path: root/drivers/ps3
2007-06-28[POWERPC] PS3: Storage Driver CoreGeert Uytterhoeven
Add storage driver core support for the PS3. PS3 storage devices are a special kind of PS3 system bus device. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Rework AV settings driverGeoff Levand
Make the PS3 ps3av driver a loadable module. - Replace static data with kmalloc()'ed. o Allocate struct ps3av dynamically, as it contains data used as vuart receive/transmit buffers o Move static recv_buf from ps3av_do_pkt() to struct ps3av - Move ps3av_vuart_{read,write}() from drivers/ps3/ps3av_cmd.c to drivers/ps3/ps3av.c and make them static as they're used in that file only. - Make device a PS3 system-bus device. - Update copyright formatting. - Make two new routines ps3av_register_flip_ctl() and ps3av_flip_ctl() to support late binding of the frame buffer flip control routine. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: System manager re-workGeoff Levand
PS3 sys-manager updates to reflect the new PS3 unifed device support. Fixups to the PS3 sys-manager driver to properly support sys_reboot(). - Add varable request_tag to struct ps3_sys_manager_header. - Move ctrl_alt_del from PS3_SM_EVENT_POWER_RELEASED to PS3_SM_EVENT_POWER_PRESSED. - Make the PS3 sys-manager driver a loadable module. - Add new file sys-manager-core.c. - Add new struct ps3_sys_manager_ops for dynamic binding. - Put data sent to device on stack. - Add support for PS3_SM_SERVICE_ID_REQUEST_ERROR. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Vuart reworkGeoff Levand
PS3 vuart updates to reflect the new PS3 unified device support. - Move vuart devices to the PS3 system bus. - Replace use of ps3_vuart_port_device with ps3_system_bus_device. - Make the PS3 vuart bus driver a loadable module. - Add remove() and shutdown() routines. - Move ps3_vuart_work into ps3_vuart_port_priv.tx_list. - Remove redundant spinlock ps3_vuart_work.lock. - No longer free ps3_vuart_port_device.priv on shutdown. - Cleanup Kconfig defs. - Export symbols needed for modular port drivers. - Arrange to use port numbers found in repository. - Fix bugs in ps3_vuart_read_async() and polled reading - Cleanup handling of shared interrupt with ps3_vuart_bus_interrupt_get() and ps3_vuart_bus_interrupt_put() - Add more comments to vuart.c. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Add support for HDMI RGB Full Range modeMasashi Kimoto
Add support for HDMI RGB Full Range mode, which is available on system software 1.80 or newer. CC: Masashi Kimoto <Masashi_Kimoto@hq.scei.sony.co.jp> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-28[POWERPC] PS3: Use __maybe_unusedGeoff Levand
Change the PS3 debug routines from using the GCC specific '__attribute__ ((unused))' to the preprocessor macro __maybe_unused. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Merge branch 'linux-2.6'Paul Mackerras
2007-05-04ps3av: Use __func__ instead of __FUNCTION__Geert Uytterhoeven
ps3av: Replace GNU extension `__FUNCTION__' by C99 `__func__' Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3: Make `ps3videomode -v 0 (auto mode) work againMasashi Kimoto
ps3: Make `ps3videomode -v 0' (auto mode) work again Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3av: misc updatesGeert Uytterhoeven
ps3av: - Move the definition of struct ps3av to ps3av.c, as it's locally used only. - Kill ps3av.sem, use the existing ps3av.mutex instead. - Make the 512-byte buffer in ps3av_do_pkt() static to reduce stack usage. Its use is protected by a semaphore anyway. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3av: thread updatesGeert Uytterhoeven
ps3av: Replace the kernel_thread and the ping pong semaphores by a singlethread workqueue and a completion. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[POWERPC] PS3: Interrupt routine fixups.Geoff Levand
Fixups for the ps3 interrupt routines to support all HV device in a generic way. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] Remove dev_dbg redefinition in drivers/ps3/vuart.cPaul Mackerras
Commit 404d5b185b4eb56d6fa2f7bd27833f8df1c38ce4 changed the definition of dev_dbg in the !DEBUG case from being a #define to being a static inline. There was code in drivers/ps3/vuart.c to do exactly that, which fails to compile now. This fixes it by removing the redefinition, as the redefinition is now superfluous. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-14[PATCH] C99 initializers, proper use of const in drivers/ps3Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] misc NULL noiseAl Viro
2007-03-10[POWERPC] ps3: always make sure were running on a PS3Geert Uytterhoeven
Add missing checks to PS3 specific drivers ps3av and sys-manager to verify that we are actually running on a PS3 (pointed out by Arnd). Correct existing checks in other subsystems/drivers to return -ENODEV instead of zero. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-16[POWERPC] PS3: System manager supportGeoff Levand
Add PS3 system manager support and the ppc_md routines restart() and power_off(). The system manager provides an event notification mechanism for reporting events like thermal alert and button presses. It also provides support to control system shutdown and startup. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] PS3: Vuart add async readGeoff Levand
Add asynchronous read support to the PS3 vuart driver. This is needed to support the PS3 system manager driver. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] PS3: Vuart cleanupsGeoff Levand
Cleanups for the PS3 vuart driver. - Hide driver private data from external interface with new structure ps3_vuart_port_priv. - Fix masking bug in ps3_vuart_get_interrupt_status(). - Add new helper routine ps3_vuart_clear_rx_bytes() to flush rx buffer. - Add new variable probe_mutex to serialize probe and destroy routines. - Rename some symbols. - Add platform check in ps3_vuart_bus_init(). Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-12[PATCH] ps3: disable display flipping during mode changesGeert Uytterhoeven
If ps3fb is available, we have to disable display flipping while changing the audio or video mode. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ps3: AV Settings DriverGeert Uytterhoeven
Add the PS3 AV Settings Driver. The AV Settings driver is used to control Audio and Video settings. It communicates with the policy manager through the virtual uart. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ps3: add shutdown to virtual uart port driver frameworkGeert Uytterhoeven
PS3: Add a shutdown method to the PS3's virtual uart port driver framework Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[POWERPC] PS3: Move vuart declarations to ps3.hGeoff Levand
Move the structures and routines needed for PS3 vuart port device registration to asm-powerpc/ps3.h. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] PS3: Move system bus to platform directoryGeoff Levand
Move the PS3 system bus routines from drivers/ps3 to arch/powerpc/platforms/ps3. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] ps3: bind interrupt to cpuGeoff Levand
Change the PS3 irq allocation routines to take an argument indicating which cpu (processor thread) the interrupt should be serviced on. The current system configuration favors device interrupts that are serviced on cpu0, so that is used as the default. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] ps3: system bus minor mmio fixBenjamin Herrenschmidt
Fix two minor bugs in the PS3 system bus mmio region code. First, on error or when freeing a region, retain the bus_addr and len fields to allow subsequent calls to create the region. Second, correct the region address argument to the lv1_unmap_device_mmio_region() call. Fixes modprobe/rmmod of some drivers. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-11[POWERPC] ps3: Add vuart supportGeoff Levand
Adds support for the PS3 virtual UART (vuart). The vuart provides a bi-directional byte stream data link between logical partitions. This is needed for the ps3 graphics driver and the ps3 power control support to be able to communicate with the lv1 policy module. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] ps3: multiplatform build fixesArnd Bergmann
A few code paths need to check whether or not they are running on the PS3's LV1 hypervisor before making hcalls. This introduces a new firmware feature bit for this, FW_FEATURE_PS3_LV1. Now when both PS3 and IBM_CELL_BLADE are enabled, but not PSERIES, FW_FEATURE_PS3_LV1 and FW_FEATURE_LPAR get enabled at compile time, which is a bug. The same problem can also happen for (PPC_ISERIES && !PPC_PSERIES && PPC_SOMETHING_ELSE). In order to solve this, I introduce a new CONFIG_PPC_NATIVE option that is set when at least one platform is selected that can run without a hypervisor and then turns the firmware feature check into a run-time option. The new cell oprofile support that was recently merged does not work on hypervisor based platforms like the PS3, therefore make it depend on PPC_CELL_NATIVE instead of PPC_CELL. This may change if we get oprofile support for PS3. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-12-04[POWERPC] ps3: add ps3 platform system bus supportGeoff Levand
Adds a PS3 system bus driver. This system bus is a virtual bus used to present the PS3 system devices in the LDM. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
