path: root/drivers/rapidio/switches
2011-05-18rapidio: fix default routing initializationAlexandre Bounine
Fix switch initialization to ensure that all switches have default routing disabled. This guarantees that no unexpected RapidIO packets arrive to the default port set by reset and there is no default routing destination until it is properly configured by software. This update also unifies handling of unmapped destinations by tsi57x, IDT Gen1 and IDT Gen2 switches. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: <stable@kernel.org> [2.6.37+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14RapidIO: add IDT CPS-1432 switch definitionsAlexandre Bounine
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17rapidio: change to new flag variablematt mooney
switches/ depends on RAPIDIO_DEBUG so the subdir-ccflags-y variant seems to be appropriate here. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-13rapidio: add new idt sRIO switchesAlexandre Bounine
Add new sRIO switch device IDs and enable a basic support for them. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: use common destid storage for endpoints and switchesAlexandre Bounine
Change code to use one storage location common for switches and endpoints. This eliminates unnecessary device type checks during basic access operations. Logic that assigns destid to RIO devices stays unchanged - as before, switches use an associated destid because they do not have their own. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix destructive port EM initialization for Tsi568Alexandre Bounine
Replace possibly damaging broadcast writes into the per-port SP_MODE registers with individual writes for each port. This will preserve individual port configurations in case if ports are configured differently. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix maximum port number in tsi57x EM initializationAlexandre Bounine
Replace hardcoded maximum port number with actual reported number of switch ports. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add support for IDT CPS Gen2 switchesAlexandre Bounine
Add the RIO switch driver and definitions for IDT CPS-1848 and CPS-1616 Gen2 devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add default handler for error-stopped stateAlexandre Bounine
The default error-stopped state handler provides recovery mechanism as defined by RIO specification. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: use default route value for CPS switchesAlexandre Bounine
Fix to use correct default value for routing table entries. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add switch domain routinesAlexandre Bounine
Add switch specific domain routines required for 16-bit routing support in switches with hierarchical implementation of routing tables. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: modify initialization of switch operationsAlexandre Bounine
Modify the way how RapidIO switch operations are declared. Multiple assignments through the linker script replaced by single initialization call. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add debug configuration optionAlexandre Bounine
Add debug configuration option for RapidIO subsystem. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: fix typos and minor editsAlexandre Bounine
2010-05-27rapidio: add Port-Write handling for EMAlexandre Bounine
Add RapidIO Port-Write message handling in the context of Error Management Extensions Specification Rev.1.3. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add IDT CPS/TSI switchesAlexandre Bounine
Extentions to RapidIO switch support: 1. modify switch route operation declarations to allow using single switch-specific file for family of switches that share the same route table operations. 2. add standard route table operations for switches that that support route table manipulation registers as defined in the Rev.1.3 of RapidIO specification. 3. add clear-route-table operation for switches 4. add CPSxx and TSIxxx families of RapidIO switches Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-11-07[PATCH] RapidIO support: core enumMatt Porter
Adds RapidIO enumeration/discovery. The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
