path: root/drivers/pps
2011-01-13pps: add parallel port PPS signal generatorAlexander Gordeev
Add PPS signal generator which utilizes STROBE pin of a parallel port to send PPS signals. It uses parport abstraction layer and hrtimers to precisely control the signal. [akpm@linux-foundation.org: fix build] Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: add parallel port PPS clientAlexander Gordeev
Add parallel port PPS client. It uses a standard method for capturing timestamps for assert edge transitions: getting a timestamp soon after an interrupt has happened. This is not a very precise source of time information due to interrupt handling delays. However, timestamps for clear edge transitions are much more precise because the interrupt handler continuously polls hardware port until the transition is done. Hardware port operations require only about 1us so the maximum error should not exceed this value. This was my primary goal when developing this client. Clear edge capture could be disabled using clear_wait parameter. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: add kernel consumer supportAlexander Gordeev
Add an optional feature of PPSAPI, kernel consumer support, which uses the added hardpps() function. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13ntp: add hardpps implementationAlexander Gordeev
This commit adds hardpps() implementation based upon the original one from the NTPv4 reference kernel code from David Mills. However, it is highly optimized towards very fast syncronization and maximum stickness to PPS signal. The typical error is less then a microsecond. To make it sync faster I had to throw away exponential phase filter so that the full phase offset is corrected immediately. Then I also had to throw away median phase filter because it gives a bigger error itself if used without exponential filter. Maybe we will find an appropriate filtering scheme in the future but it's not necessary if the signal quality is ok. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: timestamp is always passed to dcd_change()Alexander Gordeev
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case passed ts parameter is NULL because it never happens in the current code. Fix comments as well. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: simplify conditions a bitAlexander Gordeev
Bitwise conjunction is distributive so we can simplify some conditions. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: use BUG_ON for kernel API safety checksAlexander Gordeev
This way less overhead is involved when running production kernel. If you want to debug a pps client module please define DEBUG to enable the checks. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: make idr lock a mutex and protect idr_pre_getAlexander Gordeev
Now pps_idr_lock is never used in interrupt context so we can replace spin_lock_irq/spin_unlock_irq with plain spin_lock/spin_unlock. But there is also a potential race condition when someone can steal an id which was allocated by idr_pre_get before it is used. So convert spin lock to mutex and protect the whole id generation process. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: move idr stuff to pps.cAlexander Gordeev
Since now idr is only used to manage char device id's and not used in kernel API anymore it should be moved to pps.c. This also makes it possible to release id only at actual device freeing so nobody can register a pps device with the same id while our device is not freed yet. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: convert printk/pr_* to dev_*Alexander Gordeev
Since we now have direct pointers to struct pps_device everywhere it's easy to use dev_* functions to print messages instead of plain printks. Where dev_* cannot be used printks are converted to pr_*. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: access pps device by direct pointerAlexander Gordeev
Using device index as a pointer needs some unnecessary work to be done every time the pointer is needed (in irq handler for example). Using a direct pointer is much more easy (and safe as well). Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: unify timestamp gatheringAlexander Gordeev
Add a helper function to gather timestamps. This way clients don't have to duplicate it. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: fix race in PPS_FETCH handlerAlexander Gordeev
There was a race in PPS_FETCH ioctl handler when several processes want to obtain PPS data simultaneously using sleeping PPS_FETCH. They all sleep most of the time in the system call. With the old approach when the first process waiting on the pps queue is waken up it makes new system call right away and zeroes pps->go. So other processes continue to sleep. This is a clear race condition because of the global 'go' variable. With the new approach pps->last_ev holds some value increasing at each PPS event. PPS_FETCH ioctl handler saves current value to the local variable at the very beginning so it can safely check that there is a new event by just comparing both variables. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: declare variables where they are used in switchAlexander Gordeev
Move variable declarations where they are used in pps_cdev_ioctl. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: trivial fixesAlexander Gordeev
Here are some very trivial fixes combined: - add macro definitions to protect header file from including several times - remove declaration for an unexistent array - fix typos Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12pps: serial clients supportRodolfo Giometti
Adds support, by using the PPS line discipline, for the PPS sources connected with the CD (Carrier Detect) pin of a serial port. [akpm@linux-foundation.org: fix cast size warnings] Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12pps: LinuxPPS clients supportRodolfo Giometti
Each PPS source can be registered/deregistered into the system by using special modules called "clients". They simply define the PPS sources' attributes and implement the time signal registration mechanism. This patch adds a special directory for such clients and adds a dummy client that can be useful to test system integrity on real systems. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12pps: events reporting fix upRodolfo Giometti
PPS events must be recorded according to PPS's mode settings. If a process asks for (i.e.) capture-assert events only, when the PPS client calls the pps_event() function to save the current PPS event, we should verify the event type and then discard unwanted ones. Also, without this patch userland processes waiting for a specific PPS event (assert or clear but not both) may be awakened at wrong time. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Tested-by: William S. Brasher <billb958@door.net> Tested-by: Reg Clemens <clemens@dwf.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12pps: locking scheme fix up for PPS_GETPARAMSRodolfo Giometti
Userland programs may read/write PPS parameters at same time and these operations may corrupt PPS data. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Tested-by: Reg Clemens <clemens@dwf.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26pps: fix incorrect verdict checkJoonwoo Park
Fix incorrect verdict check and returns error if device_create failed, otherwise driver triggers kernel oops. Signed-off-by: Joonwoo Park<joonwpark81@gmail.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18LinuxPPS: core supportRodolfo Giometti
This patch adds the kernel side of the PPS support currently named "LinuxPPS". PPS means "pulse per second" and a PPS source is just a device which provides a high precision signal each second so that an application can use it to adjust system clock time. Common use is the combination of the NTPD as userland program with a GPS receiver as PPS source to obtain a wallclock-time with sub-millisecond synchronisation to UTC. To obtain this goal the userland programs shoud use the PPS API specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating Systems, Version 1.0) which in part is implemented by this patch. It provides a set of chars devices, one per PPS source, which can be used to get the time signal. The RFC's functions can be implemented by accessing to these char devices. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
