commit 53147b6cabee5e8d1997b5682fcc0c3b72ddf9c2 upstream.
Commit a2b3471b5b13 ("toshiba_acpi: Use the Hotkey Event Type function
for keymap choosing") changed the *setup_keyboard function to query for
the Hotkey Event Type to help choose the correct keymap, but turns out
that here are certain Toshiba models out there not implementing this
feature, and thus, failing to continue the input device registration and
leaving such laptops without hotkey support.
This patch changes such check, and instead of returning an error if
the Hotkey Event Type is not present, we simply inform userspace about it,
changing the message printed from err to notice, making the function
responsible for registering the input device to continue.
This issue was found on a Toshiba Portege Z30-B, but there might be
some other models out there affected by this regression as well.
Signed-off-by: Azael Avalos <coproscefalo@gmail.com>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit 8a1513b49321e503fd6c8b6793e3b1f9a8a3285b upstream.
Do not write initialize magic on systems that do not have
feature query 0xb. Fixes Bug #82451.
Redefine FEATURE_QUERY to align with 0xb and FEATURE2 with 0xd
for code clearity.
Add a new test function, hp_wmi_bios_2008_later() & simplify
hp_wmi_bios_2009_later(), which fixes a bug in cases where
an improper value is returned. Probably also fixes Bug #69131.
Add missing __init tag.
Signed-off-by: Kyle Evans <kvans32@gmail.com>
commit fa92a31b3335478c545cdc8e79e1e9b788184e6b upstream.
Like some of the other Yoga models the Lenovo Yoga 3 14 does not have a
hw rfkill switch, and trying to read the hw rfkill switch through the
ideapad module causes it to always reported blocking breaking wifi.
This commit adds the Lenovo Yoga 3 14 to the no_hw_rfkill dmi list, fixing
the wifi breakage.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1239050
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD fixes from Lee Jones:
- fix dependency issues on ChromeOS platforms
- fix runtime PM issues on Arizona
- fix IRQ/suspend race on Arizona
* tag 'mfd-fixes-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: Remove MFD_CROS_EC_SPI depends on OF
platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM
mfd: arizona: Fix initialisation of the PM runtime
mfd: arizona: Fix race between runtime suspend and IRQs
The Chrome platform support depends on X86 || ARM because there are
only Chromebooks using those architectures. But only some drivers
depend on a given architecture, and the ones that do already have
a dependency on their specific Kconfig symbol entries.
An option is to also make CHROME_PLATFORMS depends on || COMPILE_TEST
but is more future proof to remove the dependency and let the drivers
be built in all architectures if possible to have more build coverage.
Acked-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
'{ }' and memset will both reset the cbuf buffer.
Only once is enough and this can be done outside fo the mutex.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Update kerneldoc formatting per Documentation/kernel-dec-nano-HOWTO.txt.
Signed-off-by: qipeng.zha <qipeng.zha@intel.com>
The hwswitch state can be changed at runtime, so make sure dell-laptop
always knows the current state. It can be modified by the userspace
utility smbios-wireless-ctl.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Make sure that return value of each SMBIOS call is properly checked and do
not continue processing output if the call failed.
Make sure that before initializing SMBIOS call, the input buffer does
not contain any garbage (e.g. values from previous SMBIOS call). This
fixes problems with passing undefined/random parameters to SMBIOS
functions.
Avoid casting variables to different sizes due to different
compilers and settings.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull late x86 platform driver updates from Darren Hart:
"The following came in a bit later and I wanted them to bake in next a
few more days before submitting, thus the second pull.
A new intel_pmc_ipc driver, a symmetrical allocation and free fix in
dell-laptop, a couple minor fixes, and some updated documentation in
the dell-laptop comments.
intel_pmc_ipc:
- Add Intel Apollo Lake PMC IPC driver
tc1100-wmi:
- Delete an unnecessary check before the function call "kfree"
dell-laptop:
- Fix allocating & freeing SMI buffer page
- Show info about WiGig and UWB in debugfs
- Update information about wireless control"
* tag 'platform-drivers-x86-v4.2-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
intel_pmc_ipc: Add Intel Apollo Lake PMC IPC driver
tc1100-wmi: Delete an unnecessary check before the function call "kfree"
dell-laptop: Fix allocating & freeing SMI buffer page
dell-laptop: Show info about WiGig and UWB in debugfs
dell-laptop: Update information about wireless control
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull module_platform_driver replacement from Paul Gortmaker:
"Replace module_platform_driver with builtin_platform driver in non
modules.
We see an increasing number of non-modular drivers using
modular_driver() type register functions. There are several downsides
to letting this continue unchecked:
- The code can appear modular to a reader of the code, and they won't
know if the code really is modular without checking the Makefile
and Kconfig to see if compilation is governed by a bool or
tristate.
- Coders of drivers may be tempted to code up an __exit function that
is never used, just in order to satisfy the required three args of
the modular registration function.
- Non-modular code ends up including the <module.h> which increases
CPP overhead that they don't need.
- It hinders us from performing better separation of the module init
code and the generic init code.
So here we introduce similar macros for builtin drivers. Then we
convert builtin drivers (controlled by a bool Kconfig) by making the
following type of mapping:
module_platform_driver() ---> builtin_platform_driver()
module_platform_driver_probe() ---> builtin_platform_driver_probe().
The set of drivers that are converted here are just the ones that
showed up as relying on an implicit include of <module.h> during a
pending header cleanup. So we convert them here vs adding an include
of <module.h> to non-modular code to avoid compile fails. Additonal
conversions can be done asynchronously at any time.
Once again, an unused module_exit function that is removed here
appears in the diffstat as an outlier wrt all the other changes"
* tag 'module-builtin_driver-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
drivers/clk: convert sunxi/clk-mod0.c to use builtin_platform_driver
drivers/power: Convert non-modular syscon-reboot to use builtin_platform_driver
drivers/soc: Convert non-modular soc-realview to use builtin_platform_driver
drivers/soc: Convert non-modular tegra/pmc to use builtin_platform_driver
drivers/cpufreq: Convert non-modular s5pv210-cpufreq.c to use builtin_platform_driver
drivers/cpuidle: Convert non-modular drivers to use builtin_platform_driver
drivers/platform: Convert non-modular pdev_bus to use builtin_platform_driver
platform_device: better support builtin boilerplate avoidance
Pull x86 platform driver updates from Darren Hart:
"Fairly routine update for platform-drivers-x86.
Mostly fixes and cleanups, with a significant refactoring of toshiba*
drivers. Includes the addition of the dell-rbtn driver.
Details:
asus-wmi:
- fan control
dell*:
- add Dell airplane mode switch driver
ideapad-laptop:
- platform rfkill fixes, and regression fix
pvpanic:
- handle missing _STA correctly
toshiba*:
- rafactor bluetooth support
- haps documentation
- driver cleanup
other:
- Use acpi_video_unregister_backlight instead of
acpi_video_unregister in serveral drivers.
- Orphan msi-wmi.
* tag 'platform-drivers-x86-v4.2-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (24 commits)
MAINTAINERS: Orphan x86 driver msi-wmi
ideapad: fix software rfkill setting
dell-laptop: Use dell-rbtn instead i8042 filter when possible
dell-rbtn: Export notifier for other kernel modules
dell-rbtn: Dell Airplane Mode Switch driver
samsung-laptop: Use acpi_video_unregister_backlight instead of acpi_video_unregister
asus-wmi: Use acpi_video_unregister_backlight instead of acpi_video_unregister
apple_gmux: Use acpi_video_unregister_backlight instead of acpi_video_unregister
pvpanic: handle missing _STA correctly
ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked
asus-wmi: add fan control
Documentation/ABI: Add file describing the sysfs entries for toshiba_haps
toshiba_haps: Make use of DEVICE_ATTR_{RW, WO} macros
toshiba_haps: Replace sscanf with kstrtoint
toshiba_acpi: Bump driver version to 0.22
toshiba_acpi: Remove TOS_FAILURE check from some functions
toshiba_acpi: Comments cleanup
toshiba_acpi: Rename hci_{read, write}1 functions
toshiba_acpi: Remove no longer needed hci_{read, write}2 functions
toshiba_bluetooth: Change BT status message to debug
This driver provides support for PMC control on Apollo Lake platforms.
The PMC is an ARC processor which defines some IPC commands for
communication with other entities in the CPU.
[fengguang.wu@intel.com: Fix Sparse and Cocinelle warnings]
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
The kfree() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big, really big, staging tree patches for 4.2-rc1.
Loads of stuff in here, almost all just coding style fixes / churn,
and a few new drivers as well, one of which I just disabled from the
build a few minutes ago due to way too many build warnings.
Other than the one "disable this driver" patch, all of these have been
in linux-next for quite a while with no reported issues"
* tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits)
staging: wilc1000: disable driver due to build warnings
Staging: rts5208: fix CHANGE_LINK_STATE value
Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis
Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines
Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators
Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs
Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters
Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs
Staging: sm750fb: modedb.h: Shorten lines to under 80 characters
Staging: sm750fb: modedb.h: Replace spaces with tabs
staging: comedi: addi_apci_3120: rename 'this_board' variables
staging: comedi: addi_apci_1516: rename 'this_board' variables
staging: comedi: ni_atmio: cleanup ni_getboardtype()
staging: comedi: vmk80xx: sanity check context used to get the boardinfo
staging: comedi: vmk80xx: rename 'boardinfo' variables
staging: comedi: dt3000: rename 'this_board' variables
staging: comedi: adv_pci_dio: rename 'this_board' variables
staging: comedi: cb_pcidas64: rename 'thisboard' variables
staging: comedi: cb_pcidas: rename 'thisboard' variables
staging: comedi: me4000: rename 'thisboard' variables
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
"Specifics:
- enhance Thermal Framework with several new capabilities:
* use power estimates
* compute weights with relative integers instead of percentages
* allow governors to have private data in thermal zones
* export thermal zone parameters through sysfs
Thanks to the ARM thermal team (Javi, Punit, KP).
- introduce a new thermal governor: power allocator. First in kernel
closed loop PI(D) controller for thermal control. Thanks to ARM
thermal team.
- enhance OF thermal to allow thermal zones to have sustainable power
HW specification. Thanks to Punit.
- introduce thermal driver for Intel Quark SoC x1000platform. Thanks
to Ong, Boon Leong.
- introduce QPNP PMIC temperature alarm driver. Thanks to Ivan T. I.
- introduce thermal driver for Hisilicon hi6220. Thanks to
kongxinwei.
- enhance Exynos thermal driver to handle Exynos5433 TMU. Thanks to
Chanwoo C.
- TI thermal driver now has a better implementation for EOCZ bit.
From Pavel M.
- add id for Skylake processors in int340x processor thermal driver.
- a couple of small fixes and cleanups."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (36 commits)
thermal: hisilicon: add new hisilicon thermal sensor driver
dt-bindings: Document the hi6220 thermal sensor bindings
thermal: of-thermal: add support for reading coefficients property
thermal: support slope and offset coefficients
thermal: power_allocator: round the division when divvying up power
thermal: exynos: Add the support for Exynos5433 TMU
thermal: cpu_cooling: Fix power calculation when CPUs are offline
thermal: cpu_cooling: Remove cpu_dev update on policy CPU update
thermal: export thermal_zone_parameters to sysfs
thermal: cpu_cooling: Check memory allocation of power_table
ti-soc-thermal: request temperature periodically if hw can't do that itself
ti-soc-thermal: implement eocz bit to make driver useful on omap3
cleanup ti-soc-thermal
thermal: remove stale THERMAL_POWER_ACTOR select
thermal: Default OF created trip points to writable
thermal: core: Add Kconfig option to enable writable trips
thermal: x86_pkg_temp: drop const for thermal_zone_parameters
of: thermal: Introduce sustainable power for a thermal zone
thermal: add trace events to the power allocator governor
thermal: introduce the Power Allocator governor
This commit fix kernel crash when probing for rfkill devices in dell-laptop
driver failed. Function free_page() was incorrectly used on struct page *
instead of virtual address of SMI buffer.
This commit also simplify allocating page for SMI buffer by using
__get_free_page() function instead of sequential call of functions
alloc_page() and page_address().
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: stable@vger.kernel.org
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- Constify structures; throughout the subsystem
- Move support to DT in; cros_ec
- DT changes and documentation; cros-ec, max77693, max77686, arizona, da9063
- ACPI changes and documentation; mfd-core
- Use different platform specific API in; cros_ec_*, arizona-core
- Remove unused parent field from; cros_ec_i2c
- Add wake-up/reset delay in; cross_ec_spi, arizona-core
- Staticise structures/functions in; cros_ec
- Remove redundant code; arizona-core, max77686
- Bugfix; twl4030-power
- Allow compile test; aat2870, tps65910
- MAINTAINERS adaptions; samsung, syscon
- Resource Management (devm_*); arizona-core
- Refactor Reset code; arizona-core
- Insist on at least one full boot; arizona-core
- Trivial formatting; arizona-core
- Add low-power-sleep; arizona-core
- IRQ ONESHOT changes; twl4030-irq, mc13xxx-core, wm831x-auxadc, htc-i2cpld,
wm8350-core, ab8500-debugfs, ab8500-gpadc, si476x-i2c
(Re-)moved drivers:
- Move protocol helpers out to drivers/platform; cros_ec
New drivers/supported devices:
- Add support for AXP22x into axp20x
- Add support for OnKey into da9063-core
- Add support for Pinctrl into mt6397-core
- New STMicroelectronics LPC Watchdog driver
- New STMicroelectronics LPC Real-Time Clock driver"
* tag 'mfd-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (59 commits)
mfd: lpc_ich: Assign subdevice ids automatically
mfd: si476x-i2c: Pass the IRQF_ONESHOT flag
mfd: ab8500-gpadc: Pass the IRQF_ONESHOT flag
mfd: ab8500-debugfs: Pass the IRQF_ONESHOT flag
mfd: wm8350-core: Pass the IRQF_ONESHOT flag
mfd: htc-i2cpld: Pass the IRQF_ONESHOT flag
mfd: wm831x-auxadc: Pass the IRQF_ONESHOT flag
mfd: mc13xxx-core: Pass the IRQF_ONESHOT flag
mfd: twl4030-irq: Pass the IRQF_ONESHOT flag
mfd: mt6397-core: Add GPIO sub-module support
mfd: arizona: Add convience defines for micd_rate/micd_bias_starttime
mfd: dt: Add bindings for DA9063 OnKey
mfd: da9063: Add support for OnKey driver
mfd: arizona: Fix incorrect Makefile conditionals
mfd: arizona: Add stub for wm5102_patch()
mfd: Check ACPI device companion before checking resources
Documentation: Add WM8998/WM1814 device tree bindings
mfd: arizona: Split INx_MODE into two fields
mfd: wm5110: Add delay before releasing reset line
mfd: arizona: Add better support for system suspend
Pull power management and ACPI updates from Rafael Wysocki:
"The rework of backlight interface selection API from Hans de Goede
stands out from the number of commits and the number of affected
places perspective. The cpufreq core fixes from Viresh Kumar are
quite significant too as far as the number of commits goes and because
they should reduce CPU online/offline overhead quite a bit in the
majority of cases.
From the new featues point of view, the ACPICA update (to upstream
revision 20150515) adding support for new ACPI 6 material to ACPICA is
the one that matters the most as some new significant features will be
based on it going forward. Also included is an update of the ACPI
device power management core to follow ACPI 6 (which in turn reflects
the Windows' device PM implementation), a PM core extension to support
wakeup interrupts in a more generic way and support for the ACPI _CCA
device configuration object.
The rest is mostly fixes and cleanups all over and some documentation
updates, including new DT bindings for Operating Performance Points.
There is one fix for a regression introduced in the 4.1 cycle, but it
adds quite a number of lines of code, it wasn't really ready before
Thursday and you were on vacation, so I refrained from pushing it on
the last minute for 4.1.
Specifics:
- ACPICA update to upstream revision 20150515 including basic support
for ACPI 6 features: new ACPI tables introduced by ACPI 6 (STAO,
XENV, WPBT, NFIT, IORT), changes related to the other tables (DTRM,
FADT, LPIT, MADT), new predefined names (_BTH, _CR3, _DSD, _LPI,
_MTL, _PRR, _RDI, _RST, _TFP, _TSN), fixes and cleanups (Bob Moore,
Lv Zheng).
- ACPI device power management core code update to follow ACPI 6
which reflects the ACPI device power management implementation in
Windows (Rafael J Wysocki).
- rework of the backlight interface selection logic to reduce the
number of kernel command line options and improve the handling of
DMI quirks that may be involved in that and to make the code
generally more straightforward (Hans de Goede).
- fixes for the ACPI Embedded Controller (EC) driver related to the
handling of EC transactions (Lv Zheng).
- fix for a regression related to the ACPI resources management and
resulting from a recent change of ACPI initialization code ordering
(Rafael J Wysocki).
- fix for a system initialization regression related to ACPI
introduced during the 3.14 cycle and caused by running the code
that switches the platform over to the ACPI mode too early in the
initialization sequence (Rafael J Wysocki).
- support for the ACPI _CCA device configuration object related to
DMA cache coherence (Suravee Suthikulpanit).
- ACPI/APEI fixes and cleanups (Jiri Kosina, Borislav Petkov).
- ACPI battery driver cleanups (Luis Henriques, Mathias Krause).
- ACPI processor driver cleanups (Hanjun Guo).
- cleanups and documentation update related to the ACPI device
properties interface based on _DSD (Rafael J Wysocki).
- ACPI device power management fixes (Rafael J Wysocki).
- assorted cleanups related to ACPI (Dominik Brodowski, Fabian
Frederick, Lorenzo Pieralisi, Mathias Krause, Rafael J Wysocki).
- fix for a long-standing issue causing General Protection Faults to
be generated occasionally on return to user space after resume from
ACPI-based suspend-to-RAM on 32-bit x86 (Ingo Molnar).
- fix to make the suspend core code return -EBUSY consistently in all
cases when system suspend is aborted due to wakeup detection (Ruchi
Kandoi).
- support for automated device wakeup IRQ handling allowing drivers
to make their PM support more starightforward (Tony Lindgren).
- new tracepoints for suspend-to-idle tracing and rework of the
prepare/complete callbacks tracing in the PM core (Todd E Brandt,
Rafael J Wysocki).
- wakeup sources framework enhancements (Jin Qian).
- new macro for noirq system PM callbacks (Grygorii Strashko).
- assorted cleanups related to system suspend (Rafael J Wysocki).
- cpuidle core cleanups to make the code more efficient (Rafael J
Wysocki).
- powernv/pseries cpuidle driver update (Shilpasri G Bhat).
- cpufreq core fixes related to CPU online/offline that should reduce
the overhead of these operations quite a bit, unless the CPU in
question is physically going away (Viresh Kumar, Saravana Kannan).
- serialization of cpufreq governor callbacks to avoid race
conditions in some cases (Viresh Kumar).
- intel_pstate driver fixes and cleanups (Doug Smythies, Prarit
Bhargava, Joe Konno).
- cpufreq driver (arm_big_little, cpufreq-dt, qoriq) updates (Sudeep
Holla, Felipe Balbi, Tang Yuantian).
- assorted cleanups in cpufreq drivers and core (Shailendra Verma,
Fabian Frederick, Wang Long).
- new Device Tree bindings for representing Operating Performance
Points (Viresh Kumar).
- updates for the common clock operations support code in the PM core
(Rajendra Nayak, Geert Uytterhoeven).
- PM domains core code update (Geert Uytterhoeven).
- Intel Knights Landing support for the RAPL (Running Average Power
Limit) power capping driver (Dasaratharaman Chandramouli).
- fixes related to the floor frequency setting on Atom SoCs in the
RAPL power capping driver (Ajay Thomas).
- runtime PM framework documentation update (Ben Dooks).
- cpupower tool fix (Herton R Krzesinski)"
* tag 'pm+acpi-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (194 commits)
cpuidle: powernv/pseries: Auto-promotion of snooze to deeper idle state
x86: Load __USER_DS into DS/ES after resume
PM / OPP: Add binding for 'opp-suspend'
PM / OPP: Allow multiple OPP tables to be passed via DT
PM / OPP: Add new bindings to address shortcomings of existing bindings
ACPI: Constify ACPI device IDs in documentation
ACPI / enumeration: Document the rules regarding the PRP0001 device ID
ACPI / video: Make acpi_video_unregister_backlight() private
acpi-video-detect: Remove old API
toshiba-acpi: Port to new backlight interface selection API
thinkpad-acpi: Port to new backlight interface selection API
sony-laptop: Port to new backlight interface selection API
samsung-laptop: Port to new backlight interface selection API
msi-wmi: Port to new backlight interface selection API
msi-laptop: Port to new backlight interface selection API
intel-oaktrail: Port to new backlight interface selection API
ideapad-laptop: Port to new backlight interface selection API
fujitsu-laptop: Port to new backlight interface selection API
eeepc-laptop: Port to new backlight interface selection API
dell-wmi: Port to new backlight interface selection API
Pull trivial tree updates from Jiri Kosina:
"As usual, mostly comment, kerneldoc and printk() fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
lpfc: Grammar s/an negative/a negative/
ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/
cx25821: cx25821-medusa-reg.h: fix 0x0x prefix
lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants
rapidio: Fix kerneldoc and comment
qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config()
treewide: Kconfig: fix wording / spelling
usb/serial: fix grammar in Kconfig help text for FTDI_SIO
megaraid_sas: fix kerneldoc
netfilter: ebtables: fix comment grammar
drm/radeon: fix comment
isdn: fix grammar in comment
ARM: KVM: fix comment
This commit show additional information about rfkill state in debugfs based
on newly released documentation by Dell.
Make sure that all existing SMBIOS calls for wireless control are properly
documented. This commit also add new documentation released by Dell.
Port the backlight selection logic to the new backlight interface
selection API.
Acked-by: Azael Avalos <coproscefalo@gmail.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
selection API.
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
selection API.
This commit also removes various obsolete pr_xxx messages related to
backlight interface selection. These are obsolete because they assume
there is only a vendor or acpi backlight driver and no other choice.
Also they are not necessary, if the user wants to know which backlight
interfaces are registered a simple "ls /sys/class/backlight" suffices.
Acked-by: Mattia Dongili <malattia@linux.it>
selection API.
selection API.
selection API.
selection API.
selection API.
selection API.
Acked-by: Jonathan Woithe <jwoithe@just42.net>
selection API.
selection API.
Acked-by: Pali Rohár <pali.rohar@gmail.com>
selection API.
selection API.
selection API.
selection API.
selection API.
selection API.
Reviewed-by: Lee, Chun-Yi <jlee@suse.com>
This is a preparation patch for the backlight interface selection logic
cleanup, there are 2 reasons to not always build the video_detect code
into the kernel:
1) In order for the video_detect.c to also deal with / select native
backlight interfaces on win8 systems, instead of doing this in video.c
where it does not belong, video_detect.c needs to call into the backlight
class code. Which cannot be done if it is builtin and the blacklight class
is not.
2) Currently all the platform/x86 drivers which have quirks to prefer
the vendor driver over acpi-video call acpi_video_unregister_backlight()
to remove the acpi-video backlight interface, this logic really belongs
in video_detect.c, which will cause video_detect.c to depend on symbols of
video.c and video.c already depends on video_detect.c symbols, so they
really need to be a single module.
Note that this commits make 2 changes so as to maintain 100% kernel
commandline compatibility:
1) The __setup call for the acpi_backlight= handling is moved to
acpi/util.c as __setup may only be used by code which is alwasy builtin
2) video.c is renamed to acpi_video.c so that it can be combined with
video_detect.c into video.ko
This commit also makes changes to drivers/platform/x86/Kconfig to ensure
that drivers which use acpi_video_backlight_support() from video_detect.c,
will not be built-in when acpi_video is not built in. This also changes
some "select" uses to "depends on" to avoid dependency loops.
acpi_video_dmi_demote_vendor() is going away as part of the cleanup of
the code for determinging which backlight class driver(s) to register.
The call to acpi_video_dmi_demote_vendor() was meant to undo the call to
acpi_video_dmi_promote_vendor() when the gmux device is removed, this is
questionable though since the promote call sets a flag, not a counter, so
the demote call may undo a promoto done elsewhere. Moreover in practice
this is a nop since the gmux device is never removed, and the flag is only
checked when acpi/video.ko gets loaded, so even if the user manually
removes apple-gmux the demote call is still a nop as video.ko will already
have loaded by this time.
Also note that none of the other users of acpi_video_dmi_promote_vendor()
use acpi_video_dmi_demote_vendor().
If we ever encounter a system with a gmux where the acpi-video interface
should be used, then the proper fix would be to dmi-blacklist the gmux
driver on that system.
acpi_video_unregister() not only unregisters the acpi-video backlight
interface but also unregisters the acpi video bus event listener, causing
e.g. brightness hotkey presses to no longer generate keypress events.
The unregistering of the acpi video bus event listener usually is
undesirable, which by itself is a good reason to switch to
acpi_video_unregister_backlight().
Another problem with using acpi_video_unregister() rather then using
acpi_video_unregister_backlight() is that on systems with an intel video
opregion (most systems) and a broken_acpi_video quirk, whether or not
the acpi video bus event listener actually gets unregistered depends on
module load ordering:
Scenario a:
1) acpi/video.ko gets loaded (*), does not do acpi_video_register as there
is an intel opregion.
2) intel.ko gets loaded, calls acpi_video_register() which registers both
the listener and the acpi backlight interface
3) samsung-laptop.ko gets loaded, calls acpi_video_unregister() causing
both the listener and the acpi backlight interface to unregister
Scenario b:
2) samsung-laptop.ko gets loaded, calls acpi_video_dmi_promote_vendor(),
calls acpi_video_unregister(), which is a nop since acpi_video_register
has not yet been called
the listener, but does not register the acpi backlight interface due to
the call to the preciding call to acpi_video_dmi_promote_vendor()
*) acpi/video.ko always loads first as both other modules depend on it.
So we end up with or without an acpi video bus event listener depending
on module load ordering, not good.
Switching to using acpi_video_unregister_backlight() means that independ
of ordering we will always have an acpi video bus event listener fixing
this.
Note that this commit means that systems without an intel video opregion,
and systems which were hitting scenario a wrt module load ordering, are
now getting an acpi video bus event listener while before they were not!
On some systems this may cause the brightness hotkeys to start generating
keypresses while before they were not (good), while on other systems this
may cause the brightness hotkeys to generate multiple keypress events for
a single press (not so good). Since on most systems the acpi video bus is
the canonical source for brightness events I believe that the latter case
will needs to be handled on a case by case basis by filtering out the
duplicate keypresses at the other source for them.
Cc: Corentin Chary <corentin.chary@gmail.com>
opregion (most systems) and a wmi_backlight_power quirk, whether or not
Scenario a:
3) asus-wmi.ko gets loaded, calls acpi_video_unregister() causing both
Scenario b:
2) asus-wmi.ko gets loaded, calls acpi_video_dmi_promote_vendor(),
this.
opregion (most systems) whether or not the acpi video bus event listener
actually gets unregistered depends on module load ordering:
Scenario a:
3) apple-gmux.ko gets loaded, calls acpi_video_unregister() causing both
Scenario b:
2) apple-gmux.ko gets loaded, calls acpi_video_dmi_promote_vendor(),
this.
Cc: Seth Forshee <seth.forshee@canonical.com>
This driver is configured with a Kconfig option that is
declared as a bool. Hence it is not possible for the code
to be built as modular. However the code is currently using
the module_platform_driver() macro for driver registration.
While this currently works, we really don't want to be including
the module.h header in non-modular code, which we'll be forced
to do, pending some upcoming code relocation from init.h into
module.h. So we fix it now by using the non-modular equivalent.
And since we've already established that the code is non-modular,
we can completely drop any code relating to module_exit.
This fixes a several year old regression that I found while trying
to get the Yoga 3 11 to work. The ideapad_rfk_set function is meant
to send a command to the embedded controller through ACPI, but
as of c1f73658ed, it sends the index of the rfkill device instead
of the command, and ignores the opcode field.
This changes it back to the original behavior, which indeed
flips the rfkill state as seen in the debugfs interface.
Fixes: c1f73658ed ("ideapad: pass ideapad_priv as argument (part 2)")
Cc: stable@vger.kernel.org # v2.6.38+
Chromebooks can have more than one Embedded Controller so the
cros_ec device id has to be incremented for each EC registered.
Add a new structure to represent multiple EC as different char
devices (e.g: /dev/cros_ec, /dev/cros_pd). It connects to
cros_ec_device and allows sysfs inferface for cros_pd.
Also reduce number of allocated objects, make chromeos sysfs
class object a static and add refcounting to prevent object
deletion while command is in progress.
Signed-off-by: Gwendal Grignou <gwendal@chromium.org>
Reviewed-by: Dmitry Torokhov <dtor@chromium.org>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Lee Jones <lee.jones@linaro.org>
