path: root/drivers/power/bq27x00_battery.c
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-02-21power: bq27x00: Fix typos in commentThomas Weber
Fix two typos in comments. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-01bq27x00_battery: Fix flag register readGrazvydas Ignotas
When reading flags, bq27x00_read() argument is inverted and causes reads 2 of bytes for bq27200 and 1 byte for bq27500, while their register sizes are 1 and 2 bytes respectively. This causes bq27500 upper flag bits always to be returned as 0, causing full charge state to never be reported correctly, so fix it. Cc: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2012-02-01Revert "bq27x00_battery: Fix reporting status value for bq27500 battery"Anton Vorontsov
This reverts commit 270968c0984aeed096da3cfffb0e131f4c416166. Grazvydas Ignotas wrote: After 270968c0984ae "bq27x00_battery: Fix reporting status value for bq27500 battery" status doesn't seem to be reported correctly when the battery is close to fully charged state. It reports "Not charging" while in fact there is >130mA current flowing to the battery according to current_now. This status report seems to be based on CHG bit in status register, but looking at the datasheet the description says "(Fast) charging allowed", which I guess means that the chip recommends charging and not that charging is actually going on? If you check the bit while battery is discharging and it's not full, the bit is also set. Suggested-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-11-26bq27x00_battery: Fix OOPS caused by unregistring bq27x00 driverPali Rohár
* power_supply_unregister call bq27x00_battery_get_property which call bq27x00_battery_poll * make sure that bq27x00_battery_poll will not call schedule_delayed_work again after unregister (which cause OOPS) Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-11-26bq27x00_battery: Fix reporting error messagesPali Rohár
* Do not be noise if battery is not calibrated (use dev_dbg) Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-11-25bq27x00_battery: Fix reporting status value for bq27500 batteryPali Rohár
2011-11-25bq27x00_battery: Cache temperature value in converted unitPali Rohár
2011-11-25bq27x00_battery: Cache energy propertyPali Rohár
2011-11-25bq27x00_battery: Report -ENODATA if bq27000 battery was not calibratedPali Rohár
* CI (Capacity Inaccurate) flag is set after full reset on bq27000 battery * when is set, all capacity properties should be reported incorrectly, because there was no learning cycle and battery was not calibrated * instead reporting incorrect values, report -ENODATA Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-11-25bq27x00_battery: Add support for property POWER_SUPPLY_PROP_CAPACITY_LEVELPali Rohár
2011-11-25bq27x00_battery: Do not cache current_now value for bq27000 bateryPali Rohár
* This prevent reporting old current_now value for bq27000 * Also ask for current flags, to make sure that current_now will be reported with correct signature Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-05-20bq27x00_battery: Name of cycle count propertyPali Rohár
This patch fix using correct property POWER_SUPPLY_PROP_CYCLE_COUNT for cycle count instead POWER_SUPPLY_PROP_CHARGE_COUNTER Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-02-22bq27x00: Use single i2c_transfer call for property readGrazvydas Ignotas
Doing this by using 2 calls sometimes results in unexpected values being returned on OMAP3 i2c controller. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de>
2011-02-22bq27x00: Cleanup bq27x00_i2c_readLars-Peter Clausen
Some minor stylistic cleanups. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Minor cleanupsPali Rohár
* Consistently use uppercase for hexadecimal values. * Clarify/fix the unit of functions return value in its comment. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Give more specific reports on battery statusLars-Peter Clausen
The current code only reports whether the battery is charging or discharging. But the battery also reports whether it is fully charged, furthermore by look at if the battery is supplied we can tell whether it is discharging or not charging. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Add MODULE_DEVICE_TABLEPali Rohár
This patch adds MODULE_DEVICE_TABLE for module bq27x00_battery. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Add new propertiesPali Rohár
This patch add support for reporting properties POWER_SUPPLY_PROP_CHARGE_NOW, POWER_SUPPLY_PROP_CHARGE_FULL, POWER_SUPPLY_PROP_CHARGE_FULL_DESIGN, POWER_SUPPLY_PROP_CHARGE_COUNTER, POWER_SUPPLY_PROP_ENERGY_NOW in module bq27x00_battery. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Poll battery stateLars-Peter Clausen
This patch adds support for polling the battery state and generating a power_supply_changed() event if it has changed. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Cache battery registersLars-Peter Clausen
This patch adds a register cache to the bq27x00 battery driver. Usually multiple, if not all, power_supply properties are queried at once, for example when an uevent is generated. Since some registers are used by multiple properties caching the registers should reduce the number of reads. The cache is valid for 5 seconds this roughly matches the internal update interval of the current register for the bq27000/bq27200. Fast changing properties(*_NOW) which can be obtained by reading a single register are not cached. It will also be used in the follow up patch to check if the battery status has been changed since the last update to emit power_supply_changed events. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Add bq27000 supportLars-Peter Clausen
This patch adds support for the bq27000 battery to the bq27x00 driver. The bq27000 is similar to the bq27200 except that it uses the HDQ bus instead of I2C to communicate with the host system. The driver is implemented as a platform driver. The driver expects to be provided with a read callback function through its platform data. The read function is assumed to do the lowlevel HDQ handling and read out the value of a certain register. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Prepare code for addition of bq27000 platform driverLars-Peter Clausen
This patch simplifies the drivers data structure and moves code to be shared by the bq27000 and bq27200/bq27500 init functions into a common function. This patch has no functional changes, it only moves code around. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Return -ENODEV for properties if the battery is not presentLars-Peter Clausen
This patch changes get_property callback of the bq27x00 battery to return -ENODEV for properties other then the PROP_PRESENT if the battery is not present. The power subsystem core expects a driver to behave that way. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Fix CURRENT_NOW propertyPali Rohár
According to the bq27000 datasheet the current should be calculated by the following formula: current = AI * 3570 / 20 This patch adjust the drivers code accordingly. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Improve temperature property precessionLars-Peter Clausen
This patch improves the precession of the temperature property of the bq27x00 driver. By dividing before multiplying the current code effectively cuts of the last decimal digit. This patch fixes it by multiplying before dividing. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2011-02-22bq27x00: Add type propertyLars-Peter Clausen
This patch adds the type property to the bq27x00 battery driver. All bq27x00 are lithium ion batteries. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2010-10-06bq27x00_battery: Add missing kfree(di->bus) in bq27x00_battery_remove()Axel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-27power_supply: bq27x00: fix voltage and current unitsGrazvydas Ignotas
The chip returns voltage and current in mV and mA, but power supply class uses uV and uA, so add missing conversion. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-27power_supply: bq27x00: add status and time propertiesGrazvydas Ignotas
The BQ27x00 series of chips can report time-to-empty and time-to-full, so let's add corresponding properties. Also report charge status based on status flag register. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: add BQ27500 supportGrazvydas Ignotas
BQ27500 is newer fuel gauge chip from TI with slightly changed register layout and some different register semantics. Add new i2c ID for it and handle differences where needed. Also rename bq27200 functions to bq27x00, as they are no longer bq27200 specific. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: fix temperature conversionGrazvydas Ignotas
The power supply class requires tenths of degree Celsius. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: remove unused struct fieldsGrazvydas Ignotas
These are probably leftover from old TI code. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: remove double endian swapGrazvydas Ignotas
The bq27x00 registers are little endian, so just read them as such and don't do double endian swap on LE machines. This also gets rid of strange looking shift that was done after reading 8bit register because endian swap in bq27x00_read() was messing it up. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-03-30trivial: Fix misspelling of "Celsius".Adam Buchbinder
A few comments say "Celcius"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-09-26bq27x00_battery: use unaligned access helperHarvey Harrison
Remove hand-rolled get_unaligned_be16, this points to a possible bug as bq27x00_read does another endian byteswap which sparse notices: drivers/power/bq27x00_battery.c:81:14: warning: cast to restricted __be16 Which should probably be checked. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2008-09-01power_supply: Support for Texas Instruments BQ27200 battery managersRodolfo Giometti
These battery managers came in two different packages: one for I2C busses (BQ27200) and one for HDQ busses (BQ27000). This driver currently supports only the I2C chip version but the code is designed in order to easily allow the HDQ chip version integration. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make things static, use kasprintf()] Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
