path: root/drivers/power/Kconfig
2009-09-04power_supply: Add driver for the PMU on WM831x PMICsMark Brown
The WM831x PMICs provide power path management from three sources: a wall supply, USB and a battery with integrated charger. They also provide an additional backup supply with integrated for maintaining always on functionality such as the RTC and monitoring of power switches. After some initial configuration at startup the device operates autonomously, the driver simply provides reporting of the current state. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2009-07-01Add ds2782 battery gas gauge driverRyan Mallon
This patch adds a driver for ds2782 battery devices. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-06-09Add MAX17040 Fuel Gauge driverMinkyu Kang
The MAX17040 is a I2C interfaced Fuel Gauge systems for lithium-ion batteries This patch adds support the MAX17040 Fuel Gauge Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-01-11power_supply: PCF50633 battery charger driverBalaji Rao
Signed-off-by: Balaji Rao <balajirrao@openmoko.org> Cc: Andy Green <andy@openmoko.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-01-04power_supply: Add Dialog DA9030 battery charger driverMike Rapoport
Driver for battery charger integrated into Dialog Semiconductor DA9030 PMIC Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-01-04power_supply: Add support for WM8350 PMUMark Brown
This patch adds support for the PMU provided by the WM8350 which implements battery, line and USB supplies including a battery charger. The hardware functions largely autonomously, with minimal software control required to initiate fast charging. Support for configuration of the USB supply is not yet implemented. This means that the hardware will remain in the mode configured at startup, by default limiting the current drawn from USB to 100mA. This driver was originally written by Liam Girdwood with subsequent updates for submission by Mark Brown. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-18Merge branch 'master' of ↵Anton Vorontsov
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/power/Makefile
2008-10-12Fix Kconfig dependency for WM97xx battery driverLinus Torvalds
It needs the WM97xx touchscreen driver to be compiled in, not as a module. And it cannot itself be a module, due to some unfortunate interactions with platform data. Reported-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-02[ARM] 5248/1: wm97xx generic battery driverMarek Vašut
This patch adds generic battery driver for wm97xx chips. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26power_supply: fix dependency of tosa_batteryDmitry Baryshkov
tosa_battery should also depend on wm97xx_ts as it uses dac-accessing functions from that module. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2008-09-01power_supply: Support for Texas Instruments BQ27200 battery managersRodolfo Giometti
These battery managers came in two different packages: one for I2C busses (BQ27200) and one for HDQ busses (BQ27000). This driver currently supports only the I2C chip version but the code is designed in order to easily allow the HDQ chip version integration. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make things static, use kasprintf()] Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2008-07-30Merge branch 'master' of /home/cbou/linux-2.6Anton Vorontsov
Conflicts: drivers/power/Kconfig drivers/power/Makefile
2008-07-10[ARM] 5155/1: PalmTX battery monitorMarek Vašut
This patch adds battery monitoring driver for PalmTX. It can read voltage from the battery and temperature. It also monitors charging/discharging status. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-01power_supply: Sharp SL-6000 (tosa) batteries supportDmitry Baryshkov
This patch adds common battery interface support for Sharp SL-6000 (tosa). Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2007-07-23Don't compile the PMU power driver on 64-bit PowerPCPaul Mackerras
As reported by Stephen Rothwell, an allmodconfig build on 64-bit PowerPC reports these errors: ERROR: "pmu_batteries" [drivers/power/pmu_battery.ko] undefined! ERROR: "pmu_battery_count" [drivers/power/pmu_battery.ko] undefined! ERROR: "pmu_power_flags" [drivers/power/pmu_battery.ko] undefined! This fixes the problem by not building pmu_battery.ko on ppc64. There are no battery-powered ppc64 machines with an Apple PMU, and we can be reasonably confident there never will be. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-15PDA_POWER depends on having request_irq()Al Viro
... so all proud owners of s390-based PDAs will have to live without that one Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[BATTERY] One Laptop Per Child power/battery driverDavid Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Anton Vorontsov <cbou@mail.ru>
2007-07-10[BATTERY] Apple PMU driverDavid Woodhouse
2007-07-10[BATTERY] 1-Wire ds2760 chip battery driverAnton Vorontsov
This is driver for batteries with ds2760 chip inside, found inside almost every HP iPaq and HTC PDAs/phones. Signed-off-by: Anton Vorontsov <cbou@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-10[BATTERY] APM emulation driver for class batteriesAnton Vorontsov
Signed-off-by: Eugeny Boger <eugenyboger@dgap.mipt.ru> Signed-off-by: Anton Vorontsov <cbou@mail.ru> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-10[BATTERY] pda_power platform driverAnton Vorontsov
Common power driver for PDAs and phones with one or two external power supplies (AC/USB) connected to main and backup batteries, and optional builtin charger. It's used to stop logic duplication through different embedded devices. So, power supply *logic* is here. pda_power register power supplies, and will take care about notifying batteries about power changes through external power interface. Currently, power consumption legal limits (including USB power consumption) should be handled by platform code, inside set_charge function. Signed-off-by: Anton Vorontsov <cbou@mail.ru> Signed-off-by: Roman Moravcik <roman.moravcik@gmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-10[BATTERY] Universal power supply class (was: battery class)Anton Vorontsov
This class is result of "external power" and "battery" classes merge, as suggested by David Woodhouse. He also implemented uevent support. Here how userspace seeing it now: # ls /sys/class/power\ supply/ ac main-battery usb # cat /sys/class/power\ supply/ac/type AC # cat /sys/class/power\ supply/usb/type USB # cat /sys/class/power\ supply/main-battery/type Battery # cat /sys/class/power\ supply/ac/online 1 # cat /sys/class/power\ supply/usb/online 0 # cat /sys/class/power\ supply/main-battery/status Charging # cat /sys/class/leds/h5400\:red-left/trigger none h5400-radio timer hwtimer ac-online usb-online main-battery-charging-or-full [main-battery-charging] main-battery-full Signed-off-by: Anton Vorontsov <cbou@mail.ru> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
