path: root/drivers/pwm
2014-06-11Merge tag 'pwm/for-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The majority of these changes are cleanups and fixes across all drivers. Redundant error messages are removed and more PWM controllers set the .can_sleep flag to signal that they can't be used in atomic context. Support is added for the Broadcom Kona family of SoCs and the Intel LPSS driver can now probe PCI devices in addition to ACPI devices. Upon shutdown, the pwm-backlight driver will now power off the backlight. It also uses the new descriptor-based GPIO API for more concise GPIO handling. A large chunk of these changes also converts platforms to use the lookup mechanism rather than relying on the global number space to reference PWM devices. This is largely in preparation for more unification and cleanups in future patches. Eventually it will allow the legacy PWM API to be removed" * tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits) pwm: fsl-ftm: set pwm_chip can_sleep flag pwm: ab8500: Fix wrong value shift for disable/enable PWM pwm: samsung: do not set manual update bit in pwm_samsung_config pwm: lp3943: Set pwm_chip can_sleep flag pwm: atmel: set pwm_chip can_sleep flag pwm: mxs: set pwm_chip can_sleep flag pwm: tiehrpwm: inline accessor functions pwm: tiehrpwm: don't build PM related functions when not needed pwm-backlight: retrieve configured PWM period leds: leds-pwm: retrieve configured PWM period ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members ARM: pxa: hx4700: initialize all the struct pwm_lookup members ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data ARM: shmobile: armadillo: initialize all struct pwm_lookup members pwm: add period and polarity to struct pwm_lookup pwm: twl: Really disable twl6030 PWMs ...
2014-05-23pwm: fsl-ftm: set pwm_chip can_sleep flagAxel Lin
The implementation of .config(), .enable() and .disable() operations in this driver may sleep, thus set pwm_chip can_sleep flag. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: ab8500: Fix wrong value shift for disable/enable PWMAxel Lin
Current code only works when pdev->id is 1. Fix it by passing correct bit values to abx500_mask_and_set_register_interruptible(). Having DISABLE_PWM/ENABLE_PWM does not make the code more readable because the bit values depend on pdev->id. Thus drop the DISABLE_PWM and ENABLE_PWM defines. This patch also removes an unnecessary return in ab8500_pwm_disable(). Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Alexandre BOURDIOL <alexandre.bourdiol@st.com> Acked-by: Philippe Begnic <philippe.begnic@st.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: samsung: do not set manual update bit in pwm_samsung_configAjay Kumar
pwm_samsung_config() sets the manual update bit via a call to the pwm_samsung_enable() function even when the channel is already running. This causes noticable flicker on display if we try to change the backlight brightness from minimum to maximum, continuously. So, we remove the call to pwm_samsung_enable() from pwm_samsung_config to avoid the flicker and this change doesn't harm normal working since the pwm-backlight driver already calls pwm_samsung_enable() where needed. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: lp3943: Set pwm_chip can_sleep flagAxel Lin
Read/write through I2C can sleep, thus set pwm_chip can_sleep flag. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: atmel: set pwm_chip can_sleep flagAlexandre Belloni
atmel_pwm_config() calls clk_get_rate() which might sleep, so we need to set pwm_chip can_sleep flag. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: mxs: set pwm_chip can_sleep flagShawn Guo
The .config() calls clk_get_rate() which might sleep, so we need to set pwm_chip can_sleep flag. Otherwise, we see the following warning when using PWM driven heartbeat led. WARNING: CPU: 0 PID: 0 at kernel/locking/mutex.c:856 mutex_trylock+0x184/0x1a4() DEBUG_LOCKS_WARN_ON(in_interrupt()) Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.0-rc5 #18 [<c0015420>] (unwind_backtrace) from [<c0012cb0>] (show_stack+0x10/0x14) [<c0012cb0>] (show_stack) from [<c001daf8>] (warn_slowpath_common+0x6c/0x8c) [<c001daf8>] (warn_slowpath_common) from [<c001dbac>] (warn_slowpath_fmt+0x30/0x40) [<c001dbac>] (warn_slowpath_fmt) from [<c045df74>] (mutex_trylock+0x184/0x1a4) [<c045df74>] (mutex_trylock) from [<c0360950>] (clk_prepare_lock+0xc/0xec) [<c0360950>] (clk_prepare_lock) from [<c0362020>] (clk_get_rate+0xc/0x68) [<c0362020>] (clk_get_rate) from [<c028d07c>] (mxs_pwm_config+0x20/0x198) [<c028d07c>] (mxs_pwm_config) from [<c028bde8>] (pwm_config+0x60/0x70) [<c028bde8>] (pwm_config) from [<c034b61c>] (__led_pwm_set+0x1c/0x3c) [<c034b61c>] (__led_pwm_set) from [<c034bc3c>] (led_heartbeat_function+0x70/0x110) [<c034bc3c>] (led_heartbeat_function) from [<c00292f0>] (call_timer_fn+0x7c/0x164) [<c00292f0>] (call_timer_fn) from [<c00295c8>] (run_timer_softirq+0x1f0/0x260) [<c00295c8>] (run_timer_softirq) from [<c002255c>] (__do_softirq+0xc4/0x2f0) [<c002255c>] (__do_softirq) from [<c0022890>] (irq_exit+0xa4/0x10c) [<c0022890>] (irq_exit) from [<c0010240>] (handle_IRQ+0x34/0x84) [<c0010240>] (handle_IRQ) from [<c0013524>] (__irq_svc+0x44/0x54) [<c0013524>] (__irq_svc) from [<c00107f8>] (arch_cpu_idle+0x40/0x48) [<c00107f8>] (arch_cpu_idle) from [<c005deb8>] (cpu_startup_entry+0x70/0x198) [<c005deb8>] (cpu_startup_entry) from [<c060aac8>] (start_kernel+0x2a8/0x2f8) Reported-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: tiehrpwm: inline accessor functionsWolfram Sang
These elementary functions should be inlined for fastest access. Also fixes this warning as a side-effect (when no PM_SLEEP is selected): drivers/pwm/pwm-tiehrpwm.c:141:12: warning: 'ehrpwm_read' defined but not used [-Wunused-function] Signed-off-by: Wolfram Sang <wsa@sang-engineering.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: tiehrpwm: don't build PM related functions when not neededWolfram Sang
Fixes following warnings on AM335X with no PM_SLEEP drivers/pwm/pwm-tiehrpwm.c:534:13: warning: 'ehrpwm_pwm_save_context' defined but not used [-Wunused-function] drivers/pwm/pwm-tiehrpwm.c:548:13: warning: 'ehrpwm_pwm_restore_context' defined but not used [-Wunused-function] Signed-off-by: Wolfram Sang <wsa@sang-engineering.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: renesas-tpu: remove unused struct tpu_pwm_platform_dataAlexandre Belloni
The struct is not used anymore and the polarity initialization will be done using the PWM lookup table (or device tree). Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-21pwm: add period and polarity to struct pwm_lookupAlexandre Belloni
Add period and polarity members to struct pwm_lookup so that platforms using the lookup table can be treated the same way as those using the device tree. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-08pwm: twl: Really disable twl6030 PWMsAxel Lin
Current twl6030_pwm_disable() implementation writes TWL6030_TOGGLE3_REG twice, the second write sets TWL6030_PWMXEN bits so the PWM clock does not disable. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-07pwm: lpss: Fix const qualifier and sparse warningsThierry Reding
Fixes the following warnings reported by the 0-DAY kernel build testing backend: drivers/pwm/pwm-lpss.c: In function 'pwm_lpss_probe_pci': >> drivers/pwm/pwm-lpss.c:192:2: warning: passing argument 3 of 'pwm_lpss_probe' discards 'const' qualifier from pointer target type [enabled by default] lpwm = pwm_lpss_probe(&pdev->dev, &pdev->resource[0], info); ^ drivers/pwm/pwm-lpss.c:130:30: note: expected 'struct pwm_lpss_boardinfo *' but argument is of type 'const struct pwm_lpss_boardinfo *' static struct pwm_lpss_chip *pwm_lpss_probe(struct device *dev, ^ >> drivers/pwm/pwm-lpss.c:143:28: sparse: incorrect type in return expression (different address spaces) drivers/pwm/pwm-lpss.c:143:28: expected struct pwm_lpss_chip * drivers/pwm/pwm-lpss.c:143:28: got void [noderef] <asn:2>*regs >> drivers/pwm/pwm-lpss.c:192:63: sparse: incorrect type in argument 3 (different modifiers) drivers/pwm/pwm-lpss.c:192:63: expected struct pwm_lpss_boardinfo *info drivers/pwm/pwm-lpss.c:192:63: got struct pwm_lpss_boardinfo const *[assigned] info drivers/pwm/pwm-lpss.c: In function 'pwm_lpss_probe_pci': drivers/pwm/pwm-lpss.c:192:2: warning: passing argument 3 of 'pwm_lpss_probe' discards 'const' qualifier from pointer target type [enabled by default] lpwm = pwm_lpss_probe(&pdev->dev, &pdev->resource[0], info); ^ drivers/pwm/pwm-lpss.c:130:30: note: expected 'struct pwm_lpss_boardinfo *' but argument is of type 'const struct pwm_lpss_boardinfo *' static struct pwm_lpss_chip *pwm_lpss_probe(struct device *dev, ^ Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-07pwm: spear: fix check on pwmchip_add() return valueBeniamino Galvani
pwmchip_add() returns zero on success and a negative value on error, so the condition of the check must be inverted. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-28pwm: lpss: Add support for PCI devicesAlan Cox
Not all systems enumerate the PWM devices via ACPI. They can also be exposed via the PCI interface. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-28pwm: vt8500: Remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-28pwm: tiehrpwm: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: pwm-tiecap: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: tegra: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: spear: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: renesas-tpu: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: pxa: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: i.MX: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: ab8500: Remove unnecessary OOM messagesJingoo Han
2014-04-28pwm: kona: Introduce Kona PWM controller supportTim Kryger
Add support for the six-channel Kona PWM controller found on Broadcom mobile SoCs like bcm281xx. Signed-off-by: Tim Kryger <tim.kryger@linaro.org> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-18Shiraz has movedViresh Kumar
shiraz.hashim@st.com email-id doesn't exist anymore as he has left the company. Replace ST's id with shiraz.linux.kernel@gmail.com. It also updates .mailmap file to fix address for 'git shortlog'. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-05Merge tag 'pwm/for-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The legacy HAVE_PWM Kconfig symbol is finally being retired. Thanks a lot to Sascha Hauer for doing that. Three new drivers are added: Freescale FTM, Cirrus Logic CLPS711X and Intel Low Power Subsystem. An assortment of fixes and cleanups rounds things off for this release cycle" * tag 'pwm/for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: pxa: Constify OF match table pwm: pxa: Fix typo "pwm" -> "PWM" Revert "pwm: pxa: Use of_match_ptr()" pwm: add support for Intel Low Power Subsystem PWM pwm: Add CLPS711X PWM support pwm: atmel: correct CDTY calculation pwm: atmel: Fix polarity handling Documentation: Add device tree bindings for Freescale FTM PWM. pwm: Add Freescale FTM PWM driver support pwm: pxa: Use of_match_ptr() pwm: samsung: Use SIMPLE_DEV_PM_OPS macro pwm: renesas-tpu: Add dependency on HAS_IOMEM pwm: Remove obsolete HAVE_PWM Kconfig symbol
2014-04-01pwm: pxa: Constify OF match tableThierry Reding
The table is never modified and all OF functions that use it take a const struct of_device_id *. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-01pwm: pxa: Fix typo "pwm" -> "PWM"Thierry Reding
Being an abbreviation, PWM should always be capitalized in prose. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-01Revert "pwm: pxa: Use of_match_ptr()"Thierry Reding
This reverts commit 8468949cddcdbb1b1b1bc552aefceb252078ceb1. The OF match table dummy for non-OF configurations cannot be removed because it is still used by the pxa_pwm_get_id_dt() function. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-01pwm: add support for Intel Low Power Subsystem PWMMika Westerberg
Add support for Intel Low Power I/O subsystem PWM controllers found on Intel BayTrail SoC. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Chew, Kean Ho <kean.ho.chew@intel.com> Signed-off-by: Chang, Rebecca Swee Fun <rebecca.swee.fun.chang@intel.com> Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-03-18pwm: Add CLPS711X PWM supportAlexander Shiyan
Add a new driver for the ARM CLPS711X Pulse Width Modulator (PWM) interface. This CPU contain two 4-bit PWM outputs with constant period, based on CPU PLL frequency. PWM polarity is determined by hardware by power on reset. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-03-18pwm: atmel: correct CDTY calculationAlexandre Belloni
From the datasheet, the actual duty cycle is: (period - (1 / clk) * CDTY) / period This actually correct the polarity of the PWM and solves the issue that pwm-leds exhibits: when setting a duty cycle of 0 and then disabling a channel, the level was wrong (1 when the polarity was normal and 0 when the polarity was inversed). Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-03-18pwm: atmel: Fix polarity handlingAlexandre Belloni
When atmel_pwm_config() calculates and then sets the prescaler, it is overwriting the channel's CMR register so we are losing the CPOL configuration. As atmel_pwm_config() is always called before enabling a channel, inverting the polarity doesn't work. Fix that by reading CMR first and only overwriting the prescaler bits. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-03-18pwm: Add Freescale FTM PWM driver supportXiubo Li
The FTM PWM device can be found on Vybrid VF610 Tower and Layerscape LS-1 SoCs. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com> Signed-off-by: Jingchang Lu <b35083@freescale.com> Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-02-26pwm: pxa: Use of_match_ptr()Jingoo Han
Use of_match_ptr(), because of_match_ptr() returns NULL pointer when CONFIG_OF is disabled. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-02-26pwm: samsung: Use SIMPLE_DEV_PM_OPS macroJingoo Han
Use SIMPLE_DEV_PM_OPS macro in order to make the code simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-02-26pwm: renesas-tpu: Add dependency on HAS_IOMEMRichard Weinberger
On archs like S390 or um this driver cannot build nor work. Make it depend on HAS_IOMEM to bypass build failures. drivers/built-in.o: In function `tpu_probe': drivers/pwm/pwm-renesas-tpu.c:421: undefined reference to `devm_ioremap_resource' Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-02-26pwm: lp3943: Fix potential memory leak during requestChristian Engelmayer
Fix a memory leak in the lp3943_pwm_request_map() error handling path. Make sure already allocated pwm map memory is freed correctly. Detected by Coverity: CID 1162829. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Acked-by: Milo Kim <milo.kim@ti.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-01-27Merge tag 'pwm/for-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The patches for this release cycle include various enhancements (device tree support, better compile coverage, ...) for existing drivers. There is a new driver for Atmel SoCs. Various drivers as well as the sysfs support received minor fixes and cleanups" * tag 'pwm/for-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: tiecap: Remove duplicate put_sync call pwm: tiehrpwm: use dev_err() instead of pr_err() pwm: pxa: remove unnecessary space before tabs pwm: ep93xx: split module author names pwm: use seq_puts() instead of seq_printf() pwm: atmel-pwm: Do not unprepare clock after successful registration of: Add Atmel PWM controller device tree binding pwm: atmel-pwm: Add Atmel PWM controller driver backlight: pwm_bl: Remove error message upon devm_kzalloc() failure pwm: pca9685: depends on I2C rather than REGMAP_I2C pwm: renesas-tpu: Enable driver compilation with COMPILE_TEST pwm: jz4740: Use devm_clk_get() pwm: jz4740: Pass device to clk_get() pwm: sysfs: Convert to use ATTRIBUTE_GROUPS macro pwm: pxa: Add device tree support
2014-01-23pwm: tiecap: Remove duplicate put_sync callSourav Poddar
Remove duplicate 'pm_runtime_put_sync' in the remove path. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-01-21pwm: Add LP3943 PWM driverMilo Kim
This is the other of the LP3943 MFD driver. LP3943 can be used as a PWM generator, up to 2 channels. * Two PWM generators supported * Supported PWM operations request, free, config, enable and disable * Pin assignment A driver data, 'pin_used' is checked when a PWM is requested. If the output pin is already assigned, then returns as failure. If the pin is available, 'pin_used' is set. When the PWM is not used anymore, then it is cleared. It is defined as unsigned long type for atomic bit operation APIs, but only LSB 16bits are used because LP3943 has 16 outputs. Signed-off-by: Milo Kim <milo.kim@ti.com> Acked-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-12-20pwm: tiehrpwm: use dev_err() instead of pr_err()Jingoo Han
Use dev_err() instead of pr_err() to provide a better message to userspace. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-20pwm: pxa: remove unnecessary space before tabsJingoo Han
Remove unnecessary space before tabs in order to fix the following checkpatch warning. WARNING: please, no space before tabs Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-20pwm: ep93xx: split module author namesJingoo Han
Split module author names in order to fix the following checkpatch warning. WARNING: quoted string split across lines Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-20pwm: use seq_puts() instead of seq_printf()Jingoo Han
For a constant format without additional arguments, use seq_puts() instead of seq_printf(). Also, the following checkpatch warning is fixed. WARNING: Prefer seq_puts to seq_printf Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-20pwm: atmel-pwm: Do not unprepare clock after successful registrationBo Shen
When the PWM controller is registered successfully, the clock can not unprepare, so fix it. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-17pwm: atmel-pwm: Add Atmel PWM controller driverBo Shen
Add a PWM framework driver for the PWM controller found on Atmel SoCs. Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> [thierry.reding: coding style and other minor cleanups] Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-17pwm: pca9685: depends on I2C rather than REGMAP_I2CAxel Lin
REGMAP_I2C is not a visible config option. Thus make PWM_PCA9685 depend on I2c and then select REGMAP_I2C. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-12-12pwm: renesas-tpu: Enable driver compilation with COMPILE_TESTLaurent Pinchart
This helps increasing build testing coverage. Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-pwm@vger.kernel.org Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
