path: root/drivers/rapidio
2007-02-11[PATCH] rapidio: fix multi-switch enumerationAlexandre Bounine
This patch contains two fixes for RapisIO enumeration logic: 1. Fix enumeration in configurations with multiple switches. The patch adds: a. Enumeration of an empty switch. Empty switch is a switch that does not have any endpoint devices attached to it (except host device or previous switch in a chain). New code assigns a phony destination ID associated with the switch and sets up corresponding routes. b. Adds a second pass to the enumeration to setup routes to devices discovered after switch was scanned. 2. Fix enumeration failure when riohdid parameter has non-zero value. Current version fails to setup response path to the host when it has destination ID other that 0. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Acked-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix several typos in drivers/Matt LaPlante
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] Add rio_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-08[PATCH] fix more missing includesTim Schmielau
Include fixes for 2.6.14-git11. Should allow to remove sched.h from module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more to come since I haven't yet checked the other archs. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] rapidio: message interface updatesMatt Porter
Updates the RIO messaging interface to pass a device instance into the event registeration and callbacks. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] rapidio: core updatesMatt Porter
Addresses issues raised with the 2.6.12-rc6-mm1 RIO support. Fix dma_mask init, shrink some code, general cleanup. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core enumMatt Porter
Adds RapidIO enumeration/discovery. The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
