commit 38dabd91ff0bde33352ca3cc65ef515599b77a05 upstream.
pwm-tiehrpwm driver disables PWM output by putting it in low output
state via active AQCSFRC register in ehrpwm_pwm_disable(). But, the
AQCSFRC shadow register is not updated. Therefore, when shadow AQCSFRC
register is re-enabled in ehrpwm_pwm_enable() (say to enable second PWM
output), previous settings are lost as shadow register value is loaded
into active register. This results in things like PWMA getting enabled
automatically, when PWMB is enabled and vice versa. Fix this by
updating AQCSFRC shadow register as well during ehrpwm_pwm_disable().
Fixes: 19891b20e7c2 ("pwm: pwm-tiehrpwm: PWM driver support for EHRPWM")
Cc: stable@vger.kernel.org
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
commit aa49d628f6e016bcec8c6f8e704b9b18ee697329 upstream.
As per AM335x TRM SPRUH73P "15.2.2.11 ePWM Behavior During Emulation",
TBCTL[15:14] only have effect during emulation suspend events (IOW,
to stop PWM when debugging using a debugger). These bits have no effect
on PWM output during normal running of system. Hence, remove code
accessing these bits as they have no role in enabling/disabling PWMs.
Runtime PM callbacks can be run right after runtime PM is enabled, so
make sure to set the driver data before that. This is unlikely to ever
happen with the current driver, but it doesn't hurt to follow best
practices anyway.
I noticed most of these while reviewing another patch and thought I'd
fix them while at it. These are mostly changes to make variable types
more strict and whitespace fixups.
Make sure to unprepare the clock before returning on late probe errors.
Fixes: b388f15fd14c ("pwm: pwm-tiehrpwm: Use clk_enable/disable instead clk_prepare/unprepare.")
Signed-off-by: Johan Hovold <johan@kernel.org>
Remove unbalanced RPM put at driver unbind which resulted in a negative
usage count.
The PWMSS local clock gating registers have no real purpose on OMAP ARM
devices. These registers were left over registers from DSP IP where the
PRCM doesn't exist. There is a silicon bug where gating and ungating clocks
don't function properly. TRMs will be update to indicate that these
registers shouldn't be touched.
Therefore, all code that accesses the PWMSS_CLKCONFIG or PWMSS_CLKSTATUS
will be removed by this patch with zero loss of functionality by the ECAP
and EPWM drivers.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
When using the old eCAP and ePWM bindings for AM335x and AM437x the clock
can be retrieved from the PWMSS parent. Newer bindings will insure that
this clock is provided via device tree.
Therefore, update this driver to support the newer and older bindings. In
the case of the older binding being used give a warning.
[thierry.reding@gmail.com: rewrite slightly for readability]
Some PWM drivers are testing the PWMF_ENABLED flag. Create a helper
function to hide the logic behind enabled test. This will allow us to
smoothly move from the current approach to an atomic PWM update
approach.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
These elementary functions should be inlined for fastest access. Also
fixes this warning as a side-effect (when no PM_SLEEP is selected):
drivers/pwm/pwm-tiehrpwm.c:141:12: warning: 'ehrpwm_read' defined but not used [-Wunused-function]
Signed-off-by: Wolfram Sang <wsa@sang-engineering.com>
Fixes following warnings on AM335X with no PM_SLEEP
drivers/pwm/pwm-tiehrpwm.c:534:13: warning: 'ehrpwm_pwm_save_context' defined but not used [-Wunused-function]
drivers/pwm/pwm-tiehrpwm.c:548:13: warning: 'ehrpwm_pwm_restore_context' defined but not used [-Wunused-function]
The site-specific OOM messages are unnecessary, because they
duplicate the MM subsystem generic OOM message.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use dev_err() instead of pr_err() to provide a better message
to userspace.
Since commit ab78029 (drivers/pinctrl: grab default handles from device core),
we can rely on device core for setting the default pins. Compile tested only.
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
Fix the following sparse warnings:
drivers/pwm/pwm-tiehrpwm.c:144:16: warning: incorrect type in argument 1 (different address spaces)
drivers/pwm/pwm-tiehrpwm.c:144:16: expected void const volatile [noderef] <asn:2>*addr
drivers/pwm/pwm-tiehrpwm.c:144:16: got void *
drivers/pwm/pwm-tiehrpwm.c:149:9: warning: incorrect type in argument 2 (different address spaces)
drivers/pwm/pwm-tiehrpwm.c:149:9: expected void volatile [noderef] <asn:2>*addr
drivers/pwm/pwm-tiehrpwm.c:149:9: got void *
drivers/pwm/pwm-tiehrpwm.c:157:18: warning: incorrect type in argument 1 (different address spaces)
drivers/pwm/pwm-tiehrpwm.c:157:18: expected void const volatile [noderef] <asn:2>*addr
drivers/pwm/pwm-tiehrpwm.c:157:18: got void *
drivers/pwm/pwm-tiehrpwm.c:160:9: warning: incorrect type in argument 2 (different address spaces)
drivers/pwm/pwm-tiehrpwm.c:160:9: expected void volatile [noderef] <asn:2>*addr
drivers/pwm/pwm-tiehrpwm.c:160:9: got void *
This was found when using pwm-led on am33xx and enable
heartbeat trigger.
[ 808.624876] =================================
[ 808.629443] [ INFO: inconsistent lock state ]
[ 808.634021] 3.9.0 #2 Not tainted
[ 808.637415] ---------------------------------
[ 808.641981] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 808.648288] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 808.653494] (prepare_lock){+.?.+.}, at: [<c027c211>] clk_unprepare+0x15/0x24
[ 808.661040] {SOFTIRQ-ON-W} state was registered at:
[ 808.666155] [<c004ec4d>] __lock_acquire+0x411/0x824
[ 808.671465] [<c004f359>] lock_acquire+0x41/0x50
[ 808.676412] [<c039ee9d>] mutex_lock_nested+0x31/0x1d8
[ 808.681912] [<c027c275>] clk_prepare+0x15/0x28
[ 808.686764] [<c0590c6b>] _init+0x117/0x1e0
[ 808.691256] [<c0019ef9>] omap_hwmod_for_each+0x29/0x3c
[ 808.696842] [<c0591107>] __omap_hwmod_setup_all+0x17/0x2c
[ 808.702696] [<c0008653>] do_one_initcall+0xc3/0x10c
[ 808.708017] [<c058a627>] kernel_init_freeable+0xa7/0x134
[ 808.713778] [<c039a543>] kernel_init+0x7/0x98
[ 808.718544] [<c000cd95>] ret_from_fork+0x11/0x3c
[ 808.723583] irq event stamp: 1379172
[ 808.727328] hardirqs last enabled at (1379172): [<c03a0759>] _raw_spin_unlock_irqrestore+0x21/0x30
[ 808.736828] hardirqs last disabled at (1379171): [<c03a03c3>] _raw_spin_lock_irqsave+0x13/0x38
[ 808.745876] softirqs last enabled at (1379164): [<c002ae5d>] irq_enter+0x49/0x4c
[ 808.753747] softirqs last disabled at (1379165): [<c002aec3>] irq_exit+0x63/0x88
[ 808.761518]
[ 808.761518] other info that might help us debug this:
[ 808.768373] Possible unsafe locking scenario:
[ 808.768373]
[ 808.774578] CPU0
[ 808.777141] ----
[ 808.779705] lock(prepare_lock);
[ 808.783186] <Interrupt>
[ 808.785929] lock(prepare_lock);
[ 808.789595]
[ 808.789595] *** DEADLOCK ***
[ 808.789595]
[ 808.795805] 1 lock held by swapper/0:
[ 808.799643] #0: (((&heartbeat_data->timer))){+.-...}, at: [<c002e204>] call_timer_fn+0x0/0x90
[ 808.808814]
[ 808.808814] stack backtrace:
[ 808.813402] [<c000ff19>] (unwind_backtrace+0x1/0x98) from [<c039bd75>] (print_usage_bug.part.25+0x16d/0x1cc)
[ 808.823721] [<c039bd75>] (print_usage_bug.part.25+0x16d/0x1cc) from [<c004e595>] (mark_lock+0x18d/0x434)
[ 808.833669] [<c004e595>] (mark_lock+0x18d/0x434) from [<c004ec1d>] (__lock_acquire+0x3e1/0x824)
[ 808.842803] [<c004ec1d>] (__lock_acquire+0x3e1/0x824) from [<c004f359>] (lock_acquire+0x41/0x50)
[ 808.852031] [<c004f359>] (lock_acquire+0x41/0x50) from [<c039ee9d>] (mutex_lock_nested+0x31/0x1d8)
[ 808.861433] [<c039ee9d>] (mutex_lock_nested+0x31/0x1d8) from [<c027c211>] (clk_unprepare+0x15/0x24)
[ 808.870930] [<c027c211>] (clk_unprepare+0x15/0x24) from [<c019f7bf>] (ehrpwm_pwm_disable+0x5f/0x80)
[ 808.880431] [<c019f7bf>] (ehrpwm_pwm_disable+0x5f/0x80) from [<c019f29f>] (pwm_disable+0x27/0x28)
[ 808.889751] [<c019f29f>] (pwm_disable+0x27/0x28) from [<c026f8f3>] (led_heartbeat_function+0x3f/0xb0)
[ 808.899431] [<c026f8f3>] (led_heartbeat_function+0x3f/0xb0) from [<c002e249>] (call_timer_fn+0x45/0x90)
[ 808.909288] [<c002e249>] (call_timer_fn+0x45/0x90) from [<c002e399>] (run_timer_softirq+0x105/0x17c)
[ 808.918884] [<c002e399>] (run_timer_softirq+0x105/0x17c) from [<c002abc5>] (__do_softirq+0xa5/0x150)
[ 808.928486] [<c002abc5>] (__do_softirq+0xa5/0x150) from [<c002aec3>] (irq_exit+0x63/0x88)
[ 808.937098] [<c002aec3>] (irq_exit+0x63/0x88) from [<c000d599>] (handle_IRQ+0x21/0x54)
[ 808.945415] [<c000d599>] (handle_IRQ+0x21/0x54) from [<c0008495>] (omap3_intc_handle_irq+0x5d/0x68)
[ 808.954900] [<c0008495>] (omap3_intc_handle_irq+0x5d/0x68) from [<c000c7ff>] (__irq_svc+0x3f/0x64)
[ 808.964287] Exception stack(0xc05b1f68 to 0xc05b1fb0)
[ 808.969587] 1f60: 00000001 00000001 00000000 00000000 c05b0000 c0619748
[ 808.978158] 1f80: c05b0000 c05b0000 c0619748 413fc082 00000000 00000000 01000000 c05b1fb0
[ 808.986719] 1fa0: c004f989 c000d6f0 400f0033 ffffffff
[ 808.992024] [<c000c7ff>] (__irq_svc+0x3f/0x64) from [<c000d6f0>] (cpu_idle+0x60/0x98)
[ 809.000250] [<c000d6f0>] (cpu_idle+0x60/0x98) from [<c058a535>] (start_kernel+0x1e9/0x234)
Remove non atomic clk api calls and use only atomic for enable/disable because
can be called from atomic context (led_heartbeat_function is timer callback).
Signed-off-by: Marek Belisko <marek.belisko@streamunlimited.com>
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Both ehrpwm_pwm_save_context() and ehrpwm_pwm_restore_context() are only used in
this file, make them static.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This patch adds CONFIG_PM_SLEEP to suspend/resume functions to fix
the following build warning when CONFIG_PM_SLEEP is not selected.
drivers/pwm/pwm-tiehrpwm.c:562:12: warning: 'ehrpwm_pwm_suspend' defined but not used [-Wunused-function]
drivers/pwm/pwm-tiehrpwm.c:580:12: warning: 'ehrpwm_pwm_resume' defined but not used [-Wunused-function
Pull PWM changes from Thierry Reding:
"A new driver has been added to support the PWM mode of the timer
counter blocks found on Atmel AT91 SoCs. The VT8500 driver now
supports changing the PWM signal polarity and the TI drivers (EHRPWM
and ECAP) gained suspend and resume functionality.
User drivers can now query the core for whether access to a PWM device
will sleep (if the PWM chip is on a slow bus such as I2C or SPI).
The pwm-backlight driver now handles the backlight BL_CORE_FBBLANK
state in addition to the FB layer's blanking states.
To round things off, a few fixes and cleanups are also included"
* tag 'for-3.9-rc1' of git://gitorious.org/linux-pwm/linux-pwm:
pwm: twl: Use to_twl() instead of container_of()
pwm: tegra: assume CONFIG_OF
pwm_backlight: Validate dft_brightness in main probe function
pwm: Export pwm_{set,get}_chip_data()
pwm: Make Kconfig entries more consistent
pwm: Add can_sleep property to drivers
pwm: Add pwm_can_sleep() as exported API to users
pwm-backlight: handle BL_CORE_FBBLANK state
pwm: pwm-tiecap: Low power sleep support
pwm: pwm-tiehrpwm: Low power sleep support
pwm: pwm-tiehrpwm: Update the clock handling of pwm-tiehrpwm driver
pwm: vt8500: Add polarity support
pwm: vt8500: Register write busy test performed incorrectly
pwm: atmel: add Timer Counter Block PWM driver
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
In low power modes of AM33XX platforms, peripherals power is cut off.
This patch supports low power sleep transition support for EHRPWM
driver.
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
The clock framework has changed and it's now better to invoke
clock_prepare_enable() and clk_disable_unprepare() rather than the
legacy clk_enable() and clk_disable() calls. This patch converts the
pwm-tiehrpwm driver to the new framework.
Pull pwm changes from Thierry Reding:
"A new driver has been added for the SPEAr platform and the
TWL4030/6030 driver has been replaced by two drivers that control the
regular PWMs and the PWM driven LEDs provided by the chips.
The vt8500, tiecap, tiehrpwm, i.MX, LPC32xx and Samsung drivers have
all been improved and the device tree bindings now support the PWM
signal polarity."
Fix up trivial conflicts due to __devinit/exit removal.
* tag 'for-3.8-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (21 commits)
pwm: samsung: add missing s3c->pwm_id assignment
pwm: lpc32xx: Set the chip base for dynamic allocation
pwm: lpc32xx: Properly disable the clock on device removal
pwm: lpc32xx: Fix the PWM polarity
pwm: i.MX: eliminate build warning
pwm: Export of_pwm_xlate_with_flags()
pwm: Remove pwm-twl6030 driver
pwm: New driver to support PWM driven LEDs on TWL4030/6030 series of PMICs
pwm: New driver to support PWMs on TWL4030/6030 series of PMICs
pwm: pwm-tiehrpwm: pinctrl support
pwm: tiehrpwm: Add device-tree binding
pwm: pwm-tiehrpwm: Adding TBCLK gating support.
pwm: pwm-tiecap: pinctrl support
pwm: tiecap: Add device-tree binding
pwm: Add TI PWM subsystem driver
pwm: Device tree support for PWM polarity
pwm: vt8500: Ensure PWM clock is enabled during pwm_config
pwm: vt8500: Fix build error
pwm: spear: Staticize spear_pwm_config()
pwm: Add SPEAr PWM chip driver support
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Enable pinctrl for pwm-tiehrpwm if pinctrl driver available, else
bail out with warning message.
Signed-off-by: Philip, Avinash <avinashphilip@ti.com>
This patch
1. Add support for device-tree binding for EHRWPM driver.
2. Set size of pwm-cells set to 3 to support PWM channel number, PWM
period & polarity configuration from device tree.
3. Add enable/disable clock gating in PWM subsystem common config space.
4. When here set .owner member in platform_driver structure to
THIS_MODULE.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Rob Landley <rob@landley.net>
Some platforms (like AM33XX) requires clock gating from control module
explicitly for TBCLK. Enabling of this clock required for the
functioning of the time base sub module in EHRPWM module. Adding support
for handling by enabling the clock on PWM device enable & disable on PWM
device disable. Platforms don't have explicit TBCLK gating has to add
dummy TBCLK node.
Make sure the duty-cycle and period passed in are not negative. This
should eventually be made implicit by making them unsigned. While at
it, the drivers' .config() implementations can have the equivalent
checks removed.
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Axel Lin <axel.lin@gmail.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: "Philip, Avinash" <avinashphilip@ti.com>
Cc: Vaibhav Bedia <vaibhav.bedia@ti.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
EHRPWM hardware supports polarity configuration of PWM output. However
configuration of polarity done in hardware only in .enable() to ensure
PWM output present only after enabling PWM. This commit adds support for
polarity configuration for EHRPWM.
When being here, remove configuring of polarity during .config() and do
it explicitly from .set_polarity().
EHRPWM hardware supports 2 independent PWM channels. However the device
uses only one register to handle period setting for both channels. So
both channels should be configured for same period (in nsec).
Fix the same by returning error for conflicting period values.
However, allow
1. Configuration of period settings if not conflicting with other
channels
2. Re-configuring of period settings if no other channels being
configured
The implementation in devm_request_and_ioremap() already shows error message,
so no need to show dev_err again if devm_request_and_ioremap() fails.
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Philip, Avinash <avinashphilip@ti.com>
Enhanced high resolution PWM module (EHRPWM) hardware can be used to
generate PWM output over 2 channels. This commit adds PWM driver support
for EHRPWM device present on AM33XX SOC. Current implementation supports
simple PWM functionality.
Reviewed-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
