[ Upstream commit 5ac188b12e7cbdd92dee60877d1fac913fc1d074 ]
If riocm_get_channel() fails, then we should just return -EINVAL.
Calling riocm_put_channel() will trigger a NULL dereference and
generally we should call put() if the get() didn't succeed.
Link: http://lkml.kernel.org/r/20190110130230.GB27017@kadam
Fixes: b6e8d4aa1110 ("rapidio: add RapidIO channelized messaging driver")
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Alexandre Bounine <alexandre.bounine@idt.com>
[ Upstream commit 23015b22e47c5409620b1726a677d69e5cd032ba ]
In case create_workqueue fails, the fix releases resources and returns
-ENOMEM to avoid NULL pointer dereference.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Acked-by: Alexandre Bounine <alex.bou9@gmail.com>
Fix coccinelle warning about duplicating existing memdup_user function.
Link: http://lkml.kernel.org/r/20160811151737.20140-1-alexandre.bounine@idt.com
Link: https://lkml.org/lkml/2016/8/11/29
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com>
Cc: Barry Wood <barry.wood@idt.com>
As reported by Alexey Khoroshilov (https://lkml.org/lkml/2016/9/9/737):
riocm_send_close() is called from rio_cm_shutdown() under
spin_lock_bh(idr_lock), but riocm_send_close() uses a GFP_KERNEL
allocation.
Fix by taking riocm_send_close() outside of spinlock protected code.
[akpm@linux-foundation.org: remove unneeded `if (!list_empty())']
Link: http://lkml.kernel.org/r/20160915175402.10122-1-alexandre.bounine@idt.com
Reported-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Original patch: https://lkml.org/lkml/2016/8/4/32
If riocm_ch_alloc() fails then we end up dereferencing the error
pointer.
The problem is that we're not unwinding in the reverse order from how we
allocate things so it gets confusing. I've changed this around so now
"ch" is NULL when we are done with it after we call riocm_put_channel().
That way we can check if it's NULL and avoid calling riocm_put_channel()
on it twice.
I renamed err_nodev to err_put_new_ch so that it better reflects what
the goto does.
Then because we had flipping things around, it means we don't neeed to
initialize the pointers to NULL and we can remove an if statement and
pull things in an indent level.
Link: http://lkml.kernel.org/r/20160805152406.20713-1-alexandre.bounine@idt.com
Add channelized messaging driver to support native RapidIO messaging
exchange between multiple senders/recipients on devices that use kernel
RapidIO subsystem services.
This device driver is the result of collaboration within the RapidIO.org
Software Task Group (STG) between Texas Instruments, Prodrive
Technologies, Nokia Networks, BAE and IDT. Additional input was
received from other members of RapidIO.org.
The objective was to create a character mode driver interface which
exposes messaging capabilities of RapidIO endpoint devices (mports)
directly to applications, in a manner that allows the numerous and
varied RapidIO implementations to interoperate.
This char mode device driver allows user-space applications to setup
messaging communication channels using single shared RapidIO messaging
mailbox.
By default this driver uses RapidIO MBOX_1 (MBOX_0 is reserved for use by
RIONET Ethernet emulation driver).
[weiyj.lk@gmail.com: rapidio/rio_cm: fix return value check in riocm_init()]
Link: http://lkml.kernel.org/r/1469198221-21970-1-git-send-email-alexandre.bounine@idt.com
Link: http://lkml.kernel.org/r/1468952862-18056-1-git-send-email-alexandre.bounine@idt.com
Tested-by: Barry Wood <barry.wood@idt.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
