138f43acf03308192ec00e9614d upstream.
The SIMATIC IPC227E uses the PMC clock for on-board components and gets
stuck during boot if the clock is disabled. Therefore, add this device
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
critclk_systems DMI table
commit 9452fbf5c6cf5f470e0748fe7a14a683e7765f7a upstream.
The CB4063 board uses pmc_plt_clk* clocks for ethernet controllers. This
adds it to the critclk_systems DMI table so the clocks are marked as
CLK_CRITICAL and not turned off.
Signed-off-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
[ Upstream commit 160da20b254dd4bfc5828f12c208fa831ad4be6c ]
Fix the issue found while running kernel with the option
CONFIG_DEBUG_TEST_DRIVER_REMOVE.
Driver 'mlx-platform' registers 'i2c_mlxcpld' device and then registers
few underlying 'i2c-mux-reg' devices:
priv->pdev_i2c = platform_device_register_simple("i2c_mlxcpld", nr,
NULL, 0);
for (i = 0; i < ARRAY_SIZE(mlxplat_mux_data); i++) {
priv->pdev_mux[i] = platform_device_register_resndata(
&mlxplat_dev->dev,
"i2c-mux-reg", i, NULL,
0, &mlxplat_mux_data[i],
sizeof(mlxplat_mux_data[i]));
But actual parent of "i2c-mux-reg" device is priv->pdev_i2c->dev and
not mlxplat_dev->dev.
Patch fixes parent device parameter in a call to
platform_device_register_resndata() for "i2c-mux-reg".
It solves the race during initialization flow while 'i2c_mlxcpld.1' is
removing after probe, while 'i2c-mux-reg.0' is still in probing flow:
'i2c_mlxcpld.1' flow: probe -> remove -> probe.
'i2c-mux-reg.0' flow: probe -> ...
[ 12:621096] Registering platform device 'i2c_mlxcpld.1'. Parent at platform
[ 12:621117] device: 'i2c_mlxcpld.1': device_add
[ 12:621155] bus: 'platform': add device i2c_mlxcpld.1
[ 12:621384] Registering platform device 'i2c-mux-reg.0'. Parent at mlxplat
[ 12:621395] device: 'i2c-mux-reg.0': device_add
[ 12:621425] bus: 'platform': add device i2c-mux-reg.0
[ 12:621806] Registering platform device 'i2c-mux-reg.1'. Parent at mlxplat
[ 12:621828] device: 'i2c-mux-reg.1': device_add
[ 12:621892] bus: 'platform': add device i2c-mux-reg.1
[ 12:621906] bus: 'platform': add driver i2c_mlxcpld
[ 12:621996] bus: 'platform': driver_probe_device: matched device i2c_mlxcpld.1 with driver i2c_mlxcpld
[ 12:622003] bus: 'platform': really_probe: probing driver i2c_mlxcpld with device i2c_mlxcpld.1
[ 12:622100] i2c_mlxcpld i2c_mlxcpld.1: no default pinctrl state
[ 12:622293] device: 'i2c-1': device_add
[ 12:627280] bus: 'i2c': add device i2c-1
[ 12:627692] device: 'i2c-1': device_add
[ 12.629639] bus: 'platform': add driver i2c-mux-reg
[ 12.629718] bus: 'platform': driver_probe_device: matched device i2c-mux-reg.0 with driver i2c-mux-reg
[ 12.629723] bus: 'platform': really_probe: probing driver i2c-mux-reg with device i2c-mux-reg.0
[ 12.629818] i2c-mux-reg i2c-mux-reg.0: no default pinctrl state
[ 12.629981] platform i2c-mux-reg.0: Driver i2c-mux-reg requests probe deferral
[ 12.629986] platform i2c-mux-reg.0: Added to deferred list
[ 12.629992] bus: 'platform': driver_probe_device: matched device i2c-mux-reg.1 with driver i2c-mux-reg
[ 12.629997] bus: 'platform': really_probe: probing driver i2c-mux-reg with device i2c-mux-reg.1
[ 12.630091] i2c-mux-reg i2c-mux-reg.1: no default pinctrl state
[ 12.630247] platform i2c-mux-reg.1: Driver i2c-mux-reg requests probe deferral
[ 12.630252] platform i2c-mux-reg.1: Added to deferred list
[ 12.640892] devices_kset: Moving i2c-mux-reg.0 to end of list
[ 12.640900] platform i2c-mux-reg.0: Retrying from deferred list
[ 12.640911] bus: 'platform': driver_probe_device: matched device i2c-mux-reg.0 with driver i2c-mux-reg
[ 12.640919] bus: 'platform': really_probe: probing driver i2c-mux-reg with device i2c-mux-reg.0
[ 12.640999] i2c-mux-reg i2c-mux-reg.0: no default pinctrl state
[ 12.641177] platform i2c-mux-reg.0: Driver i2c-mux-reg requests probe deferral
[ 12.641187] platform i2c-mux-reg.0: Added to deferred list
[ 12.641198] devices_kset: Moving i2c-mux-reg.1 to end of list
[ 12.641219] platform i2c-mux-reg.1: Retrying from deferred list
[ 12.641237] bus: 'platform': driver_probe_device: matched device i2c-mux-reg.1 with driver i2c-mux-reg
[ 12.641247] bus: 'platform': really_probe: probing driver i2c-mux-reg with device i2c-mux-reg.1
[ 12.641331] i2c-mux-reg i2c-mux-reg.1: no default pinctrl state
[ 12.641465] platform i2c-mux-reg.1: Driver i2c-mux-reg requests probe deferral
[ 12.641469] platform i2c-mux-reg.1: Added to deferred list
[ 12.646427] device: 'i2c-1': device_add
[ 12.646647] bus: 'i2c': add device i2c-1
[ 12.647104] device: 'i2c-1': device_add
[ 12.669231] devices_kset: Moving i2c-mux-reg.0 to end of list
[ 12.669240] platform i2c-mux-reg.0: Retrying from deferred list
[ 12.669258] bus: 'platform': driver_probe_device: matched device i2c-mux-reg.0 with driver i2c-mux-reg
[ 12.669263] bus: 'platform': really_probe: probing driver i2c-mux-reg with device i2c-mux-reg.0
[ 12.669343] i2c-mux-reg i2c-mux-reg.0: no default pinctrl state
[ 12.669585] device: 'i2c-2': device_add
[ 12.669795] bus: 'i2c': add device i2c-2
[ 12.670201] device: 'i2c-2': device_add
[ 12.671427] i2c i2c-1: Added multiplexed i2c bus 2
[ 12.671514] device: 'i2c-3': device_add
[ 12.671724] bus: 'i2c': add device i2c-3
[ 12.672136] device: 'i2c-3': device_add
[ 12.673378] i2c i2c-1: Added multiplexed i2c bus 3
[ 12.673472] device: 'i2c-4': device_add
[ 12.673676] bus: 'i2c': add device i2c-4
[ 12.674060] device: 'i2c-4': device_add
[ 12.675861] i2c i2c-1: Added multiplexed i2c bus 4
[ 12.675941] device: 'i2c-5': device_add
[ 12.676150] bus: 'i2c': add device i2c-5
[ 12.676550] device: 'i2c-5': device_add
[ 12.678103] i2c i2c-1: Added multiplexed i2c bus 5
[ 12.678193] device: 'i2c-6': device_add
[ 12.678395] bus: 'i2c': add device i2c-6
[ 12.678774] device: 'i2c-6': device_add
[ 12.679969] i2c i2c-1: Added multiplexed i2c bus 6
[ 12.680065] device: 'i2c-7': device_add
[ 12.680275] bus: 'i2c': add device i2c-7
[ 12.680913] device: 'i2c-7': device_add
[ 12.682506] i2c i2c-1: Added multiplexed i2c bus 7
[ 12.682600] device: 'i2c-8': device_add
[ 12.682808] bus: 'i2c': add device i2c-8
[ 12.683189] device: 'i2c-8': device_add
[ 12.683907] device: 'i2c-1': device_unregister
[ 12.683945] device: 'i2c-1': device_unregister
[ 12.684387] device: 'i2c-1': device_create_release
[ 12.684536] bus: 'i2c': remove device i2c-1
[ 12.686019] i2c i2c-8: Failed to create compatibility class link
[ 12.686086] ------------[ cut here ]------------
[ 12.686087] can't create symlink to mux device
[ 12.686224] Workqueue: events deferred_probe_work_func
[ 12.686135] WARNING: CPU: 7 PID: 436 at drivers/i2c/i2c-mux.c:416 i2c_mux_add_adapter+0x729/0x7d0 [i2c_mux]
[ 12.686232] RIP: 0010:i2c_mux_add_adapter+0x729/0x7d0 [i2c_mux]
[ 0x190/0x190 [i2c_mux]
[ 12.686300] ? i2c_mux_alloc+0xac/0x110 [i2c_mux]
[ 12.686306] ? i2c_mux_reg_set+0x200/0x200 [i2c_mux_reg]
[ 12.686313] i2c_mux_reg_probe+0x22c/0x731 [i2c_mux_reg]
[ 12.686322] ? i2c_mux_reg_deselect+0x60/0x60 [i2c_mux_reg]
[ 12.686346] platform_drv_probe+0xa8/0x110
[ 12.686351] really_probe+0x185/0x720
[ 12.686358] driver_probe_device+0xdf/0x1f0
[ 12.686522] i2c i2c-1: Added multiplexed i2c bus 8
[ 12.686621] device: 'i2c-9': device_add
[ 12.686626] kobject_add_internal failed for i2c-9 (error: -2 parent: i2c-1)
[ 12.694729] i2c-core: adapter 'i2c-1-mux (chan_id 8)': can't register device (-2)
[ 12.705726] i2c i2c-1: failed to add mux-adapter 8 as bus 9 (error=-2)
[ 12.714494] device: 'i2c-8': device_unregister
[ 12.714537] device: 'i2c-8': device_unregister
Fixes: 6613d18e9038 ("platform/x86: mlx-platform: Move module from arch/x86")
Signed-off-by: Vadim Pasternak <vadimp@mellanox.com>
[ Upstream commit d6423bd03031c020121da26c41a26bd5cc6d0da3 ]
There are several Beckhoff Automation industrial PC boards which use
pmc_plt_clk* clocks for ethernet controllers. This adds affected boards
to critclk_systems DMI table so the clocks are marked as CLK_CRITICAL and
not turned off.
table
[ Upstream commit 3d0818f5eba80fbe4c0addbfe6ddb2d19dc82cd4 ]
The Lex 3I380D industrial PC has 4 ethernet controllers on board
which need pmc_plt_clk0 - 3 to function, add it to the critclk_systems
DMI table, so that drivers/clk/x86/clk-pmc-atom.c will mark the clocks
as CLK_CRITICAL and they will not get turned off.
Reported-and-tested-by: Semyon Verchenko <semverchenko@factor-ts.ru>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[ Upstream commit e61985d0550df8c2078310202aaad9b41049c36c ]
If punit or telemetry device initialization fails, pmc driver should
unregister and return failure.
This change is to fix a kernel panic when removing kernel module
intel_pmc_ipc.
Fixes: 48c1917088ba ("platform:x86: Add Intel telemetry platform device")
Signed-off-by: Junxiao Chang <junxiao.chang@intel.com>
[ Upstream commit 94d4e7af14a1170e34cf082d92e4c02de9e9fb88 ]
As new transfer mechanisms are added to the EC codebase, they may
not support v2 of the EC protocol.
If the v3 initial handshake transfer fails, the kernel will try
and call cmd_xfer as a fallback. If v2 is not supported, cmd_xfer
will be NULL, and the code will end up causing a kernel panic.
Add a check for NULL before calling the transfer function, along
with a helpful comment explaining how one might end up in this
situation.
Signed-off-by: Enrico Granata <egranata@chromium.org>
Reviewed-by: Jett Rink <jettrink@chromium.org>
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
commit f7db839fccf087664e5587966220821289b6a9cb upstream.
Some AMD based ThinkPads have a firmware bug that calling
"GBDC" will cause Bluetooth on Intel wireless cards blocked.
Probe these models by DMI match and disable Bluetooth subdriver
if specified Intel wireless card exist.
Cc: stable <stable@vger.kernel.org> # 4.14+
Signed-off-by: Jiaxun Yang <jiaxun.yang@flygoat.com>
commit 1cbd7a64959d33e7a2a1fa2bf36a62b350a9fcbd upstream.
It seems that the default case should return AE_CTRL_TERMINATE, instead
of falling through to case ACPI_RESOURCE_TYPE_END_TAG and returning AE_OK;
otherwise the line of code at the end of the function is unreachable and
makes no sense:
return AE_CTRL_TERMINATE;
This fix is based on the following thread of discussion:
https://lore.kernel.org/patchwork/patch/959782/
Fixes: 33a04454527e ("sony-laptop: Add SNY6001 device handling (sonypi reimplementation)")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
[ Upstream commit b995dcca7cf12f208cfd95fd9d5768dca7cccec7 ]
It's used by probe and that isn't an init function. Drop this so that we
don't get a section mismatch.
Reported-by: kbuild test robot <lkp@intel.com>
Cc: David Müller <dave.mueller@gmx.ch>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Fixes: 7c2e07130090 ("clk: x86: Add system specific quirk to mark clocks as critical")
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
commit 7c2e07130090ae001a97a6b65597830d6815e93e upstream.
Since commit 648e921888ad ("clk: x86: Stop marking clocks as
CLK_IS_CRITICAL"), the pmc_plt_clocks of the Bay Trail SoC are
unconditionally gated off. Unfortunately this will break systems where these
clocks are used for external purposes beyond the kernel's knowledge. Fix it
by implementing a system specific quirk to mark the necessary pmc_plt_clks as
critical.
Signed-off-by: David Müller <dave.mueller@gmx.ch>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[ Upstream commit 0e68eeea9894feeba2edf7ec63e4551b87f39621 ]
A previous commit "platform/x86: intel_pmc_core: Make the driver PCH
family agnostic <c977b98bbef5898ed3d30b08ea67622e9e82082a>" provided
better abstraction to this driver but has some fundamental issues.
e.g. the following condition
for (index = 0; index < pmcdev->map->ppfear_buckets &&
index < PPFEAR_MAX_NUM_ENTRIES; index++, iter++)
is wrong because for CNL, PPFEAR_MAX_NUM_ENTRIES is hardcoded as 5 which
is _wrong_ and even though ppfear_buckets is 8, the loop fails to read
all eight registers needed for CNL PCH i.e. PPFEAR0 and PPFEAR1. This
patch refactors the pfear show logic to correctly read PCH IP power
gating status for Cannonlake and beyond.
Cc: "David E. Box" <david.e.box@intel.com>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Fixes: c977b98bbef5 ("platform/x86: intel_pmc_core: Make the driver PCH family agnostic")
Signed-off-by: Rajneesh Bhardwaj <rajneesh.bhardwaj@linux.intel.com>
[ Upstream commit 0ee4b5f801b73b83a9fb3921d725f2162fd4a2e5 ]
Add BACKLIGHT_LCD_SUPPORT for SAMSUNG_Q10 to fix the
warning: unmet direct dependencies detected for BACKLIGHT_CLASS_DEVICE.
SAMSUNG_Q10 selects BACKLIGHT_CLASS_DEVICE but BACKLIGHT_CLASS_DEVICE
depends on BACKLIGHT_LCD_SUPPORT.
Copy BACKLIGHT_LCD_SUPPORT dependency into SAMSUNG_Q10 to fix:
WARNING: unmet direct dependencies detected for BACKLIGHT_CLASS_DEVICE
Depends on [n]: HAS_IOMEM [=y] && BACKLIGHT_LCD_SUPPORT [=n]
Selected by [y]:
- SAMSUNG_Q10 [=y] && X86 [=y] && X86_PLATFORM_DEVICES [=y] && ACPI [=y]
Signed-off-by: Sinan Kaya <okaya@kernel.org>
[ Upstream commit 6ad16b78a039b45294b1ad5d69c14ac57b2fe706 ]
EC_MKBP_EVENT_SENSOR_FIFO events can be triggered for a variety of
reasons, and there are very few cases in which they should be treated as
wakeup interrupts (particularly, when a certain
MOTIONSENSE_MODULE_FLAG_* is set, but this is not even supported in the
mainline cros_ec_sensor driver yet). Most of the time, they are benign
sensor readings. In any case, the top-level cros_ec device doesn't know
enough to determine that they should wake the system, and so it should
not report the event. This would be the job of the cros_ec_sensors
driver to parse.
This patch adds checks to cros_ec_get_next_event() such that it doesn't
signal 'wakeup' for events of type EC_MKBP_EVENT_SENSOR_FIFO.
This patch is particularly relevant on devices like Scarlet (Rockchip
RK3399 tablet, known as Acer Chromebook Tab 10), where the EC firmware
reports sensor events much more frequently. This was causing
/sys/power/wakeup_count to increase very frequently, often needlessly
interrupting our ability to suspend the system.
Signed-off-by: Brian Norris <briannorris@chromium.org>
Signed-off-by: Benson Leung <bleung@chromium.org>
[ Upstream commit 71b12beaf12f21a53bfe100795d0797f1035b570 ]
According to Asus firmware engineers, the meaning of these codes is only
to notify the OS that the screen brightness has been turned on/off by
the EC. This does not match the meaning of KEY_DISPLAYTOGGLE /
KEY_DISPLAY_OFF, where userspace is expected to change the display
brightness.
Signed-off-by: João Paulo Rechi Vita <jprvita@endlessm.com>
[ Upstream commit b3f2f3799a972d3863d0fdc2ab6287aef6ca631f ]
When the OS registers to handle events from the display off hotkey the
EC will send a notification with 0x35 for every key press, independent
of the backlight state.
The behavior of this key on Windows, with the ATKACPI driver from Asus
installed, is turning off the backlight of all connected displays with a
fading effect, and any cursor input or key press turning the backlight
back on. The key press or cursor input that wakes up the display is also
passed through to the application under the cursor or under focus.
The key that matches this behavior the closest is KEY_SCREENLOCK.
[ Upstream commit 78f3ac76d9e5219589718b9e4733bee21627b3f5 ]
In the past, Asus firmwares would change the panel backlight directly
through the EC when the display off hotkey (Fn+F7) was pressed, and
only notify the OS of such change, with 0x33 when the LCD was ON and
0x34 when the LCD was OFF. These are currently mapped to
KEY_DISPLAYTOGGLE and KEY_DISPLAY_OFF, respectively.
Most recently the EC on Asus most machines lost ability to toggle the
LCD backlight directly, but unless the OS informs the firmware it is
going to handle the display toggle hotkey events, the firmware still
tries change the brightness through the EC, to no effect. The end result
is a long list (at Endless we counted 11) of Asus laptop models where
the display toggle hotkey does not perform any action. Our firmware
engineers contacts at Asus were surprised that there were still machines
out there with the old behavior.
Calling WMNB(ASUS_WMI_DEVID_BACKLIGHT==0x00050011, 2) on the _WDG device
tells the firmware that it should let the OS handle the display toggle
event, in which case it will simply notify the OS of a key press with
0x35, as shown by the DSDT excerpts bellow.
Scope (_SB)
Device (ATKD)
Name (_WDG, Buffer (0x28)
/* 0000 */ 0xD0, 0x5E, 0x84, 0x97, 0x6D, 0x4E, 0xDE, 0x11,
/* 0008 */ 0x8A, 0x39, 0x08, 0x00, 0x20, 0x0C, 0x9A, 0x66,
/* 0010 */ 0x4E, 0x42, 0x01, 0x02, 0x35, 0xBB, 0x3C, 0x0B,
/* 0018 */ 0xC2, 0xE3, 0xED, 0x45, 0x91, 0xC2, 0x4C, 0x5A,
/* 0020 */ 0x6D, 0x19, 0x5D, 0x1C, 0xFF, 0x00, 0x01, 0x08
Method (WMNB, 3, Serialized)
CreateDWordField (Arg2, Zero, IIA0)
CreateDWordField (Arg2, 0x04, IIA1)
Local0 = (Arg1 & 0xFFFFFFFF)
If ((Local0 == 0x53564544))
If ((IIA0 == 0x00050011))
If ((IIA1 == 0x02))
^^PCI0.SBRG.EC0.SPIN (0x72, One)
^^PCI0.SBRG.EC0.BLCT = One
Return (One)
Scope (_SB.PCI0.SBRG.EC0)
Name (BLCT, Zero)
Method (_Q10, 0, NotSerialized) // _Qxx: EC Query
If ((BLCT == Zero))
Local0 = One
Local0 = RPIN (0x72)
Local0 ^= One
SPIN (0x72, Local0)
If (ATKP)
Local0 = (0x34 - Local0)
^^^^ATKD.IANE (Local0)
ElseIf ((BLCT == One))
If (ATKP)
^^^^ATKD.IANE (0x35)
[ Upstream commit 684238d79ad85c5e19a71bb5818e77e329912fbc ]
To fix:
acerhdf: unknown (unsupported) BIOS version Gateway /LT31 /v1.3307 , please report, aborting!
As can be seen in the context, the BIOS registers haven't changed in
the previous versions, so the assumption is they won't have changed
in this last update for this somewhat older platform either.
Cc: Peter Feuerer <peter@piie.net>
Cc: Darren Hart <dvhart@infradead.org>
Cc: Andy Shevchenko <andy@infradead.org>
Reviewed-by: Peter Feuerer <peter@piie.net>
[ Upstream commit 8d98b1ef368feeb7720b8b9b6f3bd93f2ad892bc ]
On some Goldmont based systems such as ASRock J3455M the BIOS may not
enable the IPC1 device that provides access to the PMC and PUNIT. In
such scenarios, the IOSS and PSS resources from the platform device can
not be obtained and result in a invalid telemetry_plt_config which is an
internal data structure that holds platform config and is maintained by
the telemetry platform driver.
This is also applicable to the platforms where the BIOS supports IPC1
device under debug configurations but IPC1 is disabled by user or the
policy.
This change allows user to know the reason for not seeing entries under
/sys/kernel/debug/telemetry/* when there is no apparent failure at boot.
Cc: Matt Turner <matt.turner@intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Souvik Kumar Chakravarty <souvik.k.chakravarty@intel.com>
Cc: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@intel.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=198779
Acked-by: Matt Turner <matt.turner@intel.com>
commit ff0e9f26288d2daee4950f42b37a3d3d30d36ec1 upstream.
An ACPI buffer that was allocated was not being freed after use.
Signed-off-by: Mario Limonciello <mario.limonciello@dell.com>
[ Upstream commit c2e2a618eb7104e18fdcf739d4d911563812a81c ]
Fix a build warning in toshiba_acpi.c when CONFIG_PROC_FS is not enabled
by marking the unused function as __maybe_unused.
../drivers/platform/x86/toshiba_acpi.c:1685:12: warning: 'version_proc_show' defined but not used [-Wunused-function]
Cc: Azael Avalos <coproscefalo@gmail.com>
Cc: platform-driver-x86@vger.kernel.org
[ Upstream commit 880b29ac107d15644bf4da228376ba3cd6af6d71 ]
Add entry to WMI keymap for lid flip event on Asus UX360.
On Asus Zenbook ux360 flipping lid from/to tablet mode triggers
keyscan code 0xfa which cannot be handled and results in kernel
log message "Unknown key fa pressed".
Signed-off-by: Aleh Filipovich<aleh@appnexus.com>
[ Upstream commit 340fd4cff43f18bace9358d4decdc9b6ed0715be ]
Fix build errors by #including <linux/io.h>.
../drivers/platform/x86/intel_punit_ipc.c: In function 'ipc_read_status':
../drivers/platform/x86/intel_punit_ipc.c:55:2: error: implicit declaration of function 'readl' [-Werror=implicit-function-declaration]
return readl(ipcdev->base[type][BASE_IFACE]);
../drivers/platform/x86/intel_punit_ipc.c: In function 'ipc_write_cmd':
../drivers/platform/x86/intel_punit_ipc.c:60:2: error: implicit declaration of function 'writel' [-Werror=implicit-function-declaration]
writel(cmd, ipcdev->base[type][BASE_IFACE]);
Fixes: 447ae3166702 ("x86: Don't include linux/irq.h from asm/hardirq.h")
Cc: Zha Qipeng <qipeng.zha@intel.com>
commit 58e73aa177850babb947555257fd4f79e5275cf1 upstream.
The commit 5d9f40b56630 ("platform/x86: ideapad-laptop: Add
Y520-15IKBN to no_hw_rfkill") added the entry for Y20-15IKBN, and it
turned out that another variant, Y20-15IKBM, also requires the
no_hw_rfkill.
Trim the last letter from the string so that it matches to both
Y20-15IKBN and Y20-15IKBM models.
Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=1098626
Cc: <stable@vger.kernel.org>
[ Upstream commit 32ffd6e8d1f6cef94bedca15dfcdebdeb590499d ]
Do not perform the rfkill cleanup routine when
(asus->driver->wlan_ctrl_by_user && ashs_present()) is true, since
nothing is registered with the rfkill subsystem in that case. Doing so
leads to the following kernel NULL pointer dereference:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff816c7348>] __mutex_lock_slowpath+0x98/0x120
PGD 1a3aa8067
PUD 1a3b3d067
PMD 0
Oops: 0002 [#1] PREEMPT SMP
Modules linked in: bnep ccm binfmt_misc uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core hid_a4tech videodev x86_pkg_temp_thermal intel_powerclamp coretemp ath3k btusb btrtl btintel bluetooth kvm_intel snd_hda_codec_hdmi kvm snd_hda_codec_realtek snd_hda_codec_generic irqbypass crc32c_intel arc4 i915 snd_hda_intel snd_hda_codec ath9k ath9k_common ath9k_hw ath i2c_algo_bit snd_hwdep mac80211 ghash_clmulni_intel snd_hda_core snd_pcm snd_timer cfg80211 ehci_pci xhci_pci drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm xhci_hcd ehci_hcd asus_nb_wmi(-) asus_wmi sparse_keymap r8169 rfkill mxm_wmi serio_raw snd mii mei_me lpc_ich i2c_i801 video soundcore mei i2c_smbus wmi i2c_core mfd_core
CPU: 3 PID: 3275 Comm: modprobe Not tainted 4.9.34-gentoo #34
Hardware name: ASUSTeK COMPUTER INC. K56CM/K56CM, BIOS K56CM.206 08/21/2012
task: ffff8801a639ba00 task.stack: ffffc900014cc000
RIP: 0010:[<ffffffff816c7348>] [<ffffffff816c7348>] __mutex_lock_slowpath+0x98/0x120
RSP: 0018:ffffc900014cfce0 EFLAGS: 00010282
RAX: 0000000000000000 RBX: ffff8801a54315b0 RCX: 00000000c0000100
RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff8801a54315b4
RBP: ffffc900014cfd30 R08: 0000000000000000 R09: 0000000000000002
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801a54315b4
R13: ffff8801a639ba00 R14: 00000000ffffffff R15: ffff8801a54315b8
FS: 00007faa254fb700(0000) GS:ffff8801aef80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001a3b1b000 CR4: 00000000001406e0
Stack:
ffff8801a54315b8 0000000000000000 ffffffff814733ae ffffc900014cfd28
ffffffff8146a28c ffff8801a54315b0 0000000000000000 ffff8801a54315b0
ffff8801a66f3820 0000000000000000 ffffc900014cfd48 ffffffff816c73e7
Call Trace:
[<ffffffff814733ae>] ? acpi_ut_release_mutex+0x5d/0x61
[<ffffffff8146a28c>] ? acpi_ns_get_node+0x49/0x52
[<ffffffff816c73e7>] mutex_lock+0x17/0x30
[<ffffffffa00a3bb4>] asus_rfkill_hotplug+0x24/0x1a0 [asus_wmi]
[<ffffffffa00a4421>] asus_wmi_rfkill_exit+0x61/0x150 [asus_wmi]
[<ffffffffa00a49f1>] asus_wmi_remove+0x61/0xb0 [asus_wmi]
[<ffffffff814a5128>] platform_drv_remove+0x28/0x40
[<ffffffff814a2901>] __device_release_driver+0xa1/0x160
[<ffffffff814a29e3>] device_release_driver+0x23/0x30
[<ffffffff814a1ffd>] bus_remove_device+0xfd/0x170
[<ffffffff8149e5a9>] device_del+0x139/0x270
[<ffffffff814a5028>] platform_device_del+0x28/0x90
[<ffffffff814a50a2>] platform_device_unregister+0x12/0x30
[<ffffffffa00a4209>] asus_wmi_unregister_driver+0x19/0x30 [asus_wmi]
[<ffffffffa00da0ea>] asus_nb_wmi_exit+0x10/0xf26 [asus_nb_wmi]
[<ffffffff8110c692>] SyS_delete_module+0x192/0x270
[<ffffffff810022b2>] ? exit_to_usermode_loop+0x92/0xa0
[<ffffffff816ca560>] entry_SYSCALL_64_fastpath+0x13/0x94
Code: e8 5e 30 00 00 8b 03 83 f8 01 0f 84 93 00 00 00 48 8b 43 10 4c 8d 7b 08 48 89 63 10 41 be ff ff ff ff 4c 89 3c 24 48 89 44 24 08 <48> 89 20 4c 89 6c 24 10 eb 1d 4c 89 e7 49 c7 45 08 02 00 00 00
RIP [<ffffffff816c7348>] __mutex_lock_slowpath+0x98/0x120
RSP <ffffc900014cfce0>
---[ end trace 8d484233fa7cb512 ]---
note: modprobe[3275] exited with preempt_count 2
https://bugzilla.kernel.org/show_bug.cgi?id=196467
Reported-by: red.f0xyz@gmail.com
commit d3b56c566d4ba8cae688baf3cca94425d57ea783 upstream.
Pointer request is being assigned but never used, so remove it. Cleans
up the clang warning:
drivers/platform/chrome/cros_ec_lpc.c:68:2: warning: Value stored to
'request' is never read
commit 9f0a93de9139c2b0a59299cd36b61564522458f8 upstream.
When the module is removed the led workqueue is destroyed in the remove
callback, before the led device is unregistered from the led subsystem.
This leads to a NULL pointer derefence when the led device is
unregistered automatically later as part of the module removal cleanup.
Bellow is the backtrace showing the problem.
IP: __queue_work+0x8c/0x410
PGD 0 P4D 0
Oops: 0000 [#1] SMP NOPTI
Modules linked in: ccm edac_mce_amd kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel aes_x86_64 joydev crypto_simd asus_nb_wmi glue_helper uvcvideo snd_hda_codec_conexant snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel asus_wmi snd_hda_codec cryptd snd_hda_core sparse_keymap videobuf2_vmalloc arc4 videobuf2_memops snd_hwdep input_leds videobuf2_v4l2 ath9k psmouse videobuf2_core videodev ath9k_common snd_pcm ath9k_hw media fam15h_power ath k10temp snd_timer mac80211 i2c_piix4 r8169 mii mac_hid cfg80211 asus_wireless(-) snd soundcore wmi shpchp 8250_dw ip_tables x_tables amdkfd amd_iommu_v2 amdgpu radeon chash i2c_algo_bit drm_kms_helper syscopyarea serio_raw sysfillrect sysimgblt fb_sys_fops ahci ttm libahci drm video
CPU: 3 PID: 2177 Comm: rmmod Not tainted 4.15.0-5-generic #6+dev94.b4287e5bem1-Endless
Hardware name: ASUSTeK COMPUTER INC. X555DG/X555DG, BIOS 5.011 05/05/2015
RIP: 0010:__queue_work+0x8c/0x410
RSP: 0018:ffffbe8cc249fcd8 EFLAGS: 00010086
RAX: ffff992ac6810800 RBX: 0000000000000000 RCX: 0000000000000008
RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff992ac6400e18
RBP: ffffbe8cc249fd18 R08: ffff992ac6400db0 R09: 0000000000000000
R10: 0000000000000040 R11: ffff992ac6400dd8 R12: 0000000000002000
R13: ffff992abd762e00 R14: ffff992abd763e38 R15: 000000000001ebe0
FS: 00007f318203e700(0000) GS:ffff992aced80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001c720e000 CR4: 00000000001406e0
Call Trace:
queue_work_on+0x38/0x40
led_state_set+0x2c/0x40 [asus_wireless]
led_set_brightness_nopm+0x14/0x40
led_set_brightness+0x37/0x60
led_trigger_set+0xfc/0x1d0
led_classdev_unregister+0x32/0xd0
devm_led_classdev_release+0x11/0x20
release_nodes+0x109/0x1f0
devres_release_all+0x3c/0x50
device_release_driver_internal+0x16d/0x220
driver_detach+0x3f/0x80
bus_remove_driver+0x55/0xd0
driver_unregister+0x2c/0x40
acpi_bus_unregister_driver+0x15/0x20
asus_wireless_driver_exit+0x10/0xb7c [asus_wireless]
SyS_delete_module+0x1da/0x2b0
entry_SYSCALL_64_fastpath+0x24/0x87
RIP: 0033:0x7f3181b65fd7
RSP: 002b:00007ffe74bcbe18 EFLAGS: 00000206 ORIG_RAX: 00000000000000b0
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f3181b65fd7
RDX: 000000000000000a RSI: 0000000000000800 RDI: 0000555ea2559258
RBP: 0000555ea25591f0 R08: 00007ffe74bcad91 R09: 000000000000000a
R10: 0000000000000000 R11: 0000000000000206 R12: 0000000000000003
R13: 00007ffe74bcae00 R14: 0000000000000000 R15: 0000555ea25591f0
Code: 01 00 00 02 0f 85 7d 01 00 00 48 63 45 d4 48 c7 c6 00 f4 fa 87 49 8b 9d 08 01 00 00 48 03 1c c6 4c 89 f7 e8 87 fb ff ff 48 85 c0 <48> 8b 3b 0f 84 c5 01 00 00 48 39 f8 0f 84 bc 01 00 00 48 89 c7
RIP: __queue_work+0x8c/0x410 RSP: ffffbe8cc249fcd8
---[ end trace 7aa4f4a232e9c39c ]---
Unregistering the led device on the remove callback before destroying the
workqueue avoids this problem.
https://bugzilla.kernel.org/show_bug.cgi?id=196097
Reported-by: Dun Hum <bitter.taste@gmx.com>
[ Upstream commit 587d8628fb71c3bfae29fb2bbe84c1478c59bac8 ]
This patch prevents the thinkpad_acpi driver from warning about 2 event
codes returned for keyboard palm-detection. No behavioral changes,
other than suppressing the warning in the kernel log. The events are
still forwarded via acpi-netlink channels.
We could, optionally, decide to forward the event through a
input-switch on the tpacpi input device. However, so far no suitable
input-code exists, and no similar drivers report such events. Hence,
leave it an acpi event for now.
Note that the event-codes are named based on empirical studies. On the
ThinkPad X1 5th Gen the sensor can be found underneath the arrow key.
Cc: Matthew Thode <mthode@mthode.org>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
[ Upstream commit 4d6bde512a86c32df3a1f289d2b4cd04b17758d1 ]
On some Dell XPS models WMI events of type 0x0000 reporting a keycode of
0xe00c get reported when the brightness of the LCD panel changes.
This leads to us reporting false-positive kbd_led change events to
userspace which in turn leads to the kbd backlight OSD showing when it
should not.
We already read the current keyboard backlight brightness value when
reporting events because the led_classdev_notify_brightness_hw_changed
API requires this. Compare this value to the last known value and filter
out duplicate events, fixing this.
Note the fixed issue is esp. a problem on XPS models with an ambient light
sensor and automatic brightness adjustments turned on, this causes the kbd
backlight OSD to show all the time there.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1514969
Fixes: 9c656b0799 ("platform/x86: dell-*: Call new led hw_changed API ...")
Acked-by: Pali Rohár <pali.rohar@gmail.com>
[ Upstream commit d48b8c58c57f6edbe2965f0a5f62c5cf9593ca96 ]
pkt_xfer should be used for protocol v3, and cmd_xfer otherwise. We had
one instance of these functions correct, but not the second, fall-back
case. We use the fall-back only when the first command returns an
IN_PROGRESS status, which is only used on some EC firmwares where we
don't want to constantly poll the bus, but instead back off and
sleep/retry for a little while.
Fixes: 2c7589af3c4d ("mfd: cros_ec: add proto v3 skeleton")
Signed-off-by: Shawn Nematbakhsh <shawnn@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
[ Upstream commit 50a0d71a5d20e1d3eff1d974fdc8559ad6d74892 ]
As gcc-8 reports, we zero out the wrong byte:
drivers/platform/chrome/cros_ec_sysfs.c: In function 'show_ec_version':
drivers/platform/chrome/cros_ec_sysfs.c:190:12: error: array subscript 4294967295 is above array bounds of 'uint8_t[]' [-Werror=array-bounds]
This changes the code back to what it did before changing to a
zero-length array structure.
Fixes: a841178445bb ("mfd: cros_ec: Use a zero-length array for command data")
[ Upstream commit 68a213d325c23d39f109f4c7c824b906a7d209de ]
This machine reports number of keyboard backlight led levels, instead of
value of the last led level index. Therefore max_brightness properly needs
to be subtracted by 1 to match led max_brightness API.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Reported-by: Gabriel M. Elder <gabriel@tekgnowsys.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196913
commit d6fa7588fd7a8def4c747c0c574ce85d453e3788 upstream.
Commit 4eebd5a4e726 ("apple-gmux: lock iGP IO to protect from vgaarb
changes") amended this driver's ->probe hook to lock decoding of normal
(non-legacy) I/O space accesses to the integrated GPU on dual-GPU
MacBook Pros. The lock stays in place until the driver is unbound.
The change was made to work around an issue with the out-of-tree nvidia
graphics driver (available at http://www.nvidia.com/object/unix.html).
It contains the following sequence in nvidia/nv.c:
#if defined(CONFIG_VGA_ARB) && !defined(NVCPU_PPC64LE)
#if defined(VGA_DEFAULT_DEVICE)
vga_tryget(VGA_DEFAULT_DEVICE, VGA_RSRC_LEGACY_MASK);
#endif
vga_set_legacy_decoding(dev, VGA_RSRC_NONE);
#endif
This code was reported to cause deadlocks with VFIO already in 2013:
https://devtalk.nvidia.com/default/topic/545560
I've reported the issue to Nvidia developers once more in 2017:
https://www.spinics.net/lists/dri-devel/msg138754.html
On the MacBookPro10,1, this code apparently breaks backlight control
(which is handled by apple-gmux via an I/O region starting at 0x700),
as reported by Petri Hodju:
https://bugzilla.kernel.org/show_bug.cgi?id=86121
I tried to replicate Petri's observations on my MacBook9,1, which uses
the same Intel Ivy Bridge + Nvidia GeForce GT 650M architecture, to no
avail. On my machine apple-gmux' I/O region remains accessible even
with the nvidia driver loaded and commit 4eebd5a4e726 reverted.
Petri reported that apple-gmux becomes accessible again after a
suspend/resume cycle because the BIOS changed the VGA routing on the
root port to the Nvidia GPU. Perhaps this is a BIOS issue after all
that can be fixed with an update?
In any case, the change made by commit 4eebd5a4e726 has turned out to
cause two new issues:
* Wilfried Klaebe reports a deadlock when launching Xorg because it
opens /dev/vga_arbiter and calls vga_get(), but apple-gmux is holding
a lock on I/O space indefinitely. It looks like apple-gmux' current
behavior is an abuse of the vgaarb API as locks are not meant to be
held for longer periods:
https://bugzilla.kernel.org/show_bug.cgi?id=88861#c11
https://bugzilla.kernel.org/attachment.cgi?id=217541
* On dual GPU MacBook Pros introduced since 2013, the integrated GPU is
powergated on boot und thus becomes invisible to Linux unless a custom
EFI protocol is used to leave it powered on. (A patch exists but is
not in mainline yet due to several negative side effects.) On these
machines, locking I/O to the integrated GPU (as done by 4eebd5a4e726)
fails and backlight control is therefore broken:
https://bugzilla.kernel.org/show_bug.cgi?id=105051
So let's revert commit 4eebd5a4e726 please. Users experiencing the
issue with the proprietary nvidia driver can comment out the above-
quoted problematic code as a workaround (or try updating the BIOS).
Cc: Petri Hodju <petrihodju@yahoo.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Bruno Prémont <bonbons@linux-vserver.org>
Cc: Andy Ritger <aritger@nvidia.com>
Cc: Ronald Tschalär <ronald@innovation.ch>
Tested-by: Wilfried Klaebe <linux-kernel@lebenslange-mailadresse.de>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
commit 98b8e4e5c17bf87c1b18ed929472051dab39878c upstream.
Calling acpi_wmi_init() at the subsys_initcall() level causes ordering
issues to appear on some systems and they are difficult to reproduce,
because there is no guaranteed ordering between subsys_initcall()
calls, so they may occur in different orders on different systems.
In particular, commit 86d9f48534e8 (mm/slab: fix kmemcg cache
creation delayed issue) exposed one of these issues where genl_init()
and acpi_wmi_init() are both called at the same initcall level, but
the former must run before the latter so as to avoid a NULL pointer
dereference.
For this reason, move the acpi_wmi_init() invocation to the
initcall_sync level which should still be early enough for things
to work correctly in the WMI land.
Link: https://marc.info/?t=151274596700002&r=1&w=2
Reported-by: Jonathan McDowell <noodles@earth.li>
Reported-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Tested-by: Jonathan McDowell <noodles@earth.li>
commit bff5bf9db1c9453ffd0a78abed3e2d040c092fd9 upstream.
Sending the switch state change twice within the same frame is invalid
evdev protocol and only works if the client handles keys immediately as
well. Processing events immediately is incorrect, it forces a fake
order of events that does not exist on the device.
Recent versions of libinput changed to only process the device state and
SYN_REPORT time, so now the key event is lost.
https://bugs.freedesktop.org/show_bug.cgi?id=104041
Signed-off-by: Peter Hutterer <peter.hutterer@who-t.net>
[ Upstream commit 163ca80013aafb6dc9cb295de3db7aeab9ab43f8 ]
Added support for HP ProBook 440 G4 laptops by including the accelerometer
orientation quirk for that device. Testing was performed based on the
axis orientation guidelines here:
https://www.kernel.org/doc/Documentation/misc-devices/lis3lv02d
which states "If the left side is elevated, X increases (becomes positive)".
When tested, on lifting the left edge, x values became increasingly negative
thus indicating an inverted x-axis on the installed lis3lv02d chip.
This was compensated by adding an entry for this device in hp_accel.c
specifying the quirk as x_inverted. The patch was tested on a
ProBook 440 G4 device and x-axis as well as y and z-axis values are now
generated as per spec.
Signed-off-by: Osama Khan <osama.khan@ericsson.com>
[ Upstream commit 6cc8cbbc8868033f279b63e98b26b75eaa0006ab ]
For PUNIT device, ISPDRIVER_IPC and GTDDRIVER_IPC resources are not
mandatory. So when PMC IPC driver creates a PUNIT device, if these
resources are not available then it creates dummy resource entries for
these missing resources. But during PUNIT device probe, doing ioremap on
these dummy resources generates following warning messages.
intel_punit_ipc: can't request region for resource [mem 0x00000000]
This patch fixes this issue by adding extra check for resource size
before performing ioremap operation.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
commit 9968e12a291e639dd51d1218b694d440b22a917f upstream.
Commit f9cf3b2880cc ("platform/x86: hp-wmi: Refactor dock and tablet
state fetchers") consolidated the methods for docking and laptop mode
detection, but omitted to apply the correct mask for the laptop mode
(it always uses the constant for docking).
Fixes: f9cf3b2880cc ("platform/x86: hp-wmi: Refactor dock and tablet state fetchers")
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Cc: Michel Dänzer <michel@daenzer.net>
