path: root/drivers/platform
2016-09-07mfd: cros_ec: Add cros_ec_cmd_xfer_status() helperTomeu Vizoso
commit 9798ac6d32c1a32d6d92d853ff507d2d39c4300c upstream. So that callers of cros_ec_cmd_xfer() don't have to repeat boilerplate code when checking for errors from the EC side. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Reviewed-by: Benson Leung <bleung@chromium.org> Signed-off-by: Brian Norris <briannorris@chromium.org> Acked-by: Lee Jones <lee.jones@linaro.org> Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20hp-wmi: Fix wifi cannot be hard-unblockedAlex Hung
commit fc8a601e1175ae351f662506030f9939cb7fdbfe upstream. Several users reported wifi cannot be unblocked as discussed in [1]. This patch removes the use of the 2009 flag by BIOS but uses the actual WMI function calls - it will be skipped if WMI reports unsupported. [1] https://bugzilla.kernel.org/show_bug.cgi?id=69131 Signed-off-by: Alex Hung <alex.hung@canonical.com> Tested-by: Evgenii Shatokhin <eugene.shatokhin@yandex.ru> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10platform/chrome: cros_ec_dev - double fetch bug in ioctlDan Carpenter
commit 096cdc6f52225835ff503f987a0d68ef770bb78e upstream. We verify "u_cmd.outsize" and "u_cmd.insize" but we need to make sure that those values have not changed between the two copy_from_user() calls. Otherwise it could lead to a buffer overflow. Additionally, cros_ec_cmd_xfer() can set s_cmd->insize to a lower value. We should use the new smaller value so we don't copy too much data to the user. Reported-by: Pengfei Wang <wpengfeinudt@gmail.com> Fixes: a841178445bb ('mfd: cros_ec: Use a zero-length array for command data') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Kees Cook <keescook@chromium.org> Tested-by: Gwendal Grignou <gwendal@chromium.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01dell-rbtn: Ignore ACPI notifications if device is suspendedGabriele Mazzotta
commit ff8651237f39cea60dc89b2d9f25d9ede3fc82c0 upstream. Some BIOSes unconditionally send an ACPI notification to RBTN when the system is resuming from suspend. This makes dell-rbtn send an input event to userspace as if a function key was pressed. Prevent this by ignoring all the notifications received while the device is suspended. Link: https://bugzilla.kernel.org/show_bug.cgi?id=106031 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Tested-by: Alex Hung <alex.hung@canonical.com> Reviewed-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04toshiba_acpi: Fix regression caused by hotkey enabling valueAzael Avalos
commit a30b8f81d9d6fe24eab8a023794548b048f08e3c upstream. Commit 52cbae0127ad ("toshiba_acpi: Change default Hotkey enabling value") changed the hotkeys enabling value, as it was the same value Windows uses, however, it turns out that the value tells the EC that the driver will now take care of the hardware events like the physical RFKill switch or the pointing device toggle button. This patch reverts such commit by changing the default hotkey enabling value to 0x09, which enables hotkey events only, making the hardware buttons working again. Fixes bugs 113331 and 114941. Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12ideapad-laptop: Add ideapad Y700 (15) to the no_hw_rfkill DMI listJohn Dahlstrom
commit 4db9675d927a71faa66e5ab128d2390d6329750b upstream. Some Lenovo ideapad models lack a physical rfkill switch. On Lenovo models ideapad Y700 Touch-15ISK and ideapad Y700-15ISK, ideapad-laptop would wrongly report all radios as blocked by hardware which caused wireless network connections to fail. Add these models without an rfkill switch to the no_hw_rfkill list. Signed-off-by: John Dahlstrom <jodarom@sdf.org> Cc: <stable@vger.kernel.org> # 3.17.x-: 4fa9dab: ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03ideapad-laptop: Add Lenovo Yoga 700 to no_hw_rfkill dmi listJosh Boyer
commit 6b31de3e698582fe0b8f7f4bab15831b73204800 upstream. Like the Yoga 900 models the Lenovo Yoga 700 does not have a hw rfkill switch, and trying to read the hw rfkill switch through the ideapad module causes it to always reported blocking breaking wifi. This commit adds the Lenovo Yoga 700 to the no_hw_rfkill dmi list, fixing the wifi breakage. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1295272 Tested-by: <dinyar.rabady+spam@gmail.com> Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03ideapad-laptop: Add Lenovo ideapad Y700-17ISK to no_hw_rfkill dmi listJosh Boyer
commit edde316acb5f07c04abf09a92f59db5d2efd14e2 upstream. One of the newest ideapad models also lacks a physical hw rfkill switch, and trying to read the hw rfkill switch through the ideapad module causes it to always reported blocking breaking wifi. Fix it by adding this model to the DMI list. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1286293 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03toshiba_acpi: Fix blank screen at boot if transflective backlight is supportedAzael Avalos
commit bae5336f0aaedffa115dab9cb3d8a4e4aed3a26a upstream. If transflective backlight is supported and the brightness is zero (lowest brightness level), the set_lcd_brightness function will activate the transflective backlight, making the LCD appear to be turned off. This patch fixes the issue by incrementing the brightness level, and by doing so, avoiding the activation of the tranflective backlight. Reported-and-tested-by: Fabian Koester <fabian.koester@bringnow.com> Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25intel_scu_ipcutil: underflow in scu_reg_access()Dan Carpenter
commit b1d353ad3d5835b16724653b33c05124e1b5acf1 upstream. "count" is controlled by the user and it can be negative. Let's prevent that by making it unsigned. You have to have CAP_SYS_RAWIO to call this function so the bug is not as serious as it could be. Fixes: 5369c02d951a ('intel_scu_ipc: Utility driver for intel scu ipc') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-13Merge tag 'chrome-platform-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform Pull chrome platform updates from Olof Johansson: "Here's the branch of chrome platform changes for v4.4. Some have been queued up for the full 4.3 release cycle since I forgot to send them in for that round (rebased early on to deal with fixes conflicts). Most of these enable EC communication stuff -- Pixel 2015 support, enabling building for ARM64 platforms, and a few fixes for memory leaks. There's also a patch in here to allow reading/writing the verified boot context, which depends on a sysfs patch acked by Greg" * tag 'chrome-platform-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform: platform/chrome: Fix i2c-designware adapter name platform/chrome: Support reading/writing the vboot context sysfs: Support is_visible() on binary attributes platform/chrome: cros_ec: Fix possible leak in led_rgb_store() platform/chrome: cros_ec: Fix leak in sequence_store() platform/chrome: Enable Chrome platforms on 64-bit ARM platform/chrome: cros_ec_dev - Add a platform device ID table platform/chrome: cros_ec_lpc - Add support for Google Pixel 2 platform/chrome: cros_ec_lpc - Use existing function to check EC result platform/chrome: Make depends on MFD_CROS_EC instead CROS_EC_PROTO Revert "platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM"
2015-11-13Merge tag 'platform-drivers-x86-v4.4-2' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull another x86 platform driver update from Darren Hart: "Support for the unfortunately rather unique ESC key on the Ideapad Yoga 3 and two DMI matches for rfkill support. Solitary fix for potential missed errors for asus-wmi. Downgrade a thinkpad_acpi message to info. asus-wmi: - fix error handling in store_sys_wmi() ideapad-laptop: - Add Lenovo Yoga 900 to no_hw_rfkill dmi list - include Yoga 3 1170 in add rfkill whitelist - add support for Yoga 3 ESC key thinkpad_acpi: - Don't yell on unsupported brightness interfaces" * tag 'platform-drivers-x86-v4.4-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: asus-wmi: fix error handling in store_sys_wmi() ideapad-laptop: Add Lenovo Yoga 900 to no_hw_rfkill dmi list ideapad-laptop: include Yoga 3 1170 in add rfkill whitelist ideapad-laptop: add support for Yoga 3 ESC key thinkpad_acpi: Don't yell on unsupported brightness interfaces
2015-11-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal updates from Zhang Rui: - Implement generic devfreq cooling mechanism through frequency reduction for devices using devfreq. From Ørjan Eide and Javi Merino. - Introduce OMAP3 support on TI SoC thermal driver. From Pavel Mack and Eduardo Valentin. - A bounch of small fixes on devfreq_cooling, Exynos, IMX, Armada, and Rockchip thermal drivers. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (24 commits) thermal: exynos: Directly return 0 instead of using local ret variable thermal: exynos: Remove unneeded semicolon thermal: exynos: Use IS_ERR() because regulator cannot be NULL thermal: exynos: Fix first temperature read after registering sensor thermal: exynos: Fix unbalanced regulator disable on probe failure devfreq_cooling: return on allocation failure thermal: rockchip: support the sleep pinctrl state to avoid glitches in s2r dt-bindings: rockchip-thermal: Add the pinctrl states in this document thermal: devfreq_cooling: Make power a u64 thermal: devfreq_cooling: use a thermal_cooling_device for register and unregister thermal: underflow bug in imx_set_trip_temp() thermal: armada: Fix possible overflow in the Armada 380 thermal sensor formula thermal: imx: register irq handler later in probe thermal: rockhip: fix setting thermal shutdown polarity thermal: rockchip: fix handling of invalid readings devfreq_cooling: add trace information thermal: Add devfreq cooling PM / OPP: get the voltage for all OPPs tools/thermal: tmon: use pkg-config also for CFLAGS linux/thermal.h: rename KELVIN_TO_CELSIUS to DECI_KELVIN_TO_CELSIUS ...
2015-11-10asus-wmi: fix error handling in store_sys_wmi()Dan Carpenter
The asus_wmi_get_devstate_simple() returns 0-1 on success. In theory according to static checkers, it can return either -EIO or -ENODEV on failure. Currently the error handling code only handles -ENODEV and -EIO is treated as success. Let's make it handle the -EIO error as well. It's possible that it can't actually return -EIO and this patch is not needed but in that case this patch is harmless and silences a static checker warning so it's still worth it. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-11-10Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "I Was Almost Tempted To Capitalise Every Word, but then I decided I couldn't read it myself! I've also got one pull request for the sti driver outstanding. It relied on a commit in Greg's tree and I didn't find out in time, that commit is in your tree now so I might send that along once this is merged. I also had the accidental misfortune to have access to a Skylake on my desk for a few days, and I've had to encourage Intel to try harder, which seems to be happening now. Here is the main drm-next pull request for 4.4. Highlights: New driver: vc4 driver for the Rasberry Pi VPU. (From Eric Anholt at Broadcom.) Core: Atomic fbdev support Atomic helpers for runtime pm dp/aux i2c STATUS_UPDATE handling struct_mutex usage cleanups. Generic of probing support. Documentation: Kerneldoc for VGA switcheroo code. Rename to gpu instead of drm to reflect scope. i915: Skylake GuC firmware fixes HPD A support VBT backlight fallbacks Fastboot by default for some systems FBC work BXT/SKL workarounds Skylake deeper sleep state fixes amdgpu: Enable GPU scheduler by default New atombios opcodes GPUVM debugging options Stoney support. Fencing cleanups. radeon: More efficient CS checking nouveau: gk20a instance memory handling improvements. Improved PGOB detection and GK107 support Kepler GDDR5 PLL statbility improvement G8x/GT2xx reclock improvements new userspace API compatiblity fixes. virtio-gpu: Add 3D support - qemu 2.5 has it merged for it's gtk backend. msm: Initial msm88896 (snapdragon 8200) exynos: HDMI cleanups Enable mixer driver byt default Add DECON-TV support vmwgfx: Move to using memremap + fixes. rcar-du: Add support for R8A7793/4 DU armada: Remove support for non-component mode Improved plane handling Power savings while in DPMS off. tda998x: Remove unused slave encoder support Use more HDMI helpers Fix EDID read handling dwhdmi: Interlace video mode support for ipu-v3/dw_hdmi Hotplug state fixes Audio driver integration imx: More color formats support. tegra: Minor fixes/improvements" [ Merge fixup: remove unused variable 'dev' that had all uses removed in commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from drm_gem_mmap_obj" ] * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits) drm/vmwgfx: Relax irq locking somewhat drm/vmwgfx: Properly flush cursor updates and page-flips drm/i915/skl: disable display side power well support for now drm/i915: Extend DSL readout fix to BDW and SKL. drm/i915: Do graphics device reset under forcewake drm/i915: Skip fence installation for objects with rotated views (v4) vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT drm/amdgpu: group together common fence implementation drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE drm/amdgpu: remove now unused fence functions drm/amdgpu: fix fence fallback check drm/amdgpu: fix stoping the scheduler timeout drm/amdgpu: cleanup on error in amdgpu_cs_ioctl() drm/i915: Fix locking around GuC firmware load drm/amdgpu: update Fiji's Golden setting drm/amdgpu: update Fiji's rev id drm/amdgpu: extract common code in vi_common_early_init drm/amd/scheduler: don't oops on failure to load drm/amdgpu: don't oops on failure to load (v2) drm/amdgpu: don't VT switch on suspend ...
2015-11-09platform/chrome: Fix i2c-designware adapter nameJarkko Nikula
Commit d80d134182ba ("i2c: designware: Move common probe code into i2c_dw_probe()") caused the I2C adapter lookup code here to fail for PCI enumerated i2c-designware because commit changed the adapter name but didn't update it here. Fix the I2C adapter lookup by using the "Synopsys DesignWare I2C adapter" name. Reported-by: Jeremiah Mahler <jmmahler@gmail.com> Fixes: d80d134182ba ("i2c: designware: Move common probe code into i2c_dw_probe()") Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Tested-by: Jeremiah Mahler <jmmahler@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-11-09ideapad-laptop: Add Lenovo Yoga 900 to no_hw_rfkill dmi listHans de Goede
Like some of the other Yoga models the Lenovo Yoga 900 does not have a hw rfkill switch, and trying to read the hw rfkill switch through the ideapad module causes it to always reported blocking breaking wifi. This commit adds the Lenovo Yoga 900 to the no_hw_rfkill dmi list, fixing the wifi breakage. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1275490 Cc: stable@vger.kernel.org Reported-and-tested-by: Kevin Fenzi <kevin@scrye.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-11-09ideapad-laptop: include Yoga 3 1170 in add rfkill whitelistArnd Bergmann
This changes the entry to the whitelist of machines that do not have a physical rfkill switch. Unfortunately, the Yoga 3 generation seems to use upper-case letters for the YOGA 3 Pro-1370, while it uses normal capitalization for its Yoga 3 1170 and 1470 siblings. In order to catch all variants of the Yoga 3, I'm changing both the entry for the 1470 (using "Yoga" as the name) and the entry for the Pro 1370 (using all-caps "YOGA") to not match the exact model number but only the generation. This way, the 1170 and 1470 models share one entry, but if the firmware changes from one format to the other, it will still work. The second entry for Yoga 2 Pro that was recently added for some reason ended up not being added in alphanumeric order, and I'm moving the Yoga 3 1470 entry down while making the change, so they are sorted more logically. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-11-09ideapad-laptop: add support for Yoga 3 ESC keyArnd Bergmann
The ideapad-laptop handles most special keys on various Lenovo Laptops including the Yoga line. Unfortunately, the Yoga 3 11/13/14 models have one important exception, which is the Fn-ESC combination. On other Lenovo Laptops, this is FnLock, which switches the function keys between the primary (Mute, Vol down, Vol up, ...) and the secondary (F1, F2, F3, ...) behavior. On the new machines, FnLock is only available through BIOS setup (possibly through a yet-to-be-implemented feature in this driver) but not through Fn-ESC, but instead the ESC key itself switched between ESC and a "Paper Display" app for Windows. Unfortunately, that means that you can never have both ESC *and* the function keys working at the same time without needing to press Fn on one of them. As pointed out in the official Lenovo Forum by dozens of users, this makes the machine rather useless for any serious work [1]. I have now studied the ACPI DSDT one more time and found the event that is generated for the ESC key. Unlike all other key events on this machine, it is actually a WMI, while the other ones are read from the embedded controller. I am now installing a WMI notifier that uses the event number from the WMI subsystem as the scancode. The only event number generated here is '128', and that fits in nicely with the two existing ranges of scancodes used by the EC: 0-15 for the 16-bit VPCCMD_R_VPC register, 16-17 for the VPCCMD_R_NOVO register and 64-67 for VPCCMD_R_SPECIAL_BUTTONS. The only sane way to handle this button (in absence of the Windows Paper Display driver) seems to be to have it emit KEY_ESC, so that is what I use as the default. Should any user ever want to overwrite the default, they can install their own keymap. To ensure that we can still build the driver without adding a CONFIG_WMI dependency, all new code is enclosed in #ifdef. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [1] https://forums.lenovo.com/t5/Lenovo-Yoga-Series-Notebooks/YOGA-3-14-How-to-reclaim-my-Esc-key-and-permanently-disable/td-p/2070816 Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-11-06Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanups from Arnd Bergmann: "The asm-generic changes for 4.4 are mostly a series from Christoph Hellwig to clean up various abuses of headers in there. The patch to rename the io-64-nonatomic-*.h headers caused some conflicts with new users, so I added a workaround that we can remove in the next merge window. The only other patch is a warning fix from Marek Vasut" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: temporarily add back asm-generic/io-64-nonatomic*.h asm-generic: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations gpio-mxc: stop including <asm-generic/bug> n_tracesink: stop including <asm-generic/bug> n_tracerouter: stop including <asm-generic/bug> mlx5: stop including <asm-generic/kmap_types.h> hifn_795x: stop including <asm-generic/kmap_types.h> drbd: stop including <asm-generic/kmap_types.h> move count_zeroes.h out of asm-generic move io-64-nonatomic*.h out of asm-generic
2015-11-06Merge tag 'mfd-for-linus-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "New Device Support: - Add support for 88pm860; 88pm80x - Add support for 24c08 EEPROM; at24 - Add support for Broxton Whiskey Cove; intel* - Add support for RTS522A; rts5227 - Add support for I2C devices; intel_quark_i2c_gpio New Functionality: - Add microphone support; arizona - Add general purpose switch support; arizona - Add fuel-gauge support; da9150-core - Add shutdown support; sec-core - Add charger support; tps65217 - Add flexible serial communication unit support; atmel-flexcom - Add power button support; axp20x - Add led-flash support; rt5033 Core Frameworks: - Supply a generic macro for defining Regmap IRQs - Rework ACPI child device matching Fix-ups: - Use Regmap to access registers; tps6105x - Use DEFINE_RES_IRQ_NAMED() macro; da9150 - Re-arrange device registration order; intel_quark_i2c_gpio - Allow OF matching; cros_ec_i2c, atmel-hlcdc, hi6421-pmic, max8997, sm501 - Handle deferred probe; twl6040 - Improve accuracy of headphone detect; arizona - Unnecessary MODULE_ALIAS() removal; bcm590xx, rt5033 - Remove unused code; htc-i2cpld, arizona, pcf50633-irq, sec-core - Simplify code; kempld, rts5209, da903x, lm3533, da9052, arizona - Remove #iffery; arizona - DT binding adaptions; many Bug Fixes: - Fix possible NULL pointer dereference; wm831x, tps6105x - Fix 64bit bug; intel_soc_pmic_bxtwc - Fix signedness issue; arizona" * tag 'mfd-for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (73 commits) bindings: mfd: s2mps11: Add documentation for s2mps15 PMIC mfd: sec-core: Remove unused s2mpu02-rtc and s2mpu02-clk children extcon: arizona: Add extcon specific device tree binding document MAINTAINERS: Add binding docs for Cirrus Logic/Wolfson Arizona devices mfd: arizona: Remove bindings covered in new subsystem specific docs mfd: rt5033: Add RT5033 Flash led sub device mfd: lpss: Add Intel Broxton PCI IDs mfd: lpss: Add Broxton ACPI IDs mfd: arizona: Signedness bug in arizona_runtime_suspend() mfd: axp20x: Add a cell for the power button part of the, axp288 PMICs mfd: dt-bindings: Document pulled down WRSTBI pin on S2MPS1X mfd: sec-core: Disable buck voltage reset on watchdog falling edge mfd: sec-core: Dump PMIC revision to find out the HW mfd: arizona: Use correct type ID for device tree config mfd: arizona: Remove use of codec build config #ifdefs mfd: arizona: Simplify adding subdevices mfd: arizona: Downgrade type mismatch messages to dev_warn mfd: arizona: Factor out checking of jack detection state mfd: arizona: Factor out DCVDD isolation control mfd: Make TPS6105X select REGMAP_I2C ...
2015-11-06thinkpad_acpi: Don't yell on unsupported brightness interfacesDavid Herrmann
The thinkpad_acpi driver currently emits error messages on unsupported brightness interfaces, giving the impression that someone will implement those. However, this error is spit out on nearly every thinkpad in production since 2 years now. Furthermore, the backlight interfaces on those devices are supported by the i915 driver just fine. Downgrade the error message to a normal pr_info() and stop telling people to report it to IBM. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-11-05toshiba_acpi: Initialize hotkey_event_type variableAzael Avalos
Commit 53147b6cabee5e8d1997b5682fcc0c3b72ddf9c2 ("toshiba_acpi: Fix hotkeys registration on some toshiba models") fixed an issue on some laptops regarding hotkeys registration, however, if failed to address the initialization of the hotkey_event_type variable, and thus, it can lead to potential unwanted effects as the variable is being checked. This patch initializes such variable to avoid such unwanted effects. Cc: <stable@vger.kernel.org> # 4.1+ Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-30platform: x86: PMC IPC depends on ACPILee Jones
This patch solves: on x86_64: when CONFIG_ACPI is not enabled: ../drivers/mfd/intel_soc_pmic_bxtwc.c: In function 'bxtwc_probe': ../drivers/mfd/intel_soc_pmic_bxtwc.c:342:2: error: implicit declaration of function 'acpi_evaluate_integer' [-Werror=implicit-function-declaration] status = acpi_evaluate_integer(handle, "_HRV", NULL, &hrv); ^ Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-10-20vga_switcheroo: Constify vga_switcheroo_handlerLukas Wunner
vga_switcheroo_client_ops has always been declared const since its introduction with 26ec685ff9d9 ("vga_switcheroo: Introduce struct vga_switcheroo_client_ops"). Do so for vga_switcheroo_handler as well. drivers/gpu/drm/amd/amdgpu/amdgpu.ko: 6 .rodata 00009888 - 19 .data 00001f00 + 19 .data 00001ee0 drivers/gpu/drm/nouveau/nouveau.ko: 6 .rodata 000460b8 17 .data 00018fe0 drivers/gpu/drm/radeon/radeon.ko: - 7 .rodata 00030944 + 7 .rodata 00030964 - 21 .data 0000d6a0 + 21 .data 0000d678 drivers/platform/x86/apple-gmux.ko: - 7 .rodata 00000140 + 7 .rodata 00000160 - 11 .data 000000e0 + 11 .data 000000b8 Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Lukas Wunner <lukas@wunner.de> Reviewed-by: Christian König <christian.koenig@amd.com>. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-10-15intel_scu_ipc: Protect dev member assignment on ->remove()Andy Shevchenko
Protect the dev member assignment in ->remove() since user may potentially call unbind from a sysfs even if the driver is built-in. The latter might be racy with ongoing SCU communication. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-15intel_scu_ipc: Switch to use module_pci_driver() macroAndy Shevchenko
Eliminate some boilerplate code by using module_pci_driver() instead of init/exit, moving the salient bits from init into probe. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-15intel_scu_ipc: Convert to use struct device *Andy Shevchenko
Switch the code to use struct device * instead of struct pci_dev * since there is no reason to access PCI related features in the driver. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-15intel_scu_ipc: Propagate pointer to struct intel_scu_ipc_devAndy Shevchenko
As much as possible propagate a pointer to struct intel_scu_ipc_dev. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-15intel_scu_ipc: Fix error path by turning to devm_* / pcim_*Andy Shevchenko
The error handling is broken right now since it leaves resources unfreed. Convert the code to use managed resources to fix the error handling. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-15move io-64-nonatomic*.h out of asm-genericChristoph Hellwig
These are not implementations of default architecture code but helpers for drivers. Move them to the place they belong to. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Darren Hart <dvhart@linux.intel.com> Acked-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-10-10linux/thermal.h: rename KELVIN_TO_CELSIUS to DECI_KELVIN_TO_CELSIUSRasmus Villemoes
The macros KELVIN_TO_CELSIUS and CELSIUS_TO_KELVIN actually convert between deciKelvins and Celsius, so rename them to reflect that. While at it, use a statement expression in DECI_KELVIN_TO_CELSIUS to prevent expanding the argument multiple times and get rid of a few casts. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-10-07platform/chrome: Support reading/writing the vboot contextEmilio López
Some EC implementations include a small nvram space used to store verified boot context data. This patch offers a way to expose this data to userspace. Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Emilio López <emilio.lopez@collabora.co.uk> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: cros_ec: Fix possible leak in led_rgb_store()Christian Engelmayer
Function led_rgb_store() contains some direct returns in error cases that leak the already allocated cros_ec_command message structure. Make sure that 'msg' is freed in all exit paths. Detected by Coverity CID 1309666. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: cros_ec: Fix leak in sequence_store()Christian Engelmayer
The allocated cros_ec_command message structure is not freed in function sequence_store(). Make sure that 'msg' is freed in all exit paths. Detected by Coverity CID 1309667. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: Enable Chrome platforms on 64-bit ARMThierry Reding
With Chrome running on 64-bit ARM devices, add ARM64 to the list of supported architectures. Signed-off-by: Thierry Reding <treding@nvidia.com> [olof; Fixed up due to addition of COMPILE_TEST] Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: cros_ec_dev - Add a platform device ID tableJavier Martinez Canillas
If the cros_ec_dev driver is built as a module, modalias information is not filled so the module is not autoloaded. Add a platform device table and use the MODULE_DEVICE_TABLE() macro to export that information in the module so user-space can match the modalias uevent and autoload it. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: cros_ec_lpc - Add support for Google Pixel 2Javier Martinez Canillas
Since the verion of ACPI in Google BIOS does not enumerate the devices in the LPC bus, the cros_ec_lpc driver resorts to DMI data to check if a system is supported by the driver and autoload if built as a module. Add information about the Google Pixel 2 to the DMI device table. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: cros_ec_lpc - Use existing function to check EC resultJavier Martinez Canillas
Commit 6db07b633658 ("mfd: cros_ec: Check result code from EC messages") added a common cros_ec_check_result() function that can be used to check the ec_msg->result for errors and warns about them. Use the existing function instead of duplicating same check in the driver. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Gwendal Grignou <gwendal@chromium.org> Tested-by: Gwendal Grignou <gwendal@chromium.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07platform/chrome: Make depends on MFD_CROS_EC instead CROS_EC_PROTOJavier Martinez Canillas
The ChromeOS EC LPC and chardev drivers depend on CROS_EC_PROTO but MFD_CROS_EC select CROS_EC_PROTO instead. Mixing select and depends on is bad practice as it may lead to circular Kconfig dependencies. Since the platform devices that are matched with these drivers are registered by the ChromeOS EC mfd driver, they really depend on MFD_CROS_EC. And because this config option selects CROS_EC_PROTO, that dependency is met as well. So make the drivers to depend on MFD_CROS_EC instead of CROS_EC_PROTO. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-07Revert "platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM"Javier Martinez Canillas
This reverts commit d12bbcd3ea44 ("platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM") since it was found to not be the correct fix for the MFD_CROS_EC config unmet direct dependencies warning. The correct solution was to add the needed dependencies to the MFD_CROS_EC symbol. Besides the revert, this patch extends the CHROME_PLATFORMS symbol dependencies and adds || COMPILE_TEST to allow drivers to have build coverage on other architectures. Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-06acer-wmi: remove threeg and interface sysfs interfacesLee, Chun-Yi
Since v3.0 kernel, acer-wmi driver auto detects internal 3G device and provides the threeg rfkill interface. So the sysfs interface of 3G is no longer necessary now. The 7b8aca65 patch added kernel information log to remind to user space for the threeg sysfs interface will be removed in 2012, then b58b9ffc patch updated the interface removing time to 2014. I think the 3 years lead time is enough for user space application to use rfkill instead of sysfs interface to control 3G device. This patch removes code about threeg sysfs interface. And it also removes the unused interface sysfs that exposes which ACPI-WMI method used by acer-wmi driver on the machine. The information is already exposed by the acer-wmi initial log. Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Martin Kepplinger <martink@posteo.de> Cc: Darren Hart <dvhart@infradead.org> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-06OLPC: Use %*ph specifier instead of passing direct valuesAndy Shevchenko
The %*ph specifier allows to dump small buffers in hex format. Let's use it instead of passing direct values via stack. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Paul Fox <pgf@laptop.org> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03platform/x86: Toshiba WMI Hotkey DriverAzael Avalos
Toshiba laptops that feature WMI events for hotkeys were left unsupported by the toshiba_acpi driver, however, commit a88bc06e5aec ("toshiba_acpi: Avoid registering input device on WMI event laptops") added hardware support for such laptops, but the hotkeys are not handled there. This driver adds support for hotkey monitoring on certain Toshiba laptops that manage the hotkeys via WMI events instead of the Toshiba Configuration Interface (TCI). The toshiba_acpi driver and this one can co-exist, as this only takes care of hotkeys, while the proper takes care of hardware related stuff. Currently the driver is under the EXPERIMENTAL flag, as the keymap and the notify function are incomplete (due to lack of hardware to test). Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03sony-laptop: Fix handling sony_nc_hotkeys_decode resultAndrzej Hajda
sony_nv_hotkeys_decode can return a negative value. real_ev is a u32 variable. The check for real_ev > 0 is incorrect. Use an intermediate ret variable. The problem has been detected using proposed semantic patch scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2046107 Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> [dvhart: clarify commit msg, drop superfluous else block] Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03intel_mid_powerbtn: Remove misuse of IRQF_NO_SUSPEND flagSudeep Holla
The IRQF_NO_SUSPEND flag is used to identify the interrupts that should be left enabled so as to allow them to work as expected during the suspend-resume cycle, but doesn't guarantee that it will wake the system from a suspended state, enable_irq_wake is recommended to be used for the wakeup. This patch removes the use of IRQF_NO_SUSPEND flags and uses newly introduce PM wakeup APIs dev_pm_{set,clear}_wake_irq. Cc: Darren Hart <dvhart@infradead.org> Cc: platform-driver-x86@vger.kernel.org Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03compal-laptop: Add charge control limitRoald Frederickx
Add charge control limit to the power supply subsystem of the Compal platform driver. This apparently was present in the original driver by Cezary Jackiewicz at http://eko.one.pl/index.php?page=compal-laptop but it seems to have been overlooked. The Kconfig description is updated to reflect this addition. It now also mentions the hwmon interface that was already present. Signed-off-by: Roald Frederickx <roald.frederickx@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03asus-wmi: restore kbd led level after resumeOleksij Rempel
Afters suspend/resume cycle with closed lid the kbd backlight level is lost. This patch will will restore this value to last known level. Signed-off-by: Oleksij Rempel <linux@rempel-privat.de> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03toshiba_acpi: Remove unneeded u32 variables from *setup_keyboardAzael Avalos
The function toshiba_acpi_setup_keyboard currently has two u32 variables used to store the Hotkey Event Type and the result of the HCI_SYSTEM_EVENT query. This patch removes those two variables, as we already have a global variable named "hotkey_event_type" and the result of the HCI_SYSTEM_EVENT query can be checked directly from the function. Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-10-03toshiba_acpi: Add 0x prefix to available_kbd_modes_show functionAzael Avalos
This patch adds the 0x prefix to the values printed by such function, the values are already being printed in hex, but without the prefix, causing confusion, even though the file under Documentation/ABI clearly states that hey are hex values. Simply add the 0x prefix to avoid such confusion. Signed-off-by: Azael Avalos <coproscefalo@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
