path: root/drivers/rapidio/rio-driver.c
2009-03-24rapidio: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: mporter@kernel.crashing.org Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-06rapidio: remove excess kernel-doc notationRandy Dunlap
Remove excess kernel-doc notation from rio header and driver: Warning(include/linux/rio_drv.h:399): Excess function parameter or struct member 'buffer' description in 'rio_get_inb_message' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10rapidio: fix device reference countingEugene Surovegin
Fix RapidIO device reference counting. Signed-of-by: Eugene Surovegin <ebs@ebshome.net> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix rapidio source filesRandy Dunlap
Fix docbook problems in rapidio source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-13[PATCH] Add rio_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
