path: root/drivers/pwm/pwm-mxs.c
2013-04-23pwm: Constify OF match tablesThierry Reding
A few drivers already annotate this properly. Make the same change for all other OF supporting drivers. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-04-02pwm: mxs: Remove unused *dev from struct mxs_pwm_chipAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2013-01-22pwm: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pwm: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pwm: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-23pwm: pwm-mxs: Return proper error if pwmchip_remove() failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-23pwm: pwm-mxs: add pinctrl supportShawn Guo
Call pinctrl subsystem to set up pwm pin. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-23pwm: pwm-mxs: use devm_* managed functionsShawn Guo
Use devm_* managed functions to have a clean fail-out. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-23pwm: pwm-mxs: use global reset function stmp_reset_blockShawn Guo
Use global reset function stmp_reset_block instead of mxs_reset_block to remove <mach/common.h> inclusion. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-23pwm: pwm-mxs: encode soc name in compatible stringShawn Guo
Encode soc name in the compatible string to know the specific version hardware block. This is the general approach adopted for most bindings. Change mxs-pwm binding to use the approach. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-02pwm: add pwm-mxs supportShawn Guo
Add generic PWM framework driver (DT only) for Freescale MXS. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
