path: root/drivers/ptp
2015-03-31ptp: remove 32 bit get/set methods.Richard Cochran
All of the PHC drivers have been converted to the new methods. This patch converts the three remaining callers within the core code and removes the older methods for good. As a result, the core PHC code is ready for the year 2038. However, some of the PHC drivers are not quite ready yet. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: pch: convert to the 64 bit get/set time methods.Richard Cochran
The device has a 64 bit clock register, where each clock tick is 32 nanoseconds, and so with this patch the driver is ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: ixp46x: convert to the 64 bit get/set time methods.Richard Cochran
The device has a 64 bit clock register, where each clock tick is 16 nanoseconds, and so with this patch the driver is ready for the year 2038. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: use the 64 bit get/set time methods for the posix clock.Richard Cochran
This patch changes the posix clock code to prefer the new methods whenever they are implemented by the PHC drivers. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: use the 64 bit gettime method for the SYS_OFFSET ioctl.Richard Cochran
This patch changes the code to use the new method whenever implemented by the PHC driver. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-01ptp: Allow reassigning calibration pin functionStefan Sørensen
The ptp pin function programming does not allow calibration pin to change function. This is problematic on hardware that uses the default calibration pin for other purposes. Removing this limitation does not impact calibration if userspace does not reprogram the calibration pin. Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-17ptp: ptp_pch depends on x86_32Jean Delvare
The ptp_pch driver is for a companion chip to the Intel Atom E600 series processors. These are 32-bit x86 processors so the driver is only needed on X86_32. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Richard Cochran <richardcochran@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/altera/altera_sgdma.c net/netlink/af_netlink.c net/sched/cls_api.c net/sched/sch_api.c The netlink conflict dealt with moving to netlink_capable() and netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations in non-init namespaces. These were simple transformations from netlink_capable to netlink_ns_capable. The Altera driver conflict was simply code removal overlapping some void pointer cast cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-12ptp: fix kconfig dependency warningsRandy Dunlap
Fix kconfig warnings: PTP_1588_CLOCK selects NET_PTP_CLASSIFY, which depends on NET, so PTP_1588_CLOCK should also depend on NET. PTP_1588_CLOCK_PCH selects PTP_1588_CLOCK so the former should depend on NET. warning: (IXP4XX_ETH && PTP_1588_CLOCK) selects NET_PTP_CLASSIFY which has unmet direct dependencies (NET) warning: (SFC && TILE_NET && BFIN_MAC_USE_HWSTAMP && TIGON3 && FEC && E1000E && IGB && IXGBE && I40E && MLX4_EN && SXGBE_ETH && STMMAC_ETH && TI_CPTS && PTP_1588_CLOCK_GIANFAR && PTP_1588_CLOCK_IXP46X && DP83640_PHY && PTP_1588_CLOCK_PCH) selects PTP_1588_CLOCK which has unmet direct dependencies (NET) [This warning is caused by the new 'depends on NET' in PTP_1588_CLOCK.] Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-28ptp: validate the requested frequency adjustment.Richard Cochran
PTP Hardware Clock drivers specify a maximum frequency adjustment that their clocks can accommodate. Normally, user space programs will want to respect the advertised limits. However, no kernel or driver code checks that the dialed frequency offset is within the bounds, and out of range values can lead to surprising results. This patch fixes the issue by rejecting bad values. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01net: ptp: move PTP classifier in its own fileDaniel Borkmann
This commit fixes a build error reported by Fengguang, that is triggered when CONFIG_NETWORK_PHY_TIMESTAMPING is not set: ERROR: "ptp_classify_raw" [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe.ko] undefined! The fix is to introduce its own file for the PTP BPF classifier, so that PTP_1588_CLOCK and/or NETWORK_PHY_TIMESTAMPING can select it independently from each other. IXP4xx driver on ARM needs to select it as well since it does not seem to select PTP_1588_CLOCK or similar that would pull it in automatically. This also allows for hiding all of the internals of the BPF PTP program inside that file, and only exporting relevant API bits to drivers. This patch also adds a kdoc documentation of ptp_classify_raw() API to make it clear that it can return PTP_CLASS_* defines. Also, the BPF program has been translated into bpf_asm code, so that it can be more easily read and altered (extensively documented in [1]). In the kernel tree under tools/net/ we have bpf_asm and bpf_dbg tools, so the commented program can simply be translated via `./bpf_asm -c prog` where prog is a file that contains the commented code. This makes it easily readable/verifiable and when there's a need to change something, jump offsets etc do not need to be replaced manually which can be very error prone. Instead, a newly translated version via bpf_asm can simply replace the old code. I have checked opcode diffs before/after and it's the very same filter. [1] Documentation/networking/filter.txt Fixes: 164d8c666521 ("net: ptp: do not reimplement PTP/BPF classifier") Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Jiri Benc <jbenc@redhat.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-21ptp: drivers: set the number of programmable pins.Richard Cochran
This patch updates the many PTP Hardware Clock drivers with the newly introduced field that advertises the number of programmable pins. Some of these devices do have programmable pins, but the implementation will have to wait for follow on patches. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-21ptp: expose the programmable pins via sysfsRichard Cochran
This patch adds the sysfs hooks needed in order to get and set the programmable pin settings. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-21ptp: introduce programmable pins.Richard Cochran
This patch adds a pair of new ioctls to the PTP Hardware Clock device interface. Using the ioctls, user space programs can query each pin to find out its current function and also reprogram a different function if desired. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-15ptp_pch: Add dependency on HAS_IOMEMRichard Weinberger
On archs like S390 or um this driver cannot build nor work. Make it depend on HAS_IOMEM to bypass build failures. drivers/ptp/ptp_pch.c: In function ‘pch_remove’: drivers/ptp/ptp_pch.c:571:3: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration] drivers/ptp/ptp_pch.c: In function ‘pch_probe’: drivers/ptp/ptp_pch.c:621:2: error: implicit declaration of function ‘ioremap’ [-Werror=implicit-function-declaration] Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-27ptp: switch to use gpiolibLinus Walleij
This platform supports gpiolib, so remove the custom API use and replace with calls to gpiolib. Also request the GPIO before starting to use it. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Alexandre Courbot <acourbot@nvidia.com> Cc: netdev@vger.kernel.org Acked-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-26PTP: convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the ptp class code to use the correct field. Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-24build some drivers only when compile-testingJiri Slaby
Some drivers can be built on more platforms than they run on. This is a burden for users and distributors who package a kernel. They have to manually deselect some (for them useless) drivers when updating their configs via oldconfig. And yet, sometimes it is even impossible to disable the drivers without patching the kernel. Introduce a new config option COMPILE_TEST and make all those drivers to depend on the platform they run on, or on the COMPILE_TEST option. Now, when users/distributors choose COMPILE_TEST=n they will not have the drivers in their allmodconfig setups, but developers still can compile-test them with COMPILE_TEST=y. Now the drivers where we use this new option: * PTP_1588_CLOCK_PCH: The PCH EG20T is only compatible with Intel Atom processors so it should depend on x86. * FB_GEODE: Geode is 32-bit only so only enable it for X86_32. * USB_CHIPIDEA_IMX: The OF_DEVICE dependency will be met on powerpc systems -- which do not actually support the hardware via that method. * INTEL_MID_PTI: It is specific to the Penwell type of Intel Atom device. [v2] * remove EXPERT dependency [gregkh - remove chipidea portion, as it's incorrect, and also doesn't apply to my driver-core tree] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: linux-usb@vger.kernel.org Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-geode@lists.infradead.org Cc: linux-fbdev@vger.kernel.org Cc: Richard Cochran <richardcochran@gmail.com> Cc: netdev@vger.kernel.org Cc: Ben Hutchings <ben@decadent.org.uk> Cc: "Keller, Jacob E" <jacob.e.keller@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-25ptp_pch: fix error handling in pch_probe()Wei Yongjun
Fix to release resources when ptp_clock_register() fail instead of return error code directly. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-12ptp: dynamic allocation of PHC char devicesJiri Benc
As network adapters supporting PTP are becoming more common, machines with many NICs suddenly have many PHCs, too. The current limit of eight /dev/ptp* char devices (and thus, 8 network interfaces with PHC) is insufficient. Let the ptp driver allocate the char devices dynamically. Tested with 28 PHCs, removing and re-adding some of them. Thanks to Ben Hutchings for advice leading to simpler and cleaner patch. Signed-off-by: Jiri Benc <jbenc@redhat.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-27ptp_pch: eliminate a number of sparse warningsSahara
This fixes a number of sparse warnings like: warning: incorrect type in argument 2 (different address spaces) expected void volatile [noderef] <asn:2>*addr got unsigned int *<noident> warning: Using plain integer as NULL pointer Additionally this fixes a warning from checkpatch.pl like: WARNING: sizeof pch_param.station should be sizeof(pch_param.station) Signed-off-by: Sahara <keun-o.park@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26ptp_pch: fix typo in module parameter descriptionJiri Benc
Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-11-28ptp: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28ptp: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26ptp: reduce stack usage when measuring the system time offsetRichard Cochran
This patch removes the large buffer from the stack of the system offset ioctl and replaces it with a kmalloced buffer. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-26ptp: reduce stack usage when reading external time stampsRichard Cochran
This patch removes the large buffer from the stack of the read file operation and replaces it with a kmalloced buffer. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-17pch_gbe, ptp_pch: Fix the dependency direction between these driversBen Hutchings
In commit a24006ed12616bde1bbdb26868495906a212d8dc ('ptp: Enable clock drivers along with associated net/PHY drivers') I wrongly made PTP_1588_CLOCK_PCH depend on PCH_GBE. The dependency is really the other way around. Therefore make PCH_GBE select PTP_1588_CLOCK_PCH and remove the 'default y' from the latter. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ptp: add an ioctl to compare PHC time with system timeRichard Cochran
This patch adds an ioctl for PTP Hardware Clock (PHC) devices that allows user space to measure the time offset between the PHC and the system clock. Rather than hard coding any kind of estimation algorithm into the kernel, this patch takes the more flexible approach of just delivering an array of raw clock readings. In that way, the user space clock servo may be adapted to new and different hardware clocks. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jacob Keller <jacob.e.keller@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ptp: Enable clock drivers along with associated net/PHY driversBen Hutchings
Where a PTP clock driver is associated with a net or PHY driver, it should be enabled automatically whenever that driver is enabled. Therefore: - Make PTP clock drivers select rather than depending on PTP_1588_CLOCK - Remove separate boolean options for PTP clock drivers that are built as part of net driver modules. (This also fixes cases where the PTP subsystem is wrongly forced to be built-in.) - Set 'default y' for PTP clock drivers that depend on specific net drivers but are built separately Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ptp: Make PTP_1588_CLOCK select rather than depend on PPSBen Hutchings
PTP hardware clock drivers that select PTP_1588_CLOCK must currently also select PPS. For those drivers that don't, the user must enable PPS, then enable PTP_1588_CLOCK, then the driver. Simplify things for developers and users by putting this selection in one place. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01pps, ptp: Remove dependencies on EXPERIMENTALBen Hutchings
These are now established subsystems, and we want drivers to be able to select PPS and PTP_1588_CLOCK without depending on EXPERIMENTAL. Further, the use of EXPERIMENTAL is now deprecated in general. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22ptp: link the phc device to its parent deviceRichard Cochran
PTP Hardware Clock devices appear as class devices in sysfs. This patch changes the registration API to use the parent device, clarifying the clock's relationship to the underlying device. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22ptp: provide the clock's adjusted frequencyRichard Cochran
If the timex.mode field indicates a query, then we provide the value of the current frequency adjustment. [ Get rid of extraneous empty lines -DaveM ] Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22ptp: remember the adjusted frequencyRichard Cochran
This patch adds a field to the representation of a PTP hardware clock in order to remember the frequency adjustment value dialed by the user. Adding this field will let us answer queries in the manner of adjtimex in a follow on patch. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07pps/ptp: Allow PHC devices to adjust PPS events for known delayBen Hutchings
Initial version by Stuart Hodgson <smhodgson@solarflare.com> Some PHC device drivers may deliver PPS events with a significant and variable delay, but still be able to measure precisely what that delay is. Add a pps_sub_ts() function for subtracting a delay from the timestamp(s) in a PPS event, and a PTP event type (PTP_CLOCK_PPSUSR) for which the caller provides a complete PPS event. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-05-16ptp_pch: Add missing #include <linux/slab.h>Geert Uytterhoeven
drivers/ptp/ptp_pch.c: In function 'pch_remove': drivers/ptp/ptp_pch.c:576:2: error: implicit declaration of function 'kfree' [-Werror=implicit-function-declaration] drivers/ptp/ptp_pch.c: In function 'pch_probe': drivers/ptp/ptp_pch.c:587:2: error: implicit declaration of function 'kzalloc' [-Werror=implicit-function-declaration] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-21pch_gbe: correct receive time stamp filteringTakahiro Shimizu
This patch fixes the driver so that multicast PTP event messages can be recognized by the hardware time stamping unit. The station address register must be set according to the desired transport type. [ RC - Rebased Takahiro's changes and wrote a commit message explaining the changes. ] Signed-off-by: Takahiro Shimizu <tshimizu818@gmail.com> Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-21pch_gbe: do not set the channel control registerTakahiro Shimizu
We will let the pch_gbe code do that according to the receive time stamp filter. [ RC - Rebased Takahiro's changes and wrote a commit message explaining the changes. ] Signed-off-by: Takahiro Shimizu <tshimizu818@gmail.com> Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-21pch_gbe: export a method to set the receive match addressTakahiro Shimizu
The code in phc_gbe_main will need to call this method in order to set the station address register according to the receive time stamping filter. [ RC - Rebased Takahiro's changes and wrote a commit message explaining the changes. ] Signed-off-by: Takahiro Shimizu <tshimizu818@gmail.com> Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-21pch_gbe: scale time stamps to nanosecondsTakahiro Shimizu
This patch fixes the helper functions that give the transmit and receive time stamps to return nanoseconds, instead of arbitrary clock ticks. [ RC - Rebased Takahiro's changes and wrote a commit message explaining the changes. ] Signed-off-by: Takahiro Shimizu <tshimizu818@gmail.com> Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-16Fix typo in various Kconfig fileMasanari Iida
Correct spelling typo in various Kconfig file. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-12ixp4xx_eth: Fix up the get_ts_info ethtool method.Richard Cochran
Commit e77bd1ec121ee4163a6b42a44e87b2e382c39e04 added support for a new ethtool function, but that cannot compile due to a misnamed global variable. Not that it really matters (since the IXP4xx does compile either, as of about Linux 3.1) but just in case, this patch fixes the misnamed variable in the PHC driver. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04ixp4xx_eth: Support the get_ts_info ethtool method.Richard Cochran
2012-04-04ptp: Add a method for obtaining the device index.Richard Cochran
This commit adds a method that MAC drivers may call in order to find out the device number of their associated PTP Hardware Clock. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-17phc: Update author's email address.Richard Cochran
This commit brings the author email address macros up to date for four modules in the PTP Hardware Clock subsystem. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-09ptp_pch: rename pch_pcidev to pci_driver to fix section mismatch warnings.David S. Miller
