i8042.h/serio.h
Make hp_accel dependent on SERIO_I8042 in the Kconfig because since commit
a4c724d0723b078e4ab4670e557cda1795036a7a ('platform: hp_accel: add a i8042
filter to remove HPQ6000 data from kb bus stream') hp_accel includes i8042.h
and serio.h.
Reported-by: Jim Davis <jim.epost@gmail.com>
Signed-off-by: Giedrius Statkevičius <giedriuswork@gmail.com>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Add a i8042 filter to hp_accel to remove accelerometer's data with acpi
id HPQ6000 from keyboard bus stream. The codes sent by accelerometer are
e0 25, e0 26, e0 27 and e0 28. The relevant information is already
passed through /dev/freefall so no need to send these undocumented weird
signals through the keyboard bus. Also, unclogs `dmesg` because atkbd
complained about weird scan codes, saves processing power and disk
space.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Éric Piel <eric.piel@tremplin-utc.net>
The Yoga 3 does not contain any physical rfkill switch. Therefore
disable the rfkill switch identically to the Yoga 2 approach.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
The acpi-video backlight interface on the Acer KAV80 is broken, and worse
it causes the entire machine to slow down significantly after a suspend/resume.
Blacklist it, and use the acer-wmi backlight interface instead. Note that
the KAV80 is somewhat unique in that it is the only Acer model where we
fall back to acer-wmi after blacklisting, rather then using the native
(e.g. intel) backlight driver. This is done because there is no native
backlight interface on this model.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1128309
Cc: stable@vger.kernel.org
The acpi-video backlight interface on the NC210 does not work, blacklist it
and use the samsung-laptop interface instead.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=861573
X550VB as many others Asus laptops need wapf4 quirk to make RFKILL
switch be functional. Otherwise system boots with wireless card
disabled and is only possible to enable it by suspend/resume.
Bug report:
http://bugzilla.redhat.com/show_bug.cgi?id=1089731#c23
Reported-and-tested-by: Vratislav Podzimek <vpodzime@redhat.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
As bug #72551, the Toshiba TECRA A50-A series models also come with the
new keymap layout as found out by Azael Avalos, so add it to the dmi
table.
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=76971
Reported-and-tested-by: Blindekinder <rafael.raccuia@blindekinder.com>
Cc: Azael Avalos <coproscefalo@gmail.com>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br>
Cc: Darren Hart <dvhart@infradead.org>
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"The following have all spent at least a few days in linux-next, most
for more than a week. These are mostly cleanups and error handling
improvements with a few updates to extend existing support to newer
hardware.
Details:
- dell-wmi: fix access out of memory
- eeepc-laptop: cleanups, refactoring, sysfs perms, and improved
error handling
- intel-rst: ACPI and error handling cleanups
- thinkpad-acpi: whitespace cleanup
- toshiba_acpi: HCI/SCI interface update, keyboard backlight type 2
support, new scancodes, cleanups"
* tag 'platform-drivers-x86-v3.18-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (23 commits)
toshiba_acpi: Adapt kbd_bl_timeout_store to the new kbd type
toshiba_acpi: Change HCI/SCI functions return code type
toshiba_acpi: Unify return codes prefix from HCI/SCI to TOS
toshiba_acpi: Rename hci_raw to tci_raw
dell-wmi: Fix access out of memory
eeepc-laptop: clean up control flow in *_rfkill_notifier
eeepc-laptop: store_cpufv: return error if set_acpi fails
eeepc-laptop: check proper return values in get_cpufv
eeepc-laptop: make fan1_input really read-only
eeepc-laptop: pull out SENSOR_STORE_FUNC and SENSOR_SHOW_FUNC macros
eeepc-laptop: tell sysfs that the disp attribute is write-only
eeepc-laptop: pull out ACPI_STORE_FUNC and ACPI_SHOW_FUNC macros
eeepc-laptop: use DEVICE_ATTR* to instantiate device_attributes
eeepc-laptop: change sysfs function names to API expectations
eeepc-laptop: clean up coding style
eeepc-laptop: simplify parse_arg()
intel-rst: Clean up ACPI add function
intel-rst: Use ACPI_FAILURE() macro instead !ACPI_SUCCESS() for error checking
x86: thinkpad_acpi.c: fixed spacing coding style issue
toshiba_acpi: Support new keyboard backlight type
Pull ACPI and power management updates from Rafael Wysocki:
"Features-wise, to me the most important this time is a rework of
wakeup interrupts handling in the core that makes them work
consistently across all of the available sleep states, including
suspend-to-idle. Many thanks to Thomas Gleixner for his help with
this work.
Second is an update of the generic PM domains code that has been in
need of some care for quite a while. Unused code is being removed, DT
support is being added and domains are now going to be attached to
devices in bus type code in analogy with the ACPI PM domain. The
majority of work here was done by Ulf Hansson who also has been the
most active developer this time.
Apart from this we have a traditional ACPICA update, this time to
upstream version 20140828 and a few ACPI wakeup interrupts handling
patches on top of the general rework mentioned above. There also are
several cpufreq commits including renaming the cpufreq-cpu0 driver to
cpufreq-dt, as this is what implements generic DT-based cpufreq
support, and a new DT-based idle states infrastructure for cpuidle.
In addition to that, the ACPI LPSS driver is updated, ACPI support for
Apple machines is improved, a few bugs are fixed and a few cleanups
are made all over.
Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree
maintained by Kevin Hilman that will be merged through the PM tree.
Numbers-wise, the generic PM domains update takes the lead this time
with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd
place goes to the wakeup interrupts handling rework (13 commits).
Specifics:
- Rework the handling of wakeup IRQs by the IRQ core such that all of
them will be switched over to "wakeup" mode in suspend_device_irqs()
and in that mode the first interrupt will abort system suspend in
progress or wake up the system if already in suspend-to-idle (or
equivalent) without executing any interrupt handlers. Among other
things that eliminates the wakeup-related motivation to use the
IRQF_NO_SUSPEND interrupt flag with interrupts which don't really
need it and should not use it (Thomas Gleixner and Rafael Wysocki)
- Switch over ACPI to handling wakeup interrupts with the help of the
new mechanism introduced by the above IRQ core rework (Rafael Wysocki)
- Rework the core generic PM domains code to eliminate code that's
not used, add DT support and add a generic mechanism by which
devices can be added to PM domains automatically during enumeration
(Ulf Hansson, Geert Uytterhoeven and Tomasz Figa).
- Add debugfs-based mechanics for debugging generic PM domains
(Maciej Matraszek).
- ACPICA update to upstream version 20140828. Included are updates
related to the SRAT and GTDT tables and the _PSx methods are in the
METHOD_NAME list now (Bob Moore and Hanjun Guo).
- Add _OSI("Darwin") support to the ACPI core (unfortunately, that
can't really be done in a straightforward way) to prevent
Thunderbolt from being turned off on Apple systems after boot (or
after resume from system suspend) and rework the ACPI Smart Battery
Subsystem (SBS) driver to work correctly with Apple platforms
(Matthew Garrett and Andreas Noever).
- ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code,
adding support for 133MHz I2C source clock on Intel Baytrail to it
and making it avoid using UART RTS override with Auto Flow Control
(Heikki Krogerus).
- ACPI backlight updates removing the video_set_use_native_backlight
quirk which is not necessary any more, making the code check the
list of output devices returned by the _DOD method to avoid
creating acpi_video interfaces that won't work and adding a quirk
for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak)
- New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin)
- Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes,
Sudip Mukherjee, Yijing Wang, and Zhang Rui)
- cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy,
Rasmus Villemoes)
- cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change
among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U
Murthy, Shilpasri G Bhat, Lucas Stach)
- cpuidle support for DT-based idle states infrastructure, new ARM64
cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus
Villemoes)
- ARM big.LITTLE cpuidle driver updates: support for DT-based
initialization and Exynos5800 compatible string (Lorenzo Pieralisi,
Kevin Hilman)
- Rework of the test_suspend kernel command line argument and a new
trace event for console resume (Srinivas Pandruvada, Todd E Brandt)
- Second attempt to optimize swsusp_free() (hibernation core) to make
it avoid going through all PFNs which may be way too slow on some
systems (Joerg Roedel)
- devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide).
- rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry
update in MAINTAINERS (Heiko Stübner, Kevin Hilman)
- PM core fix related to clock management (Geert Uytterhoeven)
- PM core's sysfs code cleanup (Johannes Berg)"
* tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits)
ACPI / fan: printk replacement
PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME
PM / Domains: Rename cpu_data to cpuidle_data
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
cpufreq: ppc-corenet: remove duplicate update of cpu_data
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPI / video: check _DOD list when creating backlight devices
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
PM / devfreq: exynos: Enable building exynos PPMU as module
PM / devfreq: Export helper functions for drivers
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
With the introduction of the new keyboard backlight
implementation, the *_timeout_store function is
broken, as it only supports the first kbd_type.
This patch adapts such function for the new kbd_type,
as well as converts from using sscanf to kstrtoint.
Signed-off-by: Azael Avalos <coproscefalo@gmail.com>
Currently the HCI/SCI read/write functions are returning
the status of the ACPI call and also assigning the
returned value of the HCI/SCI function, however, only
the HCI/SCI status is being checked.
This patch changes such functions, returning the value
of the HCI/SCI function instead of the ACPI call status,
eliminating one parameter, and returning something
useful that indeed is being checked.
The return codes are split in between HCI/SCI prefixes,
but they are shared (used) by both interfaces, mixing
hci_read/write calls with SCI_* return codes, and
sci_read/write calls with HCI_* ones.
This patch changes the prefix of the return codes
definitions, dropping the HCI/SCI naming and instead
replacing it with TOS (for TOShiba).
The function name hci_raw was used before to reflect
a raw (read/write) call to Toshiba's Hardware
Configuration Interface (HCI), however, since the
introduction of the System Configuration Interface
(SCI), that "name" no longer applies.
This patch changes the name of that function to
tci_raw (for Toshiba Configuration Interface), and
change the comments about it.
Also, the HCI_WORDS definition was changed to TCI_RAW,
to better reflect that we're no longer using pure HCI
calls, but a combination of HCI and SCI, which form
part of the Toshiba Configuration Interface.
Without this patch, dell-wmi is trying to access elements of dynamically
allocated array without checking the array size. This can lead to memory
corruption or a kernel panic. This patch adds the missing checks for
array size.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
This patch fix spelling typos found in Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Handle errors immediately in eeepc_register_rfkill_notifier and
eeepc_unregister_rfkill_notifier. This clears up the control flow for the
reader. It also removes unnecessary indentation.
Signed-off-by: Frans Klaver <fransklaver@gmail.com>
The result of set_acpi is left unchecked, but it may return errors. If
one occurs, send the error to the caller. There's no reason to lie about
it, if set_acpi fails.
In get_cpufv the return value of get_acpi is stored in the cpufv struct.
Right before this value is checked for errors, it is and'ed with 0xff.
This means c->cur can never be less than zero. Besides that, the actual
error value is ignored.
c->num is also and'ed with 0xff, which means we can ignore values below
zero.
Check the result of get_acpi() right away. While at it, propagate the
error if we got one.
In the instantiation of the fan1_input device attribute, NULL is passed
as set function to store_sys_hwmon. The function pointer is never
checked before dereferencing it. This is fine if we can guarantee that
it will never be called with an invalid pointer, but we can't. If
someone from user space decides to change the permissions on this
attribute and write to it, kernel will crash.
Introduce EEEPC_CREATE_SENSOR_ATTR_RO() to instantiate a read-only
attribute, and declare fan1_input with it. This ensures store_sys_hwmon
is never called with NULL parameters. If someone tries to write the
attribute, the system will at least keep its sanity.
This also causes EEEPC_CREATE_SENSOR_ATTR() to be only used for R/W
attributes.This enables us to drop the _mode argument from the macro
and use DEVICE_ATTR_RW() internally while we're at it. Append _RW to the
name for readability.
Pull out EEEPC_SENSOR_STORE_FUNC and EEEPC_SENSOR_SHOW_FUNC. These
macros define functions that call store_sys_hwmon() and show_sys_hwmon()
respectively. This helps prevent duplication later on.
The disp attribute is write-only, but sysfs doesn't know this. Currently
show_sys_acpi() is mimicking sysfs behavior, if the underlying acpi call
should fail. This was introduced in 6dff29b63a5bf2eaf3 "eeepc-laptop:
disp attribute should be write-only". This is not ideal; behaving like
sysfs is better left to sysfs.
Introduce EEEPC_CREATE_DEVICE_ATTR_WO() to instantiate a write-only
attribute, and declare the disp attribute with it. Sysfs makes sure
userspace can only write to disp at all times. This removes the need for
mimicking the sysfs behavior in show_sys_acpi() and store_sys_acpi(),
but we'll stick with -EIO, as changing sysfs return values should not be
taken lightly.
This change also causes EEEPC_CREATE_DEVICE_ATTR() to be used only for
R/W attributes. This enables us to drop the _mode argument from the
macro and use DEVICE_ATTR_RW() internally while we're at it. Append _RW
to the name for readability.
Pull out macros EEEPC_ACPI_STORE_FUNC and EEEPC_ACPI_SHOW_FUNC. These
macros define functions that call store_sys_acpi() and show_sys_acpi()
Device attributes are instantiated manually, while we have DEVICE_ATTR*
macros available to do much of the work for us. Let's use them.
The eeepc-laptop driver follows the function naming convention
<action>_<attrname>(), while the sysfs macros are built around the
convention <attrname>_<action>(). Rename the sysfs functions to the
convention used by sysfs. This makes it easier to use the available API
later on.
Correct indentation and brace usage to comply with
Documentation/CodingStyle.
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
parse_arg() has three possible return values:
-EINVAL if sscanf(), in short, fails;
zero if "count" is zero; and
"count" in all other cases
But "count" will never be zero. See, parse_arg() is called by the
various store functions. And the callchain of these functions starts
with sysfs_kf_write(). And that function checks for a zero "count". So
we can stop checking for a zero "count", drop the "count" argument
entirely, and transform parse_arg() into a function that returns zero on
success or a negative error. That, in turn, allows to make those store
functions just return "count" on success. The net effect is that the
code becomes a bit easier to understand.
A nice side effect is that this GCC warning is silenced too:
drivers/platform/x86/eeepc-laptop.c: In function ‘store_sys_acpi’:
drivers/platform/x86/eeepc-laptop.c:279:10: warning: ‘value’ may be used uninitialized in this function [-Wmaybe-uninitialized]
int rv, value;
Which is, of course, the reason to have a look at parse_arg().
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
There is no need to initialize the error since it is going to be assigned
with the return status of at least on of the device_create_file() call.
We can return directly in case the first file creation fails.
All the labels for goto can be removed (along with the gotos) as well.
Tell the compiler that the failures are unlikely so it can create better
binaries.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@gmail.com>
ACPI_SUCCESS is defined as:
#define ACPI_SUCCESS(a) (!(a))
There is no need for the the double ! since there is already a macro
defined for failures: ACPI_FAILURE()
Fixed 22 similar coding style issues: "ERROR: spaces required around that '?'"
Signed-off-by: Jan van den Berg <janvdberg@gmail.com>
Newer Toshiba models now come with a new (and different) keyboard
backlight implementation with three modes of operation: TIMER,
ON and OFF, and the LED is now controlled internally by the firmware.
This patch adds support for that type of backlight, changing the
existing code to accomodate the new implementation.
The timeout value range is now 1-60 seconds, and the accepted
modes are now: 1 (FN-Z), 2 (AUTO or TIMER), 8 (ON) and 10 (OFF),
this adds two new entries kbd_type and available_kbd_modes,
the first shows the keyboard type and the latter shows the
supported modes depending on the keyboard type.
The function toshiba_touchpad_store is not checking
for invalid values and simply returns silently.
This patch checks for invalid values and returns accordingly.
Some Toshiba models with illumination support set a different
value on the returned codes, thus not allowing the illumination
LED to be registered, where it should be.
This patch removes a check from toshiba_illumination_available
function to allow such models to register the illumination LED.
Appart from reporting hotkeys, the INFO method is used
as a system wide event notifier for hardware or
software changes.
This patch adds additional "events" to the keymap list,
ignored by now, until we find them a good use.
Fujitsu backlight and hotkey devices have ACPI drivers.
The PNP MODULE_DEVICE_TABLE in fujitsu-laptop driver is just used as an
indicator for module autoloading, but this is wrong because what we
need is ACPI module device table instead, because the driver is probing
ACPI devices.
Thus remove those IDs from ACPI PNP scan handler list as we don't
have a PNP driver for them, and convert the fujitsu-laptop PNP
MODULE_DEVICE_TABLE to ACPI MODULE_DEVICE_TABLE.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=81971
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Dirk Griesbach <spamthis@freenet.de>
Acked-by: Darren Hart <dvhart@linux.intel.com>
The current code just returns -EINVAL because mode can't be equal to
both 1 and 2.
Also this function is messy so I have cleaned it up:
1) Remove initializers like "int time = -1". Initializing variables to
garbage values turns off GCC's uninitialized variable warnings so it
can lead to bugs.
2) Use kstrtoint() instead of sscanf().
3) Use SCI_KBD_MODE_FNZ and SCI_KBD_MODE_AUTO instead of magic numbers 1
and 2.
4) Don't check for "mode == -1" because that can't happen.
5) Preserve the error code from toshiba_kbd_illum_status_set().
On the Toshiba Tecra Z40, after a suspend-to-disk, some FN hotkeys
driven by toshiba_acpi are not functional.
Calling the ACPI object ENAB on resume makes them back alive.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
This is a follow-up patch to commit 49458e83082d ("ideapad-laptop:
Constify DMI table and other r/o variables") to do what its commit
message says. The actual commit differs from the patch posted at
https://www.mail-archive.com/platform-driver-x86@vger.kernel.org/msg05340.html
significantly, probably due to a bad merge conflict resolution. Fix up
the mess and constify the DMI table for real and fix the bogus
double-const of ideapad_rfk_data[].
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Matthew Garrett <matthew.garrett@nebula.com>
Cc: Ike Panhc <ike.pan@canonical.com>
I've received a bug report from a user that the touchpad control part
of the ideapad-laptop ACPI interface does work for him on his
"Lenovo Yoga 2 13", and that this patch causes a regression for him.
Since it did not work for me when I had a "Lenovo Yoga 2 11" in my own
hands (loaned from a friend). It seems that this is a bit of hit and miss.
Since the result of having a false positive here is worse, then the minor
annoyance of a false touchpad disabled messages being shown after suspend /
resume on models (or is it firmware versions?) where the interface does not
work, simply revert the patch.
This reverts commit f79a901331a823ae370584b15cd39dd110b95a0a.
Reported-by: GOESSEL Guillaume <g_goessel@outlook.com>
This reverts commit bdc3ae7221213963f438faeaa69c8b4a2195f491.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
Makefile and Kconfig build support patch for the newly introduced
kernel module toshiba_haps.
This driver adds support for the built-in accelereometer found
on recent Toshiba laptops with HID TOS620A.
This driver receives ACPI notify events 0x80 when the sensor
detects a sudden move or a harsh vibration, as well as an
ACPI notify event 0x81 whenever the movement or vibration has
been stabilized.
Also provides sysfs entries to get/set the desired protection
level and reseting the HDD protection interface.
As reported here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1173681
the U32U needs wapf=4 too.
Not all HW supporting WMAX method will support the HDMI mux feature.
Explicitly quirk the HW that does support it.
Signed-off-by: Mario Limonciello <mario_limonciello@dell.com>
Constify the rfkill_blacklist[] DMI table, the ideapad_rfk_data[] table
and the ideapad_attribute_group attribute group. There's no need to have
them writeable during runtime.
The actual x401u does not use the so named x401u quirk but the x55u quirk.
All that the x401u quirk does it setting wapf to 4, so rename it to wapf4 to
stop the confusion.
Change the name of the hwmon interface from "compal-laptop" to "compal".
A dash is an invalid character for a hwmon name and caused the call to
hwmon_device_register_with_groups() to fail.
Signed-off-by: Roald Frederickx <roald.frederickx@gmail.com>
