path: root/drivers/pnp/card.c
2008-04-29PNP: add pnp_alloc_card()Bjorn Helgaas
Add pnp_alloc_card() to allocate a struct pnp_card and fill in the protocol, instance number, and initial PNP ID. Now it is always valid to use dev_printk() on any pnp_card pointer. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: change pnp_add_card_id() to allocate its own pnp_id structuresBjorn Helgaas
This moves some of the pnp_id knowledge out of the backends and into the PNP core. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-17PNP: use dev_info(), dev_err(), etc in coreBjorn Helgaas
If we have the struct pnp_dev available, we can use dev_info(), dev_err(), etc., to give a little more information and consistency. [akpm@linux-foundation.org: fix warning] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17PNP: simplify PNP card error handlingBjorn Helgaas
No functional change; just return errors early instead of putting the main part of the function inside an "if" statement. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17PNP: remove null pointer checksBjorn Helgaas
Remove some null pointer checks. Null pointers in these areas indicate programming errors, and I think it's better to oops immediately rather than return an error that is easily ignored. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-24PNP: fix up after LindentBjorn Helgaas
More manual fixups after Lindent. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-26PNP: fix up after LindentBjorn Helgaas
These are manual fixups after running Lindent. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: Lindent all source filesBjorn Helgaas
Run Lindent on all PNP source files. Produced by: $ quilt new pnp-lindent $ find drivers/pnp -name \*.[ch] | xargs quilt add $ quilt add include/linux/{pnp.h,pnpbios.h} $ scripts/Lindent drivers/pnp/*.c drivers/pnp/*/*.c include/linux/pnp*.h $ quilt refresh --sort Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27PNP: stop using the subsystem rwsemGreg Kroah-Hartman
The rwsem is not used to protect anything, so the use of it by the PNP subsystem isn't really useful, and it's doubtful if it really did anything or not. So I've removed it. Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] PNP: handle sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] pnp: card_probe(): fix memory leakJesper Juhl
We can leak `clink' if drv->probe == 0. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] pnp: PNP: adjust pnp_register_driver signatureBjorn Helgaas
Remove the assumption that pnp_register_driver() returns the number of devices claimed. Returning the count is unreliable because devices may be hot-plugged in the future. This changes the convention to "zero for success, or a negative error value," which matches pci_register_driver(), acpi_bus_register_driver(), and platform_driver_register(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] pnp bus type fixAdam Belay
This is Adam's pnp probing fix. It's been reported to fix hangs on several people's machines. I don't know if it's official or final, and Adam isn't contactable at present. But I'm not aware of the patch causing any regressions. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-22[ALSA] check return code in pnp_register_card_driver()Adam Belay
Signed-off-by: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] PATCH] Add PM support to PnP driversTakashi Iwai
Add suspend/resume callback to pnp_driver and pnp_card_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-07[PATCH] drivers/pnp/: cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - core.c: pnp_remove_device - #if 0 the following unneeded EXPORT_SYMBOL's: - card.c: pnp_add_card - card.c: pnp_remove_card - card.c: pnp_add_card_device - card.c: pnp_remove_card_device - card.c: pnp_add_card_id - core.c: pnp_register_protocol - core.c: pnp_unregister_protocol - core.c: pnp_add_device - core.c: pnp_remove_device - pnpacpi/core.c: pnpacpi_protocol - driver.c: pnp_add_id - isapnp/core.c: isapnp_read_byte - manager.c: pnp_auto_config_dev - resource.c: pnp_register_dependent_option - resource.c: pnp_register_independent_option - resource.c: pnp_register_irq_resource - resource.c: pnp_register_dma_resource - resource.c: pnp_register_port_resource - resource.c: pnp_register_mem_resource Note that this patch #if 0's exactly one functions and removes no functions. Most it does is the #if 0 of EXPORT_SYMBOL's, so if any modular code will use any of them, re-adding will be trivial. Modular ISAPnP might be interesting in some cases, but this is more legacy code. If someone would work on it to sort all the issues out (starting with the point that most users of __ISAPNP__ will have to be fixed) re-enabling the required EXPORT_SYMBOL's won't be hard for him. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] PNP: make pnp_dbg conditional directly on CONFIG_PNP_DEBUGBjorn Helgaas
Seems pointless to require .c files to test CONFIG_PNP_DEBUG and conditionally define DEBUG before including <linux/pnp.h>. Just test CONFIG_PNP_DEBUG directly in pnp.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] broken error path in drivers/pnp/card.cJaroslav Kysela
The error path in pnp_request_card_device() is broken (one variable is left initialized and the semaphore is not unlocked). This fixes it (and has been tested). Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] DocBook: update commentsMartin Waitz
This patch updates some comments to match code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/i2c/chips/w83781d.c - ↵Yani Ioannou
drivers/s390/block/dcssblk.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
