Add ARM64 platform support for i.MX PWM driver.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add TPM PWM driver support i.MX7ULP.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
[Octavian: updated for 4.9 APIs]
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"The changes for this release include a new driver for the PWM
controller found on SoCs of the ZTX ZX family. Support for an old
SH-Mobile SoC has been dropped and the Rockchip and MediaTek drivers
gain support for more generations.
Other than that there are a bunch of coding style fixes, minor bug
fixes and cleanup as well as documentation patches"
* tag 'pwm/for-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (32 commits)
pwm: pwm-samsung: fix suspend/resume support
pwm: samsung: Remove redundant checks from pwm_samsung_config()
pwm: mediatek: Disable clock on PWM configuration failure
dt-bindings: pwm: Add MT2712/MT7622 information
pwm: mediatek: Fix clock control issue
pwm: mediatek: Fix PWM source clock selection
pwm: mediatek: Fix Kconfig description
pwm: tegra: Explicitly request exclusive reset control
pwm: hibvt: Explicitly request exclusive reset control
pwm: tiehrpwm: Set driver data before runtime PM enable
pwm: tiehrpwm: Miscellaneous coding style fixups
pwm: tiecap: Set driver data before runtime PM enable
pwm: tiecap: Miscellaneous coding style fixups
dt-bindings: pwm: tiecap: Add TI 66AK2G SoC specific compatible
pwm: tiehrpwm: fix clock imbalance in probe error path
pwm: tiehrpwm: Fix runtime PM imbalance at unbind
pwm: Kconfig: Enable pwm-tiecap to be built for Keystone
pwm: Add ZTE ZX PWM device driver
dt-bindings: pwm: Add bindings doc for ZTE ZX PWM controller
pwm: bcm2835: Support for polarity setting via DT
Add support for single PWM channel on Low-Power Timer, that can be
found on some STM32 platforms.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Fix a copy/paste error that sneaked into the Kconfig description of the
Mediatek PWM driver.
Signed-off-by: Zhi Mao <zhi.mao@mediatek.com>
Acked-by: John Crispin <john@phrozen.org>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
66AK2G SoC has ECAP subsystem that is used as pwm-backlight provider for
display. Hence, enable pwm-tiecap driver to be built for Keystone
architecture.
Signed-off-by: Vignesh R <vigneshr@ti.com>
It adds PWM device driver for ZTE ZX family SoCs. The PWM controller
supports 4 devices with polarity configuration.
The driver has been tested with pwm-regulator support to scale core
voltage via cpufreq.
This patch adds support for the PWM core found on current ARM base SoCs
made by MediaTek. This IP core supports 5 channels and has 2 operational
modes. There is the old mode, which is a classical PWM and the new mode
which allows the user to define bitmasks that get clocked out on the
pins. As the subsystem currently only supports PWM cores with the "old"
mode, we can safely ignore the "new" mode for now.
Signed-off-by: John Crispin <john@phrozen.org>
[thierry.reding@gmail.com: minor cleanups]
"This set contains mostly fixes to existing drivers as well as cleanup
of code that's not been in active use for a while"
* tag 'pwm/for-4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (27 commits)
acpi: lpss: call pwm_add_table() for BSW PWM device
pwm: Try to load modules during pwm_get()
pwm: Don't hold pwm_lookup_lock longer than necessary
pwm: Make the PWM_POLARITY flag in DTB optional
pwm: Print error messages with pr_err() instead of pr_debug()
pwm: imx: Add polarity inversion support to i.MX's PWMv2
pwm: imx: doc: Update imx-pwm.txt documentation entry
pwm: imx: Remove redundant i.MX PWMv2 code
pwm: imx: Provide atomic PWM support for i.MX PWMv2
pwm: imx: Move PWMv2 wait for fifo slot code to a separate function
pwm: imx: Move PWMv2 software reset code to a separate function
pwm: imx: Rewrite v1 code to facilitate switch to atomic PWM
pwm: imx: Add separate set of PWM ops for v1 and v2
pwm: imx: Remove ipg clock and enable per clock when required
pwm: lpss: Add Intel Gemini Lake PCI ID
pwm: lpss: Do not export board infos for different PWM types
pwm: lpss: Avoid reconfiguring while UPDATE bit is still enabled
pwm: lpss: Switch to new atomic API
pwm: lpss: Allow duty cycle to be 0
pwm: lpss: Avoid potential overflow of base_unit
This driver adds support for PWM driver on STM32 platform.
The SoC have multiple instances of the hardware IP and each
of them could have small differences: number of channels,
complementary output, auto reload register size...
version 9:
- fix commit message header
- remove one space MODULE_ALIAS
version 8:
- fix comments done by Thierry on version 7
version 6:
- change st,breakinput parameter to make it usuable for stm32f7 too.
version 4:
- detect at probe time hardware capabilities
- fix comments done on v2 and v3
- use PWM atomic ops
version 2:
- only keep one comptatible
- use DT parameters to discover hardware block configuration
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@st.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Add dependency on COMMON_CLK and allow COMPILE_TEST for broader compile
coverage. Default to Y for IPROC SoCs. This allows the driver to simply
be enabled by selecting PWM.
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
[thierry.reding@gmail.com: reword commit message]
Add PWM driver for the PWM controller found on HiSilicon BVT SoCs such
as Hi3519V100, Hi3516CV300, etc. The PWM controller is primarily in
charge of controlling the P-Iris lens.
Reviewed-by: Jiancheng Xue <xuejiancheng@hisilicon.com>
Signed-off-by: Jian Yuan <yuanjian12@hisilicon.com>
Acked-by: Rob Herring <robh@kernel.org>
Add support for the PWM controller found in the Amlogic SoCs. This
driver supports the Meson8b and GXBB SoCs.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Tested-by: Jerome Brunet <jbrunet@baylibre.com>
Use the new ChromeOS EC EC_CMD_PWM_{GET,SET}_DUTY commands to control
one or more PWMs attached to the Embedded Controller. Because the EC
allows us to modify the duty cycle (as a percentage, where U16_MAX is
100%) but not the period, we assign the period a fixed value of
EC_PWM_MAX_DUTY and reject all attempts to change it.
This driver supports only device tree at the moment, because that
provides a very flexible way of describing the relationship between PWMs
and their consumer devices (e.g., backlight). On a non-DT system, we'll
probably want to use the non-GENERIC addressing (i.e., we'll need to
make special device instances that will use EC_PWM_TYPE_KB_LIGHT or
EC_PWM_TYPE_DISPLAY_LIGHT), as well as the relatively inflexible
pwm_lookup infrastructure for matching devices. Defer that work for now.
Signed-off-by: Brian Norris <briannorris@chromium.org>
Replace ARCH_RCAR_GEN{1,2} with ARCH_RENESAS in order to support R-Car Gen3.
Signed-off-by: Ryo Kodama <ryo.kodama.vz@renesas.com>
Signed-off-by: Harunobu Kurokawa <harunobu.kurokawa.dn@renesas.com>
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
This adds a driver for the PWM block found in chips of the STMPE 24xx
series of multi-purpose I2C expanders. (I think STMPE means ST
Microelectronics Multi-Purpose Expander.) This PWM was designed in
accordance with Nokia specifications and is kind of weird and usually
just switched between max and zero duty cycle. However it is indeed a
PWM so it needs to live in the PWM subsystem.
This PWM is mostly used for white LED backlight.
Cc: Lee Jones <lee.jones@linaro.org>
Add support for the PWM controller present in Broadcom's iProc family of
SoCs. It has been tested on the Northstar+ bcm958625HR board.
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com>
[thierry.reding@gmail.com: bunch of coding style fixes, cleanups]
This is part of an ongoing process to migrate from ARCH_SHMOBILE to
ARCH_RENESAS the motivation for which being that RENESAS seems to be a
more appropriate name than SHMOBILE for the majority of Renesas ARM
based SoCs.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Ran into this on UML:
drivers/built-in.o: In function `fsl_pwm_probe':
linux/drivers/pwm/pwm-fsl-ftm.c:436: undefined reference to `devm_ioremap_resource'
collect2: error: ld returned 1 exit status
devm_ioremap_resource() is defined only when HAS_IOMEM is selected.
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Xiubo Li <Li.Xiubo@freescale.com>
Cc: Alison Wang <b18965@freescale.com>
Cc: Jingchang Lu <b35083@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Yuan Yao <yao.yuan@freescale.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Adds support for using a OMAP dual-mode timer with PWM capability
as a Linux PWM device. The driver controls the timer by using the
dmtimer API.
Add a platform_data structure for each pwm-omap-dmtimer nodes containing
the dmtimers functions in order to get driver not rely on platform
specific functions.
Cc: Grant Erickson <marathon96@gmail.com>
Cc: NeilBrown <neilb@suse.de>
Cc: Joachim Eastwood <manabian@gmail.com>
Suggested-by: Tony Lindgren <tony@atomide.com>
[thierry.reding@gmail.com: coding style bikeshed, fix timer leak]
We have two users of core part right now. Let them to select core part
automatically.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
There is a chip connected to i2c bus on Intel Galileo Gen2 board. Enable it via
ACPI ID INT3492.
Add display PWM driver support to modify backlight for MT8173 and
MT6595. The PWM has one channel to control the brightness of the
display. When the (high_width / period) is closer to 1, the screen
is brighter; otherwise, it is darker.
Signed-off-by: YH Huang <yh.huang@mediatek.com>
TIPWMSS is present on TI's DRA7x and AM437x SoCs. Enable its usage.
Instead of adding each SoC individually, use the more generic symbol
ARCH_OMAP2PLUS instead.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Add support for the BCM7038-style PWM controller found in all BCM7xxx STB SoCs.
This controller has a hardcoded 2 channels per controller, and cascades a
variable frequency generator on top of a fixed frequency generator which offers
a range of a 148ns period all the way to ~622ms periods.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This patch adds support for R-Car SoCs PWM Timer. The PWM timer of
R-Car H2 has 7 channels. So, we can use the channels if we describe
device tree nodes.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Add a PWM controller driver for the Marvell Berlin SoCs. This PWM
controller has 4 channels.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
"This set of changes introduces the beginnings of a new API that's
based around the concept of states that can be atomically applied.
Drivers go to various lengths to implement something similar, which
indicates that the core should really be providing the necessary
framework.
On top of that, there is a bit of cleanup as well as improved
kerneldoc and integration into the device-drivers DocBook.
Regarding drivers there is a new one for the NXP LPC18xx family of
SoCs and a couple of fixes for existing drivers (pca9685, Broadcom
Kona and Atmel HLCDC)"
* tag 'pwm/for-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
ARM: at91: pwm: atmel-hlcdc: Add at91sam9n12 errata
pwm: Add NXP LPC18xx PWM/SCT DT binding documentation
pwm: NXP LPC18xx PWM/SCT driver
pwm-pca9685: Support changing the output frequency
pwm-pca9685: Fix several driver bugs
pwm: kona: Modify settings application sequence
pwm: pca9685: Drop owner assignment
pwm: Add to device-drivers documentation
pwm: Clean up kerneldoc
pwm: Remove useless whitespace
pwm: sysfs: Remove unnecessary padding
pwm: sysfs: Properly convert from enum to string
pwm: Make use of pwm_get_xxx() helpers where appropriate
pwm: Add pwm_get_polarity() helper function
pwm: Constify PWM device where possible
pwm: Add the pwm_is_enabled() helper
This commit adds support for NXP LPC18xx PWM/SCT.
NXP LPC SoCs family, which includes LPC18xx/LPC43xx, provides a State
Configurable Timer (SCT) which can be configured as a Pulse Width
Modulator. Other SoCs in that family may share the same hardware.
The PWM supports a total of 16 channels, but only 15 can be simultaneously
requested. There's only one period, global to all the channels, thus PWM
driver will refuse setting different values to it, unless there's only one
channel requested.
Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar>
[thierry.reding@gmail.com: remove excessive padding of fields]
The Crystalcove PMIC provides three PWM signals and this driver exports
one of them on the BYT platform which is used to control backlight for
DSI panel. This is platform device implementation of the drivers/mfd
cell device for CRC PMIC.
CC: Samuel Ortiz <sameo@linux.intel.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Tested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Shobhit Kumar <shobhit.kumar@intel.com>
Reviewed-by: Varka Bhadram <varkabhadram@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
The Pistachio SOC from Imagination Technologies includes a Pulse Width
Modulation DAC which produces 1 to 4 digital bit-outputs which represent
digital waveforms. These PWM outputs are primarily in charge of controlling
backlight LED devices.
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Signed-off-by: Naidu Tellapati <Naidu.Tellapati@imgtec.com>
Signed-off-by: Sai Masarapu <Sai.Masarapu@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Reviewed-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
[thierry.reding: fixup license header as discussed on list]
This adds a generic PWM framework driver for the PWM controller
found on Allwinner SoCs.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The include/linux/clk.h header defines dummy implementations for the
various clk_*() functions if HAVE_CLK is not selected to improve build
coverage in randconfig builds.
The dummy implementation of clk_get_rate() returns 0, which causes the
Atmel HLCDC PWM driver's atmel_hlcdc_pwm_config() implementation to end
up calling:
do_div(clk_period_ns, 0)
On x86, do_div(n, base) will end up evaluating to this:
n >>= ilog2(base)
with base = 0, the implementation of ilog2() will call ____ilog2_NaN(),
which is purposely undefined and results in a linker failure:
ERROR: "____ilog2_NaN" [drivers/pwm/pwm-atmel-hlcdc.ko] undefined!
The implementation of do_div() checks that base is a power of 2 before
calling ilog2(). The compiler doesn't optimize this away, presumably
because is_power_of_2() is an inline function and the compiler doesn't
or can't inspect it closely enough. ilog2() being a macro it still ends
up generating the ____ilog2_NaN() because of the constant 0.
The root of the problem is that the driver really should be checking
before possibly dividing by zero. That should eventually be fixed, but
for now just assume that the clock runs at a sensible frequency when
available.
Reported-by: Jim Davis <jim.epost@gmail.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
To re-use the existing PWM driver for 64-bit ARM based Exynos7 SoC, make
the driver depend on ARCH_EXYNOS along with PLAT_SAMSUNG.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
The HLCDC IP available in some Atmel SoCs (i.e. at91sam9x5, at91sam9n12
or sama5d3 families for instance) provides a PWM device.
This driver add support for a PWM chip exposing a single PWM device (which
will most likely be used to drive a backlight device).
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Anthony Harivel <anthony.harivel@emtrion.de>
Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Add PWM driver for Broadcom BCM2835 processor (Raspberry Pi)
Signed-off-by: Bart Tanghe <bart.tanghe@thomasmore.be>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
PWM_CLPS711X needs HAS_IOMEM, so depend on it, the related error (with
allmodconfig under um):
MODPOST 1205 modules
ERROR: "devm_ioremap_resource" [drivers/pwm/pwm-clps711x.ko] undefined!
ERROR: "devm_ioremap" [drivers/net/phy/mdio-bcm-unimac.ko] undefined!
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
There is no sign of this IP block on non-x86 architectures and rather will not
be. Thus, make this explicit by applying a direct dependency to X86.
The driver consists of core, PCI, and platform parts. It would be better
to split them into separate files.
The platform driver is now called pwm-lpss-platform. Thus, previously
set CONFIG_PWM_LPSS=m is not enough to build it. But we are on the safe
side since it seems no one from outside Intel is using it for now.
While here, move to use macros module_pci_driver() and
module_platform_driver().
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Alan Cox <alan@linux.intel.com>
[thierry.reding: change select to depends on PWM_LPSS, cleanup]
Commit 42fa98a9c360 ("pwm: fsl-ftm: Convert to direct regmap API usage")
introduced the following error when REGMAP_MMIO=n:
>> pwm-fsl-ftm.c:(.text+0xd7d7): undefined reference to `devm_regmap_init_mmio_clk'
Select select REGMAP_MMIO in order to fix this error.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Pull pwm changes from Thierry Reding:
"The set of changes for this merge window contains two new drivers: one
for Rockchip SoCs and another for STMicroelectronics STiH4xx SoCs.
The remainder of the changes are the usual small cleanups such as
removing redundant OOM messages, signalling that a PWM chip's
operations can sleep and removing an unneeded dependency"
* tag 'pwm/for-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: rockchip: Added to support for RK3288 SoC
pwm: rockchip: document RK3288 SoC compatible
pwm: sti: Remove PWM period table
pwm: sti: Sync between enable/disable calls
pwm: sti: Ensure same period values for all channels
pwm: sti: Fix PWM prescaler handling
pwm: sti: Supply Device Tree binding documentation for ST's PWM IP
pwm: sti: Add new driver for ST's PWM IP
pwm: imx: set can_sleep flag for imx_pwm
pwm: lpss: remove dependency on clk framework
pwm: pwm-tipwmss: remove unnecessary OOM messages
pwm: rockchip: document device tree bindings
pwm: add Rockchip SoC PWM support
This driver supports all current STi platforms' PWM IPs.
Signed-off-by: Ajit Pal Singh <ajitpal.singh@st.com>
[thierry.reding: rename module to pwm-sti, fix build breakage]
This commit adds a driver for the PWM controller found on Rockchip
RK29, RK30 and RK31 SoCs.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
The Atmel PWM IP can be found on avr32 chips. This allows selecting and building
the driver on avr32.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Add support for the six-channel Kona PWM controller found on Broadcom
mobile SoCs like bcm281xx.
Signed-off-by: Tim Kryger <tim.kryger@linaro.org>
Reviewed-by: Alex Elder <elder@linaro.org>
Reviewed-by: Markus Mayer <markus.mayer@linaro.org>
Add support for Intel Low Power I/O subsystem PWM controllers found on
Intel BayTrail SoC.
Signed-off-by: Chew, Kean Ho <kean.ho.chew@intel.com>
Signed-off-by: Chang, Rebecca Swee Fun <rebecca.swee.fun.chang@intel.com>
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Add a new driver for the ARM CLPS711X Pulse Width Modulator (PWM) interface.
This CPU contain two 4-bit PWM outputs with constant period, based on CPU
PLL frequency. PWM polarity is determined by hardware by power on reset.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
The FTM PWM device can be found on Vybrid VF610 Tower and
Layerscape LS-1 SoCs.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
Reviewed-by: Yuan Yao <yao.yuan@freescale.com>
On archs like S390 or um this driver cannot build nor work.
Make it depend on HAS_IOMEM to bypass build failures.
drivers/built-in.o: In function `tpu_probe':
drivers/pwm/pwm-renesas-tpu.c:421: undefined reference to `devm_ioremap_resource'
Signed-off-by: Richard Weinberger <richard@nod.at>
"The patches for this release cycle include various enhancements
(device tree support, better compile coverage, ...) for existing
drivers. There is a new driver for Atmel SoCs.
Various drivers as well as the sysfs support received minor fixes and
cleanups"
* tag 'pwm/for-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: tiecap: Remove duplicate put_sync call
pwm: tiehrpwm: use dev_err() instead of pr_err()
pwm: pxa: remove unnecessary space before tabs
pwm: ep93xx: split module author names
pwm: use seq_puts() instead of seq_printf()
pwm: atmel-pwm: Do not unprepare clock after successful registration
of: Add Atmel PWM controller device tree binding
pwm: atmel-pwm: Add Atmel PWM controller driver
backlight: pwm_bl: Remove error message upon devm_kzalloc() failure
pwm: pca9685: depends on I2C rather than REGMAP_I2C
pwm: renesas-tpu: Enable driver compilation with COMPILE_TEST
pwm: jz4740: Use devm_clk_get()
pwm: jz4740: Pass device to clk_get()
pwm: sysfs: Convert to use ATTRIBUTE_GROUPS macro
pwm: pxa: Add device tree support
