path: root/drivers/power
2010-07-27Merge git://git.infradead.org/users/cbou/battery-2.6.35Linus Torvalds
* git://git.infradead.org/users/cbou/battery-2.6.35: ds2782_battery: Rename get_current to fix build failure / name conflict
2010-07-20Merge git://git.infradead.org/users/cbou/battery-2.6.35Linus Torvalds
* git://git.infradead.org/users/cbou/battery-2.6.35: ds2782_battery: Fix ds2782_get_capacity return value
2010-06-21ds2782_battery: Fix ds2782_get_capacity return valueRyan Mallon
The ds2782_get_capacity function should return 0 on success, not the capacity value. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-06-14ds2782_battery: Rename get_current to fix build failure / name conflictPeter Huewe
This patch changes the name of get_current function pointer to get_battery_current to resolve a name conflict with the get_current macro defined in current.h. This conflict resulted in a build-failure[1] for the sh4 arch allyesconfig: drivers/power/ds2782_battery.c:216:48: error: macro "get_current" passed 2 arguments, but takes just This patch fixes the issue. To be consistent the other function pointers (_voltage,_capacity) were renamed too. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-06-13[ARM] pxa/z2: fix missing include in battery driverMarek Vasut
Remove redundant includes and add slab.h to fix problem with building. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-25Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply: Fix regression for 'type' property
2010-05-25power_supply: Fix regression for 'type' propertyDaniel Mack
Commit 5f487cd34f4337f9bc27ca19da72a39d1b0a0ab4 (power_supply: Use attribute groups) causes a regression the power supply core does not export the 'type' attribute anymore. POWER_SUPPLY_PROP_TYPE is handled by the power supply core without the low-level driver, so power_supply_attr_is_visible() must always return the entry as readable. Reported-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Daniel Mack <daniel@caiaq.de> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-24Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: ds2760_battery: Document ABI change ds2760_battery: Make charge_now and charge_full writeable power_supply: Add support for writeable properties power_supply: Use attribute groups power_supply: Add test_power driver tosa_battery: Fix build error due to direct driver_data usage wm97xx_battery: Quieten sparse warning (bat_set_pdata not declared) ds2782_battery: Get rid of magic numbers in driver_data ds2782_battery: Add support for ds2786 battery gas gauge pda_power: Add function callbacks for suspend and resume wm831x_power: Use genirq Driver for Zipit Z2 battery chip ds2782_battery: Fix clientdata on removal
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-19ds2760_battery: Make charge_now and charge_full writeableDaniel Mack
For userspace tools and daemons, it might be necessary to adjust the charge_now and charge_full properties of the ds2760 battery monitor, for example for unavoidable corrections due to aging batteries. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Matt Reimer <mreimer@vpop.net> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alexey Starikovskiy <astarikovskiy@suse.de> Cc: Len Brown <len.brown@intel.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-19power_supply: Add support for writeable propertiesDaniel Mack
This patch adds support for writeable power supply properties and exposes them as writeable to sysfs. A power supply implementation must implement two new function calls in order to use that feature: int set_property(struct power_supply *psy, enum power_supply_property psp, const union power_supply_propval *val); int property_is_writeable(struct power_supply *psy, enum power_supply_property psp); Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alexey Starikovskiy <astarikovskiy@suse.de> Cc: Len Brown <len.brown@intel.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Matt Reimer <mreimer@vpop.net> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-19power_supply: Use attribute groupsAnton Vorontsov
This fixes a race between power supply device and initial attributes creation, plus makes it possible to implement writable properties. [Daniel Mack - removed superflous return statement and dropped .mode attribute from POWER_SUPPLY_ATTR] Suggested-by: Greg KH <gregkh@suse.de> Suggested-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Daniel Mack <daniel@caiaq.de>
2010-05-18power_supply: Add test_power driverAnton Vorontsov
Just a handy driver that is used for testing purposes. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-03tosa_battery: Fix build error due to direct driver_data usageDmitry Eremin-Solenikov
The driver isn't buildable since 2.6.32 (i.e. commit b4028437 "Driver core: move dev_get/set_drvdata to drivers/base/dd.c"): CC tosa_battery.o tosa_battery.c: In function 'tosa_read_bat': tosa_battery.c:64: error: 'struct device' has no member named 'driver_data' tosa_battery.c: In function 'tosa_read_temp': tosa_battery.c:84: error: 'struct device' has no member named 'driver_data' Nowadays we must not access driver_data directly, use dev_get_drvdata() instead. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-02wm97xx_battery: Quieten sparse warning (bat_set_pdata not declared)Anton Vorontsov
This patch fixes following sparse warning: drivers/power/wm97xx_battery.c:311:6: warning: symbol 'wm97xx_bat_set_pdata' was not declared. Should it be static? Note that we can't just include linux/wm97xx_batt.h because the header is deprecated, and so this pops up: In file included from drivers/power/wm97xx_battery.c:22: include/linux/wm97xx_batt.h:6: warning: #warning This file will be removed soon, use wm97xx.h instead! Since wm97xx_bat_set_pdata() is also deprecated (in favour of pdata passed via AC97 bus), just workaround the issue by declaring the function in wm97xx_battery.c. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-02ds2782_battery: Get rid of magic numbers in driver_dataAnton Vorontsov
Constructions like 'if (id->driver_data == 1)' look quite weird. This patch introduces 'enum ds278x_num_id', which makes things much more understandable, i.e. 'if (id->driver_data == DS2786)'. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il>
2010-04-26ds2782_battery: Add support for ds2786 battery gas gaugeYulia Vilensky
Signed-off-by: Yulia Vilensky <vilensky@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-04-26Merge branch 'master' of ↵Anton Vorontsov
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-04-16pda_power: Add function callbacks for suspend and resumeDaniel Mack
Add function prototypes for power management events so they can be handled and used by platform implementations. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-04-06wm831x_power: Use genirqMark Brown
Since the WM831x core has been converted to use genirq for the interrupt controller there is no longer any need for chip specific wrappers for IRQ operations. Convert to use genirq directly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-04-06Driver for Zipit Z2 battery chipMarek Vasut
This patch adds driver for Zipit Z2 battery chip called AER915. No details are known about the chip. The chip is available through I2C bus at address 0x55 and it's register 0x02 contains battery voltage. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-04-06ds2782_battery: Fix clientdata on removalWolfram Sang
Probably due to a copy & paste bug, clientdata was set again to the data structure (which is freed immediately afterwards) when it should be NULLed. Just remove the calls as the i2c-core does this automatically now. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14Merge branches 'battery-2.6.34', 'bugzilla-10805', 'bugzilla-14668', ↵Len Brown
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
2010-03-07power_supply: Enable power supply of max8925Haojian Zhuang
MAX8925 is a PMIC that contains charger component Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Update WM8350 drivers for changed interrupt numbersMark Brown
The headphone detect and charger are using the IRQ numbers so need to take account of irq_base with the genirq conversion. I obviously picked the wrong system for initial testing. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Add a data argument to the WM8350 IRQ free functionMark Brown
To better match genirq. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-02-27power_supply: bq27x00: fix voltage and current unitsGrazvydas Ignotas
The chip returns voltage and current in mV and mA, but power supply class uses uV and uA, so add missing conversion. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-27power_supply: bq27x00: add status and time propertiesGrazvydas Ignotas
The BQ27x00 series of chips can report time-to-empty and time-to-full, so let's add corresponding properties. Also report charge status based on status flag register. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: add BQ27500 supportGrazvydas Ignotas
BQ27500 is newer fuel gauge chip from TI with slightly changed register layout and some different register semantics. Add new i2c ID for it and handle differences where needed. Also rename bq27200 functions to bq27x00, as they are no longer bq27200 specific. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: fix temperature conversionGrazvydas Ignotas
The power supply class requires tenths of degree Celsius. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: remove unused struct fieldsGrazvydas Ignotas
These are probably leftover from old TI code. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-16power_supply: bq27x00: remove double endian swapGrazvydas Ignotas
The bq27x00 registers are little endian, so just read them as such and don't do double endian swap on LE machines. This also gets rid of strange looking shift that was done after reading 8bit register because endian swap in bq27x00_read() was messing it up. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-02-03da9030_battery: fix spelling in commentStefan Weil
platfrom -> platform monotor -> monitor Signed-off-by: Stefan Weil <weil@mail.berlios.de> Cc: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2010-01-29wm97xx_battery: Clean up some warningsMark Brown
Staticise work_lock (nothing outside the driver has any reason to see it) and specify dev when requesting the charger IRQ (since that's what we pass in when we free it). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2010-01-29wm97xx_battery: Handle missing platform data gracefullyMark Brown
Don't unconditionally dereference the WM97xx core platform data since it may not be present, causing an oops. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2010-01-15POWER: Add support for cycle_countAlexey Starikovskiy
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-18pmu_battery: Fix battery full reportingThomas Champagne
Prior to this patch, pmu_battery was unable to report battery full status. This patch fixes the issue by adding a proper handling code into pmu_bat_get_property(): if we're on AC and the battery isn't charging, then the battery is considered full. Signed-off-by: Thomas Champagne <lafeuil@gmail.com> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-12-15Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply_sysfs: Handle -ENODATA in a special way wm831x_backup: Remove unused variables gta02: Set pcf50633 charger_reference_current_ma pcf50633: Query charger status directly pcf50633: Properly reenable charging when the supply conditions change pcf50633: Get rid of charging restart software auto-triggering pcf50633: introduces battery charging current control pcf50633: Add ac power supply class to the charger wm831x: Factor out WM831x backup battery charger
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-13mfd: Mask and unmask wm8350 IRQs on request and freeMark Brown
Bring the WM8350 IRQ API more in line with the generic IRQ API by masking and unmasking interrupts as they are requested and freed. This is mostly just a case of deleting the mask and unmask calls from the individual drivers. The RTC driver is changed to mask the periodic IRQ after requesting it rather than only unmasking the alarm IRQ. If the periodic IRQ fires in the period where it is reqested then there will be a spurious notification but there should be no serious consequences from this. The CODEC drive is changed to explicitly disable headphone jack detection prior to requesting the IRQs. This will avoid the IRQ firing with no jack set up. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Convert wm8350 IRQ handlers to irq_handler_tMark Brown
This is done as simple code transformation, the semantics of the IRQ API provided by the core are are still very different to those of genirq (mainly with regard to masking). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Fix memleak in pcf50633_client_dev_registerLars-Peter Clausen
Since platform_device_add_data copies the passed data, the allocated subdev_pdata is never freed. A simple fix would be to either free subdev_pdata or put it onto the stack. But since the pcf50633 child devices can rely on beeing children of the pcf50633 core device it's much more elegant to get access to pcf50633 core structure through that link. This allows to get completly rid of pcf5033_subdev_pdata. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Paul Fertser <fercerpav@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-03power_supply_sysfs: Handle -ENODATA in a special wayAnton Vorontsov
There are cases when some device can not report any meaningful value, e.g. TWL4030 charger can report voltage only when charging is active. In these cases drivers will return -ENODATA, and we shouldn't flood kernel log with error messages. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2009-11-27collie: add battery driverThomas Kunze
This driver is based on tosa_battery.c.
2009-11-17wm831x_backup: Remove unused variablesAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-11-16pcf50633: Query charger status directlyPaul Fertser
Current scheme is fragile and is likely to go off sync, especially on batfull->adapter charging automatic MBC transition. Query the status bit every time we need it instead. We need to export another function to query for USB presence because we can't read anything from PCF50633 (via I2C) inside irq context and that is needed by usb gadgets. Signed-off-by: Paul Fertser <fercerpav@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-11-16pcf50633: Properly reenable charging when the supply conditions changePaul Fertser
If chgmod == BATFULL, setting chgena has no effect. Datasheet says we need to set resume instead but when autoresume is used resume doesn't work. Clear and set chgena instead. This enables a user to force charging by re-plugging USB even when the charger entered Battery Full mode, might be handy before a long trip. Signed-off-by: Paul Fertser <fercerpav@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-11-16pcf50633: Get rid of charging restart software auto-triggeringPaul Fertser
After reaching Battery Full condition MBC state machine switches back into charging mode when the battery voltage falls below 96% of a battery float voltage. The voltage drop in Li-Ion batteries is marginal (1-2%) till about 80% of its capacity - which means, after a BATFULL, charging won't be restarted until 75-80%. That is a desired behaviour recommended by battery manufacturers, don't mess with it. Signed-off-by: Paul Fertser <fercerpav@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
