path: root/drivers/pnp/system.c
2008-06-05PNP: skip UNSET MEM resources as well as DISABLED onesBjorn Helgaas
We don't need to reserve "unset" resources. Trying to reserve them results in messages like this, which are ugly but harmless: system 00:08: iomem range 0x0-0x0 could not be reserved Future PNP patches will remove use of IORESOURCE_UNSET, but we still need it for now. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-02PNP: mark resources that conflict with PCI devices "disabled"Bjorn Helgaas
Both the PNP/PCI conflict detection quirk and the PNP system driver must use the same mechanism to mark resources as disabled. I think it's best to keep the resource and to keep the type bit (IORESOURCE_MEM, etc), so that we match the list from firmware as closely as possible. Fixes this regression from 2.6.25: http://lkml.org/lkml/2008/6/1/82 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Tested-by: Avuton Olrich <avuton@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29PNP: remove PNP_MAX_* usesBjorn Helgaas
Remove some PNP_MAX_* uses. The pnp_resource_table isn't dynamic yet, but with pnp_get_resource(), we can start moving away from the table size constants. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-17PNP: use dev_info() in system driverBjorn Helgaas
Use dev_info() for a little consistency. Changes this: pnp: 00:01: ioport range 0xf50-0xf58 has been reserved pnp: 00:01: ioport range 0x408-0x40f has been reserved pnp: 00:01: ioport range 0x900-0x903 has been reserved to this: system 00:01: ioport range 0xf50-0xf58 has been reserved system 00:01: ioport range 0x408-0x40f has been reserved system 00:01: ioport range 0x900-0x903 has been reserved Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: fix up after LindentBjorn Helgaas
These are manual fixups after running Lindent. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: Lindent all source filesBjorn Helgaas
Run Lindent on all PNP source files. Produced by: $ quilt new pnp-lindent $ find drivers/pnp -name \*.[ch] | xargs quilt add $ quilt add include/linux/{pnp.h,pnpbios.h} $ scripts/Lindent drivers/pnp/*.c drivers/pnp/*/*.c include/linux/pnp*.h $ quilt refresh --sort Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-02[PATCH] Correctly report PnP 64bit resourcesPetr Vandrovec
Change PnP resource handling code to use proper type for resource start and length. Fixes bogus regions reported in /proc/iomem. I've also made some pointer constant, as they are constant... Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26PNP: system.c whitespace cleanupBjorn Helgaas
No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-26PNP: reserve system board iomem resources as well as ioport resourcesBjorn Helgaas
Most x86 boxes have no iomem system board resources, but some ia64 boxes do. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
