Remove the legacy callbacks .enable(), .disable(), .set_polarity() and
.config().
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Switch the driver to atomic PWM. This makes it easier to wait a proper
amount of time when changing the duty cycle before disabling the channel
(main use case is switching the duty cycle to 0 before disabling).
Implement .get_state instead of only reading the polarity at probe time.
This allows to get the proper state, period and duty cycle.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
All PWM devices have been marked as "might sleep" since v4.5, there is
no longer a need to differentiate on a per-chip basis.
H3 PWM controller has same register layout as sun4i driver, so it works
by adding H3 specific data.
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: linux-pwm@vger.kernel.org
Cc: devicetree@vger.kernel.org
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Rob Herring <robh@kernel.org>
Use pwm_get/set_xxx() helpers instead of directly accessing the pwm->xxx
field. Doing that will ease adaptation of the PWM framework to support
atomic update.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This patch changes no code, it just fixes the whitespacing. Operators
should be separated from operands by a single space.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
The PWM controller on sun5i SoCs is identical to the one found on sun7i
SoCs. On the A13 package only one of the 2 pins is routed to the outside,
so only advertise one PWM channel there.
This adds a generic PWM framework driver for the PWM controller
found on Allwinner SoCs.
