Bug 682070
warnings like:
- defined but not used
- unused variable
- format type
- control reaches to the end of non-void function
Image builds and boots properly after these changes.
Change-Id: I91578a9684b42fcf9652cf76e492f1020194e6e6
Reviewed-on: http://git-master/r/1339
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Tested-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Gary King <gking@nvidia.com>
As we know that android doesn't polls for the battery status.
In order to update the battery and power supply related info
created a timer func which polls for every 30Sec and updates
the battery and power supply info.
Also, there is a sysfs attribure "status_poll_period" using
which this polling interval can be altered.
Already, we have these changes in nvec_battery.c which are
wokring and verified. Porting the same changes to
tegra_odm_battery.
Change-Id: I19f8e3f24c333745b7d90084a7e8c320ac8a1d6b
Reviewed-on: http://git-master/r/1064
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
1. nvec.h:Correcting enum ordering for NvEcBatterySubtype
as per ECI specs.
NvEcBatterySubtype_SetRemainingCapacityAlarm and
NvEcBatterySubtype_GetRemainingCapacityAlar
>> Verified
2. Registering interrupt for LOW_BAT# from T20 pinmux table:-
GPIO interrupt for Low battery on port w and pin 3
>> Already verified on Wince.
On Android when 0% power is left device
is shutdown. Harmony has this setting around 9.3V which is
less when the battery is at 0%.
3. Enabling LOW_BAT# as a wakeup source 11 from suspend
>> As point no. 2 is wokring this should also work.
This is not verfied as in suspend battery discharge
is slow.
4. Enabling Low capacity alarm as a wakeup source suspend
>> As remaining capacity alarm is working this should also
work.
is slow.
5. Setting the 10% of Design capacit as threshold for
Remaining capacity alaram event.
>> Verified
6. Adding 4 functions which are needed for EC firmware validation
NvOdmBatterySetRemCapacityAlarm
NvOdmBatteryGetRemCapacityAlarm
NvOdmBatterySetConfiguration
NvOdmBatteryGetConfiguration
>> Verified
7. Calling kernel_power_off() when device is running on only battery
and it is ctitically low to gracefully shutdown the system.
>> Verified
Tested on harmony + eclair + battery
Change-Id: I6f4c8a1866ba63c293813b180cc5b74714aa23cd
Reviewed-on: http://git-master/r/976
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
1. Making Battery and AC present as a wakeup source
2. Registering battery events:present, charging, remaining capacity
3. Handling battery odm flags and events in nvec_battery.c
Change-Id: I814960ab5f065e6aaad72ea1c403ad9c8d6a1af8
Reviewed-on: http://git-master/r/907
The default Battery status poll period is 30 Sec.
Adding a new sysfs attribute by which this polling period
can be modified.
To view the polling period:-
cat /sys/devices/nvec/nvec_battery/status_poll_period
To modify polling period:-
echo <newvalue> > /sys/devices/nvec/nvec_battery/status_poll_period
bug 646822
Synopsis:[Harmony/android] Battery status is not updated whenever
there is any change in battery/power supply property
Change-Id:I3b17be7f01fcf91f1c268fdb36fe348ddcf5f626
Reviewed-on: http://git-master/r/742
Tested-by: Gary King <gking@nvidia.com>
- nvec_user is the bus driver
- tegra-nvec [keyboard], nvec_mouse [touchpad], nvec_battery
are the client drivers for nvec.
- verified: suspend-resume ordering: This is synchronous now.
- Issues: after few suspend-resume EC is failed to suspend.
[working on this issue]
- Bug 648447
- Adding device_unregister for nvec bus driver.
Change-Id: I3c30ceb50a89f67d71050089766897bd7691848d
Bug 646822
- Created a timer of interval 30 Secs which calls the function
tegra_battery_poll_timer_func().
This reports to the power supply core for power supply changes
for Battery, AC and USB.
Which gets the updated info from EC battery driver and signals the uvent.
The JNI and Battery Info application which is waiting on this uevent
then updates themselves with this lateset info from /sys/class/power_supply/*
- Unregsitered to power_supply in remove function.
- Added suspend-resume functions
- Deleting polling timer while suspend and creating it again while resume.
Change-Id: I5a09bd9c6566f1732e6d2abb2e446d1e29cfdba2
enables charger status in tegra NvEc battery driver
modify the reported status to match Android expectations:
* HIGH returns FULL
* NO_BATTERY returns UNKNOWN
* any unmatched case returns UNKNOWN
adds properties for querying voltage and temperature
removes code to create attributes, since the power supply framework already
does this
- current is not a valid variable name, conflicts with the global task'
- include tegra_devices.h in nvec_battery.c
Change-Id: Ibba45c3a17a9f81958f6a4848186b8e10d2f17be
Adds a battery driver for batteries connected to NVIDIA Tegra NvEc-compliant
embedded controllers
Change-Id: I5ab13902749fcf01df93efba13a010f45e9eea30
adds a battery driver for NVIDIA Tegra SoCs for devices using the NVIDIA ODM
kit adaptation for PMU
Change-Id: I465165ca16dc686818f28dd321121e33afa348ff
The 'battery remaining capacity' calculation in
drivers/power/ds2760_battery.c lacks a parameter check to a division
operation which causes the kernel to oops on my board.
[ 21.233750] Division by zero in kernel.
[ 21.237646] [<c002955c>] (__div0+0x0/0x20) from [<c012561c>] (Ldiv0+0x8/0x10)
[ 21.244816] [<c01bef34>] (ds2760_battery_read_status+0x0/0x2a4) from [<c01bf3a4>] (ds2760_battery_get_property+0x30/0xdc)
[ 21.255803] r8:c03a22c0 r7:c7886100 r6:00000009 r5:c782fe7c r4:c7886084
[ 21.262518] [<c01bf374>] (ds2760_battery_get_property+0x0/0xdc) from [<c01bde98>] (power_supply_show_property+0x48/0x114)
[ 21.273480] r6:c7996000 r5:00000009 r4:00000000
[ 21.278111] [<c01bde50>] (power_supply_show_property+0x0/0x114) from [<c01be158>] (power_supply_uevent+0x188/0x280)
[ 21.288537] r8:00000001 r7:c7886100 r6:c7996000 r5:000000b4 r4:00000000
[ 21.295222] [<c01bdfd0>] (power_supply_uevent+0x0/0x280) from [<c015c664>] (dev_uevent+0xd4/0x10c)
[ 21.304199] [<c015c590>] (dev_uevent+0x0/0x10c) from [<c0128440>] (kobject_uevent_env+0x180/0x390)
[ 21.313170] r5:00000000 r4:c78860ac
[ 21.316725] [<c01282c0>] (kobject_uevent_env+0x0/0x390) from [<c0128664>] (kobject_uevent+0x14/0x18)
[ 21.325850] [<c0128650>] (kobject_uevent+0x0/0x18) from [<c01bdc34>] (power_supply_changed_work+0x5c/0x70)
[ 21.335506] [<c01bdbd8>] (power_supply_changed_work+0x0/0x70) from [<c004d290>] (run_workqueue+0xbc/0x144)
[ 21.345167] r4:c7812040
[ 21.347716] [<c004d1d4>] (run_workqueue+0x0/0x144) from [<c004d94c>] (worker_thread+0xa8/0xbc)
[ 21.356296] r7:c7812040 r6:c7820b00 r5:c782ffa4 r4:c7812048
[ 21.361957] [<c004d8a4>] (worker_thread+0x0/0xbc) from [<c0051008>] (kthread+0x5c/0x94)
[ 21.369971] r7:00000000 r6:c004d8a4 r5:c7812040 r4:c782e000
[ 21.375612] [<c0050fac>] (kthread+0x0/0x94) from [<c00403d0>] (do_exit+0x0/0x688)
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Szabolcs Gyurko <szabolcs.gyurko@tlt.hu>
Acked-by: Matt Reimer <mreimer@vpop.net>
Acked-by: Anton Vorontsov <cbou@mail.ru>
container_of(psy, struct pcf50633_mbc, usb); should be
container_of(psy, struct pcf50633_mbc, adapter);
Signed-off-by: Balaji Rao <balajirrao@openmoko.org>
Cc: Andy Green <andy@openmoko.com>
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
IRQF_DISABLED is not guaranteed for shared IRQs. I think power_changed_isr
doesn't need it anyway, as it only fires a timer.
This patch enables IRQF_SAMPLE_RANDOM instead.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
CC: Anton Vorontsov <cbouatmailru@gmail.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Driver for battery charger integrated into Dialog Semiconductor DA9030 PMIC
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Implement support for reporting battery health in the WM8350 battery
interface. Since we are now able to report this via the classs remove
the diagnostics from the interrupt handler.
Some systems are able to report problems with batteries being under
temperature.
Rather than check for chip revisions in the WM8350 drivers have the core
code set flags for relevant differences.
This patch adds support for the PMU provided by the WM8350 which
implements battery, line and USB supplies including a battery charger.
The hardware functions largely autonomously, with minimal software
control required to initiate fast charging.
Support for configuration of the USB supply is not yet implemented.
This means that the hardware will remain in the mode configured at
startup, by default limiting the current drawn from USB to 100mA.
This driver was originally written by Liam Girdwood with subsequent
updates for submission by Mark Brown.
* git://git.infradead.org/battery-2.6:
bq27x00_battery: use unaligned access helper
power_supply: fix dependency of tosa_battery
power_supply: Support for Texas Instruments BQ27200 battery managers
power_supply: Add function to return system-wide power state
pda_power: Check and handle return value of set_irq_wake
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs
attribute->owner unnecessary. But the field was left in the structure to
ease the merge. It's been over a year since that change and it is now
time to start killing attribute->owner along with its users - one arch at
a time!
This patch is attempt #1 to get rid of attribute->owner only for
CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on
as and when possible - avr32 will be the next since that is something I
can test. Compile (make allyesconfig / make allmodconfig / custom config)
and boot tested.
akpm: the idea is that we put the declaration of sttribute.owner inside
`#ifndef CONFIG_X86'. But that proved to be too ambitious for now because
new usages kept on turning up in subsystem trees.
[akpm: remove the ifdef for now]
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/power/Makefile
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits)
UIO: Fix mapping of logical and virtual memory
UIO: add automata sercos3 pci card support
UIO: Change driver name of uio_pdrv
UIO: Add alignment warnings for uio-mem
Driver core: add bus_sort_breadthfirst() function
NET: convert the phy_device file to use bus_find_device_by_name
kobject: Cleanup kobject_rename and !CONFIG_SYSFS
kobject: Fix kobject_rename and !CONFIG_SYSFS
sysfs: Make dir and name args to sysfs_notify() const
platform: add new device registration helper
sysfs: use ilookup5() instead of ilookup5_nowait()
PNP: create device attributes via default device attributes
Driver core: make bus_find_device_by_name() more robust
usb: turn dev_warn+WARN_ON combos into dev_WARN
debug: use dev_WARN() rather than WARN_ON() in device_pm_add()
debug: Introduce a dev_WARN() function
sysfs: fix deadlock
device model: Do a quickcheck for driver binding before doing an expensive check
Driver core: Fix cleanup in device_create_vargs().
Driver core: Clarify device cleanup.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Andres Salomon <dilinger@queued.net>
Now that device_create() has been audited, rename things back to the
original call to be sane.
It needs the WM97xx touchscreen driver to be compiled in, not as a
module. And it cannot itself be a module, due to some unfortunate
interactions with platform data.
Reported-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch adds generic battery driver for wm97xx chips.
Remove hand-rolled get_unaligned_be16, this points to a possible bug as
bq27x00_read does another endian byteswap which sparse notices:
drivers/power/bq27x00_battery.c:81:14: warning: cast to restricted __be16
Which should probably be checked.
Cc: Rodolfo Giometti <giometti@linux.it>
tosa_battery should also depend on wm97xx_ts as it uses dac-accessing
functions from that module.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
These battery managers came in two different packages: one for I2C
busses (BQ27200) and one for HDQ busses (BQ27000).
This driver currently supports only the I2C chip version but the code
is designed in order to easily allow the HDQ chip version integration.
[akpm@linux-foundation.org: make things static, use kasprintf()]
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Certain drivers benefit from knowing whether the system is on ac or
battery, for instance when determining which backlight registers to
read. This adds a simple call to determine whether there's an online
power supply other than any batteries.
The recent change in commit 2db873211ba47ef704c301f9ecf4a33413a0b649
forces the calls enable_irq_wake() and disable_irq_wake() to
be balanced. But if in pda_power_suspend() the call to
enable_irq_wake() fails (because attached gpio cannot wake
up the CPU), the corresponding disable_irq_wake will WARN().
Fix it by storing success/failure of enable_irq_wake().
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
This just leaves include/asm-arm/plat-* to deal with.
drivers/power/Kconfig
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf ("platform: prefix MODALIAS
with "platform:"), the platform modalias is prefixed with "platform:".
Add MODULE_ALIAS() to the hotpluggable "power" drivers drivers, to
re-enable auto loading.
[dbrownell@users.sourceforge.net: one was missing]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (85 commits)
[ARM] pxa: add base support for PXA930 Handheld Platform (aka SAAR)
[ARM] pxa: add base support for PXA930 Evaluation Board (aka TavorEVB)
[ARM] pxa: add base support for PXA930 (aka Tavor-P)
[ARM] Update mach-types
[ARM] pxa: make littleton to use the new smc91x platform data
[ARM] pxa: make zylonite to use the new smc91x platform data
[ARM] pxa: make mainstone to use the new smc91x platform data
[ARM] pxa: make lubbock to use new smc91x platform data
[NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform data
[NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variable
[NET] smc91x: add SMC91X_NOWAIT flag to platform data
[NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_*
[NET] smc91x: remove "irq_flags" from "struct smc91x_platdata"
[ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helper
Support for LCD on e740 e750 e400 and e800 e-series PDAs
E-series UDC support
PXA UDC - allow use of inverted GPIO for pullup
Add e350 support
Fix broken e-series build
E-series GPIO / IRQ definitions.
This mirrors the functionality that driver_for_each_device has as well.
We add a start variable, and all callers of the function are fixed up at
the same time.
The block layer will be using this new functionality in a follow-on
patch.
Cc: Kay Sievers <kay.sievers@vrfy.org>
This patch adds battery monitoring driver for PalmTX.
It can read voltage from the battery and temperature.
It also monitors charging/discharging status.
This patch adds common battery interface support for Sharp SL-6000 (tosa).
Commit 54d29ad33e3483bcc7ca433a21cf294854e5154a (Power Supply: fix race
in device_create) introduced a race in power_supply_uevent. Previously it
checked that power_supply is available by checking for dev->driver_data.
But now dev->driver_data is set before power_supply->dev is initialised.
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_drvdata().
Cc: Anton Vorontsov <cbou@mail.ru>
As Richard Smith pointed out, ACR * 6250 / 15 provides for less
precision loss than ACR * 4167 / 10, _and_ it doesn't overflow. Switch
to using that equation for CHARGE_COUNTER.
Signed-off-by: Andres Salomon <dilinger@debian.org>
Cc: "Richard A. Smith" <richard@laptop.org>
This adds PROP_CHARGE_COUNTER to the power supply class (documenting it
as well). The OLPC battery driver uses this for spitting out its ACR
values (in uAh). We have some rounding errors (the data sheet claims
416.7, the math actually works out to 416.666667, so we're forced to
choose between overflows or precision loss. I chose precision loss,
and stuck w/ data sheet values), but I don't think anyone will care
that much.
Refuse to run with an EC < 0x44. We're playing it safe, and this is a pretty
old EC version.
Also, add a comment about why we're checking the EC version.
Move portions of the massive switch statement into functions. The layout of
this thing has already caused one bug (a break in the wrong place), it needed
to shrink.
This allows you to dump 0x60 bytes from the battery's EEPROM (starting at
address 0x20). Note that it does an EC command for each byte, so it's pretty
slow. OTOH, if you want to grab just a single byte from somewhere in the
EEPROM, you can do something like:
dd bs=1 count=1 skip=16 if=/sys/class/power_supply/olpc-battery/eeprom | od -x
Userspace battery collection/logging information needs this.
This adds serial number support to the OLPC battery driver.
