path: root/drivers/power/power_supply_core.c
2015-08-03thermal: consistently use int for temperaturesSascha Hauer
The thermal code uses int, long and unsigned long for temperatures in different places. Using an unsigned type limits the thermal framework to positive temperatures without need. Also several drivers currently will report temperatures near UINT_MAX for temperatures below 0°C. This will probably immediately shut the machine down due to overtemperature if started below 0°C. 'long' is 64bit on several architectures. This is not needed since INT_MAX °mC is above the melting point of all known materials. Consistently use a plain 'int' for temperatures throughout the thermal code and the drivers. This only changes the places in the drivers where the temperature is passed around as pointer, when drivers internally use another type this is not changed. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Peter Feuerer <peter@piie.net> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Jean Delvare <jdelvare@suse.de> Cc: Peter Feuerer <peter@piie.net> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-acpi@vger.kernel.org Cc: platform-driver-x86@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: Guenter Roeck <linux@roeck-us.net> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Darren Hart <dvhart@infradead.org> Cc: lm-sensors@lm-sensors.org Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-06-19power_supply: Correct kerneldoc copy paste errorsBjorn Andersson
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-06-10power: Add devm_power_supply_get_by_phandle() helper functionHans de Goede
This commit adds a resource-managed version of the power_supply_get_by_phandle() function. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-05-21power_supply: Fix possible NULL pointer dereference on early ueventKrzysztof Kozlowski
Don't call the power_supply_changed() from power_supply_register() when parent is still probing because it may lead to accessing parent too early. In bq27x00_battery this caused NULL pointer exception because uevent of power_supply_changed called back the the get_property() method provided by the driver. The get_property() method accessed pointer which should be returned by power_supply_register(). Starting from bq27x00_battery_probe(): di->bat = power_supply_register() power_supply_changed() kobject_uevent() power_supply_uevent() power_supply_show_property() power_supply_get_property() bq27x00_battery_get_property() dereference of di->bat which is NULL here The dereference of di->bat (value returned by power_supply_register()) is the currently visible problem. However calling back the methods provided by driver before ending the probe may lead to accessing other driver-related data which is not yet initialized. The call to power_supply_changed() is postponed till probing ends - mutex of parent device is released. Reported-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Fixes: 297d716f6260 ("power_supply: Change ownership from driver to core") Tested-By: Dr. H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-05-21power_supply: Fix NULL pointer dereference during bq27x00_battery probeKrzysztof Kozlowski
Power supply is often registered during probe of a driver. The power_supply_register() returns pointer to newly allocated structure as return value. However before returning the power_supply_register() calls back the get_property() method provided by the driver through uevent. In that time the driver probe is still in progress and driver did not assigned pointer to power supply to its local variables. This leads to NULL pointer dereference from get_property() function. Starting from bq27x00_battery_probe(): di->bat = power_supply_register() device_add() kobject_uevent() power_supply_uevent() power_supply_show_property() power_supply_get_property() bq27x00_battery_get_property() dereference of (di->bat) which is NULL here The first uevent of power supply (the one coming from device creation) should not call back to the driver. To prevent that from happening, increment the atomic use counter at the end of power_supply_register(). This means that power_supply_get_property() will return -ENODEV. IMPORTANT: The patch has impact on this first uevent sent from power supply because it will not contain properties from power supply. The uevent with properties will be sent later after indicating that power supply has changed. This also has a race now, but will be fixed in other patches. Reported-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Fixes: 297d716f6260 ("power_supply: Change ownership from driver to core") Tested-By: Dr. H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Increment power supply use counter when obtaining referencesKrzysztof Kozlowski
Increment the power_supply.use_cnt usage counter on: - power_supply_get_by_phandle() - power_supply_get_by_name() and decrement it on power_supply_put() call. This helps tracking of valid usage of power supply instance by consumers. The usage counter itself also allows safe calling of power_supply_get_property-like functions even when driver unregisters this power supply. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Add power_supply_put for decrementing device reference counterKrzysztof Kozlowski
The power_supply_get_by_phandle() and power_supply_get_by_name() use function class_find_device() for obtaining the reference to power supply. Each use of class_find_device() increases the power supply's device reference counter. However the reference counter was not decreased by users of this API. Thus final device_unregister() call from power_supply_unregister() could not release the device and clean up its resources. This lead to memory leak if at least once power_supply_get_by_*() was called between registering and unregistering the power supply. Add and document new API power_supply_put() for decrementing the reference counter. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Pavel Machek <pavel@ucw.cz> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Reviewed-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Change ownership from driver to coreKrzysztof Kozlowski
Change the ownership of power_supply structure from each driver implementing the class to the power supply core. The patch changes power_supply_register() function thus all drivers implementing power supply class are adjusted. Each driver provides the implementation of power supply. However it should not be the owner of power supply class instance because it is exposed by core to other subsystems with power_supply_get_by_name(). These other subsystems have no knowledge when the driver will unregister the power supply. This leads to several issues when driver is unbound - mostly because user of power supply accesses freed memory. Instead let the core own the instance of struct 'power_supply'. Other users of this power supply will still access valid memory because it will be freed when device reference count reaches 0. Currently this means "it will leak" but power_supply_put() call in next patches will solve it. This solves invalid memory references in following race condition scenario: Thread 1: charger manager Thread 2: power supply driver, used by charger manager THREAD 1 (charger manager) THREAD 2 (power supply driver) ========================== ============================== psy = power_supply_get_by_name() Driver unbind, .remove power_supply_unregister() Device fully removed psy->get_property() The 'get_property' call is executed in invalid context because the driver was unbound and struct 'power_supply' memory was freed. This could be observed easily with charger manager driver (here compiled with max17040 fuel gauge): $ cat /sys/devices/virtual/power_supply/cm-battery/capacity & $ echo "1-0036" > /sys/bus/i2c/drivers/max17040/unbind [ 55.725123] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 55.732584] pgd = d98d4000 [ 55.734060] [00000000] *pgd=5afa2831, *pte=00000000, *ppte=00000000 [ 55.740318] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM [ 55.746210] Modules linked in: [ 55.749259] CPU: 1 PID: 2936 Comm: cat Tainted: G W 3.19.0-rc1-next-20141226-00048-gf79f475f3c44-dirty #1496 [ 55.760190] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree) [ 55.766270] task: d9b76f00 ti: daf54000 task.ti: daf54000 [ 55.771647] PC is at 0x0 [ 55.774182] LR is at charger_get_property+0x2f4/0x36c [ 55.779201] pc : [<00000000>] lr : [<c034b0b4>] psr: 60000013 [ 55.779201] sp : daf55e90 ip : 00000003 fp : 00000000 [ 55.790657] r10: 00000000 r9 : c06e2878 r8 : d9b26c68 [ 55.795865] r7 : dad81610 r6 : daec7410 r5 : daf55ebc r4 : 00000000 [ 55.802367] r3 : 00000000 r2 : daf55ebc r1 : 0000002a r0 : d9b26c68 [ 55.808879] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 55.815994] Control: 10c5387d Table: 598d406a DAC: 00000015 [ 55.821723] Process cat (pid: 2936, stack limit = 0xdaf54210) [ 55.827451] Stack: (0xdaf55e90 to 0xdaf56000) [ 55.831795] 5e80: 60000013 c01459c4 0000002a c06f8ef8 [ 55.839956] 5ea0: db651000 c06f8ef8 daebac00 c04cb668 daebac08 c0346864 00000000 c01459c4 [ 55.848115] 5ec0: d99eaa80 c06f8ef8 00000fff 00001000 db651000 c027f25c c027f240 d99eaa80 [ 55.856274] 5ee0: d9a06c00 c0146218 daf55f18 00001000 d99eaa80 db4c18c0 00000001 00000001 [ 55.864468] 5f00: daf55f80 c0144c78 c0144c54 c0107f90 00015000 d99eaab0 00000000 00000000 [ 55.872603] 5f20: 000051c7 00000000 db4c18c0 c04a9370 00015000 00001000 daf55f80 00001000 [ 55.880763] 5f40: daf54000 00015000 00000000 c00e53dc db4c18c0 c00e548c 0000000d 00008124 [ 55.888937] 5f60: 00000001 00000000 00000000 db4c18c0 db4c18c0 00001000 00015000 c00e5550 [ 55.897099] 5f80: 00000000 00000000 00001000 00001000 00015000 00000003 00000003 c000f364 [ 55.905239] 5fa0: 00000000 c000f1a0 00001000 00015000 00000003 00015000 00001000 0001333c [ 55.913399] 5fc0: 00001000 00015000 00000003 00000003 00000002 00000000 00000000 00000000 [ 55.921560] 5fe0: 7fffe000 be999850 0000a225 b6f3c19c 60000010 00000003 00000000 00000000 [ 55.929744] [<c034b0b4>] (charger_get_property) from [<c0346864>] (power_supply_show_property+0x48/0x20c) [ 55.939286] [<c0346864>] (power_supply_show_property) from [<c027f25c>] (dev_attr_show+0x1c/0x48) [ 55.948130] [<c027f25c>] (dev_attr_show) from [<c0146218>] (sysfs_kf_seq_show+0x84/0x104) [ 55.956298] [<c0146218>] (sysfs_kf_seq_show) from [<c0144c78>] (kernfs_seq_show+0x24/0x28) [ 55.964536] [<c0144c78>] (kernfs_seq_show) from [<c0107f90>] (seq_read+0x1b0/0x484) [ 55.972172] [<c0107f90>] (seq_read) from [<c00e53dc>] (__vfs_read+0x18/0x4c) [ 55.979188] [<c00e53dc>] (__vfs_read) from [<c00e548c>] (vfs_read+0x7c/0x100) [ 55.986304] [<c00e548c>] (vfs_read) from [<c00e5550>] (SyS_read+0x40/0x8c) [ 55.993164] [<c00e5550>] (SyS_read) from [<c000f1a0>] (ret_fast_syscall+0x0/0x48) [ 56.000626] Code: bad PC value [ 56.011652] ---[ end trace 7b64343fbdae8ef1 ]--- Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [for the nvec part] Reviewed-by: Marc Dietrich <marvin24@gmx.de> [for compal-laptop.c] Acked-by: Darren Hart <dvhart@linux.intel.com> [for the mfd part] Acked-by: Lee Jones <lee.jones@linaro.org> [for the hid part] Acked-by: Jiri Kosina <jkosina@suse.cz> [for the acpi part] Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Add API for safe access of power supply function attrsKrzysztof Kozlowski
Add simple wrappers for accessing power supply's function attributes: - get_property -> power_supply_get_property - set_property -> power_supply_set_property - property_is_writeable -> power_supply_property_is_writeable - external_power_changed -> power_supply_external_power_changed This API along with atomic usage counter adds a safe way of accessing a power supply from another driver. If power supply is unregistered after obtaining reference to it by some driver, then the API wrappers won't be executed in invalid (freed) context. Next patch changing the ownership of power supply class is still needed to fully fix race conditions in accessing freed power supply. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Reviewed-by: Sebastian Reichel <sre@kernel.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Move run-time configuration to separate structureKrzysztof Kozlowski
Add new structure 'power_supply_config' for holding run-time initialization data like of_node, supplies and private driver data. The power_supply_register() function is changed so all power supply drivers need updating. When registering the power supply this new 'power_supply_config' should be used instead of directly initializing 'struct power_supply'. This allows changing the ownership of power_supply structure from driver to the power supply core in next patches. When a driver does not use of_node or supplies then it should use NULL as config. If driver uses of_node or supplies then it should allocate config on stack and initialize it with proper values. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Pavel Machek <pavel@ucw.cz> [for the nvec part] Reviewed-by: Marc Dietrich <marvin24@gmx.de> [for drivers/platform/x86/compal-laptop.c] Reviewed-by: Darren Hart <dvhart@linux.intel.com> [for drivers/hid/*] Reviewed-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-03-13power_supply: Add driver private dataKrzysztof Kozlowski
Allow drivers to store private data inside power_supply structure for later usage in power supply operations. Usage of driver private data is necessary to access driver's state container object from power supply calls (like get_property()) if struct 'power_supply' is a stored there as a pointer, for example: struct some_driver_info { struct i2c_client *client; struct power_supply *power_supply; ... } In such case one cannot use container_of() and must store pointer to state container as private data. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Reviewed-by: Sebastian Reichel <sre@kernel.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-02-26power_supply core: support use of devres to register/unregister a power supply.NeilBrown
Using devm_power_supply_register allows the unregister to happen automatically on error or final put. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-10-28power_supply: Add no_thermal property to prevent recursive get_temp callsKrzysztof Kozlowski
Add a 'no_thermal' property to the power supply class. If true then thermal zone won't be created for this power supply in power_supply_register(). Power supply drivers may want to set it if they support POWER_SUPPLY_PROP_TEMP and they are forwarding this get property call to other thermal zone. If they won't set it lockdep may report false positive deadlock for thermal zone's mutex because of nested calls to thermal_zone_get_temp(). First is the call to thermal_zone_get_temp() of the driver's thermal zone. Thermal core gets POWER_SUPPLY_PROP_TEMP property from this driver. The driver then calls other thermal zone thermal_zone_get_temp() and returns result. Example of such driver is charger manager. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power_supply: Don't iterate over devices to return -EPROBE_DEFERViresh Kumar
This piece of code was added so that we return -EPROBE_DEFER when no devices are registered. But even if class_for_each_device() returns 0, we are going to return -EPROBE_DEFER only. And so this code isn't required at all. Remove it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Avoid unnecessary 'goto' statementsViresh Kumar
Using 'goto' statements for freeing resources on failures is a good choice as it makes code very clean, and reduces the chances of human errors. Though in most cases compiler may take care of this. But adding unnecessary 'goto' statements wouldn't make anything better. Code becomes less readable actually. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Use PTR_ERR_OR_ZERO() routineViresh Kumar
At multiple places we are doing exactly what PTR_ERR_OR_ZERO() does. And so that routine can be reused instead of increasing lines of code here. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Mark 'if' blocks in power_supply_changed_work() with 'likely'Viresh Kumar
The 'if' statements in power_supply_changed_work() are mostly there for taking care of races and normally they will always evaluate to true. Optimize them for fast execution with 'likely' statements. Also there is need to have better comments in code to mention about the races clearly. Get them in place. Cc: Zoran Markovic <zrn.markovic@gmail.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Drop useless 'if (ret.intval)' statementsViresh Kumar
There is no need to check the value of ret.intval before returning it, as we will be returning zero explicitly when ret.intval is zero. So essentially we will end up returning value of ret.intval as it is. Drop the unnecessary 'if' statements. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Don't return -EINVAL from __power_supply_find_supply_from_node()Viresh Kumar
We need to stop 'class_for_each_device' loop when a supply matches with the of-node. In order to achieve this we currently return -EINVAL from __power_supply_populate_supplied_from() on successful match. class_for_each_device() is free to return similar errors in other cases as well and so the choice of return value here isn't particularly great. This commit isn't removing the Hack but making it more elegant by returning '1' instead. Also power_supply_find_supply_from_node() can return errors other than -EPROBE_DEFER now if class_for_each_device() fails. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Propagate error returned by power_supply_find_supply_from_node()Viresh Kumar
Callers of power_supply_find_supply_from_node(), i.e. power_supply_check_supplies(), must propagate the errors returned by it instead of returning their own. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Rearrange code to remove duplicate linesViresh Kumar
of_node_put() was called twice in power_supply_check_supplies() whereas a single call will also work. Rearrange code a bit to make that feasible. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Use 'break' instead of 'continue' to end loopViresh Kumar
In few routines, we need to end the do-while loop when no more "power-supplies" are available. Currently we are doing 'continue' which will make the 'while(np)' conditional statement run again. Skip this by doing a 'break' instead. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Drop unnecessary typecastsViresh Kumar
Typecast from 'void *' to any other pointer type falls under implicit typecasts category and so doesn't require explicit typecasts. Drop them. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Return early if "power-supplies" property isn't validViresh Kumar
If power-supply's DT node doesn't have a valid "power-supplies" entry, then power_supply_check_supplies() should return early instead of trying to allocate memory for "supplied_from" array. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-09-16power-supply: Don't over-allocate memory for "supplied-from" arrayViresh Kumar
In routine power_supply_check_supplies(), 'cnt' is counting the number of supplies passed in "power-supplies" field of a node. The value of 'cnt' will always be one more than the number of supplies after the do-while loop ends. And so we need to allocate memory for 'cnt - 1' char pointers. But we are allocating memory for 'cnt' instead. Fix this by not over-allocating memory. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-07-20power_supply: Fix sparse non static symbol warningWei Yongjun
Fixes the following sparse warnings: drivers/power/power_supply_core.c:540:5: warning: symbol '__power_supply_register' was not declared. Should it be static? Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2014-05-30power_supply: allow power supply devices registered w/o wakeup sourceZhang Rui
Currently, all the power supply devices are registered with wakeup source, this results in that every power_supply_changed() invocation brings the system out of suspend-to-freeze state. This is overkill as some device drivers, e.g. ACPI battery driver, have the ability to check the device status and wake up the system from sleeping only when necessary. Thus introduce a new API which allows device to be registered w/o wakeup source. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-12-23power_supply: Add power_supply_get_by_phandleSebastian Reichel
Add method to get power supply by device tree phandle. Signed-off-by: Sebastian Reichel <sre@debian.org> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-01power_supply: Add power_supply notifierPali Rohár
This patch adds a notifier chain to the power_supply, this helps drivers in other subsystem to listen to changes in power supply subsystem. This would help to take some actions in those drivers on changing the power supply properties. One such scenario is to increase/decrease system performance based on the battery capacity/voltage. Another scenario is to adjust the h/w peak current detection voltage/current thresholds based on battery voltage/capacity. The notifier helps drivers to listen to changes in power_suppy susbystem without polling the power_supply properties Signed-off-by: Jenny TC <jenny.tc@intel.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Acked-by: Jenny TC <jenny.tc@intel.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-01power_supply: Fix Oops from NULL pointer dereference from wakeup_source_activateShuah Khan
power_supply_register() calls device_init_wakeup() to register a wakeup source before initializing dev_name. As a result, device_wakeup_enable() end up registering wakeup source with a null name when wakeup_source_register() gets called with dev_name(dev) which is null at the time. When kernel is booted with wakeup_source_activate enabled, it will panic when the trace point code tries to dereference ws->name. Fixed the problem by moving up the kobject_set_name() call prior to accesses to dev_name(). Replaced kobject_set_name() with dev_set_name() which is the right interface to be called from drivers. Fixed the call to device_del() prior to device_add() in for wakeup_init_failed error handling code. Trace after the change: bash-2143 [003] d... 132.280697: wakeup_source_activate: BAT1 state=0x20001 kworker/3:2-1169 [003] d... 132.281305: wakeup_source_deactivate: BAT1 state=0x30000 Oops message: [ 819.769934] device: 'BAT1': device_add [ 819.770078] PM: Adding info for No Bus:BAT1 [ 819.770235] BUG: unable to handle kernel NULL pointer dereference at (null) [ 819.770435] IP: [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.770572] PGD 3efd90067 PUD 3eff61067 PMD 0 [ 819.770716] Oops: 0000 [#1] SMP [ 819.770829] Modules linked in: arc4 iwldvm mac80211 x86_pkg_temp_thermal coretemp kvm_intel joydev i915 kvm uvcvideo ghash_clmulni_intel videobuf2_vmalloc aesni_intel videobuf2_memops videobuf2_core aes_x86_64 ablk_helper cryptd videodev iwlwifi lrw rfcomm gf128mul glue_helper bnep btusb media bluetooth parport_pc hid_generic ppdev snd_hda_codec_hdmi drm_kms_helper snd_hda_codec_realtek cfg80211 drm tpm_infineon samsung_laptop snd_hda_intel usbhid snd_hda_codec hid snd_hwdep snd_pcm microcode snd_page_alloc snd_timer psmouse i2c_algo_bit lpc_ich tpm_tis video wmi mac_hid serio_raw ext2 lp parport r8169 mii [ 819.771802] CPU: 0 PID: 2167 Comm: bash Not tainted 3.12.0+ #25 [ 819.771876] Hardware name: SAMSUNG ELECTRONICS CO., LTD. 900X3C/900X3D/900X4C/900X4D/SAMSUNG_NP1234567890, BIOS P03AAC 07/12/2012 [ 819.772022] task: ffff88002e6ddcc0 ti: ffff8804015ca000 task.ti: ffff8804015ca000 [ 819.772119] RIP: 0010:[<ffffffff813381c0>] [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.772242] RSP: 0018:ffff8804015cbc70 EFLAGS: 00010046 [ 819.772310] RAX: 0000000000000003 RBX: ffff88040cfd6d40 RCX: 0000000000000018 [ 819.772397] RDX: 0000000000020001 RSI: 0000000000000000 RDI: 0000000000000000 [ 819.772484] RBP: ffff8804015cbcc0 R08: 0000000000000000 R09: ffff8803f0768d40 [ 819.772570] R10: ffffea001033b800 R11: 0000000000000000 R12: ffffffff81c519c0 [ 819.772656] R13: 0000000000020001 R14: 0000000000000000 R15: 0000000000020001 [ 819.772744] FS: 00007ff98309b740(0000) GS:ffff88041f200000(0000) knlGS:0000000000000000 [ 819.772845] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 819.772917] CR2: 0000000000000000 CR3: 00000003f59dc000 CR4: 00000000001407f0 [ 819.773001] Stack: [ 819.773030] ffffffff81114003 ffff8804015cbcb0 0000000000000000 0000000000000046 [ 819.773146] ffff880409757a18 ffff8803f065a160 0000000000000000 0000000000020001 [ 819.773273] 0000000000000000 0000000000000000 ffff8804015cbce8 ffffffff8143e388 [ 819.773387] Call Trace: [ 819.773434] [<ffffffff81114003>] ? ftrace_raw_event_wakeup_source+0x43/0xe0 [ 819.773520] [<ffffffff8143e388>] wakeup_source_report_event+0xb8/0xd0 [ 819.773595] [<ffffffff8143e3cd>] __pm_stay_awake+0x2d/0x50 [ 819.773724] [<ffffffff8153395c>] power_supply_changed+0x3c/0x90 [ 819.773795] [<ffffffff8153407c>] power_supply_register+0x18c/0x250 [ 819.773869] [<ffffffff813d8d18>] sysfs_add_battery+0x61/0x7b [ 819.773935] [<ffffffff813d8d69>] battery_notify+0x37/0x3f [ 819.774001] [<ffffffff816ccb7c>] notifier_call_chain+0x4c/0x70 [ 819.774071] [<ffffffff81073ded>] __blocking_notifier_call_chain+0x4d/0x70 [ 819.774149] [<ffffffff81073e26>] blocking_notifier_call_chain+0x16/0x20 [ 819.774227] [<ffffffff8109397a>] pm_notifier_call_chain+0x1a/0x40 [ 819.774316] [<ffffffff81095b66>] hibernate+0x66/0x1c0 [ 819.774407] [<ffffffff81093931>] state_store+0x71/0xa0 [ 819.774507] [<ffffffff81331d8f>] kobj_attr_store+0xf/0x20 [ 819.774613] [<ffffffff811f8618>] sysfs_write_file+0x128/0x1c0 [ 819.774735] [<ffffffff8118579d>] vfs_write+0xbd/0x1e0 [ 819.774841] [<ffffffff811861d9>] SyS_write+0x49/0xa0 [ 819.774939] [<ffffffff816d1052>] system_call_fastpath+0x16/0x1b [ 819.775055] Code: 89 f8 48 89 e5 f6 82 c0 a6 84 81 20 74 15 0f 1f 44 00 00 48 83 c0 01 0f b6 10 f6 82 c0 a6 84 81 20 75 f0 5d c3 66 0f 1f 44 00 00 <80> 3f 00 55 48 89 e5 74 15 48 89 f8 0f 1f 40 00 48 83 c0 01 80 [ 819.775760] RIP [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.775881] RSP <ffff8804015cbc70> [ 819.775949] CR2: 0000000000000000 [ 819.794175] ---[ end trace c4ef25127039952e ]--- Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Acked-by: Anton Vorontsov <anton@enomsg.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: stable@vger.kernel.org Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27power_supply: Prevent suspend until power supply events are processedZoran Markovic
This patch, originally authored by Arve Hjonnevag and Todd Poynor, prevents the system from entering suspend mode until the power supply plug, unplug, or any other change of state event is fully processed. This guarantees that the screen lights up and displays the battery charging state. The implementation uses the power supply wakeup_source object. Cc: David Woodhouse <dwmw2@infradead.org> Cc: Arve Hjonnevag <arve@android.com> Cc: Todd Poynor <toddpoynor@google.com> Cc: John Stultz <john.stultz@linaro.org> Signed-off-by: Zoran Markovic <zoran.markovic@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-06-28power_supply: Add of_node_put to fix refcountRhyland Klein
of_parse_phandle increments the refcount for a dt node before returning it. Add of_node_put where needed to properly decrement the refcount when we are done using a given node. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-04-16power_supply: Populate supplied_from hierarchy from the device treeRhyland Klein
With this patch the power_supply_core will try to populate supplied_from hierarchy from the device tree. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-04-16power_supply: Add core support for supplied_fromRhyland Klein
This patch adds support for supplies to register a list of char *'s which represent the list of supplies which supply them. This is the opposite as the supplied_to list. This change maintains support for supplied_to until all drivers which make use of it already are converted. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-13Merge tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery subsystem updates from Anton Vorontsov: "Highlights: - Two new drivers from Pali Rohár and N900 hackers: rx51_battery and bq2415x_charger. The drivers are a part of a solution to replace the proprietary Nokia BME stack - Power supply core now registers devices with a thermal cooling subsystem, so we can now automatically throttle charging. Thanks to Ramakrishna Pallala! - Device tree support for ab8500 and max8925_power drivers - Random fixups and enhancements for a bunch of drivers." * tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6: (22 commits) max8925_power: Add support for device-tree initialization ab8500: Add devicetree support for chargalg ab8500: Add devicetree support for charger ab8500: Add devicetree support for btemp ab8500: Add devicetree support for fuelgauge twl4030_charger: Change TWL4030_MODULE_* ids to TWL_MODULE_* jz4740-battery: Use devm_request_and_ioremap jz4740-battery: Use devm_kzalloc bq27x00_battery: Fixup nominal available capacity reporting bq2415x_charger: Fix style issues bq2415x_charger: Add Kconfig/Makefile entries power_supply: Add bq2415x charger driver power_supply: Add new Nokia RX-51 (N900) power supply battery driver max17042_battery: Fix missing verify_model_lock() return value check ds2782_battery: Fix signedness bug in ds278x_read_reg16() lp8788-charger: Fix ADC channel names lp8788-charger: Fix wrong ADC conversion lp8788-charger: Use consumer device name on setting IIO channels power_supply: Register power supply for thermal cooling device power_supply: Add support for CHARGE_CONTROL_* attributes ...
2012-11-17power_supply: Register power supply for thermal cooling deviceRamakrishna Pallala
This patch registers the power supply as a cooling device if the power supply has support for charge throttling. Now with this change low level drivers need not register with thermal framework as it is automatically done by power supply framework. Signed-off-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com> Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-11-05Thermal: Pass zone parameters as argument to tzd_registerDurgadoss R
This patch adds the thermal zone parameter as an argument to the tzd_register() function call; and updates other drivers using this function. Signed-off-by: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-09-24Thermal: Remove tc1/tc2 in generic thermal layer.Zhang Rui
Remove tc1/tc2 in generic thermal layer. .get_trend() callback starts to take effect from this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Valentin, Eduardo <eduardo.valentin@ti.com>
2012-07-31Merge with upstream to accommodate with thermal changesAnton Vorontsov
This merge is performed to take commit c56f5c0342dfee11a1 ("Thermal: Make Thermal trip points writeable") out of Linus' tree and then fixup power supply class. This is needed since thermal stuff added a new argument: CC drivers/power/power_supply_core.o drivers/power/power_supply_core.c: In function ‘psy_register_thermal’: drivers/power/power_supply_core.c:204:6: warning: passing argument 3 of ‘thermal_zone_device_register’ makes integer from pointer without a cast [enabled by default] include/linux/thermal.h:154:29: note: expected ‘int’ but argument is of type ‘struct power_supply *’ drivers/power/power_supply_core.c:204:6: error: too few arguments to function ‘thermal_zone_device_register’ include/linux/thermal.h:154:29: note: declared here make[1]: *** [drivers/power/power_supply_core.o] Error 1 make: *** [drivers/power/] Error 2 Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-06-17power_supply: Register battery as a thermal zoneJenny TC
Battery and charger contribute to Thermals in most of the embedded devices. So, it makes sense to identify them as Thermal zones in a particular platform. This patch registers a thermal zone if the power supply is reporting a temperature property. The thermal zone will be used by platform's thermal management solution. Signed-off-by: Jenny TC <jenny.tc@intel.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2012-01-07power_supply: Drop usage of nowarn variant of sysfs_create_link()Anton Vorontsov
The function is not exported to modules, plus we do want to catch anyone who tries to create complex hierarchy (in that case we'd need to change 'powers' symlink to a directory, probably under a different name to not break ABI). This patch fixes the following build error: ERROR: "sysfs_create_link_nowarn" [drivers/power/power_supply.ko] undefined! Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2012-01-06power_supply: Assume mains power by defaultJean Delvare
If no power class device is found in power_supply_is_system_supplied(), the function currently returns 0, which basically means that the system is supposed to be running on battery. In practice, mobile devices tend to always implement at least one power class device and more often two (battery and AC adapter). Systems with no registered power class devices are more likely to be desktop systems, where the system is always powered by mains. So, change the default return value of power_supply_is_system_supplied() from 0 (running on battery) to 1 (running on mains.) Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-12-09power_supply: allow a power supply to explicitly point to powered deviceJeremy Fitzhardinge
If a power supply has a scope of "Device", then allow the power supply to indicate what device it actually powers. This is represented in the power supply's sysfs directory as a symlink named "powers", which points to the sysfs directory of the powered device. If the device has children, then the sub-devices are also powered by the same power supply. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Richard Hughes <richard@hughsie.com>
2011-02-22power_supply: Initialize changed_work before calling device_addLars-Peter Clausen
Calling device_add causes an inital uevent for that device to be generated. The power_supply uevent function calls the drivers get_property function, which might causes the driver to update its state, which again might causes the driver to call power_supply_changed(). Since the power_supplys changed_work has not been initialized at this point the behavior is undefined and can result in an OOPS. This patch fixes the issue by initializing the power_supplys changed_work prior to adding the power_supplys device to the device tree. Reported-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Grazvydas Ignotas <notasas@gmail.com>
2010-12-22power_supply: Don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. In battery drivers, the work can be canceled on probe failure and removal and should be flushed on suspend. Replace flush_scheduled_work() usages with direct cancels and flushes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-12-22power_supply: Fix use after free and memory leakVasiliy Kulikov
device_unregister() might free its argument. This leads to freed memory use in kfree(). Also use put_device() instead of kfree() as dev may be already used in another layer after call to device_add(). Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-19power_supply: Use attribute groupsAnton Vorontsov
This fixes a race between power supply device and initial attributes creation, plus makes it possible to implement writable properties. [Daniel Mack - removed superflous return statement and dropped .mode attribute from POWER_SUPPLY_ATTR] Suggested-by: Greg KH <gregkh@suse.de> Suggested-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Daniel Mack <daniel@caiaq.de>
2009-07-30power_supply: get_by_name and set_charged functionalityDaniel Mack
This adds a function that indicates that a battery is fully charged. It also includes functions to get a power_supply device from the class of registered devices by name reference. These can be used to find a specific battery to call power_supply_set_battery_charged() on. Some battery drivers might need this information to calibrate themselves. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Ian Molton <spyro@f2s.com> Cc: Anton Vorontsov <cbou@mail.ru> Cc: Matt Reimer <mreimer@vpop.net> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-07-30power_supply: EXPORT_SYMBOL cleanupsDaniel Mack
While I'm at it, cleanup the power supply code so that EXPORT_SYMBOL_GPL appears directly after the symbole declaration. checkpatch.pl wants it that way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Ian Molton <spyro@f2s.com> Cc: Matt Reimer <mreimer@vpop.net> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
