Power supply property is in fact enum, so reflect it in code.
Also use switch statement in show property function as is done
for storing property.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
The AB8540 was an evolved version of the AB8500, but it was never
mass produced or put into products, only reference designs exist.
The upstream support was never completed and it is unlikely that
this will happen so drop the support for now to simplify
maintenance of the AB8500.
Cc: Loic Pallardy <loic.pallardy@st.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Trivial fix to spelling mistake in dev_dbg message text
We should get drvdata from struct device directly. Going via
platform_device is an unneeded step back and forth.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
This device is software similar to the BQ27426 except it has
different data memory offsets. Add support here.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Pali Rohár <pali.rohar@gmail.com>
The power-off call is done in a context that must be able to sleep, so
use gpiod_set_value_cansleep instead of the atomic gpiod_set_value call.
This fixes a kernel warning at shutdown when the gpio is controlled
through an IO expander for example.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
This commit adds the 'usb_type' property to represent USB supplies
which can report a number of different types based on a connection
event.
Examples of this already exist in drivers whereby the existing 'type'
property is updated, based on an event, to represent what was
connected (e.g. USB, USB_DCP, USB_ACA, ...). Current implementations
however don't show all supported connectable types, so this knowledge
has to be exlicitly known for each driver that supports this.
The 'usb_type' property is intended to fill this void and show users
all possible USB types supported by a driver. The property, when read,
shows all available types for the driver, and the one currently chosen
is highlighted/bracketed. It is expected that the 'type' property
would then just show the top-level type 'USB', and this would be
static.
Currently the 'usb_type' enum contains all of the USB variant types
that exist for the 'type' enum at this time, and in addition has
SDP and PPS types. The mirroring is intentional so as to not impact
existing usage of the 'type' property.
Signed-off-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Currently there's no error checking of this parameter in the
registration function and it's blindly added to psy class and
subsequently used as is. For example if this is NULL the call
to psy_register_thermal() will try to dereference the pointer
thus causing a kernel dump.
This commit updates the registration code to add some basic
checks on the desc pointer validity, name, and presence of
properties.
Pull ARM SoC platform updates from Arnd Bergmann:
"This release brings up a new platform based on the old ARM9 core: the
Nuvoton NPCM is used as a baseboard management controller, competing
with the better known ASpeed AST2xx series.
Another important change is the addition of ARMv7-A based chips in
mach-stm32. The older parts in this platform are ARMv7-M based
microcontrollers, now they are expanding to general-purpose workloads.
The other changes are the usual defconfig updates to enable additional
drivers, lesser bugfixes. The largest updates as often are the ongoing
OMAP cleanups, but we also have a number of changes for the older PXA
and davinci platforms this time.
For the Renesas shmobile/r-car platform, some new infrastructure is
needed to make the watchdog work correctly.
Supporting Multiprocessing on Allwinner A80 required a significant
amount of new code, but is not doing anything unexpected"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (179 commits)
arm: npcm: modify configuration for the NPCM7xx BMC.
MAINTAINERS: update entry for ARM/berlin
ARM: omap2: fix am43xx build without L2X0
ARM: davinci: da8xx: simplify CFGCHIP regmap_config
ARM: davinci: da8xx: fix oops in USB PHY driver due to stack allocated platform_data
ARM: multi_v7_defconfig: add NXP FlexCAN IP support
ARM: multi_v7_defconfig: enable thermal driver for i.MX devices
ARM: multi_v7_defconfig: add RN5T618 PMIC family support
ARM: multi_v7_defconfig: add NXP graphics drivers
ARM: multi_v7_defconfig: add GPMI NAND controller support
ARM: multi_v7_defconfig: add OCOTP driver for NXP SoCs
ARM: multi_v7_defconfig: configure I2C driver built-in
arm64: defconfig: add CONFIG_UNIPHIER_THERMAL and CONFIG_SNI_AVE
ARM: imx: fix imx6sll-only build
ARM: imx: select ARM_CPU_SUSPEND for CPU_IDLE as well
ARM: mxs_defconfig: Re-sync defconfig
ARM: imx_v4_v5_defconfig: Use the generic fsl-asoc-card driver
ARM: imx_v4_v5_defconfig: Re-sync defconfig
arm64: defconfig: enable stmmac ethernet to defconfig
ARM: EXYNOS: Simplify code in coupled CPU idle hot path
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply
Pull power supply and reset updates from Sebastian Reichel:
- Microsemi Ocelot reset support
- Spreadtrum SC27xx reset support
- generic gpio charger: lot's of cleanups
- axp20x fuel gauge: add AXP813 support
- misc fixes, including one devicetree change for the Nokia N900, that
has been Acked-by Tony Lindgren
* tag 'for-v4.17' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (27 commits)
power: reset: at91-reset: Switch from the pr_*() to the dev_*() logging functions
power: reset: at91-poweroff: Remove redundant dev_err call in at91_poweroff_probe()
power: reset: at91-poweroff: Switch from the pr_*() to the dev_*() logging functions
power: reset: make function sc27xx_poweroff_shutdown static
power: supply: da9150-fg: remove VLA usage
ARM: dts: omap3-n900: Add link between battery and charger
power: supply: bq2415x: add DT referencing support
power: supply: bq27xxx: support missing supplier device
max17042: propagate of_node to power supply device
power: supply: axp288_fuel_gauge: Fix full status reporting
power: supply: axp288_fuel_gauge: Do not register FG on ECS EF20EA
power: reset: gpio-poweroff: Support for timeout from device property
dt-bindings: power: reset: gpio-poweroff: Add 'timeout-ms' property
power: reset: Add Spreadtrum SC27xx PMIC power off support
power: supply: axp20x_battery: add support for AXP813
dt-bindings: power: supply: axp20x: add AXP813 battery DT binding
power: supply: axp20x_battery: use data struct for variant specific code
power: supply: gpio-charger: Remove pdata from gpio_charger
power: supply: gpio-charger: Use GPIOF_ACTIVE_LOW for legacy setup
power: supply: gpio-charger: Remove redundant dev_err call in probe function
functions
Use dev_info() instead of pr_info().
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
There is an error message within devm_ioremap_resource
already, so remove the dev_err call to avoid redundancy.
functions
The function sc27xx_poweroff_shutdown is local to the source and does
not need to be in global scope, so make it static.
Cleans up sparse warning:
drivers/power/reset/sc27xx-poweroff.c:28:6: warning: symbol
'sc27xx_poweroff_shutdown' was not declared. Should it be static?
Merge for-stable fixes branch into for-next development branch.
In preparation to enabling -Wvla, remove VLA usage and replace it
with fixed-length arrays.
DA9150_QIF_LONG_SIZE (4 bytes) is the biggest size of an attribute which can
be accessed [1].
Fixed as part of the directive to remove all VLAs from
the kernel: https://lkml.org/lkml/2018/3/7/621
[1] https://marc.info/?l=kernel-hardening&m=152059600524753&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com>
Add support for using bq2415x together with power_supply_am_i_supplied().
power_supply_am_i_supplied() can return negative error
codes. In this case we should assume, that no charger
is connected and the battery should be marked as
DISCHARGING instead of NOT_CHARGING.
Reported-by: Merlijn Wajer <merlijn@wizzup.org>
max17042_get_status uses the core power_supply_am_i_supplied. That
function relies on DT properties to figure out the power supply
topology, and will error out without DT.
Fixes max17042 battery status being reported as "unknown".
Signed-off-by: Pierre Bourdon <delroth@google.com>
Signed-off-by: Andre Heider <a.heider@gmail.com>
Commit 2b5a4b4bf222 ("power: supply: axp288_fuel_gauge: Rework
get_status()"), switched from 0A current detection to using the capacity
register for full detection.
It turns out this fixes full reporting on some devices which keep trickle
charging long after the capacity register reach 100%, but breaks it on
some other devices where the charger stops charging before the capacity
register reaches 100%. This commit fixes this by also checking for
0A current when the reported capacity is above 90%.
Fixes: 2b5a4b4bf222 ("psy: axp288_fuel_gauge: Rework get_status()")
The ECS EF20EA laptop ships an AXP288 but it is actually using a
different, separate FG chip for AC and battery monitoring. On this
laptop we need to keep using the regular ACPI driver and disable the
AXP288 FG to avoid reporting two batteries to userspace.
Signed-off-by: Carlo Caione <carlo@endlessm.com>
Add support for reading a timeout value from device property.
Fall back to previous default of 3s if nothing is specified.
Signed-off-by: Moritz Fischer <mdf@kernel.org>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
On Spreadtrum platform, we need power off system through external SC27xx
series PMICs including the SC2720, SC2721, SC2723, SC2730 and SC2731 chips.
Thus this patch adds SC27xx series PMICs power-off support.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
The X-Powers AXP813 PMIC has got some slight differences from
AXP20X/AXP22X PMICs:
- the maximum voltage supplied by the PMIC is 4.35 instead of 4.36/4.24
for AXP20X/AXP22X,
- the constant charge current formula is different,
It also has a bit to tell whether the battery percentage returned by the
PMIC is valid.
Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
We used to use IDs to select a function or a feature depending on the
variant. It's easier to maintain the code by adding data structure
storing the few differences between variants so that we don't add a pile
of if conditions.
Let's use this data structure and update the code to use it.
[updated POWER_SUPPLY_PROP_VOLTAGE_MAX_DESIGN write property to use
the introduced set_max_voltage() callback]
Platform data are now used only during probe time, so remove
them from gpio_charger structure and consolidate probing
function accordingly.
[Replace of_property_read_string with dev_property_read_string]
Setting GPIOF_ACTIVE_LOW flag based on platform data gpio_active_low
makes return value of gpiod_get_value_cansleep directly usable.
There is an error message within devm_kzalloc already.
We are currently probing smartreflex with omap_device while we are
already probing smartreflex related interconnect target module with
ti-sysc driver and dts data.
Before we can flip things on for ti-sysc, we need to prepare the
smartreflex driver a bit:
1. The smartreflex clock is really for the whole interconnect target
module. So it may be configured at the parent device level with
ti-sysc
2. With ti-sysc, we have the child device manage interconnect target
module directly if pm_runtime_irq_safe() is set and there is only
one child. In that case nobody else is going to call pm_runtime_get
and put, so we need to add these calls to idle smartreflex properly
after probe if not fully configured
3. With ti-sysc, the parent driver may rebind. So we want to use
platform_driver_register() and don't want probe to be __init
Note that this patch depends on the related changes to ti-sysc driver
and omap_device probing to prevent both ti-sysc and omap_device to
try to probe smartreflex.
Cc: linux-pm@vger.kernel.org
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Kevin Hilman <khilman@baylibre.com>
On the D-Link DIR-685 we get spurious poweroff from
infrared. Since that block (CIR) doesn't even have a
driver this can be safely ignored, we can revisit this
code once we have a device supporting CIR.
On the D-Link DNS-313 we get spurious poweroff from
the power button. This appears to be an initialization
issue: we need to enable the block (start the state
machine) before we clear any dangling IRQ.
This patch fixes both issues.
Fixes: f7a388d6cd1c ("power: reset: Add a driver for the Gemini poweroff")
Temperature is measured in tenths of degree Celsius.
Fixes: 085bc24d1553 ("Add LTC2941/LTC2943 Battery Gauge Driver")
This patch adds the to_power_supply macro to upcast
a device to a power_supply struct.
This is needed because the same piece of code using
container_of is used in various other places, so we
abstract away such low-level operations via a macro.
Suggested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Ognjen Galic <smclt30p@gmail.com>
Using explicit struct device variable makes code a bit more readable.
Simplify error unwinding using devm_* allocators. This also
makes driver remove function empty, so remove it.
Add properties for charge empty and charge full thresholds.
The Microsemi Ocelot SoC has a register allowing to reset the MIPS core.
Unfortunately, the syscon-reboot driver can't be used directly (but almost)
as the reset control may be disabled using another register.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
- bq27xxx: add bq27521 support
- drop unused imx-snvs-poweroff driver
- improve axp288 driver
- misc fixes
* tag 'for-v4.16' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (32 commits)
power: supply: max17042_battery: Always fall back to default platform-data
power: supply: max17042_battery: Check battery current for status when supplied
MAINTAINERS: Add AXP288 PMIC entry
power: supply: axp288_fuel_gauge: Do not register our psy on (some) HDMI sticks
power: supply: axp288_fuel_gauge: Optimize get_current()
power: supply: axp288_fuel_gauge: Rework get_status()
power: reset: account for const type of of_device_id.data
power: supply: account for const type of of_device_id.data
bq24190: Simplify code in property_is_writeable
power: supply: axp288_fuel_gauge: Get iio-channels once during boot
power: supply: axp288_charger: Properly stop work on probe-error / remove
power: supply: axp288_charger: Simplify extcon cable handling
power: supply: axp288_charger: Use the right property for the input current limit
power: supply: axp288_charger: Pick lower input current limit not higher
power: supply: axp288_charger: Do not cache input current limit value
power: supply: axp288_charger: Remove no longer needed locking
power: supply: axp288_charger: Use regmap_update_bits to set the input limits
power: supply: axp288_charger: Cleanup some double empty lines
power: supply: axp288_charger: Remove charger-enabled state tracking
power: supply: axp288_charger: Add missing newlines to some messages
It is possible to have CONFIG_OF enabled on x86 builds, where we have no
firmware provided max17042_platform_data. The CONFIG_OF implementation of
max17042_get_pdata would return NULL in this case, causing the probe to
fail.
Instead always fallback to the default platform-data, as used on x86 sofar,
when there is no firmware provided pdata, independent of CONFIG_OF.
Even though the system is supplied, it may still be discharging if the
supply is e.g. only delivering 5V 0.5A. Check the avg battery current if
available for more accurate status reporting.
Cc: James <kernel@madingley.org>
Suggested-by: James <kernel@madingley.org>
The Intel Compute Stick (Cherry Trail version) and the Meegopad T08 HDMI
stick, both use an axp288 PMIC. They also both have this wired up in such
a way that the detection logic in the PMIC claims that a valid battery is
present, resuling in GNOME and KDE showing a full-battery in their status
bar and power-settings, while these devices do not have a battery.
For lack of a better fix add a DMI blacklist and do not register the
axp288_fuel_gauge psy on devices on the blacklist.
First check the discharge current, and when that is non 0 use that without
also checking the charge current (which will be 0 then). This makes
get_current() do only 1 i2c read instead of 2 when on battery.
This is esp. important given the pmic i2c bus mutex stuff used on boards
with an axp288 because the SoC's own punit also may access the axp288,
which makes i2c accesses more expensive then normal.
Relying on the (dis)charge current reporting for reporting FULL back to
userspace does not work really well and often leads to the reported status
getting stuck at e.g. 98/99% (the fuelgauge is not perfect) for hours.
What happens is that when the battery is full the axp288 keeps charging it
with a very low current. Until it is really really full and once really
really full, some inaccuracies in the adc lead to it then sometimes
reporting a small discharging rate, even though an external pwr source is
used. So we end up with a status of "charging" for hours after the battery
is actually already full and sometimes this then flip-flops to discharging.
This commit fixes this by first checking if a valid Vbus is present and if
it is present using the fuel-gauge's reported percentage to check for a
full battery.
This commit also changes how get_status() determines if the battery is
charging or discharging when not reporting it as full. We still use the
current direction for this, but instead of reading 4 extra registers for
this (2 16 bit regs), simplify things by using the current-direction bit
in the power-status register, which already gets read anyways.
This also reduces the amount of i2c reads to 1 when on battery and 2
when a valid Vbus is present.
This driver creates a const structure that it stores in the data
field of an of_device_id array.
Add const to the declaration of the location that receives a value
from the data field to ensure that the compiler will continue to check
that the value is not modified and remove the const-dropping cast on
the access to the data field.
Done using Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
This driver creates two const structures that it stores in the data
The data field of an of_device_id structure has type const void *, so
there is no need for a const-discarding cast when putting const values
into such a structure.
Furthermore, adding const to the declaration of the location that
receives a const value from such a field ensures that the compiler
will continue to check that the value is not modified. The
const-discarding cast on the extraction from the data field is thus
no longer needed.
Simplify function that should be trivial.
Signed-off-by: Pavel machek <pavel@ucw.cz>
Get iio-channels once during boot, delaying the probe if the axp288_adc
drivers has not loaded yet, instead of getting them on demand each time
we need them.
This fixes the following errors in dmesg:
axp288_fuel_gauge axp288_fuel_gauge: ADC charge current read failed:-19
Which were caused by the ondemand iio-channel read code not finding the
channel when the axp288_adc driver had not loaded yet.
Properly stop any work we may have queued on probe-errors / remove.
Rather then adding a remove driver callback for this, and goto style
error handling to probe, use a devm_action for this.
The devm_action gets registered before we register any of the extcon
notifiers which may queue the work, devm does cleanup in reverse order,
so this ensures that the notifiers are removed before we cancel the work.
Simplify extcon cable handling using the new
devm_extcon_register_notifier_all function to listen to all cables
in one go.
limit
Use the right property for the input current limit and make it writable.
The code before this commit would pick 900 mA when asking for an input
current limit of 600mA, rather then 500 mA, not good.
While touching almost all code using the silly xxxMA defines anyways,
also get rid of these simply typing out the numbers and switch the
unit to uA as that is the psy class standard unit for currents.
