path: root/drivers/pps
2013-11-13drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptrSachin Kamat
The data structure of_match_ptr() protects is always compiled in. Hence of_match_ptr() is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-11drivers/pps/clients/pps-gpio.c: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-19PPS: convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the pps class code to use the correct field. Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03pps-gpio: add device-tree binding and supportJan Luebbe
Instead of allocating a struct pps_gpio_platform_data in the DT case, store the necessary information in struct pps_gpio_device_data itself. This avoids an additional allocation and the ifdef. It also gets rid of some indirection. Also use dev_err instead of pr_err in the changed code. Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/pps/clients/pps-gpio.c: convert to module_platform_driverJan Luebbe
This removes some boilerplate code (no functional changes). Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/pps/clients/pps-gpio.c: convert to devm_* helpersJan Luebbe
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30pps: pps_kc_hardpps_lock can be staticFengguang Wu
drivers/pps/kc.c:37:1: sparse: symbol 'pps_kc_hardpps_lock' was not declared. Should it be static? drivers/pps/kc.c:39:19: sparse: symbol 'pps_kc_hardpps_dev' was not declared. Should it be static? drivers/pps/kc.c:40:5: sparse: symbol 'pps_kc_hardpps_mode' was not declared. Should it be static? Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30pps: hide more configuration symbols behind CONFIG_PPSFlorian Fainelli
Make CONFIG_PPS_DEBUG and CONFIG_NTP_PPS be hidden if CONFIG_PPS is not selected, so that we are not prompted for these configuration options if CONFIG_PPS is not set. Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29Include missing linux/slab.h inclusionsDavid Howells
Include missing linux/slab.h inclusions where the source file is currently expecting to get kmalloc() and co. through linux/proc_fs.h. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: linux-s390@vger.kernel.org cc: sparclinux@vger.kernel.org cc: linux-efi@vger.kernel.org cc: linux-mtd@lists.infradead.org cc: devel@driverdev.osuosl.org cc: x86@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27drivers/pps/clients/pps-gpio.c: use devm_kzallocJulia Lawall
devm_kzalloc allocates memory that is released when a driver detaches. This patch uses devm_kzalloc for data that is allocated in the probe function of a platform device and is only freed in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27pps: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-13pps: Move timestamp read into PPS code properGeorge Spelvin
The PPS (Pulse-Per-Second) line discipline has developed a number of unhealthy attachments to core tty data and functions, ultimately leading to its breakage. The previous patches fixed the crashing. This one reduces coupling further by eliminating the timestamp parameter from the dcd_change ldisc method. This reduces header file linkage and makes the extension more generic, and the timestamp read is delayed only slightly, from just before the ldisc->ops->dcd_change method call to just after. Fix attendant build breakage in drivers/tty/n_tty.c drivers/tty/tty_buffer.c drivers/staging/speakup/selection.c drivers/staging/dgrp/dgrp_*.c Cc: William Hubbs <w.d.hubbs@gmail.com> Cc: Chris Brannon <chris@the-brannons.com> Cc: Kirk Reiser <kirk@braille.uwo.ca> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-13pps: Don't crash the machine when exiting will doGeorge Spelvin
PPS is not really the must-have subsystem that warrants crashing the machine if the ldisc interface is broken. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-13pps: Fix a use-after free bug when unregistering a source.George Spelvin
Remove the cdev from the system (with cdev_del) *before* deallocating it (in pps_device_destruct, called via kobject_put from device_destroy). Also prevent deallocating a device with open file handles. A better long-term fix is probably to remove the cdev from the pps_device entirely, and instead have all devices reference one global cdev. Then the deallocation ordering becomes simpler. But that's more complex and invasive change, so we leave that for later. Signed-off-by: George Spelvin <linux@horizon.com> Cc: stable <stable@vger.kernel.org> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-13pps: Use pps_lookup_dev to reduce ldisc couplingGeorge Spelvin
Now that N_TTY uses tty->disc_data for its private data, 'subclass' ldiscs cannot use ->disc_data for their own private data. (This is a regression is v3.8-rc1) Use pps_lookup_dev to associate the tty with the pps source instead. This fixes a crashing regression in 3.8-rc1. Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-13pps: Add pps_lookup_dev() functionGeorge Spelvin
The PPS serial line discipline wants to attach a PPS device to a tty without changing the tty code to add a struct pps_device * pointer. Since the number of PPS devices in a typical system is generally very low (n=1 is by far the most common), it's practical to search the entire list of allocated pps devices. (We capture the timestamp before the lookup, so the timing isn't affected.) It is a bit ugly that this function, which is part of the in-kernel PPS API, has to be in pps.c as opposed to kapi,c, but that's not something that affects users. Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-01pps, ptp: Remove dependencies on EXPERIMENTALBen Hutchings
These are now established subsystems, and we want drivers to be able to select PPS and PTP_1588_CLOCK without depending on EXPERIMENTAL. Further, the use of EXPERIMENTAL is now deprecated in general. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-06idr: rename MAX_LEVEL to MAX_IDR_LEVELFengguang Wu
To avoid name conflicts: drivers/video/riva/fbdev.c:281:9: sparse: preprocessor token MAX_LEVEL redefined While at it, also make the other names more consistent and add parentheses. [akpm@linux-foundation.org: repair fallout] [sfr@canb.auug.org.au: IB/mlx4: fix for MAX_ID_MASK to MAX_IDR_MASK name change] Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at> Cc: walter harms <wharms@bfs.de> Cc: Glauber Costa <glommer@parallels.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30pps: return PTR_ERR on error in device_createEmil Goode
We should return PTR_ERR if the call to the device_create function fails. Without this patch we instead return the value from a successful call to cdev_add if the call to device_create fails. Signed-off-by: Emil Goode <emilgoode@gmail.com> Acked-by: Devendra Naga <devendra.aaru@gmail.com> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05pps: class_create() returns an ERR_PTR, not NULLDan Carpenter
class_create() never returns NULLs only ERR_PTRs. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02pps gpio client: add missing dependencyHeiko Carstens
Add "depends on GENERIC_HARDIRQS" to avoid compile breakage on s390: drivers/built-in.o: In function `pps_gpio_remove': linux-next/drivers/pps/clients/pps-gpio.c:189: undefined reference to `free_irq' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: James Nuss <jamesnuss@nanometrics.ca> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02pps: new client driver using GPIOJames Nuss
This client driver allows you to use a GPIO pin as a source for PPS signals. Platform data [1] are used to specify the GPIO pin number, label, assert event edge type, and whether clear events are captured. This driver is based on the work by Ricardo Martins who submitted an initial implementation [2] of a PPS IRQ client driver to the linuxpps mailing-list on Dec 3 2010. [1] include/linux/pps-gpio.h [2] http://ml.enneenne.com/pipermail/linuxpps/2010-December/004155.html [akpm@linux-foundation.org: remove unneeded cast of void*] Signed-off-by: James Nuss <jamesnuss@nanometrics.ca> Cc: Ricardo Martins <rasm@fe.up.pt> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Ricardo Martins <rasm@fe.up.pt> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Igor Plyatov <plyatov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02pps: default echo functionJames Nuss
A default echo function has been provided so it is no longer an error when you specify PPS_ECHOASSERT or PPS_ECHOCLEAR without an explicit echo function. This allows some code re-use and also makes it easier to write client drivers since the default echo function does not normally need to change. Signed-off-by: James Nuss <jamesnuss@nanometrics.ca> Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Rodolfo Giometti <giometti@linux.it> Cc: Ricardo Martins <rasm@fe.up.pt> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Igor Plyatov <plyatov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22pps: remove unreachable codeAlexander Gordeev
Remove code enabled only when CONFIG_PREEMPT_RT is turned on because it is not used in the vanilla kernel. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: john stultz <johnstul@us.ibm.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17pps: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-04pps: make pps_gen_parport depend on BROKENThomas Gleixner
This driver causes hard lockups, when the active clock soure is jiffies. The reason is that it loops with interrupts disabled waiting for a timestamp to be reached by polling getnstimeofday(). Though with a jiffies clocksource, when that code runs on the same CPU which is responsible for updating jiffies, then we loop in circles for ever simply because the timer interrupt cannot update jiffies. So both UP and SMP can be affected. There is no easy fix for that problem so make it depend on BROKEN for now. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@linux.it> Cc: john stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25pps: initialize ts_real properlyAlexander Gordeev
Initialize ts_real.flags to fix compiler warning about possible uninitialized use of this field. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: john stultz <johnstul@us.ibm.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26pps: claim parallel port exclusivelyAlexander Gordeev
Both pps_parport and pps_gen_parport are written in a way that they can't share a port with any other driver. This can result in locking up the process that loads modules or even the whole kernel if the modules are compiled in. Use PARPORT_FLAG_EXCL to indicate this. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26pps ktimer: remove noisy messageRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: add parallel port PPS signal generatorAlexander Gordeev
Add PPS signal generator which utilizes STROBE pin of a parallel port to send PPS signals. It uses parport abstraction layer and hrtimers to precisely control the signal. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Add PPS signal generator which utilizes STROBE pin of a parallel port to send PPS signals. It uses parport abstraction layer and hrtimers to precisely control the signal. [akpm@linux-foundation.org: fix build] Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: add parallel port PPS clientAlexander Gordeev
Add parallel port PPS client. It uses a standard method for capturing timestamps for assert edge transitions: getting a timestamp soon after an interrupt has happened. This is not a very precise source of time information due to interrupt handling delays. However, timestamps for clear edge transitions are much more precise because the interrupt handler continuously polls hardware port until the transition is done. Hardware port operations require only about 1us so the maximum error should not exceed this value. This was my primary goal when developing this client. Clear edge capture could be disabled using clear_wait parameter. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: add kernel consumer supportAlexander Gordeev
Add an optional feature of PPSAPI, kernel consumer support, which uses the added hardpps() function. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13ntp: add hardpps implementationAlexander Gordeev
This commit adds hardpps() implementation based upon the original one from the NTPv4 reference kernel code from David Mills. However, it is highly optimized towards very fast syncronization and maximum stickness to PPS signal. The typical error is less then a microsecond. To make it sync faster I had to throw away exponential phase filter so that the full phase offset is corrected immediately. Then I also had to throw away median phase filter because it gives a bigger error itself if used without exponential filter. Maybe we will find an appropriate filtering scheme in the future but it's not necessary if the signal quality is ok. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: timestamp is always passed to dcd_change()Alexander Gordeev
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case passed ts parameter is NULL because it never happens in the current code. Fix comments as well. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: simplify conditions a bitAlexander Gordeev
Bitwise conjunction is distributive so we can simplify some conditions. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: use BUG_ON for kernel API safety checksAlexander Gordeev
This way less overhead is involved when running production kernel. If you want to debug a pps client module please define DEBUG to enable the checks. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: make idr lock a mutex and protect idr_pre_getAlexander Gordeev
Now pps_idr_lock is never used in interrupt context so we can replace spin_lock_irq/spin_unlock_irq with plain spin_lock/spin_unlock. But there is also a potential race condition when someone can steal an id which was allocated by idr_pre_get before it is used. So convert spin lock to mutex and protect the whole id generation process. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: move idr stuff to pps.cAlexander Gordeev
Since now idr is only used to manage char device id's and not used in kernel API anymore it should be moved to pps.c. This also makes it possible to release id only at actual device freeing so nobody can register a pps device with the same id while our device is not freed yet. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: convert printk/pr_* to dev_*Alexander Gordeev
Since we now have direct pointers to struct pps_device everywhere it's easy to use dev_* functions to print messages instead of plain printks. Where dev_* cannot be used printks are converted to pr_*. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: access pps device by direct pointerAlexander Gordeev
Using device index as a pointer needs some unnecessary work to be done every time the pointer is needed (in irq handler for example). Using a direct pointer is much more easy (and safe as well). Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: unify timestamp gatheringAlexander Gordeev
Add a helper function to gather timestamps. This way clients don't have to duplicate it. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: fix race in PPS_FETCH handlerAlexander Gordeev
There was a race in PPS_FETCH ioctl handler when several processes want to obtain PPS data simultaneously using sleeping PPS_FETCH. They all sleep most of the time in the system call. With the old approach when the first process waiting on the pps queue is waken up it makes new system call right away and zeroes pps->go. So other processes continue to sleep. This is a clear race condition because of the global 'go' variable. With the new approach pps->last_ev holds some value increasing at each PPS event. PPS_FETCH ioctl handler saves current value to the local variable at the very beginning so it can safely check that there is a new event by just comparing both variables. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: declare variables where they are used in switchAlexander Gordeev
Move variable declarations where they are used in pps_cdev_ioctl. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: trivial fixesAlexander Gordeev
Here are some very trivial fixes combined: - add macro definitions to protect header file from including several times - remove declaration for an unexistent array - fix typos Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
