path: root/drivers/pnp
2006-08-06[PATCH] pnpacpi: reject ACPI_PRODUCER resourcesmatthieu castet
A patch in -mm kernel correct the parsing of "address resources" of pnpacpi. Before we assumed it was memory only, but it could be also IO. But this change show an hidden bug : some resources could be producer type that are not handled by pnp layer. So we should ignore the producer resources. This patch fixes bug 6292 (http://bugzilla.kernel.org/show_bug.cgi?id=6292). Some devices like PNP0A03 have 0xd00-0xffff and 0x0-0xcf7 as IO producer resources. Before correcting "address resources" parsing, it was seen as memory and was harmless, because nobody tried to reserve this memory range as it should be IO. With the correction it become IO resources, and make failed all others device that want to register IO in this range and use pnp layer (like a ISA sound card). The solution is to ignore producer resources Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: "Brown, Len" <len.brown@intel.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03PNP: Add missing casts in printk() argumentsPierre Ossman
Some resource_size_t values are fed to printk() without handling the fact that they can have different size depending on your .config. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] Fix swsusp with PNP BIOSOndrej Zary
swsusp is unable to suspend my machine (DTK FortisPro TOP-5A notebook) with kernel 2.6.17.5 because it's unable to suspend PNP device 00:16 (mouse). The problem is in PNP BIOS. pnp_bus_suspend() calls pnp_stop_dev() for the device if the device can be disabled according to pnp_can_disable(). The problem is that pnpbios_disable_resources() returns -EPERM if the device is not dynamic (!pnpbios_is_dynamic()) but insert_device() happily sets PNP_DISABLE capability/flag even if the device is not dynamic. So we try to disable non-dynamic devices which will fail. This patch prevents insert_device() from setting PNP_DISABLE if the device is not dynamic and fixes suspend on my system. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] PNPACPI: support shareable interruptsBjorn Helgaas
ACPI supplies a "shareable" indication, but PNPACPI ignores it. If a PNP device uses a shared interrupt, request_irq() fails because the PNP driver can't tell whether to supply SA_SHIRQ. This patch allows PNP drivers to test (pnp_irq_flags(dev, 0) & IORESOURCE_IRQ_SHAREABLE) Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu Castet <castet.matthieu@free.fr> Cc: Li Shaohua <shaohua.li@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] pnp: suppress request_irq() warningAndrew Morton
Suppress the "setup_irq: irq handler mismatch" coming out of pnp_check_irq(): failures are expected here. Cc: <stable@kernel.org> Cc: Santiago Garcia Mantinan <manty@manty.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: change pnp core to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25[PATCH] pnp: card_probe(): fix memory leakJesper Juhl
We can leak `clink' if drv->probe == 0. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-15Pull pnpacpi into release branchLen Brown
2006-04-19[PATCH] pnp: fix two messages in manager.cJan Engelhardt
The wording of two messages in drivers/pnp/manager.c is incorrect. Fix that. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01PNPACPI: whitespace cleanupBjorn Helgaas
Tidy up whitespace. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01PNPACPI: remove some code duplicationBjorn Helgaas
Factor out the duplicated switch from pnpacpi_count_resources() and pnpacpi_type_resources(). Remove the unnecessary re-initialization of resource->type and length from all the encode functions (id and length are originally set in the pnpacpi_build_resource_template() -> pnpacpi_type_resources() path). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01PNPACPI: fix non-memory address space descriptor handling Bjorn Helgaas
Fix resource_type handling for QWORD, DWORD, and WORD Address Space Descriptors. Previously we ignored the resource_type, so I/O ports and bus number ranges were incorrectly parsed as memory ranges. Sample PCI root bridge resources from HP rx2600 before this patch: # cat /sys/bus/pnp/devices/00:02/resources state = active mem 0x0-0x1f mem 0x0-0x3af mem 0x3e0-0x1fff mem 0x80000000-0x8fffffff With this patch: # cat /sys/bus/pnp/devices/00:02/resources state = active io 0x0-0x3af io 0x3e0-0x1fff mem 0x80000000-0x8fffffff mem 0x80004000000-0x80103fffffe Changes: 0x0-0x1f PCI bus number range was incorrectly reported as memory, now not reported at all 0x0-0x3af I/O port range was incorrectly reported as memory 0x3e0-0x1fff I/O port range was incorrectly reported as memory 0x80004000000-0x80103fffffe memory range wasn't reported at all because we only support PNP_MAX_MEM (4) memory resources Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-27[PATCH] pnp: PNP: adjust pnp_register_driver signatureBjorn Helgaas
Remove the assumption that pnp_register_driver() returns the number of devices claimed. Returning the count is unreliable because devices may be hot-plugged in the future. This changes the convention to "zero for success, or a negative error value," which matches pci_register_driver(), acpi_bus_register_driver(), and platform_driver_register(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Fix memory leak in isapnpJesper Juhl
Spotted by the Coverity checker as bug #666 akpm; there are several other `return 1;'s in there which aren't freeing `dev'. (A fix which converts this function to single-exit would be preferred..) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] PnPBIOS: Missing SMALL_TAG_ENDDEP tagRene Herman
Without the attached, the kernel complains about my BIOS' PNP tables. It was ACKed before, but never merged: http://marc.theaimsgroup.com/?l=linux-kernel&m=110237794007900&w=2 Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] pnp bus type fixAdam Belay
This is Adam's pnp probing fix. It's been reported to fix hangs on several people's machines. I don't know if it's official or final, and Adam isn't contactable at present. But I'm not aware of the patch causing any regressions. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-22[ALSA] check return code in pnp_register_card_driver()Adam Belay
Signed-off-by: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-20[ACPI] better fix for pnpacpi regression resulting from ACPICA 20051117Len Brown
Rather than tweaking acpi_walk_resource() again not return end tags, modify the pnpacpi code to ignore them. The pnpacpi resource type switch statements now include all known types in the order that they're defined -- so it is easy to see what is not implemented. The code will squawk only if it sees a truly undefined type. Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-13[PATCH] Add pnp_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-07[PNPACPI] clean excluded_id_list[]matthieu castet
Clean the blacklist. Battery, Button, Fan have no _CRS and can be removed. PCI root is in pnpbios and is harmless. Cc: Adam Belay <ambx1@neo.rr.com> Cc: "Li, Shaohua" <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-07[PNPACPI] Ignore devices that have no resourcesmatthieu castet
Ignore devices that don't have a _CRS method. They are useless for the PNP layer as they don't provide any resources. Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-07Pull pnpacpi into acpica branchLen Brown
2006-01-07[ACPI] enable PNPACPI support for resource types used by HP serial portsBjorn Helgaas
PNPACPI complained about and ignored devices with ADDRESS16, ADDRESS32, or ADDRESS64 descriptors in _PRS. HP firmware uses them for built-in serial ports, so this patch adds support for parsing these descriptors from _PRS. Note that this does not add the corresponding support for encoding them in preparation for _SRS, because I don't have any machine that supports _SRS on these descriptors, so I couldn't test that support. Attempts to encode them will cause a warning and an -EINVAL return. http://sourceforge.net/mailarchive/forum.php?thread_id=8250154&forum_id=6102 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-06[PATCH] x86: Fixed pnp bios limitsZachary Amsden
PnP BIOS data, code, and 32-bit entry segments all have fixed limits as well; set them in the GDT rather than adding more code. It would be nice to add these fixups to the boot GDT rather than setting the GDT for each CPU; perhaps I can wiggle this in later, but getting it in before the subsys init looks tricky. Also, make some progress on deprecating the ugly Q_SET_SEL macros. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: "Seth, Rohit" <rohit.seth@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86: Pnp byte granularityZachary Amsden
The one remaining caller of set_limit, the PnP BIOS code, calls into the PnP BIOS, passing kernel parameters in and out. These parameteres may be passed from arbitrary kernel virtual memory, so they deserve strict protection to stop a bad BIOS from smashing beyond the object size. Unfortunately, the use of set_limit was badly botching this by setting the limit in terms of pages, when it really should have byte granularity. When doing this, I discovered my BIOS had the buggy code during the "get system device node" call: mov ax, es:[bx] Which is harmless, but has a trivial workaround. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: "Seth, Rohit" <rohit.seth@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86: Pnp segments in segment hZachary Amsden
Move PnP BIOS segment definitions into segment.h; the segments are reserved here, so they might as well be defined here as well. Note I didn't do this for APM BIOS, as Macintosh and other systems use those values to emulate APM in some scary way I don't want to understand. Signed-off-by: Zachary Amsden <zach@vmware.com> Acked-by: "Seth, Rohit" <rohit.seth@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86: GDT alignment fixZachary Amsden
Make GDT page aligned and page padded to support running inside of a hypervisor. This prevents false sharing of the GDT page with other hot data, which is not allowed in Xen, and causes performance problems in VMware. Rather than go back to the old method of statically allocating the GDT (which wastes unneded space for non-present CPUs), the GDT for APs is allocated dynamically. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: "Seth, Rohit" <rohit.seth@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04[PATCH] keep pnpbios usermod_helper away from hotplug_path[]Kay Sievers
These days we use udev to manage all kernel events. /proc/sys/kernel/hotplug will usually be disabled by an init-script. pnpnbios is not integrated with the driver core and should stay away from the now disabled /sbin/hotplug. Set the helper to /sbin/phpbios, even when there is probably no current user of this faciliy. If it's needed, it should definitely get proper driver core integration instead of forking binaries from the kernel. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03[ALSA] [PATCH] alsa: Improved PnP suspend supportPierre Ossman
Also use the PnP functions to start/stop the devices during the suspend so that drivers will not have to duplicate this code. Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] PATCH] Add PM support to PnP driversTakashi Iwai
Add suspend/resume callback to pnp_driver and pnp_card_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-12-10[ACPI] ACPICA 20051021Bob Moore
Implemented support for the EM64T and other x86_64 processors. This essentially entails recognizing that these processors support non-aligned memory transfers. Previously, all 64-bit processors were assumed to lack hardware support for non-aligned transfers. Completed conversion of the Resource Manager to nearly full table-driven operation. Specifically, the resource conversion code (convert AML to internal format and the reverse) and the debug code to dump internal resource descriptors are fully table-driven, reducing code and data size and improving maintainability. The OSL interfaces for Acquire and Release Lock now use a 64-bit flag word on 64-bit processors instead of a fixed 32-bit word. (Alexey Starikovskiy) Implemented support within the resource conversion code for the Type-Specific byte within the various ACPI 3.0 *WordSpace macros. Fixed some issues within the resource conversion code for the type-specific flags for both Memory and I/O address resource descriptors. For Memory, implemented support for the MTP and TTP flags. For I/O, split the TRS and TTP flags into two separate fields. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-06Pull release into acpica branchLen Brown
2005-11-07[PATCH] drivers/pnp/: cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - core.c: pnp_remove_device - #if 0 the following unneeded EXPORT_SYMBOL's: - card.c: pnp_add_card - card.c: pnp_remove_card - card.c: pnp_add_card_device - card.c: pnp_remove_card_device - card.c: pnp_add_card_id - core.c: pnp_register_protocol - core.c: pnp_unregister_protocol - core.c: pnp_add_device - core.c: pnp_remove_device - pnpacpi/core.c: pnpacpi_protocol - driver.c: pnp_add_id - isapnp/core.c: isapnp_read_byte - manager.c: pnp_auto_config_dev - resource.c: pnp_register_dependent_option - resource.c: pnp_register_independent_option - resource.c: pnp_register_irq_resource - resource.c: pnp_register_dma_resource - resource.c: pnp_register_port_resource - resource.c: pnp_register_mem_resource Note that this patch #if 0's exactly one functions and removes no functions. Most it does is the #if 0 of EXPORT_SYMBOL's, so if any modular code will use any of them, re-adding will be trivial. Modular ISAPnP might be interesting in some cases, but this is more legacy code. If someone would work on it to sort all the issues out (starting with the point that most users of __ISAPNP__ will have to be fixed) re-enabling the required EXPORT_SYMBOL's won't be hard for him. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[ACPI] handle ACPICA 20050916's acpi_resource.type renameLen Brown
2005-09-08Merge linux-2.6 with linux-acpi-2.6Len Brown
2005-09-07[PATCH] PNP: make pnp_dbg conditional directly on CONFIG_PNP_DEBUGBjorn Helgaas
Seems pointless to require .c files to test CONFIG_PNP_DEBUG and conditionally define DEBUG before including <linux/pnp.h>. Just test CONFIG_PNP_DEBUG directly in pnp.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] pnp: consolidate kmalloc wrappersBjorn Helgaas
ISAPNP, PNPBIOS, and PNPACPI all had their own kmalloc wrappers that reimplemented kcalloc(). Remove the wrappers and just use kcalloc() directly. Note that this also removes the PNPBIOS error message when the kmalloc fails. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-03[ACPI] PNPACPI IRQ workaround for HP workstationsBjorn Helgaas
Move pcibios_penalize_isa_irq() to pnpacpi_parse_allocated_irqresource(). Previously we passed the GSI, not the IRQ, and we did it even if parsing the IRQ resource failed. Parse IRQ descriptors that contain multiple interrupts. This violates the spec (in _CRS, only one interrupt per descriptor is allowed), but some firmware, e.g., HP rx7620 and rx8620 descriptions of HPET, has this bug. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-24[ACPI] delete CONFIG_ACPI_BUSLen Brown
it is a synonym for CONFIG_ACPI Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-23Merge from-linus to-akpmLen Brown
2005-08-18[PATCH] broken error path in drivers/pnp/card.cJaroslav Kysela
The error path in pnp_request_card_device() is broken (one variable is left initialized and the semaphore is not unlocked). This fixes it (and has been tested). Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[ACPI] Merge acpi-2.6.12 branch into 2.6.13-rc3Len Brown
