Make sure to disable the PWM clock if the PWM cannot be configured due
to the clock divider exceeding the maximum value.
While at it, replace the hardcoded maximum clock divider with a defined
constant to improve code readability.
Signed-off-by: Zhi Mao <zhi.mao@mediatek.com>
Acked-by: John Crispin <john@phrozen.org>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
In order to save some power, do not prepare the top and main clocks
during mtk_pwm_probe(). Instead, prepare the clocks only when necessary
and also make sure to enable the clocks to match the semantics of the
common clock framework.
While at it, don't explicitly disable all PWM channels in ->remove()
because all users should have done that already.
In original code, the PWM output frequency is not correct when set
bit<3>=1 to PWMCON register.
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
drivers/pwm/pwm-mediatek.c:210:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: John Crispin <john@phrozen.org>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
This patch adds support for the PWM core found on current ARM base SoCs
made by MediaTek. This IP core supports 5 channels and has 2 operational
modes. There is the old mode, which is a classical PWM and the new mode
which allows the user to define bitmasks that get clocked out on the
pins. As the subsystem currently only supports PWM cores with the "old"
mode, we can safely ignore the "new" mode for now.
Signed-off-by: John Crispin <john@phrozen.org>
[thierry.reding@gmail.com: minor cleanups]
