path: root/drivers/pwm/pwm-bfin.c
2017-07-06pwm: bfin: Remove unneeded error messageMarkus Elfring
Omit an extra message for a memory allocation failure in this function. This issue was detected by using the Coccinelle software. Link: http://events.linuxfoundation.org/sites/events/files/slides/LCJ16-Refactor_Strings-WSang_0.pdf Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-19pwm: constify pwm_ops structuresBhumika Goyal
Declare pwm_ops structures as const as they are only stored in the ops field of a pwm_chip structure. This field is of type const struct pwm_ops *, so pwm_ops structures having this property can be declared as const. Done using Coccinelle: @r1 disable optional_qualifier@ identifier i; position p; @@ static struct pwm_ops i@p={...}; @ok1@ identifier r1.i; position p; struct pxa_pwm_chip pwm; struct bfin_pwm_chip bwm; struct vt8500_chip vp; struct imx_chip icp; @@ ( pwm.chip.ops=&i@p | bwm.chip.ops=&i@p | vp.chip.ops=&i@p | icp.chip.ops=&i@p ) @bad@ position p!={r1.p,ok1.p}; identifier r1.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r1.i; @@ +const struct pwm_ops i; File size details: text data bss dec hex filename 1646 328 0 1974 7b6 drivers/pwm/pwm-imx.o 1742 224 0 1966 7ae drivers/pwm/pwm-imx.o 1941 296 0 2237 8bd drivers/pwm/pwm-pxa.o 2037 192 0 2229 8b5 drivers/pwm/pwm-pxa.o 1946 296 0 2242 8c2 drivers/pwm/pwm-vt8500.o 2050 192 0 2242 8c2 drivers/pwm/pwm-vt8500.o The drivers/pwm/pwm-bfin.o file did not compile. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-10-20pwm: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-06-12pwm: Fill in missing .owner fieldsThierry Reding
Some drivers don't set the .owner fields of the struct device_driver or struct pwm_ops, which causes the module usage count to become wrong. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2012-11-28pwm: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pwm: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-05pwm: Check for negative duty-cycle and periodThierry Reding
Make sure the duty-cycle and period passed in are not negative. This should eventually be made implicit by making them unsigned. While at it, the drivers' .config() implementations can have the equivalent checks removed. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Sachin Kamat <sachin.kamat@linaro.org> Cc: Axel Lin <axel.lin@gmail.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: "Philip, Avinash" <avinashphilip@ti.com> Cc: Vaibhav Bedia <vaibhav.bedia@ti.com> Acked-by: Jingoo Han <jg1.han@samsung.com>
2012-07-23pwm: pwm-bfin: Return proper error if pwmchip_remove() failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-02pwm: Move Blackfin PWM driver to PWM frameworkThierry Reding
This commit moves the Blackfin PWM driver to the drivers/pwm sub- directory and converts it to register with the new PWM framework. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
