path: root/drivers/ps3
2010-04-23Merge branch 'master' into for-nextJiri Kosina
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16Fix typos in commentsThomas Weber
[Ss]ytem => [Ss]ystem udpate => update paramters => parameters orginal => original Signed-off-by: Thomas Weber <swirl@gmx.li> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-09powerpc: Remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: linuxppc-dev@ozlabs.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-11powerpc/ps3: Workaround for flash memory I/O errorGeoff Levand
A workaround for flash memory I/O errors when the PS3 internal hard disk has not been formatted for OtherOS use. This error condition mainly effects 'Live CD' users who have not formatted the PS3's internal hard disk for OtherOS. Fixes errors similar to these when using the ps3-flash-util or ps3-boot-game-os programs: ps3flash read failed 0x2050000 os_area_header_read: read error: os_area_header: Input/output error main:627: os_area_read_hp error. ERROR: can't change boot flag Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15drivers/ps3: Add missing annotationsGeert Uytterhoeven
probe functions should be __devinit initialization functions should be __init Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3fb/vram: Extract common GPU stuff into <asm/ps3gpu.h>Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3av: Set 16:9 aspect ratio for 720p video modessebastian.blanes@gmail.com
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: linux-fbdev-devel@lists.sourceforge.net Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc/ps3: Make ps3av_set_video_mode mode ID signedroel kluin
Change the ps3av_auto_videomode() mode id argument type from unsigned to signed so a negative id can be detected and reported as an -EINVAL failure. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-16powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/ps3Stephen Rothwell
Also some min -> mint_t conversion. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-16powerpc/ps3: The lv1_ routines have u64 parametersStephen Rothwell
We just fix up the reference parameters as the others are dealt with by arithmetic promotion rules and don't cause warnings. This removes warnings like this: arch/powerpc/platforms/ps3/interrupt.c:327: warning: passing argument 1 of 'lv1_construct_event_receive_port' from incompatible pointer type Also, these: drivers/ps3/ps3-vuart.c:462: warning: passing argument 4 of 'ps3_vuart_raw_read' from incompatible pointer type drivers/ps3/ps3-vuart.c:592: warning: passing argument 4 of 'ps3_vuart_raw_read' from incompatible pointer type Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-11-19powerpc/ps3: Replace the flip_ctl logic in ps3av and ps3fb by a mutexGeert Uytterhoeven
Introduce ps3_gpu_mutex to synchronizes GPU-related operations, like: - invoking the L1GPU_CONTEXT_ATTRIBUTE_FB_BLIT command using the lv1_gpu_context_attribute() hypervisor call, - handling the PS3AV_CID_AVB_PARAM packet in the PS3 A/V Settings driver. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/ps3: Fix compile error in ps3-lpm.cAlexey Dobriyan
Compiling with CONFIG_SMP = n and CONFIG_PS3_LPM != n gives this error: drivers/ps3/ps3-lpm.c:838: error: implicit declaration of function 'get_hard_smp_processor_id' This fixes it. We have to include <asm/smp.h> rather than <linux/smp.h> because the UP definition of get_hard_smp_processor_id() is in <asm/smp.h>, and <linux/smp.h> only includes <asm/smp.h> if CONFIG_SMP = y. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-20ps3: Add passthru support for non-audio streamsTakashi Iwai
Add support for the channel status bit setting so that non-PCM data stream can be sent (i.e. pass-through) via SPDIF/HDMI. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ps3: Add ps3av_audio_mute_analog()Masakazu Mokuno
Add support for muting the analog output so that it does not play noises while non-PCM data is played. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-02[POWERPC] PS3: Remove unsupported wakeup sourcesGeoff Levand
Other OS wakeup is not supported from the IR controller, the bluetooth controller nor the RTC. Remove references to these in the PS3 sys-manager source. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-02[POWERPC] PS3: Add time include to lpmFUJITA Tomonori
Add an include <asm/time.h> statement for get_tb(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-01[POWERPC] PS3: Sys-manager Wake-on-LAN supportGeoff Levand
Add Wake-on-LAN support to the PS3 system-manager. Other OS WOL support was introduced in PS3 system firmware 2.20. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-01[POWERPC] PS3: Save power in busy loops on haltGeert Uytterhoeven
PS3 save power on halt: - Replace infinite busy loops by smarter loops calling lv1_pause() to save power. - Add ps3_halt() and ps3_sys_manager_halt(). - Add __noreturn annotations. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-14[POWERPC] PS3: Update sys-manager button eventsGeoff Levand
PS3 firmware 1.94 added the source of power and reset events to the payload of the system manager POWER_PRESSED and RESET_PRESSED events. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-14[POWERPC] PS3: Sys-manager code cleanupGeoff Levand
General code cleanups for PS3 system-manager: o Move all MODULE_ macros to bottom. o Correct PS3_SM_WAKE_P_O_R value. o Enhance comment on wakeup source values. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-14[POWERPC] PS3: Use system reboot on restartGeoff Levand
The PS3 Other OS boot flag is not checked when an LPAR reboot is done, so the ps3-boot-game-os utility fails to reboot the system into the Game OS. This fix changes the PS3 restart handler from requesting an PS3_SM_NEXT_OP_LPAR_REBOOT to requesting an PS3_SM_NEXT_OP_SYS_REBOOT. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-14[POWERPC] PS3: Fix reading pm interval in logical performance monitorTakashi Yamamoto
ps3_read_pm (pm_interval) should return an actual HW register value because the pm_interval register is a counter register. This removes the shadow pm_interval register. Signed-off-by: Takashi Yamamoto <TakashiA.Yamamoto@jp.sony.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-14[POWERPC] PS3: Fix setting bookmark in logical performance monitorTakashi Yamamoto
Fix the ps3_set_bookmark() routine of the PS3 logical performance monitor driver. To properly set a performance monitor bookmark the Cell processor requires no instruction branches near the setting of the bookmark SPR. Testing showed that the use of the db10cyc instruction did not work correctly. This change replaces the db10cyc instruction with 10 nop instructions. Signed-off-by: Takashi Yamamoto <TakashiA.Yamamoto@jp.sony.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-06ps3: use symbolic names for video modesGeert Uytterhoeven
Use symbolic names for video modes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ps3av: ps3av_get_scanmode() and ps3av_get_refresh_rate() are unusedGeert Uytterhoeven
ps3av_get_scanmode() and ps3av_get_refresh_rate() are unused, so remove them Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25[POWERPC] PS3: Vuart: change semaphore to mutexGeoff Levand
A general housekeeping change of the PS3 vuart variable vuart_bus_priv.probe_mutex from semaphore to mutex. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-25[POWERPC] PS3: Add logical performance monitor driver supportTakashi Yamamoto
Add PS3 logical performance monitor (lpm) device driver. The PS3's LV1 hypervisor provides a Logical Performance Monitor that abstracts the Cell processor's performance monitor features for use by guest operating systems. Signed-off-by: Takashi Yamamoto <TakashiA.Yamamoto@jp.sony.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-25[POWERPC] PS3: Checkpatch cleanups for drivers/ps3/ps3-vuart.cGeert Uytterhoeven
Cleanup coding errors in drivers/ps3/ps3-vuart.c as reported by checkpatch. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-25[POWERPC] PS3: Checkpatch cleanups for drivers/ps3/ps3-sys-manager.cGeert Uytterhoeven
Cleanup coding errors in drivers/ps3/ps3-sys-manager.c as reported by checkpatch. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-23ps3: vuart: fix error path lockingDaniel Walker
This stray down would cause a permanent sleep which doesn't seem correct. The other uses of this semaphore appear fairly mutex like it's even initialized with init_MUTEX() .. So here a patch for removing this one down(). Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29ps3: prefix all ps3-specific kernel modules with `ps3-'Geert Uytterhoeven
- vuart.ko -> ps3-vuart.ko - sys-manager.ko -> ps3-sys-manager.ko Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ps3av: remove unused fields in ps3av_monitor_quirksGeert Uytterhoeven
Remove the `clear_50' and `clear_vesa' fields of struct ps3av_monitor_quirk, as they're currently unused. We can always re-add them when we really need them. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: default to 480p on DVI-D/HDMI if video=safeGeert Uytterhoeven
Default to the 480p video mode on DVI-D and HDMI displays if `video=safe' is passed on the kernel command line. This is intended to be used by `kboot'-style boot loaders (i.e. first-stage kernels) for the PS3, to provide a failsafe video mode. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: dont distinguish between `boot' and `non-boot' autodetectionGeert Uytterhoeven
don't distinguish between `boot' and `non-boot' autodetection now the autodetection code has been improved Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: remove unused ps3av_set_mode()Geert Uytterhoeven
remove unused ps3av_set_mode() Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: add quirk database for broken monitorsGeert Uytterhoeven
add a quirk database for broken monitors where the `best' advertised video mode doesn't work Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: add autodetection for VESA modesGeert Uytterhoeven
add autodetection for VESA modes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: treat DVI-D like HDMI in autodetectGeert Uytterhoeven
treat DVI-D monitors like HDMI monitors when autodetecting the best video mode Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: use PS3 video mode ids in autodetect codeGeert Uytterhoeven
It doesn't make much sense to use the PS3AV_CMD_VIDEO_VID_* values in the autodetection code, just to convert them to PS3 video mode ids afterwards. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: eliminate PS3AV_DEBUGGeert Uytterhoeven
ps3av: eliminate PS3AV_DEBUG - Move ps3av_cmd_av_monitor_info_dump from ps3av_cmd.c to ps3av.c, as it's used there only - Integrate ps3av_cmd_av_hw_conf_dump() into its sole user - Use pr_debug() for printing debug info Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: eliminate unneeded temporary variablesGeert Uytterhoeven
ps3av: eliminate unneeded temporary variables Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3: Fix black and white stripesMasashi Kimoto
Fix the black and white stripes issue with WUXGA monitor via HDMI. It seems that when we use a VESA resolution from boot up, the AV settings driver could not be initialized correctly. In that case we need a dummy packet before VESA setting. [Geert] Refactored to reduce code duplication. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> CC: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28[POWERPC] PS3: Storage Driver CoreGeert Uytterhoeven
Add storage driver core support for the PS3. PS3 storage devices are a special kind of PS3 system bus device. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Rework AV settings driverGeoff Levand
Make the PS3 ps3av driver a loadable module. - Replace static data with kmalloc()'ed. o Allocate struct ps3av dynamically, as it contains data used as vuart receive/transmit buffers o Move static recv_buf from ps3av_do_pkt() to struct ps3av - Move ps3av_vuart_{read,write}() from drivers/ps3/ps3av_cmd.c to drivers/ps3/ps3av.c and make them static as they're used in that file only. - Make device a PS3 system-bus device. - Update copyright formatting. - Make two new routines ps3av_register_flip_ctl() and ps3av_flip_ctl() to support late binding of the frame buffer flip control routine. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: System manager re-workGeoff Levand
PS3 sys-manager updates to reflect the new PS3 unifed device support. Fixups to the PS3 sys-manager driver to properly support sys_reboot(). - Add varable request_tag to struct ps3_sys_manager_header. - Move ctrl_alt_del from PS3_SM_EVENT_POWER_RELEASED to PS3_SM_EVENT_POWER_PRESSED. - Make the PS3 sys-manager driver a loadable module. - Add new file sys-manager-core.c. - Add new struct ps3_sys_manager_ops for dynamic binding. - Put data sent to device on stack. - Add support for PS3_SM_SERVICE_ID_REQUEST_ERROR. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Vuart reworkGeoff Levand
PS3 vuart updates to reflect the new PS3 unified device support. - Move vuart devices to the PS3 system bus. - Replace use of ps3_vuart_port_device with ps3_system_bus_device. - Make the PS3 vuart bus driver a loadable module. - Add remove() and shutdown() routines. - Move ps3_vuart_work into ps3_vuart_port_priv.tx_list. - Remove redundant spinlock ps3_vuart_work.lock. - No longer free ps3_vuart_port_device.priv on shutdown. - Cleanup Kconfig defs. - Export symbols needed for modular port drivers. - Arrange to use port numbers found in repository. - Fix bugs in ps3_vuart_read_async() and polled reading - Cleanup handling of shared interrupt with ps3_vuart_bus_interrupt_get() and ps3_vuart_bus_interrupt_put() - Add more comments to vuart.c. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
