commit 5515e9a6273b8c02034466bcbd717ac9f53dab99 upstream.
The PPS assert/clear offset corrections are set by the PPS_SETPARAMS
ioctl in the pps_ktime structs, which also contain flags. The flags are
not initialized by applications (using the timepps.h header) and they
are not used by the kernel for anything except returning them back in
the PPS_GETPARAMS ioctl.
Set the flags to zero to make it clear they are unused and avoid leaking
uninitialized data of the PPS_SETPARAMS caller to other applications
that have a read access to the PPS device.
Link: http://lkml.kernel.org/r/20190702092251.24303-1-mlichvar@redhat.com
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
Acked-by: Rodolfo Giometti <giometti@enneenne.com>
Cc: Greg KH <greg@kroah.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
CONFIG_NO_HZ currently only sets the default value of dynticks config so
if PPS kernel consumer needs periodic timer ticks it should depend on
!CONFIG_NO_HZ_COMMON instead of !CONFIG_NO_HZ.
Otherwise it is possible to enable it even on tickless system which has
CONFIG_NO_HZ not set and CONFIG_NO_HZ_IDLE (or CONFIG_NO_HZ_FULL) set.
Link: http://lkml.kernel.org/r/57E2B769.50202@maciej.szmigiero.name
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
With this command sequence:
modprobe plip
modprobe pps_parport
rmmod pps_parport
the partport_pps modules causes this crash:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: parport_detach+0x1d/0x60 [pps_parport]
Oops: 0000 [#1] SMP
Call Trace:
parport_unregister_driver+0x65/0xc0 [parport]
SyS_delete_module+0x187/0x210
The sequence that builds up to this is:
1) plip is loaded and takes the parport device for exclusive use:
plip0: Parallel port at 0x378, using IRQ 7.
2) pps_parport then fails to grab the device:
pps_parport: parallel port PPS client
parport0: cannot grant exclusive access for device pps_parport
pps_parport: couldn't register with parport0
3) rmmod of pps_parport is then killed because it tries to access
pardev->name, but pardev (taken from port->cad) is NULL.
So add a check for NULL in the test there too.
Link: http://lkml.kernel.org/r/20160714115245.12651-1-jslaby@suse.cz
Cc: <stable@vger.kernel.org>
The pps_event_time uses two 'timespec' structures internally, which
suffer from the y2038 problem. The uses of this structure are
fairly self-contained in the pps code, so this replaces them all at
once.
Unfortunately, this includes the sfc ethernet driver aside from the
pps subsystem, so we change that one as well. Both touch the
same data structure, and there probably is no good way to split
the patch into smaller units.
Acked-by: Richard Cochran <richardcochran@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
There is only one user of the hardpps function in the kernel, so
it makes sense to atomically change it over to using 64-bit
timestamps for y2038 safety. In the hardpps implementation,
we also need to change the pps_normtime structure, which is
similar to struct timespec and also requires a 64-bit
seconds portion.
This introduces two temporary variables in pps_kc_event() to
do the conversion, they will be removed again in the next step,
which seemed preferable to having a larger patch changing it
all at the same time.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The data structure of_match_ptr() protects is always compiled in. Hence
of_match_ptr() is not needed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Rodolfo Giometti <giometti@enneenne.com>
After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
The driver core clears the driver data to NULL after device_release or on
probe failure. Thus, it is not needed to manually clear the device driver
data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the pps class code to use the
correct field.
Instead of allocating a struct pps_gpio_platform_data in the DT case,
store the necessary information in struct pps_gpio_device_data itself.
This avoids an additional allocation and the ifdef. It also gets rid of
some indirection.
Also use dev_err instead of pr_err in the changed code.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
This removes some boilerplate code (no functional changes).
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
drivers/pps/kc.c:37:1: sparse: symbol 'pps_kc_hardpps_lock' was not declared. Should it be static?
drivers/pps/kc.c:39:19: sparse: symbol 'pps_kc_hardpps_dev' was not declared. Should it be static?
drivers/pps/kc.c:40:5: sparse: symbol 'pps_kc_hardpps_mode' was not declared. Should it be static?
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Make CONFIG_PPS_DEBUG and CONFIG_NTP_PPS be hidden if CONFIG_PPS is not
selected, so that we are not prompted for these configuration options if
CONFIG_PPS is not set.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Include missing linux/slab.h inclusions where the source file is currently
expecting to get kmalloc() and co. through linux/proc_fs.h.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: linux-s390@vger.kernel.org
cc: sparclinux@vger.kernel.org
cc: linux-efi@vger.kernel.org
cc: linux-mtd@lists.infradead.org
cc: devel@driverdev.osuosl.org
cc: x86@kernel.org
devm_kzalloc allocates memory that is released when a driver detaches.
This patch uses devm_kzalloc for data that is allocated in the probe
function of a platform device and is only freed in the remove function.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Convert to the much saner new idr interface.
The PPS (Pulse-Per-Second) line discipline has developed a number of
unhealthy attachments to core tty data and functions, ultimately leading
to its breakage.
The previous patches fixed the crashing. This one reduces coupling further
by eliminating the timestamp parameter from the dcd_change ldisc method.
This reduces header file linkage and makes the extension more generic,
and the timestamp read is delayed only slightly, from just before the
ldisc->ops->dcd_change method call to just after.
Fix attendant build breakage in
drivers/tty/n_tty.c
drivers/tty/tty_buffer.c
drivers/staging/speakup/selection.c
drivers/staging/dgrp/dgrp_*.c
Cc: William Hubbs <w.d.hubbs@gmail.com>
Cc: Chris Brannon <chris@the-brannons.com>
Cc: Kirk Reiser <kirk@braille.uwo.ca>
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: George Spelvin <linux@horizon.com>
PPS is not really the must-have subsystem that warrants crashing
the machine if the ldisc interface is broken.
Remove the cdev from the system (with cdev_del) *before* deallocating it
(in pps_device_destruct, called via kobject_put from device_destroy).
Also prevent deallocating a device with open file handles.
A better long-term fix is probably to remove the cdev from the pps_device
entirely, and instead have all devices reference one global cdev. Then
the deallocation ordering becomes simpler.
But that's more complex and invasive change, so we leave that
for later.
Cc: stable <stable@vger.kernel.org>
Now that N_TTY uses tty->disc_data for its private data,
'subclass' ldiscs cannot use ->disc_data for their own private data.
(This is a regression is v3.8-rc1)
Use pps_lookup_dev to associate the tty with the pps source instead.
This fixes a crashing regression in 3.8-rc1.
The PPS serial line discipline wants to attach a PPS device to a tty
without changing the tty code to add a struct pps_device * pointer.
Since the number of PPS devices in a typical system is generally very low
(n=1 is by far the most common), it's practical to search the entire list
of allocated pps devices. (We capture the timestamp before the lookup,
so the timing isn't affected.)
It is a bit ugly that this function, which is part of the in-kernel
PPS API, has to be in pps.c as opposed to kapi,c, but that's not
something that affects users.
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
These are now established subsystems, and we want drivers to be able
to select PPS and PTP_1588_CLOCK without depending on EXPERIMENTAL.
Further, the use of EXPERIMENTAL is now deprecated in general.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
To avoid name conflicts:
drivers/video/riva/fbdev.c:281:9: sparse: preprocessor token MAX_LEVEL redefined
While at it, also make the other names more consistent and add
parentheses.
[akpm@linux-foundation.org: repair fallout]
[sfr@canb.auug.org.au: IB/mlx4: fix for MAX_ID_MASK to MAX_IDR_MASK name change]
Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at>
Cc: walter harms <wharms@bfs.de>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Roland Dreier <roland@purestorage.com>
We should return PTR_ERR if the call to the device_create function fails.
Without this patch we instead return the value from a successful call to
cdev_add if the call to device_create fails.
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Acked-by: Devendra Naga <devendra.aaru@gmail.com>
Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su>
class_create() never returns NULLs only ERR_PTRs.
Add "depends on GENERIC_HARDIRQS" to avoid compile breakage on s390:
drivers/built-in.o: In function `pps_gpio_remove':
linux-next/drivers/pps/clients/pps-gpio.c:189: undefined reference to `free_irq'
Cc: James Nuss <jamesnuss@nanometrics.ca>
This client driver allows you to use a GPIO pin as a source for PPS
signals. Platform data [1] are used to specify the GPIO pin number,
label, assert event edge type, and whether clear events are captured.
This driver is based on the work by Ricardo Martins who submitted an
initial implementation [2] of a PPS IRQ client driver to the linuxpps
mailing-list on Dec 3 2010.
[1] include/linux/pps-gpio.h
[2] http://ml.enneenne.com/pipermail/linuxpps/2010-December/004155.html
[akpm@linux-foundation.org: remove unneeded cast of void*]
Signed-off-by: James Nuss <jamesnuss@nanometrics.ca>
Cc: Ricardo Martins <rasm@fe.up.pt>
Acked-by: Rodolfo Giometti <giometti@linux.it>
Signed-off-by: Ricardo Martins <rasm@fe.up.pt>
Cc: Igor Plyatov <plyatov@gmail.com>
A default echo function has been provided so it is no longer an error when
you specify PPS_ECHOASSERT or PPS_ECHOCLEAR without an explicit echo
function. This allows some code re-use and also makes it easier to write
client drivers since the default echo function does not normally need to
change.
Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca>
Remove code enabled only when CONFIG_PREEMPT_RT is turned on because it is
not used in the vanilla kernel.
Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Rodolfo Giometti <giometti@linux.it>
Replace EXTRA_CFLAGS with ccflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
This driver causes hard lockups, when the active clock soure is jiffies.
The reason is that it loops with interrupts disabled waiting for a
timestamp to be reached by polling getnstimeofday(). Though with a
jiffies clocksource, when that code runs on the same CPU which is
responsible for updating jiffies, then we loop in circles for ever
simply because the timer interrupt cannot update jiffies. So both UP
and SMP can be affected.
There is no easy fix for that problem so make it depend on BROKEN for
now.
Initialize ts_real.flags to fix compiler warning about possible
uninitialized use of this field.
Both pps_parport and pps_gen_parport are written in a way that they
can't share a port with any other driver. This can result in locking up
the process that loads modules or even the whole kernel if the modules
are compiled in. Use PARPORT_FLAG_EXCL to indicate this.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Reported-by: Ingo Molnar <mingo@elte.hu>
Add PPS signal generator which utilizes STROBE pin of a parallel port to
send PPS signals. It uses parport abstraction layer and hrtimers to
precisely control the signal.
[akpm@linux-foundation.org: fix build]
Add parallel port PPS client. It uses a standard method for capturing
timestamps for assert edge transitions: getting a timestamp soon after an
interrupt has happened.
This is not a very precise source of time information due to interrupt
handling delays. However, timestamps for clear edge transitions are much
more precise because the interrupt handler continuously polls hardware
port until the transition is done.
Hardware port operations require only about 1us so the maximum error
should not exceed this value. This was my primary goal when developing
this client.
Clear edge capture could be disabled using clear_wait parameter.
Add an optional feature of PPSAPI, kernel consumer support, which uses the
added hardpps() function.
This commit adds hardpps() implementation based upon the original one from
the NTPv4 reference kernel code from David Mills. However, it is highly
optimized towards very fast syncronization and maximum stickness to PPS
signal. The typical error is less then a microsecond.
To make it sync faster I had to throw away exponential phase filter so
that the full phase offset is corrected immediately. Then I also had to
throw away median phase filter because it gives a bigger error itself if
used without exponential filter.
Maybe we will find an appropriate filtering scheme in the future but it's
not necessary if the signal quality is ok.
Acked-by: John Stultz <johnstul@us.ibm.com>
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case
passed ts parameter is NULL because it never happens in the current code.
Fix comments as well.
Bitwise conjunction is distributive so we can simplify some conditions.
This way less overhead is involved when running production kernel. If you
want to debug a pps client module please define DEBUG to enable the
checks.
Now pps_idr_lock is never used in interrupt context so we can replace
spin_lock_irq/spin_unlock_irq with plain spin_lock/spin_unlock. But
there is also a potential race condition when someone can steal an id
which was allocated by idr_pre_get before it is used. So convert spin
lock to mutex and protect the whole id generation process.
Since now idr is only used to manage char device id's and not used in
kernel API anymore it should be moved to pps.c. This also makes it
possible to release id only at actual device freeing so nobody can
register a pps device with the same id while our device is not freed yet.
